[QGIS Commit] r9787 - trunk/qgis/src/providers/ogr
svn_qgis at osgeo.org
Sat Dec 13 15:42:49 EST 2008
Author: mhugent
Date: 2008-12-13 15:42:49 -0500 (Sat, 13 Dec 2008)
New Revision: 9787
trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
Applied patch #1295 from smizuno. Thanks!
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2008-12-13 20:25:01 UTC (rev 9786)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2008-12-13 20:42:49 UTC (rev 9787)
@@ -723,15 +723,11 @@
bool QgsOgrProvider::createSpatialIndex()
- QString fileName = dataSourceUri().section( '/', -1, -1 );//find out the file name from the uri
- QString layerName = fileName.section( '.', 0, 0 );
- QString sql = "CREATE SPATIAL INDEX ON " + layerName;
- OGR_DS_ExecuteSQL( ogrDataSource, sql.toAscii(), OGR_L_GetSpatialFilter( ogrLayer ), "" );
+ QFileInfo fi( dataSourceUri() ); // to get the base name
+ QString sql = QString( "CREATE SPATIAL INDEX ON %1" ).arg( quotedIdentifier( fi.completeBaseName() ) ); // quote the layer name so spaces are handled
+ OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).data(), OGR_L_GetSpatialFilter( ogrLayer ), "" );
//find out, if the .qix file is there
- QString indexname = dataSourceUri();
- indexname.truncate( dataSourceUri().length() - fileName.length() );
- indexname = indexname + layerName + ".qix";
- QFile indexfile( indexname );
+ QFile indexfile( fi.path().append( "/").append( fi.completeBaseName() ).append( ".qix" ) );
if ( indexfile.exists() )
return true;
@@ -753,11 +749,10 @@
- OGR_L_SyncToDisk( ogrLayer );
- QString sql = "REPACK " + layerName;
- OGR_DS_ExecuteSQL( ogrDataSource, sql.toLocal8Bit().data(), NULL, NULL );
+ OGR_L_SyncToDisk( ogrLayer );
+ QString sql = QString( "REPACK %1" ).arg( fi.completeBaseName() ); // don't quote the layer name as it works with spaces in the name and won't work if the name is quoted
+ OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).data(), NULL, NULL );
featuresCounted = OGR_L_GetFeatureCount( ogrLayer, TRUE ); //new feature count
return returnvalue;
@@ -1177,7 +1172,7 @@
OGRLayerH layer;
- layer = OGR_DS_CreateLayer( dataSource, QFile::encodeName( QFileInfo( uri ).baseName() ).constData(), reference, OGRvectortype, NULL );
+ layer = OGR_DS_CreateLayer( dataSource, QFile::encodeName( QFileInfo( uri ).completeBaseName() ).constData(), reference, OGRvectortype, NULL );
if ( layer == NULL )
return false;
@@ -1268,7 +1263,7 @@
QString sql = QString( "SELECT DISTINCT %1 FROM %2 ORDER BY %1" )
.arg( quotedIdentifier( fld.name() ) )
- .arg( quotedIdentifier( fi.baseName() ) );
+ .arg( quotedIdentifier( fi.completeBaseName() ) );
uniqueValues.clear();
@@ -1298,7 +1293,7 @@
QString sql = QString( "SELECT MIN(%1) FROM %2" )
OGRLayerH l = OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).data(), NULL, "SQL" );
@@ -1329,7 +1324,7 @@
QString sql = QString( "SELECT MAX(%1) FROM %2" )
if ( l == 0 )
