[QGIS Commit] r9816 - branches/Version-1_0/doc
svn_qgis at osgeo.org
Tue Dec 16 03:01:15 EST 2008
Author: timlinux
Date: 2008-12-16 03:01:14 -0500 (Tue, 16 Dec 2008)
New Revision: 9816
branches/Version-1_0/doc/CODING.t2t
branches/Version-1_0/doc/INSTALL.t2t
Added note for generating LaTeX sources
Modified: branches/Version-1_0/doc/CODING.t2t
--- branches/Version-1_0/doc/CODING.t2t 2008-12-16 07:49:42 UTC (rev 9815)
+++ branches/Version-1_0/doc/CODING.t2t 2008-12-16 08:01:14 UTC (rev 9816)
@@ -26,6 +26,8 @@
% txt2tags -t moin CODING.moin CODING.t2t
% To generate the html version of this document
% txt2tags -t html CODING.html CODING.t2t
+% To generate LaTeX version of this document do:
+% txt2tags -t tex -o CODING.tex CODING.t2t
% End of comments
Modified: branches/Version-1_0/doc/INSTALL.t2t
--- branches/Version-1_0/doc/INSTALL.t2t 2008-12-16 07:49:42 UTC (rev 9815)
+++ branches/Version-1_0/doc/INSTALL.t2t 2008-12-16 08:01:14 UTC (rev 9816)
@@ -17,15 +17,17 @@
%txt2tags home page for more details. Please insert manual line breaks in this
%document as it makes diffing for changes much easier. To do this in vim
%automatically, select a section then issue (gq) command. Please dont
-%apply vim formatting to the whol document as it screws up some formatting
+%apply vim formatting to the whole document as it screws up some formatting
%rather apply it selectively to paragraphs where needed.
% To generate the text version of this document:
% txt2tags -t txt -o INSTALL INSTALL.t2t
% To generate the moinmoin version of this document
-% txt2tags -t moin INSTALL.moin INSTALL.t2t
+% txt2tags -t moin -o INSTALL.moin INSTALL.t2t
-% txt2tags -t html INSTALL.html INSTALL.t2t
+% txt2tags -t html -o INSTALL.html INSTALL.t2t
+% txt2tags -t tex -o INSTALL.tex INSTALL.t2t
% End of comments
@@ -75,8 +77,8 @@
= General Build Notes =
-At version 0.8.1 QGIS no longer uses the autotools for building. QGIS, like a
-number of major projects (eg. KDE 4.0), now uses cmake (http://www.cmake.org)
+Since version 0.8.1 QGIS no longer uses the autotools for building. QGIS, like a
+number of major projects (eg. KDE 4.0), now uses CMake (http://www.cmake.org)
for building from source. The configure script in this directory simply checks
for the existence of cmake and provides some clues to build QGIS.
