[QGIS Commit] r8715 - trunk/qgis/tests/src/core
svn_qgis at osgeo.org
Sun Jul 6 18:04:29 EDT 2008
Author: timlinux
Date: 2008-07-06 18:04:28 -0400 (Sun, 06 Jul 2008)
New Revision: 8715
trunk/qgis/tests/src/core/testqgsapplication.cpp
trunk/qgis/tests/src/core/testqgsgeometry.cpp
trunk/qgis/tests/src/core/testqgsmaplayer.cpp
Updates so that paths are correctly set based on changes in
qgisapplication
Modified: trunk/qgis/tests/src/core/testqgsapplication.cpp
--- trunk/qgis/tests/src/core/testqgsapplication.cpp 2008-07-06 11:46:51 UTC (rev 8714)
+++ trunk/qgis/tests/src/core/testqgsapplication.cpp 2008-07-06 22:04:28 UTC (rev 8715)
@@ -26,42 +26,27 @@
Q_OBJECT;
private slots:
- void getPaths();
void checkTheme();
+ void initTestCase();
private:
QString getQgisPath();
-QString TestQgsApplication::getQgisPath()
-#ifdef Q_OS_LINUX
- QString qgisPath = QCoreApplication::applicationDirPath () + "/../";
-#else //mac and win
- QString qgisPath = QCoreApplication::applicationDirPath () ;
-#endif
- return qgisPath;
-void TestQgsApplication::getPaths()
+void TestQgsGeometry::initTestCase()
+ // Runs once before any tests are run
// init QGIS's paths - true means that all path will be inited from prefix
- QgsApplication::setPrefixPath(getQgisPath(), TRUE);
- std::cout << "Prefix PATH: " << QgsApplication::prefixPath().toLocal8Bit().data() << std::endl;
- std::cout << "Plugin PATH: " << QgsApplication::pluginPath().toLocal8Bit().data() << std::endl;
- std::cout << "PkgData PATH: " << QgsApplication::pkgDataPath().toLocal8Bit().data() << std::endl;
- std::cout << "User DB PATH: " << QgsApplication::qgisUserDbFilePath().toLocal8Bit().data() << std::endl;
+ QString qgisPath = QCoreApplication::applicationDirPath ();
+ QgsApplication::setPrefixPath(INSTALL_PREFIX, true);
+ QgsApplication::showSettings();
void TestQgsApplication::checkTheme()
QString myIconPath = QgsApplication::themePath();
QPixmap myPixmap;
myPixmap.load(myIconPath+"/mIconProjectionDisabled.png");
Modified: trunk/qgis/tests/src/core/testqgsgeometry.cpp
--- trunk/qgis/tests/src/core/testqgsgeometry.cpp 2008-07-06 11:46:51 UTC (rev 8714)
+++ trunk/qgis/tests/src/core/testqgsgeometry.cpp 2008-07-06 22:04:28 UTC (rev 8715)
@@ -35,7 +35,6 @@
Q_OBJECT;
private slots:
- QString getQgisPath(); // Gets the path to QGIS installation
void initTestCase();// will be called before the first testfunction is executed.
void cleanupTestCase();// will be called after the last testfunction was executed.
void init();// will be called before each testfunction is executed.
@@ -64,15 +63,6 @@
QString mTestDataDir;
-QString TestQgsGeometry::getQgisPath()
-#ifdef Q_OS_LINUX
-#endif
- return qgisPath;
void TestQgsGeometry::init()
@@ -118,19 +108,11 @@
- //QString qgisPath = QCoreApplication::applicationDirPath ();
-#ifdef Q_OS_LINUX
-// QgsApplication::setPkgDataPath(qgisPath + "/../share/qgis");
-// QgsApplication::setPluginPath(qgisPath + "/../lib/qgis");
-#endif
void TestQgsGeometry::cleanupTestCase()
Modified: trunk/qgis/tests/src/core/testqgsmaplayer.cpp
--- trunk/qgis/tests/src/core/testqgsmaplayer.cpp 2008-07-06 11:46:51 UTC (rev 8714)
+++ trunk/qgis/tests/src/core/testqgsmaplayer.cpp 2008-07-06 22:04:28 UTC (rev 8715)
@@ -47,23 +47,17 @@
void TestQgsMapLayer::initTestCase()
- QgsApplication::setPrefixPath(qgisPath, TRUE);
-#ifdef Q_OS_LINUX
- QgsApplication::setPkgDataPath(qgisPath + "/../share/qgis");
- QgsApplication::setPluginPath(qgisPath + "/../lib/qgis");
-#endif
// Instantiate the plugin directory so that providers are loaded
QgsProviderRegistry::instance(QgsApplication::pluginPath());
//create some objects that will be used in all tests...
//create a map layer that will be used in all tests...
QString myFileName (TEST_DATA_DIR); //defined in CmakeLists.txt
myFileName = myFileName + QDir::separator() + "points.shp";
