[QGIS Commit] r9850 - in docs/trunk/english_us/user_guide: .
getting_started_screenies
svn_qgis at osgeo.org
Thu Dec 18 13:12:33 EST 2008
Author: dassau
Date: 2008-12-18 13:12:33 -0500 (Thu, 18 Dec 2008)
New Revision: 9850
Added:
docs/trunk/english_us/user_guide/getting_started_screenies/simple_session.png
Removed:
docs/trunk/english_us/user_guide/getting_started_screenies/startup1_0_0.png
docs/trunk/english_us/user_guide/getting_started.tex
docs/trunk/english_us/user_guide/getting_started_screenies/Makefile
finished and reviewed getting_started with a simple QGIS session
Modified: docs/trunk/english_us/user_guide/getting_started.tex
--- docs/trunk/english_us/user_guide/getting_started.tex 2008-12-18 15:59:28 UTC (rev 9849)
+++ docs/trunk/english_us/user_guide/getting_started.tex 2008-12-18 18:12:33 UTC (rev 9850)
@@ -6,7 +6,9 @@
% comment out the following line:
% \updatedisclaimer
-This chapter gives a quick overview of running QGIS with data available on the QGIS web page.
+This chapter gives a quick overview of installing QGIS, some sample
+data from the QGIS web page and running a first and simple session
+visualizing raster and vector layers.
\subsection{Installation}\label{label_installation}
\index{installation}
@@ -97,29 +99,31 @@
\item \osx{double click the icon in your Applications folder.}
\end{itemize}
-\minisec{Load a raster layer from the sample dataset}
+\minisec{Load raster and vector layers from the sample dataset}
-Raster layers are loaded either by clicking on the
-\toolbtntwo{mActionAddRasterLayer}{Load Raster} icon or by selecting the \mainmenuopt{View}>\dropmenuopttwo{mActionAddRasterLayer}{Add Raster Layer}
-menu option. More than one layer can be loaded at the same time by holding
-down the \keystroke{Control} or \keystroke{Shift} key and clicking on
-multiple items in the dialog \dialog{Open a GDAL Supported Raster Data Source}.
-\minisec{Load a vector layer from the sample dataset}
-\begin{enumerate}
-\item Load the shapefile \filename{lakes.shp}.
-\item Zoom in a bit to your favorite area with some lake.
-\item Make the \filename{lakes} layer active.
-\item Open the \dialog{Layer Properties} dialog.
-\item Click on the \tab{Labels} tab.
-\item Check the \checkbox{Display labels} checkbox to enable labeling.
-\item Choose the field to label with. We'll use \selectstring{Field containing label}{NAMES}.
-\item Enter a default for lakes that have no name. The default label will be
- used each time QGIS encounters a lake with no value in the \guilabel{NAMES} field.
+\begin{enumerate}
+\item Click on the \toolbtntwo{mActionAddRasterLayer}{Load Raster} icon.
+\item Browse to the folder \filename{qgis\_sample\_data/raster/}, select
+the ERDAS Img file \filename{landcover.img} and click \button{Open}.
+\item Now click on the \toolbtntwo{mActionAddOgrLayer}{Load Vector} icon.
+\item browse to the folder \filename{qgis\_sample\_data/gml/}, select
+the GML file \filename{lakes.gml} and click \button{Open}.
+\item Zoom in a bit to your favorite area with some lakes.
+\item Double click the \filename{lakes} layer in the map legend to open the
+\dialog{Layer Properties} dialog.
+\item Click on the \tab{Symbology} tab and select a blue as fill color.
+\item Click on the \tab{Labels} tab and check the \checkbox{Display labels}
+checkbox to enable labeling.
\item Click \button{Apply}.
\end{enumerate}
+\begin{figure}[ht]
+ \begin{center}
+ \caption{A Simple QGIS Session}\label{fig:simple_session}\smallskip
+ \includegraphics[clip=true, width=14cm]{simple_session}
+\end{center}
+\end{figure}
+You see how easy it is to visualize raster and vector layers in
+QGIS. Move on to the next sections to learn more about the available
+functionalities, features and settings and how to use them.
\ No newline at end of file
Modified: docs/trunk/english_us/user_guide/getting_started_screenies/Makefile
--- docs/trunk/english_us/user_guide/getting_started_screenies/Makefile 2008-12-18 15:59:28 UTC (rev 9849)
+++ docs/trunk/english_us/user_guide/getting_started_screenies/Makefile 2008-12-18 18:12:33 UTC (rev 9850)
@@ -10,7 +10,7 @@
# with .eps extension:
# JPG=qgis_icon_new_verylarge.eps\
-PNG=startup1_0_0.eps\
+PNG=simple_session.eps\
##### TARGETS #####
Added: docs/trunk/english_us/user_guide/getting_started_screenies/simple_session.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/getting_started_screenies/simple_session.png
___________________________________________________________________
+ application/octet-stream
Deleted: docs/trunk/english_us/user_guide/getting_started_screenies/startup1_0_0.png
