[QGIS Commit] r9860 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Fri Dec 19 03:47:34 EST 2008
Author: dassau
Date: 2008-12-19 03:47:34 -0500 (Fri, 19 Dec 2008)
New Revision: 9860
docs/trunk/english_us/user_guide/features_at_a_glance.tex
docs/trunk/english_us/user_guide/getting_started.tex
docs/trunk/english_us/user_guide/preamble.tex
docs/trunk/english_us/user_guide/print_composer.tex
docs/trunk/english_us/user_guide/qgis_style.sty
docs/trunk/english_us/user_guide/qgis_style.tex
docs/trunk/english_us/user_guide/toc.tex
added QGIS Tips to TOC
added missing platform indication for some figures
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2008-12-19 05:06:30 UTC (rev 9859)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2008-12-19 08:47:34 UTC (rev 9860)
@@ -699,7 +699,7 @@
\includegraphics[width=0.7cm]{mActionMeasureArea} Also areas can be measured. The window only shows the accumulated area-size in the measure window
\begin{figure}[h]
-\caption{Measure tools in action} \label{fig:measure}
+\caption{Measure tools in action \nixcaption} \label{fig:measure}
\centering
\subfigure[Measure lines] {\label{subfig:measure_line}\includegraphics[clip=true, width=0.4\textwidth]{measure_line}}\goodgap
\subfigure[Measure areas]{\label{subfig:measure_area}\includegraphics[clip=true, width=0.4\textwidth]{measure_area}}
Modified: docs/trunk/english_us/user_guide/getting_started.tex
--- docs/trunk/english_us/user_guide/getting_started.tex 2008-12-19 05:06:30 UTC (rev 9859)
+++ docs/trunk/english_us/user_guide/getting_started.tex 2008-12-19 08:47:34 UTC (rev 9860)
@@ -117,7 +117,7 @@
\begin{figure}[ht]
\begin{center}
- \caption{A Simple QGIS Session}\label{fig:simple_session}\smallskip
+ \caption{A Simple QGIS Session \nixcaption}\label{fig:simple_session}\smallskip
\includegraphics[clip=true, width=14cm]{simple_session}
\end{center}
\end{figure}
Modified: docs/trunk/english_us/user_guide/preamble.tex
--- docs/trunk/english_us/user_guide/preamble.tex 2008-12-19 05:06:30 UTC (rev 9859)
+++ docs/trunk/english_us/user_guide/preamble.tex 2008-12-19 08:47:34 UTC (rev 9860)
@@ -1,7 +1,23 @@
% vim: set textwidth=78 autoindent:
+% QGIS Tips
+% define tip float
+% doesn't work if written in qgis_style.sty
+% please keep the style definitions here and
+% and load float package in qgis_style.sty
+\floatstyle{ruled}
+\newfloat{Tip}{ht}{lox}
+\floatname{Tip}{Tip}
+\newcommand\qgistip[1]{\raggedright\small{#1}}
+\renewcommand{\topfraction}{0.85}
+\renewcommand{\textfraction}{0.1}
+\renewcommand{\floatpagefraction}{0.75}
\thispagestyle{empty}
\addcontentsline{toc}{section}{Preamble}
+%%%%%%%%%%% nothing to change above %%%%%%%%%%
\section*{Preamble}
% when the revision of a section has been finalized,
Modified: docs/trunk/english_us/user_guide/print_composer.tex
--- docs/trunk/english_us/user_guide/print_composer.tex 2008-12-19 05:06:30 UTC (rev 9859)
+++ docs/trunk/english_us/user_guide/print_composer.tex 2008-12-19 08:47:34 UTC (rev 9860)
@@ -75,7 +75,7 @@
\begin{figure}[ht]
\begin{center}
- \caption{Print Composer}\label{fig:print_composer_blank}\smallskip
+ \caption{Print Composer \nixcaption}\label{fig:print_composer_blank}\smallskip
\includegraphics[clip=true, width=\textwidth]{print_composer_blank}
\end{center}
\end{figure}
@@ -191,7 +191,7 @@
\begin{figure}[h]
\begin{center}
- \caption{Print Composer with map view, legend, scalebar, and text added}
+ \caption{Print Composer with map view, legend, scalebar, and text added \nixcaption}
\label{fig:print_composer_complete}\smallskip
\includegraphics[clip=true, width=\textwidth]{print_composer_complete}
\end{center}
Modified: docs/trunk/english_us/user_guide/qgis_style.sty
--- docs/trunk/english_us/user_guide/qgis_style.sty 2008-12-19 05:06:30 UTC (rev 9859)
+++ docs/trunk/english_us/user_guide/qgis_style.sty 2008-12-19 08:47:34 UTC (rev 9860)
@@ -2,40 +2,11 @@
%% [$Id$]
%% nothing to change below
% creating an Index using package makeidx
% see http://web.image.ufl.edu/help/latex/latex_indexes.shtml
\usepackage{makeidx}
\makeindex
-% QGIS Tips
-% define tip float
-% doesn't work if written in qgis_style.sty
-% please keep it here
-\usepackage{float}
-\floatstyle{ruled}
-\newfloat{Tip}{ht}{lox}
-\floatname{Tip}{Tip}
-\newcommand\qgistip[1]{\raggedright\small{#1}}
-\renewcommand{\topfraction}{0.85}
-\renewcommand{\textfraction}{0.1}
-\renewcommand{\floatpagefraction}{0.75}
-% internal macros for style consitency from Gary's foss4g 07 workbook
-% package fancybox is used for \button and \toolbtn
-% moved to conventions.tex
-%\newcommand{\button}[1]{\cornersize{0.1}\ovalbox{\textsf{\scriptsize#1}}}
-%\newcommand{\classname}[1]{\textsf{\textbf{#1}}}
-%\newcommand{\fieldname}[1]{\textsl{#1}}
-%\newcommand{\filename}[1]{\texttt{#1}}
-%\newcommand{\keystroke}[1]{\fbox{\textsf{\scriptsize#1}}}
-%\newcommand{\menuopt}[1]{\textsf{#1}}
-%\newcommand{\method}[1]{\textsf{\textit{#1}}}
-%\newcommand{\server}[1]{\textit{#1}}
-%\newcommand{\sqltable}[1]{\textsf{\textbf{#1}}}
-%\newcommand{\toolbtn}[1]{\cornersize{7mm}\Ovalbox{\textsf{\scriptsize#1}}}
-%\newcommand{\usertext}[1]{\texttt{#1}}
% important for nice acroread-visualization as pdf.
\usepackage[latin1]{inputenc}
\usepackage[T1]{fontenc}
Modified: docs/trunk/english_us/user_guide/qgis_style.tex
--- docs/trunk/english_us/user_guide/qgis_style.tex 2008-12-19 05:06:30 UTC (rev 9859)
+++ docs/trunk/english_us/user_guide/qgis_style.tex 2008-12-19 08:47:34 UTC (rev 9860)
@@ -17,6 +17,9 @@
% http://irb.cs.tu-berlin.de/leitfaden/manuale/latex-local/html/node20.html
\usepackage{html}
+% float package needed for QGIS tips, QGIS tips style is in preamble.tex
+\usepackage{float}
% Serif font
%\usepackage{palatino}
% mathpazo are mathefonts for formulars in palatino font
Modified: docs/trunk/english_us/user_guide/toc.tex
--- docs/trunk/english_us/user_guide/toc.tex 2008-12-19 05:06:30 UTC (rev 9859)
+++ docs/trunk/english_us/user_guide/toc.tex 2008-12-19 08:47:34 UTC (rev 9860)
@@ -5,16 +5,17 @@
\tableofcontents
\newpage
-\addcontentsline{toc}{section}{List of figures}
+\addcontentsline{toc}{section}{List of Figures}
\listoffigures
\newpage
-\addcontentsline{toc}{section}{List of tables}
+\addcontentsline{toc}{section}{List of Tables}
\listoftables
\newpage
-% \addcontentsline{toc}{section}{List of QGIS Tips}
-% \listof{Tip}{QGIS Tips}
+\addcontentsline{toc}{section}{List of QGIS Tips}
+\listof{Tip}{QGIS Tips}
+\newpage
\renewcommand{\baselinestretch}{1.1}
\parskip1.5ex
