[QGIS Commit] r9781 - in trunk/qgis: python/plugins/plugin_installer src/app src/app/composer src/app/legend src/core src/core/composer src/core/symbology src/gui src/providers/grass src/providers/postgres src/providers/wms src/python
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Dec 13 06:07:45 EST 2008
Author: jef
Date: 2008-12-13 06:07:45 -0500 (Sat, 13 Dec 2008)
New Revision: 9781
   trunk/qgis/python/plugins/plugin_installer/i18n.cpp
   trunk/qgis/src/app/composer/qgscomposer.cpp
   trunk/qgis/src/app/composer/qgscomposer.h
   trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp
   trunk/qgis/src/app/legend/qgslegend.cpp
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsattributetable.cpp
   trunk/qgis/src/app/qgslabeldialog.cpp
   trunk/qgis/src/app/qgsmaptooladdisland.cpp
   trunk/qgis/src/app/qgspluginmanager.cpp
   trunk/qgis/src/app/qgspluginregistry.cpp
   trunk/qgis/src/app/qgspluginregistry.h
   trunk/qgis/src/app/qgsrasterlayerproperties.cpp
   trunk/qgis/src/app/qgsserversourceselect.cpp
   trunk/qgis/src/core/composer/qgscomposerscalebar.cpp
   trunk/qgis/src/core/qgsgeometry.h
   trunk/qgis/src/core/qgslabelattributes.cpp
   trunk/qgis/src/core/qgslabelattributes.h
   trunk/qgis/src/core/qgsmaplayer.cpp
   trunk/qgis/src/core/qgsmaprenderer.cpp
   trunk/qgis/src/core/qgssnapper.cpp
   trunk/qgis/src/core/qgssnapper.h
   trunk/qgis/src/core/qgsvectordataprovider.h
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/core/qgsvectorlayer.h
   trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp
   trunk/qgis/src/core/symbology/qgssymbol.cpp
   trunk/qgis/src/gui/qgsmapcanvas.cpp
   trunk/qgis/src/gui/qgsmapcanvas.h
   trunk/qgis/src/gui/qgsmapcanvassnapper.cpp
   trunk/qgis/src/gui/qgsprojectionselector.cpp
   trunk/qgis/src/gui/qgsrubberband.cpp
   trunk/qgis/src/gui/qgsrubberband.h
   trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
   trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
   trunk/qgis/src/providers/wms/qgswmsprovider.cpp
   trunk/qgis/src/python/qgspythonutilsimpl.cpp
   trunk/qgis/src/python/qgspythonutilsimpl.h
automatic indentation update (r9447-r9780)
Modified: trunk/qgis/python/plugins/plugin_installer/i18n.cpp
--- trunk/qgis/python/plugins/plugin_installer/i18n.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/python/plugins/plugin_installer/i18n.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -26,12 +26,12 @@
 file: installer_data.py
- // Repositories::xmlDownloaded
- translate("QgsPluginInstaller","Couldn't parse output from the repository")
+// Repositories::xmlDownloaded
+translate( "QgsPluginInstaller", "Couldn't parse output from the repository" )
- // Plugins::getAllInstalled
- translate("QgsPluginInstaller","Couldn't open the system plugin directory")
- translate("QgsPluginInstaller","Couldn't open the local plugin directory")
+// Plugins::getAllInstalled
+translate( "QgsPluginInstaller", "Couldn't open the system plugin directory" )
+translate( "QgsPluginInstaller", "Couldn't open the local plugin directory" )
@@ -41,18 +41,18 @@
 // InstallerPlugin::initGui
-  translate("QgsPluginInstaller","Fetch Python Plugins...")
-  translate("QgsPluginInstaller","Install more plugins from remote repositories")
-  translate("QgsPluginInstaller","Looking for new plugins...")
+translate( "QgsPluginInstaller", "Fetch Python Plugins..." )
+translate( "QgsPluginInstaller", "Install more plugins from remote repositories" )
+translate( "QgsPluginInstaller", "Looking for new plugins..." )
 // InstallerPlugin::checkingDone
-  translate("QgsPluginInstaller","There is a new plugin available")
-  translate("QgsPluginInstaller","There is a plugin update available")
+translate( "QgsPluginInstaller", "There is a new plugin available" )
+translate( "QgsPluginInstaller", "There is a plugin update available" )
 // InstallerPlugin::run
-  translate("QgsPluginInstaller","QGIS Python Plugin Installer")
-  translate("QgsPluginInstaller","Error reading repository:")
+translate( "QgsPluginInstaller", "QGIS Python Plugin Installer" )
+translate( "QgsPluginInstaller", "Error reading repository:" )
@@ -62,160 +62,160 @@
 // common functions
-  translate("QgsPluginInstaller","Nothing to remove! Plugin directory doesn't exist:")
-  translate("QgsPluginInstaller","Failed to remove the directory:")
-  translate("QgsPluginInstaller","Check permissions or remove it manually")
+translate( "QgsPluginInstaller", "Nothing to remove! Plugin directory doesn't exist:" )
+translate( "QgsPluginInstaller", "Failed to remove the directory:" )
+translate( "QgsPluginInstaller", "Check permissions or remove it manually" )
 QgsPluginInstallerFetchingDialog::foo()
- // def displayState
-  tr("Success")
-  tr("Resolving host name...")
-  tr("Connecting...")
-  tr("Host connected. Sending request...")
-  tr("Downloading data...")
-  tr("Idle")
-  tr("Closing connection...")
-  tr("Error")
+// def displayState
+  tr( "Success" )
+  tr( "Resolving host name..." )
+  tr( "Connecting..." )
+  tr( "Host connected. Sending request..." )
+  tr( "Downloading data..." )
+  tr( "Idle" )
+  tr( "Closing connection..." )
+  tr( "Error" )
 QgsPluginInstallerInstallingDialog::foo()
- // def stateChanged
-  tr("Installing...")
-  tr("Idle")
-  tr("Error")
+// def stateChanged
+  tr( "Installing..." )
+  tr( "Idle" )
+  tr( "Error" )
- // def requestFinished
-  tr("Failed to unzip the plugin package. Probably it's broken or missing from the repository. You may also want to make sure that you have write permission to the plugin directory:")
+// def requestFinished
+  tr( "Failed to unzip the plugin package. Probably it's broken or missing from the repository. You may also want to make sure that you have write permission to the plugin directory:" )
- // def abort
-  tr("Aborted by user")
+// def abort
+  tr( "Aborted by user" )
 QgsPluginInstallerPluginErrorDialog::foo()
- // def __init__
-  tr("no error message received")
+// def __init__
+  tr( "no error message received" )
 QgsPluginInstallerDialog::foo()
- // def __init__
+// def __init__
- // def getAllAvailablePlugins
-  tr("QGIS Python Plugin Installer")
-  tr("Error reading repository:")
+// def getAllAvailablePlugins
+  tr( "QGIS Python Plugin Installer" )
+  tr( "Error reading repository:" )
- // def populateMostWidgets
-  tr("all repositories")
-  tr("connected")
-  tr("This repository is connected")
-  tr("unavailable")
-  tr("This repository is enabled, but unavailable")
-  tr("disabled")
-  tr("This repository is disabled")
-  tr("This repository is blocked due to incompatibility with your Quantum GIS version")
-  tr("orphans")
-  tr("any status")
-  tr("not installed", "plural")
-  tr("installed", "plural")
-  tr("upgradeable and news")
+// def populateMostWidgets
+  tr( "all repositories" )
+  tr( "connected" )
+  tr( "This repository is connected" )
+  tr( "unavailable" )
+  tr( "This repository is enabled, but unavailable" )
+  tr( "disabled" )
+  tr( "This repository is disabled" )
+  tr( "This repository is blocked due to incompatibility with your Quantum GIS version" )
+  tr( "orphans" )
+  tr( "any status" )
+  tr( "not installed", "plural" )
+  tr( "installed", "plural" )
+  tr( "upgradeable and news" )
- // def filterChanged
+// def filterChanged
- // def filterCheck
-  tr("orphans")
-  tr("orphans")
+// def filterCheck
+  tr( "orphans" )
+  tr( "orphans" )
- // def populatePluginTree
-  tr("This plugin is not installed")
-  tr("This plugin is installed")
-  tr("This plugin is installed, but there is an updated version available")
-  tr("This plugin is installed, but I can't find it in any enabled repository")
-  tr("This plugin is not installed and is seen for the first time")
-  tr("This plugin is installed and is newer than its version available in a repository")
-  tr("This plugin is incompatible with your Quantum GIS version and probably won't work.")
-  tr("The required Python module is not installed.\nFor more information, please visit its homepage and Quantum GIS wiki.")
-  tr("This plugin seems to be broken.\nIt has been installed but can't be loaded.\nHere is the error message:")
-  tr("not installed", "singular")
-  tr("installed", "singular")
-  tr("upgradeable", "singular")
-  tr("new!", "singular")
-  tr("invalid", "singular")
-  tr("Note that it's an uninstallable core plugin")
-  tr("installed version")
-  tr("available version")
-  tr("That's the newest available version")
-  tr("There is no version available for download")
-  tr("This plugin is broken")
-  tr("This plugin requires a newer version of Quantum GIS")
-  tr("This plugin requires a missing module")
-  tr("only locally available")
+// def populatePluginTree
+  tr( "This plugin is not installed" )
+  tr( "This plugin is installed" )
+  tr( "This plugin is installed, but there is an updated version available" )
+  tr( "This plugin is installed, but I can't find it in any enabled repository" )
+  tr( "This plugin is not installed and is seen for the first time" )
+  tr( "This plugin is installed and is newer than its version available in a repository" )
+  tr( "This plugin is incompatible with your Quantum GIS version and probably won't work." )
+  tr( "The required Python module is not installed.\nFor more information, please visit its homepage and Quantum GIS wiki." )
+  tr( "This plugin seems to be broken.\nIt has been installed but can't be loaded.\nHere is the error message:" )
+  tr( "not installed", "singular" )
+  tr( "installed", "singular" )
+  tr( "upgradeable", "singular" )
+  tr( "new!", "singular" )
+  tr( "invalid", "singular" )
+  tr( "Note that it's an uninstallable core plugin" )
+  tr( "installed version" )
+  tr( "available version" )
+  tr( "That's the newest available version" )
+  tr( "There is no version available for download" )
+  tr( "This plugin is broken" )
+  tr( "This plugin requires a newer version of Quantum GIS" )
+  tr( "This plugin requires a missing module" )
+  tr( "only locally available" )
- // def treeClicked
-  tr("Install plugin")
-  tr("Reinstall plugin")
-  tr("Upgrade plugin")
-  tr("Install/upgrade plugin")
-  tr("Downgrade plugin")
+// def treeClicked
+  tr( "Install plugin" )
+  tr( "Reinstall plugin" )
+  tr( "Upgrade plugin" )
+  tr( "Install/upgrade plugin" )
+  tr( "Downgrade plugin" )
- // def installPlugin
-  tr("Are you sure you want to downgrade the plugin to the latest available version? The installed one is newer!")
-  tr("Plugin installation failed")
-  tr("Plugin has disappeared")
-  tr("The plugin seems to have been installed but I don't know where. Probably the plugin package contained a wrong named directory.\nPlease search the list of installed plugins. I'm nearly sure you'll find the plugin there, but I just can't determine which of them it is. It also means that I won't be able to determine if this plugin is installed and inform you about available updates. However the plugin may work. Please contact the plugin author and submit this issue.")
-  tr("Plugin installed successfully")
-  tr("Python plugin installed.\nNow you need to enable it in Plugin Manager.")
-  tr("Plugin reinstalled successfully")
-  tr("Python plugin reinstalled.\nYou need to restart Quantum GIS in order to reload it.")
-  tr("The plugin is designed for a newer version of Quantum GIS. The minimum required version is:")
-  tr("The plugin depends on some components missing on your system. You need to install the following Python module in order to enable it:")
-  tr("The plugin is broken. Python said:")
-  tr("Plugin uninstall failed")
+// def installPlugin
+  tr( "Are you sure you want to downgrade the plugin to the latest available version? The installed one is newer!" )
+  tr( "Plugin installation failed" )
+  tr( "Plugin has disappeared" )
+  tr( "The plugin seems to have been installed but I don't know where. Probably the plugin package contained a wrong named directory.\nPlease search the list of installed plugins. I'm nearly sure you'll find the plugin there, but I just can't determine which of them it is. It also means that I won't be able to determine if this plugin is installed and inform you about available updates. However the plugin may work. Please contact the plugin author and submit this issue." )
+  tr( "Plugin installed successfully" )
+  tr( "Python plugin installed.\nNow you need to enable it in Plugin Manager." )
+  tr( "Plugin reinstalled successfully" )
+  tr( "Python plugin reinstalled.\nYou need to restart Quantum GIS in order to reload it." )
+  tr( "The plugin is designed for a newer version of Quantum GIS. The minimum required version is:" )
+  tr( "The plugin depends on some components missing on your system. You need to install the following Python module in order to enable it:" )
+  tr( "The plugin is broken. Python said:" )
+  tr( "Plugin uninstall failed" )
- // def uninstallPlugin
-  tr("Are you sure you want to uninstall the following plugin?")
-  tr("Warning: this plugin isn't available in any accessible repository!")
-  tr("Plugin uninstalled successfully")
-  tr("Python plugin uninstalled. Note that tou may need to restart Quantum GIS in order to remove it completely.")
- // def ChangeCheckingPolicy
+// def uninstallPlugin
+  tr( "Are you sure you want to uninstall the following plugin?" )
+  tr( "Warning: this plugin isn't available in any accessible repository!" )
+  tr( "Plugin uninstalled successfully" )
+  tr( "Python plugin uninstalled. Note that tou may need to restart Quantum GIS in order to remove it completely." )
+// def ChangeCheckingPolicy
- // def addKnownRepositories
-  tr("You are going to add some plugin repositories neither authorized nor supported by the Quantum GIS team, however provided by folks associated with us. Plugin authors generally make efforts to make their works useful and safe, but we can't assume any responsibility for them. FEEL WARNED!")
+// def addKnownRepositories
+  tr( "You are going to add some plugin repositories neither authorized nor supported by the Quantum GIS team, however provided by folks associated with us. Plugin authors generally make efforts to make their works useful and safe, but we can't assume any responsibility for them. FEEL WARNED!" )
- // def addRepository
-  tr("Unable to add another repository with the same URL!")
+// def addRepository
+  tr( "Unable to add another repository with the same URL!" )
- // def editRepository
+// def editRepository
- // def deleteRepository
-  tr("Are you sure you want to remove the following repository?")
+// def deleteRepository
+  tr( "Are you sure you want to remove the following repository?" )
- // def reject
+// def reject
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -71,7 +71,7 @@
   QString myIconPath = QgsApplication::activeThemePath();
   QActionGroup* toggleActionGroup = new QActionGroup( this );
-  toggleActionGroup->addAction( mActionMoveItemContent);
+  toggleActionGroup->addAction( mActionMoveItemContent );
   toggleActionGroup->addAction( mActionAddNewMap );
   toggleActionGroup->addAction( mActionAddNewLabel );
   toggleActionGroup->addAction( mActionAddNewLegend );
@@ -222,13 +222,13 @@
   mActionAddNewLegend->setIcon( QgisApp::getThemeIcon( "/mActionAddLegend.png" ) );
   mActionAddNewScalebar->setIcon( QgisApp::getThemeIcon( "/mActionScaleBar.png" ) );
   mActionSelectMoveItem->setIcon( QgisApp::getThemeIcon( "/mActionSelectPan.png" ) );
-  mActionMoveItemContent->setIcon( QgisApp::getThemeIcon("/mActionMoveItemContent.png"));
-  mActionGroupItems->setIcon( QgisApp::getThemeIcon("/mActionGroupItems.png"));
-  mActionUngroupItems->setIcon( QgisApp::getThemeIcon("/mActionUngroupItems.png"));
-  mActionRaiseItems->setIcon( QgisApp::getThemeIcon("/mActionRaiseItems.png"));
-  mActionLowerItems->setIcon( QgisApp::getThemeIcon("/mActionLowerItems.png"));
-  mActionMoveItemsToTop->setIcon( QgisApp::getThemeIcon("/mActionMoveItemsToTop.png"));
-  mActionMoveItemsToBottom->setIcon( QgisApp::getThemeIcon("/mActionMoveItemsToBottom.png"));
+  mActionMoveItemContent->setIcon( QgisApp::getThemeIcon( "/mActionMoveItemContent.png" ) );
+  mActionGroupItems->setIcon( QgisApp::getThemeIcon( "/mActionGroupItems.png" ) );
+  mActionUngroupItems->setIcon( QgisApp::getThemeIcon( "/mActionUngroupItems.png" ) );
+  mActionRaiseItems->setIcon( QgisApp::getThemeIcon( "/mActionRaiseItems.png" ) );
+  mActionLowerItems->setIcon( QgisApp::getThemeIcon( "/mActionLowerItems.png" ) );
+  mActionMoveItemsToTop->setIcon( QgisApp::getThemeIcon( "/mActionMoveItemsToTop.png" ) );
+  mActionMoveItemsToBottom->setIcon( QgisApp::getThemeIcon( "/mActionMoveItemsToBottom.png" ) );
 void QgsComposer::connectSlots()
@@ -712,7 +712,7 @@
-void QgsComposer::on_mActionMoveItemContent_activated(void)
+void QgsComposer::on_mActionMoveItemContent_activated( void )
   if ( mView )
@@ -744,7 +744,7 @@
-void QgsComposer::on_mActionLowerItems_activated(void)
+void QgsComposer::on_mActionLowerItems_activated( void )
   if ( mComposition )
@@ -752,7 +752,7 @@
-void QgsComposer::on_mActionMoveItemsToTop_activated(void)
+void QgsComposer::on_mActionMoveItemsToTop_activated( void )
   if ( mComposition )
@@ -760,7 +760,7 @@
-void QgsComposer::on_mActionMoveItemsToBottom_activated(void)
+void QgsComposer::on_mActionMoveItemsToBottom_activated( void )
   if ( mComposition )
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/composer/qgscomposer.h	2008-12-13 11:07:45 UTC (rev 9781)
@@ -133,7 +133,7 @@
     void on_mActionAddImage_activated( void );
     //! Set tool to move item content
-    void on_mActionMoveItemContent_activated(void);
+    void on_mActionMoveItemContent_activated( void );
     //! Group selected items
     void on_mActionGroupItems_activated( void );
@@ -142,16 +142,16 @@
     void on_mActionUngroupItems_activated( void );
     //! Move selected items one position up
-    void on_mActionRaiseItems_activated(void);
+    void on_mActionRaiseItems_activated( void );
     //!Move selected items one position down
-    void on_mActionLowerItems_activated(void);
+    void on_mActionLowerItems_activated( void );
     //!Move selected items to top
-    void on_mActionMoveItemsToTop_activated(void);
+    void on_mActionMoveItemsToTop_activated( void );
     //!Move selected items to bottom
-    void on_mActionMoveItemsToBottom_activated(void);
+    void on_mActionMoveItemsToBottom_activated( void );
     //! Save window state
     void saveWindowState();
Modified: trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp
--- trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -283,35 +283,35 @@
   QString untranslatedStyleName;
-  if(text == tr("Single Box"))
+  if ( text == tr( "Single Box" ) )
     untranslatedStyleName = "Single Box";
-  else if(text == tr("Double Box"))
+  else if ( text == tr( "Double Box" ) )
-     untranslatedStyleName =  "Double Box";
+    untranslatedStyleName =  "Double Box";
-  else if(text == tr( "Line Ticks Middle" ))
+  else if ( text == tr( "Line Ticks Middle" ) )
-      untranslatedStyleName = "Line Ticks Middle";
+    untranslatedStyleName = "Line Ticks Middle";
-  else if(text == tr("Line Ticks Middle"))
-  else if(text == tr( "Line Ticks Down" ))
+  else if ( text == tr( "Line Ticks Down" ) )
-      untranslatedStyleName = "Line Ticks Down";
+    untranslatedStyleName = "Line Ticks Down";
-  else if(text == tr( "Line Ticks Up"))
+  else if ( text == tr( "Line Ticks Up" ) )
-     untranslatedStyleName =  "Line Ticks Up";
+    untranslatedStyleName =  "Line Ticks Up";
-  else if(text == tr( "Numeric"))
+  else if ( text == tr( "Numeric" ) )
-     untranslatedStyleName =  "Numeric";
+    untranslatedStyleName =  "Numeric";
-  mComposerScaleBar->setStyle(untranslatedStyleName);
+  mComposerScaleBar->setStyle( untranslatedStyleName );
   mComposerScaleBar->update();
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/legend/qgslegend.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -156,7 +156,7 @@
   QTreeWidgetItem* theItem = firstItem();
   QgsDebugMsg( "called." );
   QgsLegendLayer* lastLL = NULL;
   while ( theItem )
@@ -177,15 +177,15 @@
           mStateOfCheckBoxes.erase( llf );
           removeItem( llf );
           delete llf;
           // delete also parent legend layer if now it's empty
-          if (lastLL->mapLayers().size() == 0)
+          if ( lastLL->mapLayers().size() == 0 )
             mStateOfCheckBoxes.erase( lastLL );
             removeItem( lastLL );
             delete lastLL;
           break;
@@ -637,7 +637,7 @@
-    if (layerCount == 0)
+    if ( layerCount == 0 )
       // delete the item only when it didn't have any child legend layer files
       // (otherwise it is deleted in QgsLegend::removeLayer when deleting last legend layer file)
@@ -645,7 +645,7 @@
       removeItem( ll );
       delete ll;
     adjustIconSize();
     return;
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/qgisapp.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -304,7 +304,7 @@
 QgisApp::QgisApp( QSplashScreen *splash, QWidget * parent, Qt::WFlags fl )
     : QMainWindow( parent, fl ),
     mSplash( splash ),
-    mComposer(0),
+    mComposer( 0 ),
     mPythonConsole( NULL ),
     mPythonUtils( NULL )
@@ -1482,7 +1482,7 @@
   mActionAddWmsLayer->setIcon( getThemeIcon( "/mActionAddWmsLayer.png" ) );
   mActionAddToOverview->setIcon( getThemeIcon( "/mActionInOverview.png" ) );
-  if(mComposer)
+  if ( mComposer )
     mComposer->setupTheme();
@@ -4872,7 +4872,7 @@
         mActionToggleEditing->setEnabled( false );
       if ( dprovider->capabilities() & QgsVectorDataProvider::AddFeatures )
         mActionPasteFeatures->setEnabled( vlayer->isEditable() && !clipboard()->empty() );
@@ -4893,7 +4893,7 @@
         mActionDeleteSelected->setEnabled( false );
         mActionCutFeatures->setEnabled( false );
       // moving enabled if geometry changes are supported
       if ( vlayer->isEditable() && dprovider->capabilities() & QgsVectorDataProvider::ChangeGeometries )
Modified: trunk/qgis/src/app/qgsattributetable.cpp
--- trunk/qgis/src/app/qgsattributetable.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/qgsattributetable.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -491,7 +491,7 @@
   else
     QgsRectangle rect;
-    if( behaviour == 2 )
+    if ( behaviour == 2 )
       // current canvas only
       rect = QgisApp::instance()->mapCanvas()->extent();
Modified: trunk/qgis/src/app/qgslabeldialog.cpp
--- trunk/qgis/src/app/qgslabeldialog.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/qgslabeldialog.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -203,8 +203,8 @@
     spinYOffset->setValue( 0 );
   spinAngle->setRange( -1, 360 );
-  spinAngle->setSpecialValueText( tr("Auto") );
-  if( myLabelAttributes->angleIsAuto() )
+  spinAngle->setSpecialValueText( tr( "Auto" ) );
+  if ( myLabelAttributes->angleIsAuto() )
     spinAngle->setValue( -1 );
@@ -256,7 +256,7 @@
   spinBufferSize->setValue( static_cast<int>( myLabelAttributes->bufferSize() ) );
   //TODO - transparency attributes for buffers
-  listWidget->setItemSelected( listWidget->item(0), true);
+  listWidget->setItemSelected( listWidget->item( 0 ), true );
@@ -352,7 +352,7 @@
   myLabelAttributes->setOffset( spinXOffset->value(), spinYOffset->value(), myTypeInt );
   myLabelAttributes->setAutoAngle( spinAngle->value() == -1 );
   myLabelAttributes->setAngle( spinAngle->value() );
   //the values here may seem a bit counterintuitive - basically everything
   //is the reverse of the way you think it should be...
   //TODO investigate in QgsLabel why this needs to be the case
Modified: trunk/qgis/src/app/qgsmaptooladdisland.cpp
--- trunk/qgis/src/app/qgsmaptooladdisland.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/qgsmaptooladdisland.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -56,22 +56,22 @@
   //inform user at the begin of the digitising action that the island tool only works if exactly one feature is selected
   int nSelectedFeatures = vlayer->selectedFeatureCount();
   QString selectionErrorMsg;
-  if(nSelectedFeatures < 1)
+  if ( nSelectedFeatures < 1 )
-      selectionErrorMsg = "No feature selected. Please select a feature with the selection tool or in the attribute table";
+    selectionErrorMsg = "No feature selected. Please select a feature with the selection tool or in the attribute table";
-  else if(nSelectedFeatures > 1)
+  else if ( nSelectedFeatures > 1 )
-      selectionErrorMsg = "Several features are selected. Please select only one feature to which an island should be added.";
+    selectionErrorMsg = "Several features are selected. Please select only one feature to which an island should be added.";
-  if(!selectionErrorMsg.isEmpty())
+  if ( !selectionErrorMsg.isEmpty() )
-      QMessageBox::critical( 0, QObject::tr( "Error, could not add island" ), selectionErrorMsg );
-      mCaptureList.clear();
-      delete mRubberBand;
-      mRubberBand = 0;
-      return;
+    QMessageBox::critical( 0, QObject::tr( "Error, could not add island" ), selectionErrorMsg );
+    mCaptureList.clear();
+    delete mRubberBand;
+    mRubberBand = 0;
+    return;
   //add point to list and to rubber band
Modified: trunk/qgis/src/app/qgspluginmanager.cpp
--- trunk/qgis/src/app/qgspluginmanager.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/qgspluginmanager.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -147,11 +147,11 @@
     QString version     = mPythonUtils->getPluginMetadata( packageName, "version" );
     if ( pluginName == "???" || description == "???" || version == "???" ) continue;
     bool isCompatible = QgsPluginRegistry::instance()->isPythonPluginCompatible( packageName );
     QString compatibleString; // empty by default
-    if (!isCompatible)
-      compatibleString = "  " + tr("[ incompatible ]");
+    if ( !isCompatible )
+      compatibleString = "  " + tr( "[ incompatible ]" );
     // filtering will be done on the display role so give it name and desription
     // user wont see this text since we are using a custome delegate
Modified: trunk/qgis/src/app/qgspluginregistry.cpp
--- trunk/qgis/src/app/qgspluginregistry.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/qgspluginregistry.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -152,44 +152,44 @@
-bool QgsPluginRegistry::checkQgisVersion(QString minVersion)
+bool QgsPluginRegistry::checkQgisVersion( QString minVersion )
-  QStringList minVersionParts = minVersion.split('.');
+  QStringList minVersionParts = minVersion.split( '.' );
   // qgis version must be in form x.y.z or just x.y
-  if (minVersionParts.count() != 2 && minVersionParts.count() != 3)
+  if ( minVersionParts.count() != 2 && minVersionParts.count() != 3 )
     return false;
-  int minVerMajor, minVerMinor, minVerBugfix=0;
+  int minVerMajor, minVerMinor, minVerBugfix = 0;
   bool ok;
-  minVerMajor = minVersionParts.at(0).toInt(&ok);
-  if (!ok) return false;
-  minVerMinor = minVersionParts.at(1).toInt(&ok);
-  if (minVersionParts.count() == 3)
+  minVerMajor = minVersionParts.at( 0 ).toInt( &ok );
+  if ( !ok ) return false;
+  minVerMinor = minVersionParts.at( 1 ).toInt( &ok );
+  if ( minVersionParts.count() == 3 )
-    minVerBugfix = minVersionParts.at(2).toInt(&ok);
+    minVerBugfix = minVersionParts.at( 2 ).toInt( &ok );
   // our qgis version - cut release name after version number
-  QString qgisVersion = QString(QGis::QGIS_VERSION).section( '-', 0, 0 );
+  QString qgisVersion = QString( QGis::QGIS_VERSION ).section( '-', 0, 0 );
   QStringList qgisVersionParts = qgisVersion.split( "." );
   int qgisMajor = qgisVersionParts.at( 0 ).toInt();
   int qgisMinor = qgisVersionParts.at( 1 ).toInt();
-  int qgisBugfix= qgisVersionParts.at( 2 ).toInt();
+  int qgisBugfix = qgisVersionParts.at( 2 ).toInt();
   // first check major version
-  if (minVerMajor > qgisMajor) return false;
-  if (minVerMajor < qgisMajor) return true;
+  if ( minVerMajor > qgisMajor ) return false;
+  if ( minVerMajor < qgisMajor ) return true;
   // if same, check minor version
-  if (minVerMinor > qgisMinor) return false;
-  if (minVerMinor < qgisMinor) return true;
+  if ( minVerMinor > qgisMinor ) return false;
+  if ( minVerMinor < qgisMinor ) return true;
   // if still same, check bugfix version
-  if (minVerBugfix > qgisBugfix) return false;
+  if ( minVerBugfix > qgisBugfix ) return false;
   // looks like min version is the same as our version - that's fine
   return true;
@@ -202,7 +202,7 @@
     QgsDebugMsg( "Python is not enabled in QGIS." );
     return;
   QSettings settings;
   // is loaded already?
@@ -214,12 +214,12 @@
       settings.setValue( "/PythonPlugins/" + packageName, false );
       return;
     mPythonUtils->loadPlugin( packageName );
     mPythonUtils->startPlugin( packageName );
     // TODO: test success
     QString pluginName = mPythonUtils->getPluginMetadata( packageName, "name" );
     // add to plugin registry
@@ -228,7 +228,7 @@
     // add to settings
     settings.setValue( "/PythonPlugins/" + packageName, true );
     std::cout << "Loaded : " << pluginName.toLocal8Bit().constData() << " (package: "
-        << packageName.toLocal8Bit().constData() << ")" << std::endl; // OK
+              << packageName.toLocal8Bit().constData() << ")" << std::endl; // OK
@@ -247,7 +247,7 @@
     // QMessageBox::warning(this, "Already Loaded", description + " is already loaded");
     return;
   QLibrary myLib( theFullPathName );
   QString myError; //we will only show detailed diagnostics if something went wrong
@@ -259,7 +259,7 @@
     QgsDebugMsg( "Failed to load " + theFullPathName );
     return;
   myError += "Attempting to resolve the classFactory function " +  QString( __LINE__ ) + " in " + QString( __FUNCTION__ ) + "\n";
   type_t *pType = ( type_t * ) cast_to_fptr( myLib.resolve( "type" ) );
@@ -288,8 +288,8 @@
           // something went wrong
           QMessageBox::warning( mQgisInterface->mainWindow(), QObject::tr( "Error Loading Plugin" ),
                                 QObject::tr( "There was an error loading a plugin."
-              "The following diagnostic information may help the QGIS developers resolve the issue:\n%1." ).arg
-                  ( myError ) );
+                                             "The following diagnostic information may help the QGIS developers resolve the issue:\n%1." ).arg
+                                ( myError ) );
           //disable it to the qsettings file [ts]
           settings.setValue( "/Plugins/" + baseName, false );
@@ -326,7 +326,7 @@
   for ( uint i = 0; i < myPluginDir.count(); i++ )
     QString myFullPath = thePluginDirString + "/" + myPluginDir[i];
-    if (checkCppPlugin( myFullPath ) )
+    if ( checkCppPlugin( myFullPath ) )
       // check if the plugin was active on last session
@@ -337,18 +337,18 @@
   if ( mPythonUtils && mPythonUtils->isEnabled() )
     // check for python plugins system-wide
     QStringList pluginList = mPythonUtils->pluginList();
-    QgsDebugMsg("Loading python plugins");
+    QgsDebugMsg( "Loading python plugins" );
     for ( int i = 0; i < pluginList.size(); i++ )
       QString packageName = pluginList[i];
-      if (checkPythonPlugin( packageName ) )
+      if ( checkPythonPlugin( packageName ) )
@@ -360,10 +360,10 @@
-  QgsDebugMsg("Plugin loading completed");
+  QgsDebugMsg( "Plugin loading completed" );
 bool QgsPluginRegistry::checkCppPlugin( QString pluginFullPath )
   QLibrary myLib( pluginFullPath );
@@ -378,15 +378,15 @@
   name_t * myName = ( name_t * ) cast_to_fptr( myLib.resolve( "name" ) );
   description_t *  myDescription = ( description_t * )  cast_to_fptr( myLib.resolve( "description" ) );
   version_t *  myVersion = ( version_t * ) cast_to_fptr( myLib.resolve( "version" ) );
   if ( myName && myDescription  && myVersion )
     return true;
-  QgsDebugMsg("Failed to get name, description, or type for " + myLib.fileName());
+  QgsDebugMsg( "Failed to get name, description, or type for " + myLib.fileName() );
   return false;
 bool QgsPluginRegistry::checkPythonPlugin( QString packageName )
   // import plugin's package
@@ -394,7 +394,7 @@
     return false;
   QString pluginName, description, version;
   // get information from the plugin
   // if there are some problems, don't continue with metadata retreival
@@ -411,14 +411,14 @@
                           QObject::tr( "Error when reading metadata of plugin " ) + packageName );
     return false;
   return true;
 bool QgsPluginRegistry::isPythonPluginCompatible( QString packageName )
   QString minVersion = mPythonUtils->getPluginMetadata( packageName, "qgisMinimumVersion" );
-  if (minVersion == "__error__" || !checkQgisVersion(minVersion))
+  if ( minVersion == "__error__" || !checkQgisVersion( minVersion ) )
     //QMessageBox::information(mQgisInterface->mainWindow(),
     //   QObject::tr("Incompatible plugin"),
Modified: trunk/qgis/src/app/qgspluginregistry.h
--- trunk/qgis/src/app/qgspluginregistry.h	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/qgspluginregistry.h	2008-12-13 11:07:45 UTC (rev 9781)
@@ -42,7 +42,7 @@
   public:
     //! Returns the instance pointer, creating the object on the first call
     static QgsPluginRegistry* instance();
     //! set pointer to qgis interface passed to plugins (used by QgisApp)
     void setQgisInterface( QgisInterface* iface );
@@ -77,13 +77,13 @@
     void loadCppPlugin( QString mFullPath );
     //! Python plugin loader
     void loadPythonPlugin( QString packageName );
     //! Load any plugins used in the last qgis session
     void restoreSessionPlugins( QString thePluginDirString );
     //! Check whether plugin is compatible with current version of QGIS
     bool isPythonPluginCompatible( QString packageName );
   protected:
     //! protected constructor
     QgsPluginRegistry();
@@ -92,10 +92,10 @@
     bool checkCppPlugin( QString pluginFullPath );
     //! Try to load and get metadata from Python plugin, return true on success
     bool checkPythonPlugin( QString packageName );
     //! Check current QGIS version against plugin's minimal requested QGIS version
-    bool checkQgisVersion(QString minVersion);
+    bool checkQgisVersion( QString minVersion );
   private:
     static QgsPluginRegistry* _instance;
     QMap<QString, QgsPluginMetadata> mPlugins;
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -434,11 +434,11 @@
   if ( myEstimatedValues )
-    lblMinMaxEstimateWarning->setText( tr("Note: Minimum Maximum values are estimates or user defined") );
+    lblMinMaxEstimateWarning->setText( tr( "Note: Minimum Maximum values are estimates or user defined" ) );
   else
-    lblMinMaxEstimateWarning->setText( tr("Note: Minimum Maximum values are actual values computed from the band(s)") );
+    lblMinMaxEstimateWarning->setText( tr( "Note: Minimum Maximum values are actual values computed from the band(s)" ) );
Modified: trunk/qgis/src/app/qgsserversourceselect.cpp
--- trunk/qgis/src/app/qgsserversourceselect.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/app/qgsserversourceselect.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -484,7 +484,7 @@
         QStringList parts = i->split( ":" );
-        if ( parts.at(0).compare("EPSG", Qt::CaseInsensitive) == 0 )
+        if ( parts.at( 0 ).compare( "EPSG", Qt::CaseInsensitive ) == 0 )
           long epsg = atol( parts.at( 1 ).toUtf8() );
           if ( epsg == m_Epsg )
Modified: trunk/qgis/src/core/composer/qgscomposerscalebar.cpp
--- trunk/qgis/src/core/composer/qgscomposerscalebar.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/composer/qgscomposerscalebar.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -197,32 +197,32 @@
   mStyle = 0;
   //switch depending on style name
-  if ( styleName == "Single Box")
+  if ( styleName == "Single Box" )
     mStyle = new QgsSingleBoxScaleBarStyle( this );
-  else if ( styleName == "Double Box")
+  else if ( styleName == "Double Box" )
     mStyle = new QgsDoubleBoxScaleBarStyle( this );
   else if ( styleName == "Line Ticks Middle"  || styleName == "Line Ticks Down" || styleName == "Line Ticks Up" )
     QgsTicksScaleBarStyle* tickStyle = new QgsTicksScaleBarStyle( this );
-    if ( styleName == "Line Ticks Middle")
+    if ( styleName == "Line Ticks Middle" )
       tickStyle->setTickPosition( QgsTicksScaleBarStyle::TicksMiddle );
-    else if ( styleName == "Line Ticks Down")
+    else if ( styleName == "Line Ticks Down" )
       tickStyle->setTickPosition( QgsTicksScaleBarStyle::TicksDown );
-    else if ( styleName == "Line Ticks Up")
+    else if ( styleName == "Line Ticks Up" )
       tickStyle->setTickPosition( QgsTicksScaleBarStyle::TicksUp );
     mStyle = tickStyle;
-  else if ( styleName == "Numeric")
+  else if ( styleName == "Numeric" )
     mStyle = new QgsNumericScaleBarStyle( this );
Modified: trunk/qgis/src/core/qgsgeometry.h
--- trunk/qgis/src/core/qgsgeometry.h	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/qgsgeometry.h	2008-12-13 11:07:45 UTC (rev 9781)
@@ -418,7 +418,7 @@
     GEOSGeometry* nodeGeometries( const GEOSGeometry *splitLine, GEOSGeometry *poly ) const;
     /**Returns number of single geometry in a geos geometry. Is save for geos 2 and 3*/
-    int numberOfGeometries(GEOSGeometry* g) const;
+    int numberOfGeometries( GEOSGeometry* g ) const;
     int mergeGeometriesMultiTypeSplit( QVector<GEOSGeometry*>& splitResult );
Modified: trunk/qgis/src/core/qgslabelattributes.cpp
--- trunk/qgis/src/core/qgslabelattributes.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/qgslabelattributes.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -70,7 +70,7 @@
     setOffset( 0, 0, PointUnits );
     setAngle( 0 );
-    setAutoAngle(false);
+    setAutoAngle( false );
     setAlignment( Qt::AlignCenter );
     setColor( QColor( 0, 0, 0 ) );
@@ -157,7 +157,7 @@
   return mAngleIsAuto;
-void QgsLabelAttributes::setAutoAngle ( bool state )
+void QgsLabelAttributes::setAutoAngle( bool state )
   mAngleIsAuto = state;
Modified: trunk/qgis/src/core/qgslabelattributes.h
--- trunk/qgis/src/core/qgslabelattributes.h	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/qgslabelattributes.h	2008-12-13 11:07:45 UTC (rev 9781)
@@ -141,7 +141,7 @@
     double angle( void ) const;
     bool   angleIsAuto( void ) const;
-    void   setAutoAngle(bool state);
+    void   setAutoAngle( bool state );
     /* Alignment */
     void setAlignment( int alignment );
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/qgsmaplayer.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -452,7 +452,7 @@
   QgsDebugMsg( QString( "Trying to load style for \"%1\" from \"%2\"" ).arg( theURI ).arg( db ) );
-  if( !QFile( db ).exists() )
+  if ( !QFile( db ).exists() )
     return false;
   myResult = sqlite3_open( db.toUtf8().data(), &myDatabase );
Modified: trunk/qgis/src/core/qgsmaprenderer.cpp
--- trunk/qgis/src/core/qgsmaprenderer.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/qgsmaprenderer.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -289,7 +289,7 @@
     QgsDebugMsg( "  Scale dep. visibility enabled? " + QString( "%1" ).arg( ml->hasScaleBasedVisibility() ) );
     QgsDebugMsg( "  Input extent: " + ml->extent().toString() );
-    if ( !ml->hasScaleBasedVisibility() || (ml->minimumScale() < mScale && mScale < ml->maximumScale() ) )
+    if ( !ml->hasScaleBasedVisibility() || ( ml->minimumScale() < mScale && mScale < ml->maximumScale() ) )
       connect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
@@ -389,7 +389,7 @@
         // only make labels if the layer is visible
         // after scale dep viewing settings are checked
-        if ( !ml->hasScaleBasedVisibility() || (ml->minimumScale() < mScale && mScale < ml->maximumScale() ))
           bool split = false;
Modified: trunk/qgis/src/core/qgssnapper.cpp
--- trunk/qgis/src/core/qgssnapper.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/qgssnapper.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -52,12 +52,12 @@
   QgsSnappingResult newResult;
   QList<QgsSnapper::SnapLayer>::iterator snapLayerIt;
-  for (snapLayerIt = mSnapLayers.begin(); snapLayerIt != mSnapLayers.end(); ++snapLayerIt )
+  for ( snapLayerIt = mSnapLayers.begin(); snapLayerIt != mSnapLayers.end(); ++snapLayerIt )
     //transform point from map coordinates to layer coordinates
     layerCoordPoint = mMapRenderer->mapToLayerCoordinates( snapLayerIt->mLayer, mapCoordPoint );
     if ( snapLayerIt->mLayer->snapWithContext( layerCoordPoint, snapLayerIt->mTolerance,
-                                               currentResultList, snapLayerIt->mSnapTo ) != 0 )
+         currentResultList, snapLayerIt->mSnapTo ) != 0 )
       //error
Modified: trunk/qgis/src/core/qgssnapper.h
--- trunk/qgis/src/core/qgssnapper.h	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/qgssnapper.h	2008-12-13 11:07:45 UTC (rev 9781)
@@ -87,7 +87,7 @@
       /**What snapping type to use (snap to segment or to vertex)*/
       QgsSnapper::SnappingType mSnapTo;
     QgsSnapper( QgsMapRenderer* mapRender );
     ~QgsSnapper();
     /**Does the snapping operation
Modified: trunk/qgis/src/core/qgsvectordataprovider.h
--- trunk/qgis/src/core/qgsvectordataprovider.h	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/qgsvectordataprovider.h	2008-12-13 11:07:45 UTC (rev 9781)
@@ -64,10 +64,10 @@
       RandomSelectGeometryAtId =     1 << 10,
       SequentialSelectGeometryAtId = 1 << 11
     /** bitmask of all provider's editing capabilities */
     const static int EditingCapabilities = AddFeatures | DeleteFeatures |
-        ChangeAttributeValues | ChangeGeometries | AddAttributes | DeleteAttributes;
+                                           ChangeAttributeValues | ChangeGeometries | AddAttributes | DeleteAttributes;
      * Constructor of the vector provider
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -1164,7 +1164,7 @@
   // remove all attributes that will disappear
   const QgsAttributeMap &map = f.attributeMap();
   for ( QgsAttributeMap::const_iterator it = map.begin(); it != map.end(); it++ )
-    if( !mUpdatedFields.contains( it.key() ) )
+    if ( !mUpdatedFields.contains( it.key() ) )
       f.deleteAttribute( it.key() );
   // null/add all attributes that were added, but don't exist in the feature yet
@@ -2641,7 +2641,7 @@
     QgsNewAttributesMap addedAttributes;
     for ( QgsAttributeIds::const_iterator it = mAddedAttributeIds.begin(); it != mAddedAttributeIds.end(); it++ )
-      addedAttributes[ mUpdatedFields[ *it ].name() ] = mUpdatedFields[ *it ].typeName();
+      addedAttributes[ mUpdatedFields[ *it ].name()] = mUpdatedFields[ *it ].typeName();
     if (( cap & QgsVectorDataProvider::AddAttributes ) && mDataProvider->addAttributes( addedAttributes ) )
@@ -2666,7 +2666,7 @@
     QMap<int, QString> src;
     for ( QgsFieldMap::const_iterator it = mUpdatedFields.begin(); it != mUpdatedFields.end(); it++ )
-      src[ it.key() ] = it.value().name();
+      src[ it.key()] = it.value().name();
     int maxAttrIdx = -1;
@@ -2676,7 +2676,7 @@
     QMap<QString, int> dst;
     for ( QgsFieldMap::const_iterator it = pFields.begin(); it != pFields.end(); it++ )
-      dst[ it.value().name() ] = it.key();
+      dst[ it.value().name()] = it.key();
       if ( it.key() > maxAttrIdx )
         maxAttrIdx = it.key();
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/qgsvectorlayer.h	2008-12-13 11:07:45 UTC (rev 9781)
@@ -133,7 +133,7 @@
     void invertSelection();
     /** Invert selection of features found within the search rectangle (in layer's coordinates) */
-    void invertSelectionInRectangle( QgsRectangle & rect);
+    void invertSelectionInRectangle( QgsRectangle & rect );
     /** Get a copy of the user-selected features */
     QgsFeatureList selectedFeatures();
Modified: trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp
--- trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -122,8 +122,8 @@
   int imageSize;
   if ( fullName.left( 5 ) == "hard:" )
-    int pw = ( ( pen.width()==0 ? 1 : pen.width() ) + 1 ) / 2 * 2;	// make even (round up); handle cosmetic pen
-    imageSize = ( (int) size + pw ) / 2 * 2 + 1;	//  make image width, height odd; account for pen width
+    int pw = (( pen.width() == 0 ? 1 : pen.width() ) + 1 ) / 2 * 2; // make even (round up); handle cosmetic pen
+    imageSize = (( int ) size + pw ) / 2 * 2 + 1; //  make image width, height odd; account for pen width
     myImage = QImage( imageSize, imageSize, QImage::Format_ARGB32_Premultiplied );
   else
@@ -131,7 +131,7 @@
     // TODO Change this logic so width is size and height is same
     // proportion of scale factor as in oritignal SVG TS XXX
     //QPixmap myPixmap = QPixmap(width,height);
-    imageSize = ( (int) size ) / 2 * 2 + 1;	//  make image width, height odd
+    imageSize = (( int ) size ) / 2 * 2 + 1; //  make image width, height odd
@@ -195,7 +195,7 @@
-    hardMarker( &myPainter, (int) size, fullName.mid( 5 ), size, pen, brush, qtBug );
+    hardMarker( &myPainter, ( int ) size, fullName.mid( 5 ), size, pen, brush, qtBug );
     return myPicture;
   else if ( fullName.left( 4 ) == "svg:" )
@@ -219,20 +219,20 @@
   // around a circle with diameter mPointSize
 #if 0
-  s = s - pen.widthF();	// to make the overall size of the symbol at the specified size
+  s = s - pen.widthF(); // to make the overall size of the symbol at the specified size
 #else
   // the size of the base symbol is at the specified size; the outline is applied additionally
 #endif
   // Circle radius, is used for other figures also, when compensating for line
   // width is necessary.
-  double r = s / 2;	// get half the size of the figure to be rendered (the radius)
+  double r = s / 2; // get half the size of the figure to be rendered (the radius)
   QgsDebugMsg( QString( "Hard marker size %1" ).arg( s ) );
   // Find out center coordinates of the QImage to draw on.
-  double x_c = (double) ( imageSize / 2 ) + 0.5;	// add 1/2 pixel for proper rounding when the figure's coordinates are added
-  double y_c = x_c;		// is square image
+  double x_c = ( double )( imageSize / 2 ) + 0.5; // add 1/2 pixel for proper rounding when the figure's coordinates are added
+  double y_c = x_c;  // is square image
   thepPainter->setPen( pen );
   thepPainter->setBrush( brush );
@@ -245,29 +245,29 @@
     // "A stroked ellipse has a size of rectangle.size() plus the pen width."
     // (from Qt doc)
-    thepPainter->drawEllipse( QRectF( x_c - r, y_c - r, s, s ) );	// x,y,w,h
+    thepPainter->drawEllipse( QRectF( x_c - r, y_c - r, s, s ) ); // x,y,w,h
   else if ( name == "rectangle" )
-    thepPainter->drawRect( QRectF( x_c - r, y_c - r, s, s ) );		// x,y,w,h
+    thepPainter->drawRect( QRectF( x_c - r, y_c - r, s, s ) );  // x,y,w,h
   else if ( name == "diamond" )
     QPolygonF pa;
     pa << QPointF( x_c - r, y_c )
-       << QPointF( x_c, y_c + r )
-       << QPointF( x_c + r, y_c )
-       << QPointF( x_c, y_c - r );
+    << QPointF( x_c, y_c + r )
+    << QPointF( x_c + r, y_c )
+    << QPointF( x_c, y_c - r );
     thepPainter->drawPolygon( pa );
   else if ( name == "pentagon" )
     QPolygonF pa;
     pa << QPointF( x_c + ( r * sin( DEG2RAD( 288.0 ) ) ), y_c - ( r * cos( DEG2RAD( 288.0 ) ) ) )
-       << QPointF( x_c + ( r * sin( DEG2RAD( 216.0 ) ) ), y_c - ( r * cos( DEG2RAD( 216.0 ) ) ) )
-       << QPointF( x_c + ( r * sin( DEG2RAD( 144.0 ) ) ), y_c - ( r * cos( DEG2RAD( 144.0 ) ) ) )
-       << QPointF( x_c + ( r * sin( DEG2RAD( 72.0 ) ) ), y_c - ( r * cos( DEG2RAD( 72.0 ) ) ) )
+    << QPointF( x_c + ( r * sin( DEG2RAD( 216.0 ) ) ), y_c - ( r * cos( DEG2RAD( 216.0 ) ) ) )
+    << QPointF( x_c + ( r * sin( DEG2RAD( 144.0 ) ) ), y_c - ( r * cos( DEG2RAD( 144.0 ) ) ) )
+    << QPointF( x_c + ( r * sin( DEG2RAD( 72.0 ) ) ), y_c - ( r * cos( DEG2RAD( 72.0 ) ) ) )
   else if ( name == "cross" )
@@ -284,16 +284,16 @@
     QPolygonF pa;
     pa << QPointF( x_c - r, y_c + r )
-       << QPointF( x_c + r, y_c + r )
+    << QPointF( x_c + r, y_c + r )
   else if ( name == "equilateral_triangle" )
     QPolygonF pa;
     pa << QPointF( x_c + ( r * sin( DEG2RAD( 240.0 ) ) ), y_c - ( r * cos( DEG2RAD( 240.0 ) ) ) )
-       << QPointF( x_c + ( r * sin( DEG2RAD( 120.0 ) ) ), y_c - ( r * cos( DEG2RAD( 120.0 ) ) ) )
-       << QPointF( x_c, y_c - r );	// 0
+    << QPointF( x_c + ( r * sin( DEG2RAD( 120.0 ) ) ), y_c - ( r * cos( DEG2RAD( 120.0 ) ) ) )
+    << QPointF( x_c, y_c - r ); // 0
   else if ( name == "star" )
@@ -302,15 +302,15 @@
     QPolygonF pa;
     pa << QPointF( x_c, y_c - r )
-       << QPointF( x_c - oneSixth, y_c - oneSixth )
-       << QPointF( x_c - r, y_c - oneSixth )
-       << QPointF( x_c - oneSixth, y_c )
-       << QPointF( x_c - r, y_c + r )
-       << QPointF( x_c, y_c + oneSixth )
-       << QPointF( x_c + oneSixth, y_c )
-       << QPointF( x_c + r, y_c - oneSixth )
-       << QPointF( x_c + oneSixth, y_c - oneSixth );
+    << QPointF( x_c - oneSixth, y_c - oneSixth )
+    << QPointF( x_c - r, y_c - oneSixth )
+    << QPointF( x_c - oneSixth, y_c )
+    << QPointF( x_c - r, y_c + r )
+    << QPointF( x_c, y_c + oneSixth )
+    << QPointF( x_c + oneSixth, y_c )
+    << QPointF( x_c + r, y_c - oneSixth )
+    << QPointF( x_c + oneSixth, y_c - oneSixth );
   else if ( name == "regular_star" )
@@ -319,16 +319,16 @@
     double inner_r = r * cos( DEG2RAD( 72.0 ) ) / cos( DEG2RAD( 36.0 ) );
     QPolygonF pa;
-    pa << QPointF( x_c + ( inner_r * sin( DEG2RAD( 324.0 ) ) ), y_c - ( inner_r * cos( DEG2RAD( 324.0 ) ) ) )	// 324
-       << QPointF( x_c + ( r * sin( DEG2RAD( 288.0 ) ) ), y_c - ( r * cos( DEG2RAD( 288 ) ) ) )			// 288
-       << QPointF( x_c + ( inner_r * sin( DEG2RAD( 252.0 ) ) ), y_c - ( inner_r * cos( DEG2RAD( 252.0 ) ) ) )	// 252
-       << QPointF( x_c + ( r * sin( DEG2RAD( 216.0 ) ) ), y_c - ( r * cos( DEG2RAD( 216.0 ) ) ) )		// 216
-       << QPointF( x_c, y_c + ( inner_r ) )									// 180
-       << QPointF( x_c + ( r * sin( DEG2RAD( 144.0 ) ) ), y_c - ( r * cos( DEG2RAD( 144.0 ) ) ) )		// 144
-       << QPointF( x_c + ( inner_r * sin( DEG2RAD( 108.0 ) ) ), y_c - ( inner_r * cos( DEG2RAD( 108.0 ) ) ) )	// 108
-       << QPointF( x_c + ( r * sin( DEG2RAD( 72.0 ) ) ), y_c - ( r * cos( DEG2RAD( 72.0 ) ) ) )			//  72
-       << QPointF( x_c + ( inner_r * sin( DEG2RAD( 36.0 ) ) ), y_c - ( inner_r * cos( DEG2RAD( 36.0 ) ) ) )	//  36
+    pa << QPointF( x_c + ( inner_r * sin( DEG2RAD( 324.0 ) ) ), y_c - ( inner_r * cos( DEG2RAD( 324.0 ) ) ) ) // 324
+    << QPointF( x_c + ( r * sin( DEG2RAD( 288.0 ) ) ), y_c - ( r * cos( DEG2RAD( 288 ) ) ) )   // 288
+    << QPointF( x_c + ( inner_r * sin( DEG2RAD( 252.0 ) ) ), y_c - ( inner_r * cos( DEG2RAD( 252.0 ) ) ) ) // 252
+    << QPointF( x_c + ( r * sin( DEG2RAD( 216.0 ) ) ), y_c - ( r * cos( DEG2RAD( 216.0 ) ) ) )  // 216
+    << QPointF( x_c, y_c + ( inner_r ) )         // 180
+    << QPointF( x_c + ( r * sin( DEG2RAD( 144.0 ) ) ), y_c - ( r * cos( DEG2RAD( 144.0 ) ) ) )  // 144
+    << QPointF( x_c + ( inner_r * sin( DEG2RAD( 108.0 ) ) ), y_c - ( inner_r * cos( DEG2RAD( 108.0 ) ) ) ) // 108
+    << QPointF( x_c + ( r * sin( DEG2RAD( 72.0 ) ) ), y_c - ( r * cos( DEG2RAD( 72.0 ) ) ) )   //  72
+    << QPointF( x_c + ( inner_r * sin( DEG2RAD( 36.0 ) ) ), y_c - ( inner_r * cos( DEG2RAD( 36.0 ) ) ) ) //  36
   else if ( name == "arrow" )
@@ -338,12 +338,12 @@
     QPolygonF pa;
-       << QPointF( x_c + quarter,  y_c - quarter )
-       << QPointF( x_c + oneEight, y_c - quarter )
-       << QPointF( x_c + oneEight, y_c + r )
-       << QPointF( x_c - oneEight, y_c + r )
-       << QPointF( x_c - oneEight, y_c - quarter )
-       << QPointF( x_c - quarter,  y_c - quarter );
+    << QPointF( x_c + quarter,  y_c - quarter )
+    << QPointF( x_c + oneEight, y_c - quarter )
+    << QPointF( x_c + oneEight, y_c + r )
+    << QPointF( x_c - oneEight, y_c + r )
+    << QPointF( x_c - oneEight, y_c - quarter )
+    << QPointF( x_c - quarter,  y_c - quarter );
   thepPainter->end();
Modified: trunk/qgis/src/core/symbology/qgssymbol.cpp
--- trunk/qgis/src/core/symbology/qgssymbol.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/core/symbology/qgssymbol.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -485,7 +485,7 @@
     QString name = node.toElement().text();
     for ( QgsFieldMap::const_iterator it = fields.begin(); it != fields.end(); it++ )
-      if( it->name() == name )
+      if ( it->name() == name )
         return it.key();
     return -1;
Modified: trunk/qgis/src/gui/qgsmapcanvas.cpp
--- trunk/qgis/src/gui/qgsmapcanvas.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/gui/qgsmapcanvas.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -860,7 +860,7 @@
     case WheelZoom:
       // zoom without changing extent
-      if (e->delta() > 0)
+      if ( e->delta() > 0 )
         zoomIn();
       else
         zoomOut();
Modified: trunk/qgis/src/gui/qgsmapcanvas.h
--- trunk/qgis/src/gui/qgsmapcanvas.h	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/gui/qgsmapcanvas.h	2008-12-13 11:07:45 UTC (rev 9781)
@@ -215,7 +215,7 @@
     //! Zoom out with fixed factor
     void zoomOut( );
     //! Zoom with the factor supplied. Factor > 1 zooms in
     void zoomByFactor( double scaleFactor );
Modified: trunk/qgis/src/gui/qgsmapcanvassnapper.cpp
--- trunk/qgis/src/gui/qgsmapcanvassnapper.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/gui/qgsmapcanvassnapper.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -206,7 +206,7 @@
           snapLayer.mSnapTo = QgsSnapper::SnapToVertexAndSegment;
-        snapLayers.append(snapLayer);
+        snapLayers.append( snapLayer );
     else //nothing in project. Use default snapping tolerance to vertex of current layer
@@ -243,8 +243,8 @@
       //default snapping tolerance
       snapLayer.mTolerance = settings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble();
     mSnapper->setSnapLayers( snapLayers );
Modified: trunk/qgis/src/gui/qgsprojectionselector.cpp
--- trunk/qgis/src/gui/qgsprojectionselector.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/gui/qgsprojectionselector.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -132,7 +132,7 @@
-    if ( parts.at( 0 ) == "EPSG" && parts.size()>=2 )
+    if ( parts.at( 0 ) == "EPSG" && parts.size() >= 2 )
       epsgParts.push_back( parts.at( 1 ) );
Modified: trunk/qgis/src/gui/qgsrubberband.cpp
--- trunk/qgis/src/gui/qgsrubberband.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/gui/qgsrubberband.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -178,14 +178,14 @@
       mIsPolygon = true;
       double d = mMapCanvas->extent().width() * 0.005;
       QgsPoint pt;
-      if(layer)
-	  pt = mr->layerToMapCoordinates( layer, geom->asPoint() );
+      if ( layer )
+        pt = mr->layerToMapCoordinates( layer, geom->asPoint() );
       else
-	  pt = geom->asPoint();
+        pt = geom->asPoint();
       addPoint( QgsPoint( pt.x() - d, pt.y() - d ) );
       addPoint( QgsPoint( pt.x() + d, pt.y() - d ) );
       addPoint( QgsPoint( pt.x() + d, pt.y() + d ) );
@@ -202,20 +202,20 @@
       for ( int i = 0; i < mpt.size(); ++i )
         QgsPoint pt = mpt[i];
-	if(layer)
-	    addPoint( mr->layerToMapCoordinates( layer, QgsPoint( pt.x() - d, pt.y() - d ) ) );
-	    addPoint( mr->layerToMapCoordinates( layer, QgsPoint( pt.x() + d, pt.y() - d ) ) );
-	    addPoint( mr->layerToMapCoordinates( layer, QgsPoint( pt.x() + d, pt.y() + d ) ) );
-	    addPoint( mr->layerToMapCoordinates( layer, QgsPoint( pt.x() - d, pt.y() + d ) ) );
-	else
-	    addPoint(QgsPoint( pt.x() - d, pt.y() - d ) );
-	    addPoint(QgsPoint( pt.x() + d, pt.y() - d ) );
-	    addPoint(QgsPoint( pt.x() + d, pt.y() + d ) );
-	    addPoint(QgsPoint( pt.x() - d, pt.y() + d ) );
+        if ( layer )
+          addPoint( mr->layerToMapCoordinates( layer, QgsPoint( pt.x() - d, pt.y() - d ) ) );
+          addPoint( mr->layerToMapCoordinates( layer, QgsPoint( pt.x() + d, pt.y() - d ) ) );
+          addPoint( mr->layerToMapCoordinates( layer, QgsPoint( pt.x() + d, pt.y() + d ) ) );
+          addPoint( mr->layerToMapCoordinates( layer, QgsPoint( pt.x() - d, pt.y() + d ) ) );
+        else
+          addPoint( QgsPoint( pt.x() - d, pt.y() - d ) );
+          addPoint( QgsPoint( pt.x() + d, pt.y() - d ) );
+          addPoint( QgsPoint( pt.x() + d, pt.y() + d ) );
+          addPoint( QgsPoint( pt.x() - d, pt.y() + d ) );
     break;
@@ -227,14 +227,14 @@
       QgsPolyline line = geom->asPolyline();
       for ( int i = 0; i < line.count(); i++ )
-	if(layer)
-	    addPoint( mr->layerToMapCoordinates( layer, line[i] ) );
-	else
-	    addPoint(line[i]);
+        if ( layer )
+          addPoint( mr->layerToMapCoordinates( layer, line[i] ) );
+        else
+          addPoint( line[i] );
     break;
@@ -253,14 +253,14 @@
         QgsPolyline line = mline[i];
         for ( int j = 0; j < line.size(); ++j )
-	  if(layer)
-	      addPoint( mr->layerToMapCoordinates( layer, line[j] ), false, i );
-	  else
-	      addPoint(line[j]);
+          if ( layer )
+            addPoint( mr->layerToMapCoordinates( layer, line[j] ), false, i );
+          else
+            addPoint( line[j] );
@@ -274,14 +274,14 @@
       QgsPolyline line = poly[0];
-	if(layer)
-	else
+        if ( layer )
+        else
     break;
@@ -301,14 +301,14 @@
         for ( int j = 0; j < line.count(); ++j )
-	  if(layer)
-	  else
+          if ( layer )
+          else
Modified: trunk/qgis/src/gui/qgsrubberband.h
--- trunk/qgis/src/gui/qgsrubberband.h	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/gui/qgsrubberband.h	2008-12-13 11:07:45 UTC (rev 9781)
@@ -56,7 +56,7 @@
     /**Sets this rubber band to the geometry of an existing feature.
      This is usefull for feature highlighting.
     @param geom the geometry object
-    @param layer the layer containing the feature, used for coord transformation to map
+    @param layer the layer containing the feature, used for coord transformation to map
     crs. In case of 0 pointer, the coordinates are not going to be transformed.
     @param render the maprender object (used for coord transformation)*/
     void setToGeometry( QgsGeometry* geom, QgsVectorLayer* layer );
Modified: trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -1045,7 +1045,7 @@
     ( ( GRASS_VERSION_MAJOR == 6 && GRASS_VERSION_MINOR >= 4 ) || GRASS_VERSION_MAJOR > 6 )
     Vect_build( map.map );
 #else
-    Vect_build( map.map, stderr );
+    Vect_build( map.map, stderr );
 #endif
     if ( QgsGrass::getError() == QgsGrass::FATAL )
@@ -1528,8 +1528,8 @@
 #if defined(GRASS_VERSION_MAJOR) && defined(GRASS_VERSION_MINOR) && \
   Vect_build_partial( map->map, GV_BUILD_NONE );
-  Vect_build( map->map );
-#else
+  Vect_build( map->map );
+#else
   Vect_build_partial( map->map, GV_BUILD_NONE, NULL );
   Vect_build( map->map, stderr );
 #endif
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -423,9 +423,9 @@
         query += QString( ",boolout(%1)" ).arg( quotedIdentifier( fieldname ) );
-      else if ( type == "geometry")
+      else if ( type == "geometry" )
-        query += QString(",asewkt(%1)").arg(quotedIdentifier(fieldname));
+        query += QString( ",asewkt(%1)" ).arg( quotedIdentifier( fieldname ) );
       else
@@ -1806,9 +1806,9 @@
             values += "," + defVal;
-        else if( fit->typeName()=="geometry" )
+        else if ( fit->typeName() == "geometry" )
-          values += QString(",geomfromewkt(%1)").arg( quotedValue( it->toString() ) );
+          values += QString( ",geomfromewkt(%1)" ).arg( quotedValue( it->toString() ) );
         else
@@ -1818,7 +1818,7 @@
       else
         // value is not unique => add parameter
-        if( fit->typeName()=="geometry" )
+        if ( fit->typeName() == "geometry" )
           values += QString( ",geomfromewkt($%1)" ).arg( defaultValues.size() + 3 );
@@ -2054,7 +2054,7 @@
           else
             first = false;
-          sql += QString( fld.typeName()!="geometry" ? "%1=%2" : "%1=geomfromewkt(%2)" )
+          sql += QString( fld.typeName() != "geometry" ? "%1=%2" : "%1=geomfromewkt(%2)" )
                  .arg( quotedIdentifier( fld.name() ) )
                  .arg( quotedValue( siter->toString() ) );
@@ -2565,7 +2565,7 @@
                  tr( ". The database communication log was:\n" ) );
     showMessageBox( tr( "Unable to get feature type and srid" ), log );
   // store whether the geometry includes measure value
   if ( fType == "POINTM" || fType == "MULTIPOINTM" ||
        fType == "LINESTRINGM" || fType == "MULTILINESTRINGM" ||
@@ -2573,10 +2573,10 @@
     // explicitly disable adding new features and editing of geometries
     // as this would lead to corruption of measures
-    enabledCapabilities &= ~(QgsVectorDataProvider::ChangeGeometries | QgsVectorDataProvider::AddFeatures);
+    enabledCapabilities &= ~( QgsVectorDataProvider::ChangeGeometries | QgsVectorDataProvider::AddFeatures );
   if ( valid )
     QgsDebugMsg( "SRID is " + srid );
@@ -2670,10 +2670,10 @@
                     .arg( PQresultErrorMessage( res ) );
       QgsDebugMsgLevel( err, 3 );
 #endif
-      if( openCursors )
+      if ( openCursors )
         PQexecNR( "ROLLBACK" );
-        QgsDebugMsg( QString("Re-starting read-only transaction after errornous statement - state of %1 cursors lost" ).arg( openCursors ) );
+        QgsDebugMsg( QString( "Re-starting read-only transaction after errornous statement - state of %1 cursors lost" ).arg( openCursors ) );
         PQexecNR( "BEGIN READ ONLY" );
Modified: trunk/qgis/src/providers/wms/qgswmsprovider.cpp
--- trunk/qgis/src/providers/wms/qgswmsprovider.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/providers/wms/qgswmsprovider.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -381,7 +381,7 @@
   QString url;
   std::vector<QgsWmsDcpTypeProperty> dcpType = mCapabilities.capability.request.getMap.dcpType;
-  if(dcpType.size() < 1)
+  if ( dcpType.size() < 1 )
     url = baseUrl;
Modified: trunk/qgis/src/python/qgspythonutilsimpl.cpp
--- trunk/qgis/src/python/qgspythonutilsimpl.cpp	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/python/qgspythonutilsimpl.cpp	2008-12-13 11:07:45 UTC (rev 9781)
@@ -87,17 +87,17 @@
   runString(
     "def qgis_except_hook_msg(type, value, tb, msg):\n"
     "  lst = traceback.format_exception(type, value, tb)\n"
-    "  if msg == None: msg = '" + QObject::tr( "An error has occured while executing Python code:" ).replace("'", "\\'") + "'\n"
+    "  if msg == None: msg = '" + QObject::tr( "An error has occured while executing Python code:" ).replace( "'", "\\'" ) + "'\n"
     "  txt = '<font color=\"red\">'+msg+'</font><br><br>'\n"
     "  for s in lst:\n"
     "    txt += s\n"
-    "  txt += '<br>" + QObject::tr( "Python version:" ).replace("'", "\\'") + "<br>' + sys.version + '<br><br>'\n"
-    "  txt += '" + QObject::tr( "Python path:" ).replace("'", "\\'") + "' + str(sys.path)\n"
+    "  txt += '<br>" + QObject::tr( "Python version:" ).replace( "'", "\\'" ) + "<br>' + sys.version + '<br><br>'\n"
+    "  txt += '" + QObject::tr( "Python path:" ).replace( "'", "\\'" ) + "' + str(sys.path)\n"
     "  txt = txt.replace('\\n', '<br>')\n"
     "  txt = txt.replace('  ', '&nbsp; ')\n" // preserve whitespaces for nicer output
     "  \n"
     "  msg = QgsMessageOutput.createMessageOutput()\n"
-    "  msg.setTitle('" + QObject::tr( "Python error" ).replace("'", "\\'") + "')\n"
+    "  msg.setTitle('" + QObject::tr( "Python error" ).replace( "'", "\\'" ) + "')\n"
     "  msg.setMessage(txt, QgsMessageOutput.MessageHtml)\n"
     "  msg.showMessage()\n" );
   runString(
@@ -427,7 +427,7 @@
   // temporary disable error hook - UI will handle this gracefully
   uninstallErrorHook();
   PyObject* obj = PyRun_String( command.toLocal8Bit().data(), Py_eval_input, mMainDict, mMainDict );
   if ( PyErr_Occurred() )
     PyErr_Print(); // just print it to console
@@ -437,7 +437,7 @@
   else if ( PyUnicode_Check( obj ) )
     PyObject* utf8 = PyUnicode_AsUTF8String( obj );
-    if (utf8)
+    if ( utf8 )
       retval = QString::fromUtf8( PyString_AS_STRING( utf8 ) );
     else
       retval = "__error__";
@@ -453,7 +453,7 @@
   Py_XDECREF( obj );
   installErrorHook();
   return retval;
Modified: trunk/qgis/src/python/qgspythonutilsimpl.h
--- trunk/qgis/src/python/qgspythonutilsimpl.h	2008-12-13 10:12:02 UTC (rev 9780)
+++ trunk/qgis/src/python/qgspythonutilsimpl.h	2008-12-13 11:07:45 UTC (rev 9781)
@@ -113,7 +113,7 @@
     void installErrorHook();
     void uninstallErrorHook();
     QString getTraceback();
     //! reference to module __main__
More information about the QGIS-commit mailing list
