[QGIS Commit] r9773 - in docs/trunk/english_us/user_guide: .
plugins_georeferencer_images
svn_qgis at osgeo.org
Thu Dec 11 17:26:32 EST 2008
Author: dassau
Date: 2008-12-11 17:26:32 -0500 (Thu, 11 Dec 2008)
New Revision: 9773
Added:
docs/trunk/english_us/user_guide/plugins_georeferencer_images/choose_points.png
docs/trunk/english_us/user_guide/plugins_georeferencer_images/georefplugin.png
docs/trunk/english_us/user_guide/plugins_georeferencer_images/result_map.png
docs/trunk/english_us/user_guide/plugins_georeferencer_images/select_image.png
docs/trunk/english_us/user_guide/forward.tex
docs/trunk/english_us/user_guide/getting_started.tex
docs/trunk/english_us/user_guide/plugins_georeferencer.tex
docs/trunk/english_us/user_guide/plugins_georeferencer_images/Makefile
updated some weblinks
added figures for georeferencer plugin and reviewed the section
Modified: docs/trunk/english_us/user_guide/forward.tex
--- docs/trunk/english_us/user_guide/forward.tex 2008-12-11 13:34:18 UTC (rev 9772)
+++ docs/trunk/english_us/user_guide/forward.tex 2008-12-11 22:26:32 UTC (rev 9773)
@@ -35,7 +35,7 @@
\qgistip{The latest version of this document in PDF format can always be found at \newline
\url{http://download.osgeo.org/qgis/doc/manual/}
or on the QGIS website at
-\url{http://qgis.org/index.php?option=com_content&task=view&id=106&Itemid=79}
+\url{http://qgis.osgeo.org/http://qgis.osgeo.org/documentation/manuals.html}
\end{Tip}
Modified: docs/trunk/english_us/user_guide/getting_started.tex
--- docs/trunk/english_us/user_guide/getting_started.tex 2008-12-11 13:34:18 UTC (rev 9772)
+++ docs/trunk/english_us/user_guide/getting_started.tex 2008-12-11 22:26:32 UTC (rev 9773)
@@ -13,7 +13,7 @@
Building QGIS from source is documented in \win Appendix \ref{sec:install_windows} for windows,
\osx Appendix \ref{sec:install_macosx} for Mac OSX and \nix Appendix \ref{sec:install_linux} for GNU/Linux.
The Installation instructions are distributed with the QGIS source code and also available
-at \url{http://qgis.org}.
+at \url{http://qgis.osgeo.org}.
Standard installer packages are available for Windows and Mac OS X. For many
flavors of GNU/Linux binary packages are provided. Get the latest information
@@ -33,7 +33,7 @@
\begin{itemize}
\item{use GIS data that you already have;}
\item{download the sample data from the QGIS website
- \url{http://qgis.org} on the Downloads page; or}
+ \url{http://qgis.osgeo.org} on the Downloads page; or}
\item{uninstall QGIS and reinstall with the data download option checked.}
\end{itemize}
%FIXME- what about Mac and *nix?
Modified: docs/trunk/english_us/user_guide/plugins_georeferencer.tex
--- docs/trunk/english_us/user_guide/plugins_georeferencer.tex 2008-12-11 13:34:18 UTC (rev 9772)
+++ docs/trunk/english_us/user_guide/plugins_georeferencer.tex 2008-12-11 22:26:32 UTC (rev 9773)
@@ -22,21 +22,23 @@
The next step is to start QGIS, load the georeferencer plugin and select the file \filename{spearfish\_topo24.tif}.
-%\begin{figure}[ht]
-%\begin{center}
-% \caption{Select an image to georeference}\label{fig:select_image}\smallskip
-% \includegraphics[clip=true]{select_image}
-%\end{center}
-%\end{figure}
+\begin{figure}[ht]
+\begin{center}
+\caption{Select an image to georeference \nixcaption}\label{fig:select_image}\smallskip
+ \includegraphics[clip=true, width=10cm]{select_image}
+\end{center}
+\end{figure}
-Now click on the button \button{Arrange plugin window} to open the image in the georeferencer and to arrange it with the reference map in the qgis map canvas on your desktop.
+Now click on the button \button{Arrange plugin window} to open the image in
+the georeferencer and to arrange it with the reference map in the qgis map
+canvas on your desktop (see Figure \ref{fig:georefplugin}).
-%\begin{center}
-% \caption{Arrange plugin window with the qgis map canvas}\label{fig:georeferencer}\smallskip
-% \includegraphics[clip=true,width=\textwidth]{georeferencer}
-%\end{center}
-%\end{figure}
+\begin{figure}[ht]
+\begin{center}
+ \caption{Arrange plugin window with the qgis map canvas \nixcaption}\label{fig:georefplugin}\smallskip
+ \includegraphics[clip=true,width=\textwidth]{georefplugin}
+\end{center}
+\end{figure}
With the button \button{Add Point} you can start to add points on the raster image and enter their coordinates, and the plugin will compute the world file parameters (see Figure \ref{fig:choose_points}).
The more coordinates you provide the better the result will be.
@@ -47,19 +49,19 @@
\item You click on a point in the raster map and choose the button \button{from map canvas} to add the X and Y coordinates with the help of a georeferenced map already loaded in QGIS.
\end{enumerate}
-%\begin{center}
-% \caption{Add points to the raster image}\label{fig:choose_points}\smallskip
-% \includegraphics[clip=true,width=0.8\textwidth]{choose_points}
-%\end{center}
-%\end{figure}
+\begin{figure}[ht]
+\begin{center}
+ \caption{Add points to the raster image \nixcaption}\label{fig:choose_points}\smallskip
+ \includegraphics[clip=true,width=0.8\textwidth]{choose_points}
+\end{center}
+\end{figure}
For this example we use the second option and enter the coordinates for the selected points with the help of the \filename{roads} map provided with the \filename{spearfish60} location from: \url{http://grass.osgeo.org/sampledata/spearfish\_grass60data-0.3.tar.gz}
-If you don't know how to integrate the \filename{spearfish60} location with the GRASS plugin, information are provided in Section \ref{sec:grass}.
+If you don't know how to integrate the \filename{spearfish60} location with
+the GRASS plugin, information are provided in Section \ref{sec:grass}. As you
+can see in Figure \ref{fig:choose_points}, the georeferencer provides buttons to zoom, pan, add and delete points in the image.
-As you can see in Figure \ref{fig:choose_points}, the georeferencer provides buttons to zoom, pan, add and delete points in the image.
After you added enough points to the image you need to select the transformation type for the georeferencing process and save the resulting world file together with the Tiff.
In our example we choose
\selectstring{Transform type}{linear transformation}
@@ -91,9 +93,10 @@
To get correct results it is important to disperse the points regulary in the image.
Finally we check the result and load the new georeferenced map \filename{spearfish\_topo24.tif} and overlay it with the map \filename{roads} of the \filename{spearfish60} location.
-%\begin{center}
-% \caption{Georeferenced map with overlayed roads from spearfish60 location}\label{fig:result_map}\smallskip
-% \includegraphics[clip=true,width=0.8\textwidth]{result_map}
-%\end{center}
-%\end{figure}
\ No newline at end of file
+\begin{figure}[ht]
+\begin{center}
+ \caption{Georeferenced map with overlayed roads from spearfish60 location
+ \nixcaption}\label{fig:result_map}\smallskip
+ \includegraphics[clip=true,width=\textwidth]{result_map}
+\end{center}
+\end{figure}
Modified: docs/trunk/english_us/user_guide/plugins_georeferencer_images/Makefile
--- docs/trunk/english_us/user_guide/plugins_georeferencer_images/Makefile 2008-12-11 13:34:18 UTC (rev 9772)
+++ docs/trunk/english_us/user_guide/plugins_georeferencer_images/Makefile 2008-12-11 22:26:32 UTC (rev 9773)
@@ -13,7 +13,11 @@
PNG=georef.eps\
georeferencer.eps\
pencil.eps\
+ select_image.eps\
+ choose_points.eps\
+ georefplugin.eps\
+ result_map.eps
##### TARGETS #####
all: $(PNG) $(JPG)
Added: docs/trunk/english_us/user_guide/plugins_georeferencer_images/choose_points.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/plugins_georeferencer_images/choose_points.png
___________________________________________________________________
+ application/octet-stream
Added: docs/trunk/english_us/user_guide/plugins_georeferencer_images/georefplugin.png
Property changes on: docs/trunk/english_us/user_guide/plugins_georeferencer_images/georefplugin.png
Added: docs/trunk/english_us/user_guide/plugins_georeferencer_images/result_map.png
Property changes on: docs/trunk/english_us/user_guide/plugins_georeferencer_images/result_map.png
Added: docs/trunk/english_us/user_guide/plugins_georeferencer_images/select_image.png
Property changes on: docs/trunk/english_us/user_guide/plugins_georeferencer_images/select_image.png
