[QGIS Commit] r9867 -
branches/Version-1_0/python/plugins/plugin_installer
svn_qgis at osgeo.org
Fri Dec 19 18:05:51 EST 2008
Author: borysiasty
Date: 2008-12-19 18:05:51 -0500 (Fri, 19 Dec 2008)
New Revision: 9867
branches/Version-1_0/python/plugins/plugin_installer/__init__.py
branches/Version-1_0/python/plugins/plugin_installer/installer_data.py
branches/Version-1_0/python/plugins/plugin_installer/installer_gui.py
Plugin Installer update - new repositories for the 1.x
Modified: branches/Version-1_0/python/plugins/plugin_installer/__init__.py
--- branches/Version-1_0/python/plugins/plugin_installer/__init__.py 2008-12-19 20:17:30 UTC (rev 9866)
+++ branches/Version-1_0/python/plugins/plugin_installer/__init__.py 2008-12-19 23:05:51 UTC (rev 9867)
@@ -14,7 +14,7 @@
return "Plugin Installer"
def version():
- return "Version 0.9.7"
+ return "Version 0.9.8"
def description():
return "Downloads and installs QGIS python plugins"
Modified: branches/Version-1_0/python/plugins/plugin_installer/installer_data.py
--- branches/Version-1_0/python/plugins/plugin_installer/installer_data.py 2008-12-19 20:17:30 UTC (rev 9866)
+++ branches/Version-1_0/python/plugins/plugin_installer/installer_data.py 2008-12-19 23:05:51 UTC (rev 9867)
@@ -73,11 +73,13 @@
seenPluginGroup = "/Qgis/plugin-seen"
-# knownRepos: (name, url for QGIS 0.x, url for QGIS 1.x, possible depreciated url, another possible depreciated url)
-knownRepos = [("Official QGIS Repository","http://spatialserver.net/cgi-bin/pyqgis_plugin.rb","http://pyqgis.org/repo/official","",""),
- ("Carson Farmer's Repository","http://www.ftools.ca/cfarmerQgisRepo.xml","http://www.ftools.ca/cfarmerQgisRepo.xml", "http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml","http://www.ftools.ca/cfarmerQgisRepo_0.xx.xml"),
- ("Borys Jurgiel's Repository","http://bwj.aster.net.pl/qgis-oldapi/plugins.xml","http://bwj.aster.net.pl/qgis/plugins.xml","",""),
- ("Faunalia Repository","http://faunalia.it/qgis/plugins.xml","http://faunalia.it/qgis/plugins.xml","http://faunalia.it/qgis/1.x/plugins.xml","")]
+# Repositories: (name, url, possible depreciated url)
+oldRepo = ("QGIS 0.x Plugin Repository", "http://spatialserver.net/cgi-bin/pyqgis_plugin.rb","")
+officialRepo = ("QGIS Official Repository", "http://pyqgis.org/repo/official","")
+contribRepo = ("QGIS Contributed Repository", "http://pyqgis.org/repo/contributed","")
+authorRepos = [("Carson Farmer's Repository", "http://www.ftools.ca/cfarmerQgisRepo.xml", "http://www.ftools.ca/cfarmerQgisRepo_0.xx.xml"),
+ ("Borys Jurgiel's Repository", "http://bwj.aster.net.pl/qgis/plugins.xml", "http://bwj.aster.net.pl/qgis-oldapi/plugins.xml"),
+ ("Faunalia Repository", "http://faunalia.it/qgis/plugins.xml", "http://faunalia.it/qgis/1.x/plugins.xml")]
@@ -152,15 +154,27 @@
presentURLs = []
for i in self.all().values():
presentURLs += [QString(i["url"])]
- for i in knownRepos:
- if i[QGIS_MAJOR_VER+1] and presentURLs.count(i[QGIS_MAJOR_VER+1]) == 0:
- settings = QSettings()
- settings.beginGroup(reposGroup)
+ settings = QSettings()
+ settings.beginGroup(reposGroup)
+ # add the central repositories
+ if QGIS_MAJOR_VER: # QGIS 1.x
+ if presentURLs.count(officialRepo[1]) == 0:
+ settings.setValue(officialRepo[0]+"/url", QVariant(officialRepo[1]))
+ settings.setValue(officialRepo[0]+"/enabled", QVariant(True))
+ if presentURLs.count(contribRepo[1]) == 0:
+ settings.setValue(contribRepo[0]+"/url", QVariant(contribRepo[1]))
+ settings.setValue(contribRepo[0]+"/enabled", QVariant(True))
+ else: # QGIS 0.x
+ if presentURLs.count(oldRepo[1]) == 0:
+ settings.setValue(oldRepo[0]+"/url", QVariant(oldRepo[1]))
+ settings.setValue(oldRepo[0]+"/enabled", QVariant(True))
+ # add author repositories
+ for i in authorRepos:
+ if i[1] and presentURLs.count(i[1]) == 0:
repoName = QString(i[0])
if self.all().has_key(repoName):
- repoName = repoName + "(2)"
- # add to settings
- settings.setValue(repoName+"/url", QVariant(i[QGIS_MAJOR_VER+1]))
+ repoName = repoName + " (original)"
+ settings.setValue(repoName+"/url", QVariant(i[1]))
settings.setValue(repoName+"/enabled", QVariant(True))
@@ -225,24 +239,32 @@
self.mRepositories = {}
- # first, update the QSettings repositories if needed
- if len(settings.childGroups()) == 0: # add the default repository when there isn't any
- settings.setValue(knownRepos[0][0]+"/url", QVariant(knownRepos[0][QGIS_MAJOR_VER+1]))
- else: # else update invalid urls
- for key in settings.childGroups():
- url = settings.value(key+"/url", QVariant()).toString()
- allOk = True
- for repo in knownRepos:
- if repo[3] == url or repo[4] == url or (repo[QGIS_MAJOR_VER+1] != url and repo[int(not QGIS_MAJOR_VER)+1] == url):
- if repo[QGIS_MAJOR_VER+1]: #update the URL
- settings.setValue(key+"/url", QVariant(repo[QGIS_MAJOR_VER+1]))
- settings.setValue(key+"/valid", QVariant(True))
- allOk = False
- else: # mark as invalid
- settings.setValue(key+"/valid", QVariant(False))
- allOk = False
- if allOk: # marking as valid if no problem.
+ # first, update repositories in QSettings if needed
+ mainRepo = officialRepo
+ invalidRepo = oldRepo
+ else:
+ mainRepo = oldRepo
+ invalidRepo = officialRepo
+ mainRepoPresent = False
+ for key in settings.childGroups():
+ url = settings.value(key+"/url", QVariant()).toString()
+ if url == contribRepo[1]:
+ settings.setValue(key+"/valid", QVariant(True)) # unlock the contrib repo in qgis 1.x
+ else:
+ settings.setValue(key+"/valid", QVariant(False)) # lock the contrib repo in qgis 0.x
+ else:
+ settings.setValue(key+"/valid", QVariant(True)) # unlock any other repo
+ if url == mainRepo[1]:
+ mainRepoPresent = True
+ if url == invalidRepo[1]:
+ settings.remove(key)
+ for authorRepo in authorRepos:
+ if url == authorRepo[2]:
+ settings.setValue(key+"/url", QVariant(authorRepo[1])) # correct a depreciated url
+ if not mainRepoPresent:
+ settings.setValue(mainRepo[0]+"/url", QVariant(mainRepo[1]))
self.mRepositories[key] = {}
Modified: branches/Version-1_0/python/plugins/plugin_installer/installer_gui.py
--- branches/Version-1_0/python/plugins/plugin_installer/installer_gui.py 2008-12-19 20:17:30 UTC (rev 9866)
+++ branches/Version-1_0/python/plugins/plugin_installer/installer_gui.py 2008-12-19 23:05:51 UTC (rev 9867)
@@ -412,7 +412,7 @@
ver = availableVersion
else:
ver = installedVersion
- if p["status"] in ["upgradeable","newer"] or installedVersion == "?" or availableVersion == "?":
+ if p["status"] in ["upgradeable","newer"] or p["error"]:
verTip = self.tr("installed version") + ": " + installedVersion + "\n" + self.tr("available version") + ": " + availableVersion
elif p["status"] in ["not installed", "new"]:
verTip = self.tr("available version") + ": " + availableVersion
