[QGIS Commit] r9825 - branches/vector_overlay_branch/src/core
svn_qgis at osgeo.org
Tue Dec 16 08:51:17 EST 2008
Author: mhugent
Date: 2008-12-16 08:51:17 -0500 (Tue, 16 Dec 2008)
New Revision: 9825
branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.cpp
handle multitypes appropriate
Modified: branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.cpp
--- branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.cpp 2008-12-16 12:21:16 UTC (rev 9824)
+++ branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.cpp 2008-12-16 13:51:17 UTC (rev 9825)
@@ -72,31 +72,6 @@
-#if 0
-void QgsCentralPointPositionManager::findObjectPositions(const QgsRect& viewExtent, const QgsMapToPixel * cXf, const QgsCoordinateTransform* ct)
- QgsPoint currentPosition;
- for(std::list<QgsVectorOverlay*>::iterator list_it = mOverlays.begin(); list_it != mOverlays.end(); ++list_it)
- std::multimap<int, QgsOverlayObject*>* objectMapPointer = (*list_it)->overlayObjects();
- if(!objectMapPointer)
- continue;
- std::multimap<int, QgsOverlayObject*>::iterator map_it;
- for(map_it = objectMapPointer->begin(); map_it != objectMapPointer->end(); ++map_it)
- if(findObjectPosition(map_it->second->wkb(), currentPosition) != 0)
- //error
- map_it->second->setPosition(currentPosition);
-#endif //0
int QgsCentralPointPositionManager::findObjectPosition(const unsigned char* wkb, QgsPoint& position) const
QGis::WkbType type;
@@ -110,15 +85,9 @@
switch (type)
- //multigeometries should be already split
+ case QGis::WKBMultiPoint:
case QGis::WKBMultiPoint25D:
- case QGis::WKBMultiPoint:
- case QGis::WKBMultiLineString25D:
- case QGis::WKBMultiLineString:
- case QGis::WKBMultiPolygon25D:
- case QGis::WKBMultiPolygon:
- return 1;
+ currentPosition += (2 * sizeof(int) + 1);
case QGis::WKBPoint25D:
case QGis::WKBPoint:
memcpy(¤tX, &(wkb[currentPosition]), sizeof(double));
@@ -128,73 +97,120 @@
position.setY(currentY);
return 0;
- case QGis::WKBLineString25D:
- hasZValue = true;
- case QGis::WKBLineString://get the middle point
+ case QGis::WKBMultiLineString25D:
+ case QGis::WKBMultiLineString:
- int numberOfPoints;
- memcpy(&numberOfPoints, &(wkb[currentPosition]), sizeof(int));
- currentPosition += sizeof(int);
- if(numberOfPoints < 1)
- return 1;
- if(numberOfPoints > 2)
- int midpoint = (numberOfPoints-1)/2 ;
- for(int i = 0; i < midpoint; ++i)
+ int numberOfLines;
+ memcpy(&numberOfLines, &(wkb[currentPosition]), sizeof(int));
+ if(numberOfLines < 1)
- currentPosition += 2 * sizeof(double);
- if(hasZValue)
- currentPosition += sizeof(double);
+ return 1;
- double xPos, yPos;
- memcpy(&xPos, &(wkb[currentPosition]), sizeof(double));
- currentPosition+= sizeof(double);
- memcpy(&yPos, &(wkb[currentPosition]), sizeof(double));
- position.setX(xPos);
- position.setY(yPos);
- return 0;
+ case QGis::WKBLineString25D:
+ case QGis::WKBLineString://get the middle point
+ if(type == QGis::WKBLineString25D || type == QGis::WKBMultiLineString25D)
+ hasZValue = true;
+ int numberOfPoints;
+ memcpy(&numberOfPoints, &(wkb[currentPosition]), sizeof(int));
+ currentPosition += sizeof(int);
+ if(numberOfPoints < 1)
+ return 2;
+ if(numberOfPoints > 2)
+ int midpoint = (numberOfPoints-1)/2 ;
+ for(int i = 0; i < midpoint; ++i)
+ currentPosition += 2 * sizeof(double);
+ if(hasZValue)
+ currentPosition += sizeof(double);
+ double xPos, yPos;
+ memcpy(&xPos, &(wkb[currentPosition]), sizeof(double));
+ currentPosition+= sizeof(double);
+ memcpy(&yPos, &(wkb[currentPosition]), sizeof(double));
+ position.setX(xPos);
+ position.setY(yPos);
+ return 0;
+ case QGis::WKBMultiPolygon25D:
+ case QGis::WKBMultiPolygon:
+ int numberOfPolygons;
+ memcpy(&numberOfPolygons, &(wkb[currentPosition]), sizeof(int));
+ if(numberOfPolygons < 1)
+ return 3;
+ currentPosition += (1 + sizeof(int));
case QGis::WKBPolygon25D:
- hasZValue = true;
case QGis::WKBPolygon: //calculate the centroid of the first ring
- currentPosition+= sizeof(int); //skip number of rings
- double x[numberOfPoints];
- double y[numberOfPoints];
+ //2.5D or 2D type?
+ if(type == QGis::WKBPolygon25D || type == QGis::WKBMultiPolygon25D)
+ hasZValue = true;
+ //number of rings
+ int numberOfRings;
+ memcpy(&numberOfRings, &(wkb[currentPosition]), sizeof(int));
+ if(numberOfRings < 1)
+ return 4;
+ currentPosition+= sizeof(int);
- for(int i = 0; i < numberOfPoints; ++i)
- memcpy(&(x[i]), &(wkb[currentPosition]), sizeof(double));
- memcpy(&(y[i]), &(wkb[currentPosition]), sizeof(double));
- if(hasZValue)
+ //number of points
+ return 5;
+ double x[numberOfPoints];
+ double y[numberOfPoints];
+ for(int i = 0; i < numberOfPoints; ++i)
+ memcpy(&(x[i]), &(wkb[currentPosition]), sizeof(double));
+ memcpy(&(y[i]), &(wkb[currentPosition]), sizeof(double));
+ if(hasZValue)
- double centroidX, centroidY;
- if(calculatePolygonCentroid(x, y, numberOfPoints, centroidX, centroidY) != 0)
- return 1;
- else
- position.setX(centroidX);
- position.setY(centroidY);
- return 0;
+ double centroidX, centroidY;
+ if(calculatePolygonCentroid(x, y, numberOfPoints, centroidX, centroidY) != 0)
+ return 1;
+ else
+ position.setX(centroidX);
+ position.setY(centroidY);
+ return 0;
default:
- return 1;
+ return 6;
return 0;
