[QGIS Commit] r8712 - trunk/qgis/tests/src/core
svn_qgis at osgeo.org
Sun Jul 6 07:36:54 EDT 2008
Author: timlinux
Date: 2008-07-06 07:36:54 -0400 (Sun, 06 Jul 2008)
New Revision: 8712
trunk/qgis/tests/src/core/CMakeLists.txt
trunk/qgis/tests/src/core/testqgsvectorfilewriter.cpp
Fixed broken filewriter unit test by changes in qgsapplication by adding a mechanism to find the install root of
qgis.
Modified: trunk/qgis/tests/src/core/CMakeLists.txt
--- trunk/qgis/tests/src/core/CMakeLists.txt 2008-07-05 19:44:35 UTC (rev 8711)
+++ trunk/qgis/tests/src/core/CMakeLists.txt 2008-07-06 11:36:54 UTC (rev 8712)
@@ -41,6 +41,7 @@
# the TEST_DATA_DIR variable is set in the top level CMakeLists.txt
ADD_DEFINITIONS(-DTEST_DATA_DIR="\\"${TEST_DATA_DIR}\\"")
+ADD_DEFINITIONS(-DINSTALL_PREFIX="\\"${CMAKE_INSTALL_PREFIX}\\"")
# libraries
Modified: trunk/qgis/tests/src/core/testqgsvectorfilewriter.cpp
--- trunk/qgis/tests/src/core/testqgsvectorfilewriter.cpp 2008-07-05 19:44:35 UTC (rev 8711)
+++ trunk/qgis/tests/src/core/testqgsvectorfilewriter.cpp 2008-07-06 11:36:54 UTC (rev 8712)
@@ -93,14 +93,10 @@
"******************\n");
// init QGIS's paths - true means that all path will be inited from prefix
QString qgisPath = QCoreApplication::applicationDirPath ();
- QgsApplication::setPrefixPath(qgisPath, TRUE);
+ QgsApplication::setPrefixPath(INSTALL_PREFIX, true);
+ QgsApplication::showSettings();
//create some objects that will be used in all tests...
- std::cout << "Prefix PATH: " << QgsApplication::prefixPath().toLocal8Bit().data() << std::endl;
- std::cout << "Plugin PATH: " << QgsApplication::pluginPath().toLocal8Bit().data() << std::endl;
- std::cout << "PkgData PATH: " << QgsApplication::pkgDataPath().toLocal8Bit().data() << std::endl;
- std::cout << "User DB PATH: " << QgsApplication::qgisUserDbFilePath().toLocal8Bit().data() << std::endl;
mEncoding = "UTF-8";
QgsField myField1("Field1",QVariant::String,"String",10,0,"Field 1 comment");
mFields.insert(0, myField1);
@@ -117,7 +113,7 @@
// Remove old copies that may be lying around
- QString myFileName = "testpt.shp";
+ QString myFileName = "/testpt.shp";
myFileName = QDir::tempPath() + myFileName;
QVERIFY(QgsVectorFileWriter::deleteShapeFile(myFileName));
QgsVectorFileWriter myWriter (myFileName,
