[QGIS Commit] r8175 - trunk/qgis/src/core
svn_qgis at osgeo.org
Sat Feb 23 01:48:18 EST 2008
Author: mhugent
Date: 2008-02-23 01:48:18 -0500 (Sat, 23 Feb 2008)
New Revision: 8175
trunk/qgis/src/core/qgshttptransaction.cpp
trunk/qgis/src/core/qgshttptransaction.h
Add capability of doing HTTP POST request to QgsHttpTransaction. Uses a default argument to maintain interface compatibility
Modified: trunk/qgis/src/core/qgshttptransaction.cpp
--- trunk/qgis/src/core/qgshttptransaction.cpp 2008-02-23 00:46:19 UTC (rev 8174)
+++ trunk/qgis/src/core/qgshttptransaction.cpp 2008-02-23 06:48:18 UTC (rev 8175)
@@ -67,7 +67,7 @@
-bool QgsHttpTransaction::getSynchronously(QByteArray &respondedContent, int redirections)
+bool QgsHttpTransaction::getSynchronously(QByteArray &respondedContent, int redirections, const QByteArray* postData)
httpredirections = redirections;
@@ -106,7 +106,16 @@
// executing an http GET.
QString pathAndQuery = httpurl.remove(0,
httpurl.indexOf(qurl.path()));
- httpid = http->get( pathAndQuery );
+ if(!postData) //do request with HTTP GET
+ httpid = http->get( pathAndQuery );
+ else //do request with HTTP POST
+ httpid = http->post(pathAndQuery, *postData);
connect(http, SIGNAL( requestStarted ( int ) ),
this, SLOT( dataStarted ( int ) ) );
Modified: trunk/qgis/src/core/qgshttptransaction.h
--- trunk/qgis/src/core/qgshttptransaction.h 2008-02-23 00:46:19 UTC (rev 8174)
+++ trunk/qgis/src/core/qgshttptransaction.h 2008-02-23 06:48:18 UTC (rev 8175)
@@ -64,11 +64,17 @@
The function returns FALSE if there is an error while getting the response.
- \param[out] respondedContent is replaced with the new content.
- \param[in] redirections is used to measure how many http redirections we've been through.
- Clients typically don't need to set this.
+ @param[out] respondedContent is replaced with the new content.
+ @param[in] redirections is used to measure how many http redirections we've been through.
+ Clients typically don't need to set this.
+ @param postData data to send with the http message. This is only used for HTTP POST. If
+ 0 then the request is done with HTTP GET.
+ @return true in case of success
- bool getSynchronously(QByteArray &respondedContent, int redirections = 0);
+ bool getSynchronously(QByteArray &respondedContent, int redirections = 0, const QByteArray* postData = 0);
QString responseContentType();
