[QGIS Commit] r9838 - trunk/qgis/src/core
svn_qgis at osgeo.org
Wed Dec 17 06:03:46 EST 2008
Author: wonder
Date: 2008-12-17 06:03:46 -0500 (Wed, 17 Dec 2008)
New Revision: 9838
Removed:
trunk/qgis/src/core/qgsline.cpp
trunk/qgis/src/core/qgsline.h
trunk/qgis/src/core/CMakeLists.txt
removed legacy class QgsLine
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt 2008-12-16 20:57:42 UTC (rev 9837)
+++ trunk/qgis/src/core/CMakeLists.txt 2008-12-17 11:03:46 UTC (rev 9838)
@@ -19,7 +19,6 @@
qgshttptransaction.cpp
qgslabel.cpp
qgslabelattributes.cpp
- qgsline.cpp
qgslogger.cpp
qgsmaplayer.cpp
qgsmaplayerregistry.cpp
@@ -248,7 +247,6 @@
qgshttptransaction.h
qgslabel.h
qgslabelattributes.h
-qgsline.h
qgslogger.h
qgsmaplayer.h
qgsmaplayerregistry.h
Deleted: trunk/qgis/src/core/qgsline.cpp
--- trunk/qgis/src/core/qgsline.cpp 2008-12-16 20:57:42 UTC (rev 9837)
+++ trunk/qgis/src/core/qgsline.cpp 2008-12-17 11:03:46 UTC (rev 9838)
@@ -1,107 +0,0 @@
- qgsline - description
- A simple line composed of two endpoints
- begin : 2004-10-24
- copyright : (C) 2004 by Gary E.Sherman
- email : sherman at mrcc.com
- * This program is free software; you can redistribute it and/or modify *
- * it under the terms of the GNU General Public License as published by *
- * the Free Software Foundation; either version 2 of the License, or *
- * (at your option) any later version. *
-/* $Id$ */
-#include "qgsline.h"
-QgsLine::QgsLine()
-// Create a line from two points
-QgsLine::QgsLine( QgsPoint &p1, QgsPoint &p2 ) : mBegin( p1 ), mEnd( p2 )
-//! Destructor
-QgsLine::~QgsLine()
-/// Sets the begin point of the line
-void QgsLine::setBegin( QgsPoint &p1 )
- mBegin = p1;
-/// Sets the end point of the line
-void QgsLine::setEnd( QgsPoint &p2 )
- mEnd = p2;
-/// Get the begin point of the line
-QgsPoint QgsLine::begin() const
- return mBegin;
-/// Get the end point of the line
-QgsPoint QgsLine::end() const
- return mEnd;
-//! String representation of the line
-QString QgsLine::toString() const
- return QString( "Not implemented" );
-//! As above but with precision for string representaton of a line
-QString QgsLine::toString( int thePrecision ) const
-/*! Return the well known text representation for the line.
- * The wkt is created without an SRID.
- * @return Well known text
-QString QgsLine::wellKnownText()
-//! Inequality operator
-bool QgsLine::operator!=( const QgsLine &other )
- // Note this function assumes that "flipped" lines are not equal,
- // thus preserving the concept of direction
- if (( mBegin != other.begin() ) || ( mEnd != other.end() ) )
- return true;
- else
- return false;
-/// Assignment
-QgsLine & QgsLine::operator=( const QgsLine & other )
- if ( &other != this )
- mBegin = other.begin();
- mEnd = other.end();
- return *this;
Deleted: trunk/qgis/src/core/qgsline.h
--- trunk/qgis/src/core/qgsline.h 2008-12-16 20:57:42 UTC (rev 9837)
+++ trunk/qgis/src/core/qgsline.h 2008-12-17 11:03:46 UTC (rev 9838)
@@ -1,123 +0,0 @@
- qgsline.h - description
-/* $Id$ */
-#ifndef QGSLINE_H
-#define QGSLINE_H
-#include <iostream>
-#include "qgspoint.h"
-/** \ingroup core
- * A simple line object composed of a begin and end point.
- * Comparisons (==, !=) honor the direction of the line. This means that
- * flipped lines with the same coordinates are not considered to be equal.
- * For example, (1,1 2,2) != (2,2 1,1)
-class CORE_EXPORT QgsLine
- public:
- //! Default constructor
- QgsLine();
- /*! Create a line from two points
- * @param p1 begin point
- * @param p2 end point
- QgsLine( QgsPoint &p1, QgsPoint &p2 );
- //! Destructor
- ~QgsLine();
- /*! Sets the begin point of the line
- * @param p1 Beginning point of the line
- void setBegin( QgsPoint &p1 );
- /*! Sets the end point of the line
- * @param p1 End point of the line
- void setEnd( QgsPoint &p2 );
- /*! Get the begin point of the line
- * @return Begin point of the line
- QgsPoint begin() const;
- /*! Get the end point of the line
- * @return End point of the line
- QgsPoint end() const;
- //! String representation of the line
- QString toString() const;
- //! As above but with precision for string representation of a line
- QString toString( int thePrecision ) const;
- /*! Return the well known text representation for the line.
- QString wellKnownText();
- //! Equality operator
- bool operator==( const QgsLine &other );
- //! Inequality operator
- bool operator!=( const QgsLine &other );
- /// Assignment
- QgsLine & operator=( const QgsLine &other );
- private:
- //! Begin point
- QgsPoint mBegin;
- //! End point
- QgsPoint mEnd;
-}; // class QgsLine
-inline bool operator==( const QgsLine &l1, const QgsLine &l2 )
- if (( l1.begin() == l2.begin() ) && ( l1.end() == l2.end() ) )
- return true;
- else
- return false;
-//! Stream operator for writing the line
-inline std::ostream& operator << ( std::ostream& os, const QgsLine &l )
- os << l.toString().toLocal8Bit().data();
- return os;
-#endif //QGSLINE_H
