[QGIS Commit] r9878 - in branches/Version-1_0: debian
	src/app/composer src/plugins/gps_importer
    svn_qgis at osgeo.org
    Sat Dec 20 14:33:41 EST 2008
Author: jef
Date: 2008-12-20 14:33:41 -0500 (Sat, 20 Dec 2008)
New Revision: 9878
   branches/Version-1_0/debian/changelog
   branches/Version-1_0/debian/control
   branches/Version-1_0/debian/rules
   branches/Version-1_0/src/app/composer/qgscomposer.cpp
   branches/Version-1_0/src/plugins/gps_importer/qgsgpsplugingui.cpp
apply r9875 to r9877 from trunk
Modified: branches/Version-1_0/debian/changelog
--- branches/Version-1_0/debian/changelog	2008-12-20 18:21:41 UTC (rev 9877)
+++ branches/Version-1_0/debian/changelog	2008-12-20 19:33:41 UTC (rev 9878)
@@ -1,3 +1,9 @@
+qgis (1.0preview18) experimental; urgency=low
+  * add suggestion for gpsbabel
+ -- JÃŒrgen E. Fischer <jef at norbit.de>  Sat, 20 Dec 2008 19:08:34 +0100
 qgis (1.0preview17) experimental; urgency=low
   * include quickprint and coordinate capture plugin
Modified: branches/Version-1_0/debian/control
--- branches/Version-1_0/debian/control	2008-12-20 18:21:41 UTC (rev 9877)
+++ branches/Version-1_0/debian/control	2008-12-20 19:33:41 UTC (rev 9878)
@@ -18,6 +18,7 @@
 Architecture: any
 Depends: ${shlibs:Depends}, ${misc:Depends}
 Recommends: qgis-plugin-grass, python-qgis
+Suggests: gpsbabel
 Conflicts: uim-qt3
 Description: Geographic Information System (GIS)
  A Geographic Information System (GIS) manages, analyzes, and displays
Modified: branches/Version-1_0/debian/rules
--- branches/Version-1_0/debian/rules	2008-12-20 18:21:41 UTC (rev 9877)
+++ branches/Version-1_0/debian/rules	2008-12-20 19:33:41 UTC (rev 9878)
@@ -18,7 +18,7 @@
 	-D CMAKE_INSTALL_PREFIX=/usr \
 	-D CMAKE_SKIP_RPATH=TRUE \
 	-D BINDINGS_GLOBAL_INSTALL=TRUE \
-	-D PEDANTIC=TRUE \
+	-D PEDANTIC=TRUE
 ifneq (,$(findstring noopt,$(DEB_BUILD_OPTIONS)))
 	CFLAGS += -O0
Modified: branches/Version-1_0/src/app/composer/qgscomposer.cpp
--- branches/Version-1_0/src/app/composer/qgscomposer.cpp	2008-12-20 18:21:41 UTC (rev 9877)
+++ branches/Version-1_0/src/app/composer/qgscomposer.cpp	2008-12-20 19:33:41 UTC (rev 9878)
@@ -600,18 +600,18 @@
     m->setCheckBoxVisible( true );
     m->setCheckBoxQSettingsLabel( myQSettingsLabel );
     m->setMessageAsHtml( tr( "<p>The SVG export function in Qgis has several "
-                             "problems due to bugs and deficiencies in the "
+                             "problems due to bugs and deficiencies in the " )
 #if QT_VERSION < 0x040300
-                             "Qt4 svg code. Of note, text does not "
+                       + tr( "Qt4 svg code. Of note, text does not "
                              "appear in the SVG file and there are problems "
                              "with the map bounding box clipping other items "
-                             "such as the legend or scale bar.</p>"
+                             "such as the legend or scale bar.</p>" )
 #else
-                             "Qt4 svg code. In particular, there are problems "
+                       + tr( "Qt4 svg code. In particular, there are problems "
                              "with layers not being clipped to the map "
-                             "bounding box.</p>"
+                             "bounding box.</p>" )
 #endif
-                             "If you require a vector-based output file from "
+                       + tr( "If you require a vector-based output file from "
                              "Qgis it is suggested that you try printing "
                              "to PostScript if the SVG output is not "
                              "satisfactory."
Modified: branches/Version-1_0/src/plugins/gps_importer/qgsgpsplugingui.cpp
--- branches/Version-1_0/src/plugins/gps_importer/qgsgpsplugingui.cpp	2008-12-20 18:21:41 UTC (rev 9877)
+++ branches/Version-1_0/src/plugins/gps_importer/qgsgpsplugingui.cpp	2008-12-20 19:33:41 UTC (rev 9878)
@@ -335,6 +335,8 @@
       break;
+  cmbDLPort->addItem( "usb:" );
+  cmbULPort->addItem( "usb:" );
 #endif
 #ifdef __FreeBSD__ // freebsd
