[QGIS Commit] r9881 - in branches/Version-1_0: doc src/app
svn_qgis at osgeo.org
Sat Dec 20 15:07:21 EST 2008
Author: jef
Date: 2008-12-20 15:07:20 -0500 (Sat, 20 Dec 2008)
New Revision: 9881
branches/Version-1_0/doc/CODING.t2t
branches/Version-1_0/doc/INSTALL.t2t
branches/Version-1_0/doc/index.dox
branches/Version-1_0/src/app/qgisapp.cpp
sync doc with trunk
Modified: branches/Version-1_0/doc/CODING.t2t
--- branches/Version-1_0/doc/CODING.t2t 2008-12-20 20:06:32 UTC (rev 9880)
+++ branches/Version-1_0/doc/CODING.t2t 2008-12-20 20:07:20 UTC (rev 9881)
@@ -17,16 +17,16 @@
%txt2tags home page for more details. Please insert manual line breaks in this
%document as it makes diffing for changes much easier. To do this in vim
%automatically, select a section then issue (gq) command. Please dont
-%apply vim formatting to the whol document as it screws up some formatting
+%apply vim formatting to the whole document as it screws up some formatting
%rather apply it selectively to paragraphs where needed.
% To generate the text version of this document:
% txt2tags -t txt -o CODING CODING.t2t
-% To generate the moinmoin version of this document
+% To generate the moinmoin version of this document:
% txt2tags -t moin -o CODING.moin CODING.t2t
-% To generate the html version of this document
+% To generate the html version of this document:
% txt2tags -t html -o CODING.html CODING.t2t
-% To generate LaTeX version of this document do:
+% To generate the LaTeX version of this document:
% txt2tags -t tex -o CODING.tex CODING.t2t
% End of comments
Modified: branches/Version-1_0/doc/INSTALL.t2t
--- branches/Version-1_0/doc/INSTALL.t2t 2008-12-20 20:06:32 UTC (rev 9880)
+++ branches/Version-1_0/doc/INSTALL.t2t 2008-12-20 20:07:20 UTC (rev 9881)
@@ -22,12 +22,12 @@
% txt2tags -t txt -o INSTALL INSTALL.t2t
-% txt2tags -t moin -o INSTALL.moin INSTALL.t2t
-% txt2tags -t html -o INSTALL.html INSTALL.t2t
-% txt2tags -t tex -o INSTALL.tex INSTALL.t2t
+% txt2tags -t moin -o INSTALL.moin INSTALL.t2t
+% txt2tags -t html -o INSTALL.html INSTALL.t2t
+% To generate LaTeX version of this document:
+% txt2tags -t tex -o INSTALL.tex INSTALL.t2t
% End of comments
Modified: branches/Version-1_0/doc/index.dox
--- branches/Version-1_0/doc/index.dox 2008-12-20 20:06:32 UTC (rev 9880)
+++ branches/Version-1_0/doc/index.dox 2008-12-20 20:07:20 UTC (rev 9881)
@@ -29,11 +29,11 @@
'stable' (bugfixes and very minor tweaks only).
\section index_maillist Mailing Lists
-For support we encourage you to join our <a
-href="http://qgis.org/content/view/115/96/">mailing lists</a> for
-developers.
+<ul>
+<li>For support we encourage you to join our <a
+href="http://qgis.osgeo.org/community/mailing-lists.html">mailing lists</a> for
+developers.</li> </ul>
\section index_bugs Bug Reporting
If you think you have found a bug, please report it using our <a
href="https://trac.osgeo.org/qgis/">bug tracker</a>. When reporting bugs,
Modified: branches/Version-1_0/src/app/qgisapp.cpp
--- branches/Version-1_0/src/app/qgisapp.cpp 2008-12-20 20:06:32 UTC (rev 9880)
+++ branches/Version-1_0/src/app/qgisapp.cpp 2008-12-20 20:07:20 UTC (rev 9881)
@@ -1835,7 +1835,7 @@
+ tr( "A new plugin was added for interpolating point features into ASCII grid layers." )
+ "</li>"
+ "<li>"
- + tr( "The python plugin manager was completely overhauled, the new version having many improvements, including checking that the version of QGIS running will support a plugin that is being installed." )
+ + tr( "The python plugin installer was completely overhauled, the new version having many improvements, including checking that the version of QGIS running will support a plugin that is being installed." )
+ "</li>"
+ "<li>"
+ tr( "Plugin toolbar positions are now correctly saved when the application is closed." )
@@ -1850,7 +1850,8 @@
+ tr( "Ported all GDAL/OGR and GEOS usage to use C APIs only." )
+ "</li>"
+ "<li>"
+ + tr( "Vector editing overhaul - handling of geometry and attribute edit transactions is now handled transparently in one place." )
+ + "</li>"
//+ "<li>"
//+ tr("X")
//+ "</li>"
