[QGIS Commit] r9798 - trunk/qgis/python/plugins/plugin_installer
svn_qgis at osgeo.org
Sun Dec 14 11:23:38 EST 2008
Author: borysiasty
Date: 2008-12-14 11:23:38 -0500 (Sun, 14 Dec 2008)
New Revision: 9798
trunk/qgis/python/plugins/plugin_installer/__init__.py
trunk/qgis/python/plugins/plugin_installer/installer_data.py
trunk/qgis/python/plugins/plugin_installer/installer_gui.py
trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
Plugin Installer update
Modified: trunk/qgis/python/plugins/plugin_installer/__init__.py
--- trunk/qgis/python/plugins/plugin_installer/__init__.py 2008-12-14 14:51:00 UTC (rev 9797)
+++ trunk/qgis/python/plugins/plugin_installer/__init__.py 2008-12-14 16:23:38 UTC (rev 9798)
@@ -14,7 +14,7 @@
return "Plugin Installer"
def version():
- return "Version 0.9.4"
+ return "Version 0.9.5"
def description():
return "Downloads and installs QGIS python plugins"
Modified: trunk/qgis/python/plugins/plugin_installer/installer_data.py
--- trunk/qgis/python/plugins/plugin_installer/installer_data.py 2008-12-14 14:51:00 UTC (rev 9797)
+++ trunk/qgis/python/plugins/plugin_installer/installer_data.py 2008-12-14 16:23:38 UTC (rev 9798)
@@ -61,6 +61,13 @@
QGIS_MAJOR_VER = 1
+def setIface(qgisIface):
+ global iface
+ iface = qgisIface
reposGroup = "/Qgis/plugin-repos"
settingsGroup = "/Qgis/plugin-installer"
seenPluginGroup = "/Qgis/plugin-seen"
@@ -317,10 +324,13 @@
"repository" : reposName,
"localdir" : name,
"read-only" : False}
- #if compatible, add the plugin to list
qgisMinimumVersion = pluginNodes.item(i).firstChildElement("qgis_minimum_version").text().trimmed()
if not qgisMinimumVersion: qgisMinimumVersion = "0"
- if compareVersions(QGIS_VER, qgisMinimumVersion) < 2:
+ # please use the tag below only if really needed! (for example if plugin development is abandoned)
+ qgisMaximumVersion = pluginNodes.item(i).firstChildElement("qgis_maximum_version").text().trimmed()
+ if not qgisMaximumVersion: qgisMaximumVersion = "2"
+ #if compatible, add the plugin to the list
+ if compareVersions(QGIS_VER, qgisMinimumVersion) < 2 and compareVersions(qgisMaximumVersion, QGIS_VER) < 2:
plugins.addPlugin(plugin)
plugins.workarounds()
self.mRepositories[reposName]["state"] = 2
@@ -440,10 +450,10 @@
errorDetails = qgisMinimumVersion
except:
pass
- #try:
- # exec ("%s.classFactory(QgisInterface)" % key)
- #except Exception, error:
- # error = error.message
+ try:
+ exec ("%s.classFactory(iface)" % key)
+ except Exception, error:
+ error = error.message
@@ -571,8 +581,6 @@
def workarounds(self):
""" workarounds for particular plugins with wrong metadata """
- if self.mPlugins.has_key("postgps") and self.mPlugins["postgps"]["version_avail"] == "0.2":
- self.mPlugins["postgps"]["version_avail"] = "0.01"
if self.mPlugins.has_key("select") and self.mPlugins["select"]["version_avail"] == "0.1":
self.mPlugins["select"]["version_avail"] = "0.2"
Modified: trunk/qgis/python/plugins/plugin_installer/installer_gui.py
--- trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2008-12-14 14:51:00 UTC (rev 9797)
+++ trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2008-12-14 16:23:38 UTC (rev 9798)
@@ -412,7 +412,7 @@
ver = availableVersion
else:
ver = installedVersion
- if p["status"] in ["upgradeable","newer"]:
+ if p["status"] in ["upgradeable","newer"] or installedVersion == "?" or availableVersion == "?":
verTip = self.tr("installed version") + ": " + installedVersion + "\n" + self.tr("available version") + ": " + availableVersion
elif p["status"] in ["not installed", "new"]:
verTip = self.tr("available version") + ": " + availableVersion
@@ -568,7 +568,7 @@
message = self.tr("The plugin is designed for a newer version of Quantum GIS. The minimum required version is:")
message += " <b>" + plugin["error_details"] + "</b>"
elif plugin["error"] == "dependent":
- message = self.tr("The plugin depends on some components missing on this system. You need to install the following Python module in order to enable it:")
+ message = self.tr("The plugin depends on some components missing on your system. You need to install the following Python module in order to enable it:")
message += "<b> " + plugin["error_details"] + "</b>"
else:
message = self.tr("The plugin is broken. Python said:")
Modified: trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
--- trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2008-12-14 14:51:00 UTC (rev 9797)
+++ trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2008-12-14 16:23:38 UTC (rev 9798)
@@ -26,6 +26,7 @@
def __init__(self, iface):
self.iface = iface
+ setIface(self.iface) #pass self.iface to installer_data module (needed for plugin loading & testing)
if QGIS_MAJOR_VER: # new plugin API
self.mainWindow = self.iface.mainWindow
else: # old plugin API
