[QGIS Commit] r9863 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Fri Dec 19 11:05:43 EST 2008
Author: dassau
Date: 2008-12-19 11:05:43 -0500 (Fri, 19 Dec 2008)
New Revision: 9863
docs/trunk/english_us/user_guide/features_at_a_glance.tex
docs/trunk/english_us/user_guide/user_guide.tex
docs/trunk/english_us/user_guide/working_with_vector.tex
more updates for working with vector data - not finished yet
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2008-12-19 11:12:10 UTC (rev 9862)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2008-12-19 16:05:43 UTC (rev 9863)
@@ -537,10 +537,9 @@
\end{Tip}
\begin{Tip}\caption{\textsc{Panning the Map with the Arrow Keys}}\index{pan!arrow keys}
-\qgistip{You can use the arrow keys to pan in and out on the map. Place
-the mouse cursor inside the map area and click on the right arrow key to
-pan east, left arrow key to pan west, up arrow key to pan north and down arrow
-key to pan south.
+\qgistip{You can use the arrow keys to pan in the map. Place the mouse cursor
+inside the map area and click on the right arrow key to pan east, left arrow
+key to pan west, up arrow key to pan north and down arrow key to pan south.
\end{Tip}
Modified: docs/trunk/english_us/user_guide/user_guide.tex
--- docs/trunk/english_us/user_guide/user_guide.tex 2008-12-19 11:12:10 UTC (rev 9862)
+++ docs/trunk/english_us/user_guide/user_guide.tex 2008-12-19 16:05:43 UTC (rev 9863)
@@ -38,7 +38,7 @@
\include{plugins_ogr_converter}
\include{external_plugins}
\include{plugins_ftools}
-\include{plugins_table_manager}
+%\include{plugins_table_manager}
\include{plugins_raster_algebra}
\include{plugins_writing_in_cpp}
\include{plugins_writing_in_python}
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2008-12-19 11:12:10 UTC (rev 9862)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2008-12-19 16:05:43 UTC (rev 9863)
@@ -10,23 +10,16 @@
QGIS supports vector data in a number of formats, including those
supported by the OGR library data provider plugin, such as ESRI shapefiles,
-\index{shapefiles}
-\index{ESRI!shapefiles}
-\index{SHP files}
-MapInfo MIF (interchange format)
-\index{MIF files}
-\index{MapInfo!MIF files}
-and MapInfo TAB (native format).
-\index{TAB files}
-\index{MapInfo!TAB files}
-QGIS also supports PostGIS
-\index{PostGIS}
-\index{PostgreSQL!PostGIS}
-layers in a PostgreSQL database using the PostgreSQL data provider plugin.
-Support for
-additional data types (eg. delimited text) is provided by additional data provider plugins.
-\index{delimited text}
+\index{shapefiles}\index{ESRI!shapefiles}\index{SHP files}
+MapInfo MIF (interchange format)\index{MIF files}\index{MapInfo!MIF files}
+and MapInfo TAB (native format).\index{TAB files}\index{MapInfo!TAB files}
+A list of OGR supported formats in Appendix~\ref{appdx_ogr}.
+QGIS also supports PostGIS\index{PostGIS}\index{PostgreSQL!PostGIS} layers
+in a PostgreSQL database using the PostgreSQL data provider plugin.
+Support for additional data types (eg. delimited text) is provided by
+additional data provider plugins.\index{delimited text}
This section describes how to work with two common formats:
ESRI shapefiles and PostGIS layers. Many of the
features available in QGIS work the same regardless of the vector data source.
@@ -41,13 +34,11 @@
\index{SHP files}
-ESRI Shapefile support is provided by a library of functions known as
-the OGR Simple Feature Library (\url{http://www.gdal.org/ogr})\index{OGR}. See Appendix
-\ref{appdx_ogr} for a list of all supported formats in OGR.
+The standard vector file format used in QGIS is the ESRI Shapefile. It's support
+is provided by the OGR Simple Feature Library (\url{http://www.gdal.org/ogr/})
+\index{OGR}. A shapefile actually consists of a minimum of three files:
+\index{shapefile!format}
-A shapefile actually consists of a minimum of three
-files:\index{shapefile!format}
\begin{itemize}
\item \filename{.shp} file containing the feature geometries.
\item \filename{.dbf} file containing the attributes in dBase format.
@@ -55,12 +46,11 @@
\end{itemize}
Ideally it comes with another file with a \filename{.prj} suffix, that contains
-the projection information for the shapefile.
+the projection information for the shapefile. There can be more files belonging
+to a shapefile dataset. To have a closer look at this we recommend the technical
+specification for the shapefile format, that can be found at \url{http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf}.
+\index{shapefile!specification}.
-There can be more files belonging to a shapefile dataset.
-To have a closer look at this we recommend the technical specification for the shapefile format,
-that can be found at \url{http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf}\index{shapefile!specification}.
\subsubsection{Loading a Shapefile}\label{sec:load_shapefile}
\includegraphics[width=0.7cm]{mActionAddNonDbLayer}
To load a shapefile, start
@@ -88,7 +78,7 @@
\begin{figure}[ht]
\begin{center}
\caption{QGIS with Shapefile of Alaska loaded \nixcaption}\label{fig:loadedshapefile}\smallskip
- \includegraphics[clip=true, width=17cm]{shapefileloaded}
+ \includegraphics[clip=true, width=16cm]{shapefileloaded}
\end{center}
\end{figure}
@@ -118,8 +108,7 @@
\item Open the \dialog{Layer Properties} dialog by double-clicking on the
shapefile name in the legend or by right-clicking and choosing
\dropmenuopt{Properties} from the popup menu.
-\item In the tab \tab{General} click the \button{Create} button on the Spatial
-Index section.
+\item In the tab \tab{General} click the \button{Create Spatial Index} button.
\end{itemize}
\subsubsection{Loading a MapInfo Layer}
@@ -209,11 +198,17 @@
\end{tabular}
\end{table}
-Once the parameters have been filled in, you can test the connection by
-clicking on the \button{Test
-Connection} button\index{PostgreSQL!connection!testing}. To save the password
-with the connection information, check the \checkbox{Save Password} option.
+Optional you can activate follwing checkboxes:
+\begin{itemize}
+\item \checkbox{Save Password}
+\item \checkbox{Only look in the geometry\_columns table}
+\item \checkbox{Only look in the 'public' schema}
+\end{itemize}
+Once all parameters and options are set, you can test the connection by
+clicking on the \button{Test Connect} button\index{PostgreSQL!connection!testing}.
\begin{Tip}\caption{\textsc{QGIS User Settings and
Security}}\index{settings}\index{security}
\qgistip{Your customized settings for QGIS are stored based on the operating
@@ -309,7 +304,7 @@
\end{Tip}
\minisec{SPIT Plugin}
-\includegraphics[width=0.7cm]{spit} QGIS comes with a
+\includegraphics[width=0.7cm]{spiticon} QGIS comes with a
plugin named
SPIT (Shapefile to PostGIS Import Tool)\index{PostGIS!SPIT}.
SPIT can be used to load multiple shapefiles at one time and includes support
@@ -317,13 +312,13 @@
menu, check the box next to the \checkbox{SPIT plugin} and click \button{OK}. The SPIT
icon will be added to the plugin toolbar\index{PostGIS!SPIT!loading}.
-To import a shapefile, click on the \toolbtntwo{spit}{SPIT} tool in the
+To import a shapefile, click on the \toolbtntwo{spiticon}{SPIT} tool in the
toolbar to open the
-\dialog{SPIT - Shapefile to PostGIS Import Tool} dialog.
-You can add one or more files to the queue by clicking on the \button{Add}
-button. To process the files, click on the \button{Import} button. The progress of the
-import as well as any errors/warnings will be displayed as each shapefile is
-processed.
+\dialog{SPIT - Shapefile to PostGIS Import Tool} dialog. Select the PostGIS database
+you want to connect to and click on \button{Connect}. Now you can add one or more
+files to the queue by clicking on the \button{Add} button. To process the files,
+click on the \button{OK} button. The progress of the import as well as any
+errors/warnings will be displayed as each shapefile is processed.
\begin{Tip}\caption{\textsc{Importing Shapefiles Containing
PostgreSQL Reserved Words}}\index{PostGIS!SPIT!reserved words}
@@ -524,7 +519,7 @@
\filename{qgis\_example\_dataset}:
\begin{enumerate}
-\item Load the shapefiles \filename{alaska.shp} and \filename{lakes.shp} in QGIS.
+\item Load the Shapefile \filename{alaska.shp} and GML file \filename{lakes.gml} in QGIS.
\item Zoom in a bit to your favorite area with some lake.
\item Make the \filename{lakes} layer active.
\item Open the \dialog{Layer Properties} dialog.
@@ -761,22 +756,38 @@
fields, specifying them in the same way we did in our Google search example.
\subsubsection{Attributes Tab}\index{attributes}\label{label_attributes}
-Within the \tab{attributes} tab the attributes of the selected dataset can be
+Within the \tab{Attributes} tab the attributes of the selected dataset can be
manipulated. The buttons \button{New Column} and \button{Delete Column} can be
-used when the dataset is in editing mode.
+used, when the dataset is in editing mode. At the moment only columns from
+PostGIS layers can be edited, because this feature was not supported by
+the OGR library so far.
-The button \button{Toggle Editing} toggles this mode.
+The button \button{Toggle editing mode} toggles this mode.
-\begin{Tip}[ht]\caption{\textsc{Manipulating Attribute data}}
-\qgistip{Currently on PostGIS-layers are supported to add or drop attribute
-columns withing this dialog. In further versions of QGIS also other
-datasources will be supported.
-\end{Tip}
+\minisec{edit widget}
-%FIXME: More to come here, since I do not know exactly what the edit-widget is
-%for.
+Within the \tab{Attributes} tab you also find an \texttt{edit widget} and a
+\texttt{value} column. These two columns can be used to define values or a range
+of values that are allowed to be added to the specific attribute table columns.
+Possible edit definitions are:
+%% IMPORTANT
+%% FIXME this must be extended also with an example. I asked Juergen for some explanations
+\begin{itemize}
+\item line edit:
+\item unique value: Only one value (INT/REAL/STRING) is allowed to insert.
+\item unique value (editable): One value (INT,REAL,STRING) is suggested but can be changed.
+\item value map:
+\item classification: Several values (INT/REAL/STRING) are allowed to insert.
+\item range (editable): A range between two values (INT/REAL) are suggested but can be changed.
+\item range (slider): Only a range between two values (INT/REAL) are allowed to insert.
+\item file name:
+\end{itemize}
+As an example we will load the Point Shapefile \filename{popp.shp} (populated places)
+and define for column type, that only values 'CABIN' or 'BARACK' can be used for the
+attribute table columns 'TYPE', when we add a new points
\subsection{Editing}\index{editing}
QGIS supports basic capabilities for editing spatial data. Before reading any
@@ -860,12 +871,12 @@
\end{Tip}
-\index{Allow Editing}
-All editing sessions start by choosing the \dropmenuopttwo{mActionToggleEditing}{Toggle editing} option.
-This can be found in the context menu after right clicking on the legend
-entry for that layer.
-Alternately, you can use the \index{Toggle Editing}
-\toolbtntwo{mActionToggleEditing}{Toggle editing} button from the toolbar to start or stop the editing mode.\index{editing!icons}
+\begin{Tip}[ht]\caption{\textsc{Manipulating Attribute data}}
+\qgistip{Currently only PostGIS layers are supported to add or drop attribute
+columns withing this dialog. In further versions of QGIS also other datasources
+will be supported, because this feature was recently implemented in GDAL > 1.6.0
+\end{Tip}
\begin{Tip}[ht]\caption{\textsc{Editing a Map is Different to Editing an Attribute Table}}
\qgistip{In this version of QGIS, the \button{Start editing}/\button{Stop editing}
@@ -887,9 +898,6 @@
\end{Tip}
-Once the layer is in edit mode, markers will appear at the
-vertices.
\begin{Tip}[ht]\caption{\textsc{Zoom in Before Editing}}
\qgistip{Before editing a layer, you should
zoom in to your area of interest. This
@@ -908,23 +916,46 @@
\end{Tip}
+All editing sessions start by choosing the \dropmenuopttwo{mActionToggleEditing}{Toggle editing} option.
+This can be found in the context menu after right clicking on the legend
+entry for that layer.\index{Allow Editing}
+Alternately, you can use the \index{Toggle Editing}
+\toolbtntwo{mActionToggleEditing}{Toggle editing} button from the toolbar to start or stop the editing mode.\index{editing!icons} Once the layer is in edit mode, markers will appear at the
+vertices.
+\minisec{Zooming with the mouse wheel}
+While digitizing you can use the mouse wheel to zoom in and out on the map
+Place the mouse cursor inside the map area and roll it forward (away from you)
+to zoom in and backwards (towards you) to zoom out. The mouse cursor is the
+center where the zoom occurs. You can customize the behavior of the mouse wheel
+zoom using the \tab{Map tools} tab under the \mainmenuopt{Settings}
+>\dropmenuopt{Options} menu.
+\minisec{Panning with the arrow keys}
+Panning the Map during digitizing is possible with the arrow keys. Place
+the mouse cursor inside the map area and click on the right arrow key to
+pan east, left arrow key to pan west, up arrow key to pan north and down arrow
+key to pan south.
You can perform the following editing functions:
\begin{itemize}
-\item Add Features: \toolbtntwo{mActionCapturePoint}{point},
- \toolbtntwo{mActionCaptureLine}{line} and
- \toolbtntwo{mActionCapturePolygon}{polygone}
-\item \toolbtntwo{mActionMoveFeature}{Move Selected Features}
-\item \toolbtntwo{mActionSplitFeatures}{Split Selected Features}
-\item \toolbtntwo{mActionDeleteSelected}{Delete Selected Features}
-\item \toolbtntwo{mActionAddVertex}{Add Vertex of a Feature}
-\item \toolbtntwo{mActionDeleteVertex}{Delete Vertex of a Feature}
-\item \toolbtntwo{mActionMoveVertex}{Move Vertex of a Feature}
+\item Add Features: \toolbtntwo{mActionCapturePoint}{Capture Point},
+ \toolbtntwo{mActionCaptureLine}{Capture Line} and
+ \toolbtntwo{mActionCapturePolygon}{Capture Polygon}
\item \toolbtntwo{mActionAddRing}{Add Ring}
\item \toolbtntwo{mActionAddIsland}{Add Island}
-\item \toolbtntwo{mActionEditCut}{Cut Selected Features}
-\item \toolbtntwo{mActionEditCopy}{Copy Selected Features}
-\item \toolbtntwo{mActionEditPaste}{Paste Selected Features}
+\item \toolbtntwo{mActionSplitFeatures}{Split Features}
+\item \toolbtntwo{mActionMoveFeature}{Move Features}
+\item \toolbtntwo{mActionMoveVertex}{Move Vertex}
+\item \toolbtntwo{mActionAddVertex}{Add Vertex}
+\item \toolbtntwo{mActionDeleteVertex}{Delete Vertex}
+\item \toolbtntwo{mActionDeleteSelected}{Delete Selected}
+\item \toolbtntwo{mActionEditCut}{Cut Features}
+\item \toolbtntwo{mActionEditCopy}{Copy Features}
+\item \toolbtntwo{mActionEditPaste}{Paste Features}
\end{itemize}
\minisec{Adding Features}
@@ -970,19 +1001,17 @@
\end{Tip}
-% FIXME: Write me
-\minisec{Move Selected Feature}
+\minisec{Move Feature}
\index{vector layers!move!feature}
-%% INPUT IS MISSING
-write me
+You can move features using the \toolbtntwo{mActionMoveFeature}{Move Feature} icon
+on the toolbar.
-% FIXME: Write me
-\minisec{Split Selected Feature}
+\minisec{Split Feature}
\index{vector layers!split!feature}
-%%%% INPUT IS MISSING
-write me
+You can split features using the \toolbtntwo{mActionSplitFeatures}{Split Features} icon
+on the toolbar.
\minisec{Editing Vertices of a Feature}
\index{vector layers!editing!vertex}
@@ -1088,15 +1117,13 @@
in the OGC Well-Known Text (WKT) format.
However in this version of QGIS, text features from outside QGIS cannot
-be pasted to a layer within QGIS.
+be pasted to a layer within QGIS. When would the copy and paste function
+come in handy? Well, it turns out that you can edit more than one layer
+at a time and copy/paste features between layers. Why would we want to do
+this? Say we need to do some work on a new layer but only need one or
+two lakes, not the 5,000 on our \filename{big\_lakes} layer. We can create
+a new layer and use copy/paste to plop the needed lakes into it.
-When would the copy and paste function come in handy? Well, it turns out that
-you can edit more than one layer at a time and copy/paste features between
-layers. Why would we want to do this? Say we need to do some work on a new
-layer but only need one or two lakes, not the 5,000 on our \filename{big\_lakes}
-layer. We can create a new layer and use copy/paste to plop the needed lakes
-into it.
As an example we are copying some lakes to a new layer:
\begin{enumerate}
