[QGIS Commit] r9778 - trunk/qgis/src/app
svn_qgis at osgeo.org
Fri Dec 12 20:28:06 EST 2008
Author: jef
Date: 2008-12-12 20:28:05 -0500 (Fri, 12 Dec 2008)
New Revision: 9778
trunk/qgis/src/app/qgsdbsourceselect.cpp
postgis table selection dialog:
- only ask for a password, when postgis needs one (fixes #1400)
- don't complain about 'no accessible geometry tables', before checking for
tables not listed in geometry_columns (fixes #1455)
Modified: trunk/qgis/src/app/qgsdbsourceselect.cpp
--- trunk/qgis/src/app/qgsdbsourceselect.cpp 2008-12-12 21:50:47 UTC (rev 9777)
+++ trunk/qgis/src/app/qgsdbsourceselect.cpp 2008-12-13 01:28:05 UTC (rev 9778)
@@ -357,22 +357,12 @@
// populate the table list
QSettings settings;
- bool makeConnection = true;
QString key = "/PostgreSQL/connections/" + cmbConnections->currentText();
QString database = settings.value( key + "/database" ).toString();
QString username = settings.value( key + "/username" ).toString();
QString password = settings.value( key + "/password" ).toString();
- if ( password.isEmpty() )
- // get password from user
- makeConnection = false;
- password = QInputDialog::getText( this, tr( "Password for " ) + username,
- tr( "Please enter your password:" ),
- QLineEdit::Password, QString::null, &makeConnection );
- // allow null password entry in case its valid for the database
QgsDataSourceURI uri;
uri.setConnection( settings.value( key + "/host" ).toString(),
@@ -388,55 +378,80 @@
QgsDebugMsg( "Connection info: " + uri.connectionInfo() );
- if ( makeConnection )
+ m_connectionInfo = uri.connectionInfo();
+ //qDebug(m_connectionInfo);
+ // Tidy up an existing connection if one exists.
+ if ( pd != 0 )
+ PQfinish( pd );
+ pd = PQconnectdb( m_connectionInfo.toLocal8Bit() ); // use what is set based on locale; after connecting, use Utf8
+ // if the connection needs a password ask for one
+ if ( PQstatus( pd ) == CONNECTION_BAD && PQconnectionNeedsPassword( pd ) )
- m_connectionInfo = uri.connectionInfo();
- //qDebug(m_connectionInfo);
- // Tidy up an existing connection if one exists.
- if ( pd != 0 )
+ // get password from user
+ bool makeConnection = false;
+ password = QInputDialog::getText( this, tr( "Password for " ) + username,
+ tr( "Please enter your password:" ),
+ QLineEdit::Password, QString::null, &makeConnection );
+ // allow null password entry in case its valid for the database
+ if ( makeConnection )
+ uri.setConnection( settings.value( key + "/host" ).toString(),
+ settings.value( key + "/port" ).toString(),
+ database,
+ settings.value( key + "/username" ).toString(),
+ password );
PQfinish( pd );
- pd = PQconnectdb( m_connectionInfo.toLocal8Bit() ); // use what is set based on locale; after connecting, use Utf8
- if ( PQstatus( pd ) == CONNECTION_OK )
- //qDebug("Connection succeeded");
- // tell the DB that we want text encoded in UTF8
- PQsetClientEncoding( pd, QString( "UNICODE" ).toLocal8Bit() );
+ if ( PQstatus( pd ) == CONNECTION_OK )
+ //qDebug("Connection succeeded");
+ // tell the DB that we want text encoded in UTF8
+ PQsetClientEncoding( pd, QString( "UNICODE" ).toLocal8Bit() );
- // get the list of suitable tables and columns and populate the UI
- geomCol details;
+ // get the list of suitable tables and columns and populate the UI
+ geomCol details;
- if ( getTableInfo( pd, searchGeometryColumnsOnly, searchPublicOnly ) )
+ if ( getTableInfo( pd, searchGeometryColumnsOnly, searchPublicOnly ) )
+ // Start the thread that gets the geometry type for relations that
+ // may take a long time to return
+ if ( mColumnTypeThread != NULL )
- // Start the thread that gets the geometry type for relations that
- // may take a long time to return
- if ( mColumnTypeThread != NULL )
- connect( mColumnTypeThread, SIGNAL( setLayerType( QString, QString, QString, QString ) ),
- this, SLOT( setLayerType( QString, QString, QString, QString ) ) );
+ connect( mColumnTypeThread, SIGNAL( setLayerType( QString, QString, QString, QString ) ),
+ this, SLOT( setLayerType( QString, QString, QString, QString ) ) );
- // Do it in a thread.
- mColumnTypeThread->start();
+ // Do it in a thread.
+ mColumnTypeThread->start();
- else
- qDebug( "Unable to get list of spatially enabled tables from the database" );
- qDebug( PQerrorMessage( pd ) );
- // BEGIN CHANGES ECOS
- if ( cmbConnections->count() > 0 )
- btnAdd->setEnabled( true );
- // END CHANGES ECOS
else
- QMessageBox::warning( this, tr( "Connection failed" ),
- tr
- ( "Connection to %1 on %2 failed. Either the database is down or your settings are incorrect.%3Check your username and password and try again.%4The database said:%5%6" ).
- arg( settings.value( key + "/database" ).toString() ).arg( settings.value( key + "/host" ).toString() ).arg( "\n\n" ).arg( "\n\n" ).arg( "\n" ).arg( QString::fromUtf8( PQerrorMessage( pd ) ) ) );
+ qDebug( "Unable to get list of spatially enabled tables from the database" );
+ qDebug( PQerrorMessage( pd ) );
+ // BEGIN CHANGES ECOS
+ if ( cmbConnections->count() > 0 )
+ btnAdd->setEnabled( true );
+ // END CHANGES ECOS
+ else
+ QMessageBox::warning( this, tr( "Connection failed" ),
+ tr( "Connection to %1 on %2 failed. Either the database is down or your settings are incorrect.%3Check your username and password and try again.%4The database said:%5%6" )
+ .arg( settings.value( key + "/database" ).toString() )
+ .arg( settings.value( key + "/host" ).toString() )
+ .arg( "\n\n" )
+ .arg( "\n\n" )
+ .arg( "\n" )
+ .arg( QString::fromUtf8( PQerrorMessage( pd ) ) ) );
mTablesTreeView->sortByColumn( 1, Qt::AscendingOrder );
mTablesTreeView->sortByColumn( 0, Qt::AscendingOrder );
@@ -523,7 +538,7 @@
bool QgsDbSourceSelect::getTableInfo( PGconn *pg, bool searchGeometryColumnsOnly, bool searchPublicOnly )
- bool ok = false;
+ int n = 0;
QApplication::setOverrideCursor( Qt::WaitCursor );
// The following query returns only tables that exist and the user has SELECT privilege on.
@@ -542,20 +557,13 @@
tr( "Accessible tables could not be determined" ),
- QString( tr( "Database connection was successful, but the accessible tables could not be determined.\n\n"
- "The error message from the database was:\n%1\n" ) )
+ tr( "Database connection was successful, but the accessible tables could not be determined.\n\n"
+ "The error message from the database was:\n%1\n" )
.arg( QString::fromUtf8( PQresultErrorMessage( result ) ) ) );
+ n = -1;
- else if ( PQntuples( result ) == 0 )
+ else if ( PQntuples( result ) > 0 )
- QMessageBox::warning( this, tr( "No accessible tables found" ),
- tr
- ( "Database connection was successful, but no accessible tables were found.\n\n"
- "Please verify that you have SELECT privilege on a table carrying PostGIS\n"
- "geometry." ) );
- else
for ( int idx = 0; idx < PQntuples( result ); idx++ )
QString tableName = QString::fromUtf8( PQgetvalue( result, idx, PQfnumber( result, QString( "f_table_name" ).toUtf8() ) ) );
@@ -572,170 +580,97 @@
mTableModel.addTableEntry( type, schemaName, tableName, column, "" );
+ n++;
- ok = true;
PQclear( result );
//search for geometry columns in tables that are not in the geometry_columns metatable
QApplication::restoreOverrideCursor();
- if ( searchGeometryColumnsOnly )
- return ok;
- // Now have a look for geometry columns that aren't in the
- // geometry_columns table. This code is specific to postgresql,
- // but an equivalent query should be possible in other
- // databases.
- sql = "select pg_class.relname,pg_namespace.nspname,pg_attribute.attname,pg_class.relkind "
- "from pg_attribute, pg_class, pg_namespace "
- "where pg_namespace.oid = pg_class.relnamespace "
- "and pg_attribute.attrelid = pg_class.oid "
- "and ("
- "pg_attribute.atttypid = regtype('geometry')"
- " or "
- "pg_attribute.atttypid IN (select oid FROM pg_type WHERE typbasetype=regtype('geometry'))"
- "and has_schema_privilege(pg_namespace.nspname,'usage') "
- "and has_table_privilege('\"'||pg_namespace.nspname||'\".\"'||pg_class.relname||'\"','select') ";
- // user has select privilege
- if ( searchPublicOnly )
- sql += "and pg_namespace.nspname = 'public' ";
- sql += "and not exists (select * from geometry_columns WHERE pg_namespace.nspname=f_table_schema AND pg_class.relname=f_table_name) "
- "and pg_class.relkind in ('v', 'r')"; // only from views and relations (tables)
- result = PQexec( pg, sql.toUtf8() );
- for ( int i = 0; i < PQntuples( result ); i++ )
+ if ( !searchGeometryColumnsOnly )
- // Have the column name, schema name and the table name. The concept of a
- // catalog doesn't exist in postgresql so we ignore that, but we
- // do need to get the geometry type.
+ // Now have a look for geometry columns that aren't in the
+ // geometry_columns table. This code is specific to postgresql,
+ // but an equivalent query should be possible in other
+ // databases.
+ sql = "select pg_class.relname,pg_namespace.nspname,pg_attribute.attname,pg_class.relkind "
+ "from pg_attribute, pg_class, pg_namespace "
+ "where pg_namespace.oid = pg_class.relnamespace "
+ "and pg_attribute.attrelid = pg_class.oid "
+ "and ("
+ "pg_attribute.atttypid = regtype('geometry')"
+ " or "
+ "pg_attribute.atttypid IN (select oid FROM pg_type WHERE typbasetype=regtype('geometry'))"
+ "and has_schema_privilege(pg_namespace.nspname,'usage') "
+ "and has_table_privilege('\"'||pg_namespace.nspname||'\".\"'||pg_class.relname||'\"','select') ";
+ // user has select privilege
+ if ( searchPublicOnly )
+ sql += "and pg_namespace.nspname = 'public' ";
- // Make the assumption that the geometry type for the first
- // row is the same as for all other rows.
+ if ( n > 0 )
+ sql += "and not exists (select * from geometry_columns WHERE pg_namespace.nspname=f_table_schema AND pg_class.relname=f_table_name) ";
+ else
+ n = 0;
- QString table = QString::fromUtf8( PQgetvalue( result, i, 0 ) ); // relname
- QString schema = QString::fromUtf8( PQgetvalue( result, i, 1 ) ); // nspname
- QString column = QString::fromUtf8( PQgetvalue( result, i, 2 ) ); // attname
- QString relkind = QString::fromUtf8( PQgetvalue( result, i, 3 ) ); // relation kind
+ sql += "and pg_class.relkind in ('v', 'r')"; // only from views and relations (tables)
- addSearchGeometryColumn( schema, table, column );
- //details.push_back(geomPair(fullDescription(schema, table, column, "WAITING"), "WAITING"));
- mTableModel.addTableEntry( "Waiting", schema, table, column, "" );
- ok = true;
+ result = PQexec( pg, sql.toUtf8() );
- PQclear( result );
- return ok;
-#if 0 // this function is never called - smizuno
-bool QgsDbSourceSelect::getGeometryColumnInfo( PGconn *pg,
- geomCol& details, bool searchGeometryColumnsOnly,
- bool searchPublicOnly )
- bool ok = false;
- QApplication::setOverrideCursor( Qt::waitCursor );
- QString sql = "select * from geometry_columns";
- // where f_table_schema ='" + settings.value(key + "/database").toString() + "'";
- sql += " order by f_table_schema,f_table_name";
- //qDebug("Fetching tables using: " + sql);
- PGresult *result = PQexec( pg, sql.toUtf8() );
- if ( result )
- QString msg;
- QTextStream( &msg ) << "Fetched " << PQntuples( result ) << " tables from database";
- //qDebug(msg);
- for ( int idx = 0; idx < PQntuples( result ); idx++ )
+ if ( PQresultStatus( result ) != PGRES_TUPLES_OK )
- // Be a bit paranoid and check that the table actually
- // exists. This is not done as a subquery in the query above
- // because I can't get it to work correctly when there are tables
- // with capital letters in the name.
- // Take care to deal with tables with the same name but in different schema.
- QString tableName = QString::fromUtf8( PQgetvalue( result, idx, PQfnumber( result, "f_table_name" ) ) );
- QString schemaName = QString::fromUtf8( PQgetvalue( result, idx, PQfnumber( result, "f_table_schema" ) ) );
- sql = "select oid from pg_class where relname = '" + tableName + "'";
- if ( schemaName.length() > 0 )
- sql += " and relnamespace = (select oid from pg_namespace where nspname = '" +
- schemaName + "')";
- PGresult* exists = PQexec( pg, sql.toUtf8() );
- if ( PQntuples( exists ) == 1 )
+ tr( "Accessible tables could not be determined" ),
+ .arg( QString::fromUtf8( PQresultErrorMessage( result ) ) ) );
+ if ( n == 0 )
+ n = -1;
+ for ( int i = 0; i < PQntuples( result ); i++ )
- QString column = QString::fromUtf8( PQgetvalue( result, idx, PQfnumber( result, "f_geometry_column" ) ) );
- QString type = QString::fromUtf8( PQgetvalue( result, idx, PQfnumber( result, "type" ) ) );
+ // Have the column name, schema name and the table name. The concept of a
+ // catalog doesn't exist in postgresql so we ignore that, but we
+ // do need to get the geometry type.
- QString as = "";
- if ( type == "GEOMETRY" && !searchGeometryColumnsOnly )
- addSearchGeometryColumn( schemaName, tableName, column );
- as = type = "WAITING";
+ // Make the assumption that the geometry type for the first
+ // row is the same as for all other rows.
- details.push_back( geomPair( fullDescription( schemaName, tableName, column, as ), type ) );
+ QString table = QString::fromUtf8( PQgetvalue( result, i, 0 ) ); // relname
+ QString schema = QString::fromUtf8( PQgetvalue( result, i, 1 ) ); // nspname
+ QString column = QString::fromUtf8( PQgetvalue( result, i, 2 ) ); // attname
+ QString relkind = QString::fromUtf8( PQgetvalue( result, i, 3 ) ); // relation kind
+ addSearchGeometryColumn( schema, table, column );
+ //details.push_back(geomPair(fullDescription(schema, table, column, "WAITING"), "WAITING"));
+ mTableModel.addTableEntry( "Waiting", schema, table, column, "" );
+ n++;
- PQclear( exists );
- ok = true;
+ PQclear( result );
- QApplication::restoreOverrideCursor();
- return ok;
- // databases.
- sql = "select pg_class.relname, pg_namespace.nspname, pg_attribute.attname, "
- "pg_class.relkind from "
- "pg_attribute, pg_class, pg_type, pg_namespace where pg_type.typname = 'geometry' and "
- "pg_attribute.atttypid = pg_type.oid and pg_attribute.attrelid = pg_class.oid ";
- sql += "and cast(pg_class.relname as character varying) not in "
- "(select f_table_name from geometry_columns) "
- "and pg_namespace.oid = pg_class.relnamespace "
+ if ( n == 0 )
- details.push_back( geomPair( fullDescription( schema, table, column, "WAITING" ), "WAITING" ) );
+ tr( "No accessible tables found" ),
+ tr( "Database connection was successful, but no accessible tables were found.\n\n"
+ "Please verify that you have SELECT privilege on a table carrying PostGIS\n"
+ "geometry." ) );
- ok = true;
- return ok;
+ return n > 0;
-#endif
void QgsDbSourceSelect::showHelp()
