[QGIS Commit] r8132 - trunk/qgis/src/gui
svn_qgis at osgeo.org
Sat Feb 9 12:50:52 EST 2008
Author: timlinux
Date: 2008-02-09 12:50:52 -0500 (Sat, 09 Feb 2008)
New Revision: 8132
trunk/qgis/src/gui/qgsquickprint.cpp
Cleanups to the quickprint output to manage text overruns in legend and improve alignment of text in various places.
Modified: trunk/qgis/src/gui/qgsquickprint.cpp
--- trunk/qgis/src/gui/qgsquickprint.cpp 2008-02-09 16:20:53 UTC (rev 8131)
+++ trunk/qgis/src/gui/qgsquickprint.cpp 2008-02-09 17:50:52 UTC (rev 8132)
@@ -229,7 +229,11 @@
int myMapDateFontSize = 16;
int myMapNameFontSize = 32;
int myLegendFontSize = 12;
-#ifdef WIN32 //this sucks...
+#ifdef Q_OS_LINUX//this sucks...
+ myLegendFontSize -= 2;
+#endif
+#ifdef WIN32 //this sucks too...
myMapTitleFontSize /= 2;
myMapDateFontSize /= 2;
myMapNameFontSize /= 2;
@@ -388,7 +392,9 @@
myPrintPainter.setFont( myLegendFont );
QStringList myLayerSet = mpMapRender->layerSet();
QStringListIterator myLayerIterator ( myLayerSet );
- while ( myLayerIterator.hasNext() )
+ //second clause below is to prevent legend spilling out the bottom
+ while ( myLayerIterator.hasNext() &&
+ myLegendYPos < myLegendDimensionY )
QString myLayerId = myLayerIterator.next();
QgsMapLayer * mypLayer =
@@ -460,11 +466,20 @@
QStringList myWrappedLayerNameList = wordWrap(myLayerName,
myLegendFontMetrics,
myLegendDimensionX - myIconWidth);
+ // Check the wrapped layer name wont overrun the space we have
+ // for the legend ...
+ int myLabelHeight = myLegendFontHeight *
+ myWrappedLayerNameList.count();
+ if (myLegendYPos + myLabelHeight > myLegendDimensionY )
+ continue;
// Loop through wrapped legend label lines
QStringListIterator myLineWrapIterator(myWrappedLayerNameList);
- while (myLineWrapIterator.hasNext())
+ while (myLineWrapIterator.hasNext())
QString myLine = myLineWrapIterator.next();
myLegendXPos = myIconWidth;
@@ -477,10 +492,10 @@
myLegendYPos += myLegendVerticalSpacer + myLegendFontHeight;
- // Lop through the class breaks
+ // Loop through the class breaks
QListIterator<QgsSymbol *> myIterator ( mySymbolList );
- while ( myIterator.hasNext() )
+ while ( myIterator.hasNext() && myLegendYPos < myLegendDimensionY)
QgsSymbol * mypSymbol = myIterator.next();
myPrintPainter.setPen( mypSymbol->pen() );
@@ -502,7 +517,8 @@
else //polygon
- myPrintPainter.drawRect( myLegendXPos, myLegendYPos, myIconWidth, myIconWidth );
+ myPrintPainter.drawRect(
+ myLegendXPos, myLegendYPos, myIconWidth, myIconWidth );
// Now work out the class break label
@@ -533,7 +549,7 @@
QStringList myWrappedLayerNameList = wordWrap(myLabel,
- myLegendDimensionX - myIconWidth);
+ myLegendDimensionX - myLegendXPos);
@@ -617,19 +633,21 @@
// Draw the north arrow
myOriginX += myHorizontalSpacing + myLogoXDim;
+ // use half the available space for the n.arrow
+ // and the rest for the scale bar (see below)
QPixmap myNorthArrow ( myLogoYDim/2, myLogoYDim/2 );
myNorthArrow.fill ( Qt::white );
QPainter myNorthPainter ( &myNorthArrow );
QSvgRenderer mySvgRenderer ( mNorthArrowFile );
mySvgRenderer.render ( &myNorthPainter );
- myPrintPainter.drawPixmap( myOriginX + ((myLogoXDim/2)-(myLogoYDim/2)) ,
+ myPrintPainter.drawPixmap( myOriginX + ((myLogoXDim/2)) ,
myOriginY ,
myNorthArrow);
// Draw the scale bar
- myOriginY += myLogoYDim/2;
+ myOriginY += myLogoYDim/2 + myVerticalSpacing;
myPrintPainter.setViewport(myOriginX,
myOriginY,
myOriginalViewport.width(),
@@ -885,10 +903,13 @@
QString myScaleBarMaxLabel=QString::number(myActualSize);
//Calculate total width of scale bar and label
- double myTotalScaleBarWidth = myScaleBarWidth + myFontWidth;
+ //we divide by 2 because the max scale label
+ //will be centered over the endpoint of the scale bar
+ double myTotalScaleBarWidth = myScaleBarWidth + (myFontWidth/2);
//determine the origin of scale bar (bottom right)
- int myOriginX=myXMargin;
+ //for x origin set things up so the scalebar is centered
+ int myOriginX=(theMaximumWidth - myTotalScaleBarWidth)/2;
int myOriginY=myYMargin;
//Set pen to draw with
@@ -906,17 +927,6 @@
myStops << QGradientStop(0.5,QColor("#505050"));
myStops << QGradientStop(0.6,QColor("#434343"));
myStops << QGradientStop(1.0,QColor("#656565"));
- /** Delete this I think
- QLinearGradient myGlossyBrush(QPointF(myOriginX,myOriginY),
- QPointF(myOriginX,myOriginY + myMajorTickSize*3));
- thepPainter->setBrush(myGlossyBrush);
- thepPainter->drawRect(
- myOriginX,
- myOriginY,
- myOriginX + myScaleBarWidthInt,
- myOriginY + myMajorTickSize
//draw again with the brush in the revers direction to complete teh glossiness
QLinearGradient myReverseGlossyBrush(
QPointF(myOriginX,myOriginY + myMajorTickSize*3),
