[QGIS Commit] r8733 - in trunk/qgis: src/gui tests/src/core
tests/src/gui
svn_qgis at osgeo.org
Tue Jul 8 06:15:38 EDT 2008
Author: timlinux
Date: 2008-07-08 06:15:38 -0400 (Tue, 08 Jul 2008)
New Revision: 8733
trunk/qgis/src/gui/qgsquickprint.cpp
trunk/qgis/tests/src/core/CMakeLists.txt
trunk/qgis/tests/src/gui/CMakeLists.txt
fix divide by zero bug in quickprint. Fix issue preventing quickprint test from running
Modified: trunk/qgis/src/gui/qgsquickprint.cpp
--- trunk/qgis/src/gui/qgsquickprint.cpp 2008-07-08 09:54:15 UTC (rev 8732)
+++ trunk/qgis/src/gui/qgsquickprint.cpp 2008-07-08 10:15:38 UTC (rev 8733)
@@ -227,6 +227,8 @@
// so we can restore it properly
int myOriginalDpi = mpMapRender->outputDpi();
+ //sensible default to prevent divide by zero
+ if (0==myOriginalDpi) myOriginalDpi=96;
QSize myOriginalSize = mpMapRender->outputSize();
int mySymbolScalingAmount = myPrintResolutionDpi / myOriginalDpi;
Modified: trunk/qgis/tests/src/core/CMakeLists.txt
--- trunk/qgis/tests/src/core/CMakeLists.txt 2008-07-08 09:54:15 UTC (rev 8732)
+++ trunk/qgis/tests/src/core/CMakeLists.txt 2008-07-08 10:15:38 UTC (rev 8733)
@@ -76,9 +76,26 @@
ADD_EXECUTABLE(qgis_applicationtest ${qgis_applicationtest_SRCS})
ADD_DEPENDENCIES(qgis_applicationtest qgis_applicationtestmoc)
TARGET_LINK_LIBRARIES(qgis_applicationtest ${QT_LIBRARIES} qgis_core)
+ #No relinking and full RPATH for the install tree
+ #See: http://www.cmake.org/Wiki/CMake_RPATH_handling#No_relinking_and_full_RPATH_for_the_install_tree
SET_TARGET_PROPERTIES(qgis_applicationtest
+ # skip the full RPATH for the build tree
+ PROPERTIES SKIP_BUILD_RPATH TRUE
+SET_TARGET_PROPERTIES(qgis_applicationtest
+ # when building, use the install RPATH already
+ # (so it doesn't need to relink when installing)
+ PROPERTIES BUILD_WITH_INSTALL_RPATH TRUE
+ # the RPATH to be used when installing
PROPERTIES INSTALL_RPATH ${QGIS_LIB_DIR}
- INSTALL_RPATH_USE_LINK_PATH true)
+ # add the automatically determined parts of the RPATH
+ # which point to directories outside the build tree to the install RPATH
+ PROPERTIES INSTALL_RPATH_USE_LINK_PATH TRUE
IF (APPLE)
# For Mac OS X, the executable must be at the root of the bundle's executable folder
INSTALL(TARGETS qgis_applicationtest RUNTIME DESTINATION ${CMAKE_INSTALL_PREFIX})
Modified: trunk/qgis/tests/src/gui/CMakeLists.txt
--- trunk/qgis/tests/src/gui/CMakeLists.txt 2008-07-08 09:54:15 UTC (rev 8732)
+++ trunk/qgis/tests/src/gui/CMakeLists.txt 2008-07-08 10:15:38 UTC (rev 8733)
@@ -87,7 +87,7 @@
ADD_TEST(qgis_quickprinttest ${CMAKE_INSTALL_PREFIX}/qgis_quickprinttest)
ELSE (APPLE)
INSTALL(TARGETS qgis_quickprinttest RUNTIME DESTINATION ${QGIS_BIN_DIR})
- ADD_TEST(qgis_quickprinttest ${QGIS_BIN_DIR}/qgis_quickprinttest)
+ ADD_TEST(qgis_quickprinttest ${CMAKE_INSTALL_PREFIX}/bin/qgis_quickprinttest)
ENDIF (APPLE)
