[QGIS Commit] r8778 - trunk/qgis/src/plugins/grass
svn_qgis at osgeo.org
Mon Jul 14 18:08:48 EDT 2008
Author: timlinux
Date: 2008-07-14 18:08:48 -0400 (Mon, 14 Jul 2008)
New Revision: 8778
Added:
trunk/qgis/src/plugins/grass/qgsgrasstoolsbase.ui
trunk/qgis/src/plugins/grass/CMakeLists.txt
trunk/qgis/src/plugins/grass/qgsgrasstools.cpp
trunk/qgis/src/plugins/grass/qgsgrasstools.h
Implement grass toolbox as a designer ui and make toolbox subclass it - reduces the amount of manually (programmatically) constructed gui code required.
Modified: trunk/qgis/src/plugins/grass/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/CMakeLists.txt 2008-07-14 20:23:43 UTC (rev 8777)
+++ trunk/qgis/src/plugins/grass/CMakeLists.txt 2008-07-14 22:08:48 UTC (rev 8778)
@@ -42,6 +42,7 @@
SET (GRASS_PLUGIN_UIS
+ qgsgrasstoolsbase.ui
qgsgrassselectbase.ui
qgsgrasseditbase.ui
qgsgrassmapcalcbase.ui
Modified: trunk/qgis/src/plugins/grass/qgsgrasstools.cpp
--- trunk/qgis/src/plugins/grass/qgsgrasstools.cpp 2008-07-14 20:23:43 UTC (rev 8777)
+++ trunk/qgis/src/plugins/grass/qgsgrasstools.cpp 2008-07-14 22:08:48 UTC (rev 8778)
@@ -95,27 +95,14 @@
#endif
-QgsGrassToolsTabWidget::QgsGrassToolsTabWidget( QWidget * parent ):
- QTabWidget(parent)
- // Default height seems to be too small for our purpose
- int height = (int)(1.5 * tabBar()->iconSize().height());
- // Max width (see QgsGrassModule::pixmap for hardcoded sizes)
- int width = 3*height + 28 + 29;
- tabBar()->setIconSize( QSize(width,height) );
-QSize QgsGrassToolsTabWidget::iconSize()
- return tabBar()->iconSize();
-QgsGrassToolsTabWidget::~QgsGrassToolsTabWidget() {}
QgsGrassTools::QgsGrassTools ( QgisInterface *iface,
QWidget * parent, const char * name, Qt::WFlags f )
- : QDialog ( parent )
+ : QDialog(parent, f ), QgsGrassToolsBase ()
+ setupUi(this);
#ifdef QGISDEBUG
std::cerr << "QgsGrassTools()" << std::endl;
#endif
@@ -129,35 +116,14 @@
connect( qApp, SIGNAL(aboutToQuit()),
this, SLOT(closeTools()) );
- mTabWidget = new QgsGrassToolsTabWidget (this);
- QVBoxLayout *layout1 = new QVBoxLayout(this);
- layout1->addWidget(mTabWidget);
// Radims original tree view code.
- // Warning: if the tree is not the first page modules are
- // displayed over the other pages on first load
+ mModulesTree->header()->hide();
+ connect( mModulesTree, SIGNAL(itemClicked(QTreeWidgetItem *, int)),
+ this, SLOT(moduleClicked( QTreeWidgetItem *, int)) );
- mModulesListView = new QTreeWidget();
- mTabWidget->addTab( mModulesListView, tr("Modules Tree") );
- mModulesListView->setColumnCount(1);
- QStringList headers;
- headers << tr("Modules");
- mModulesListView->setHeaderLabels(headers);
- // Set list view
- mModulesListView->clear();
- mModulesListView->setSortingEnabled(false);
- mModulesListView->setRootIsDecorated(true);
- // mModulesListView->setResizeMode(QTreeWidget::AllColumns);
- mModulesListView->header()->hide();
- connect( mModulesListView, SIGNAL(itemClicked(QTreeWidgetItem *, int)),
- this, SLOT(moduleClicked( QTreeWidgetItem *, int)) );
// Tims experimental list view with filter
@@ -165,20 +131,16 @@
mModelProxy = new QSortFilterProxyModel(this);
mModelProxy->setSourceModel(mModelTools);
mModelProxy->setFilterRole(Qt::UserRole + 2);
- mListView = new QListView();
mListView->setModel(mModelProxy);
- mListView->setFocus();
mListView->setItemDelegateForColumn(0,new QgsDetailedItemDelegate());
mListView->setUniformItemSizes(false);
- QWidget * mypBase = new QWidget(this);
- QVBoxLayout * mypListTabLayout = new QVBoxLayout(mypBase);
- mypListTabLayout->addWidget(mListView);
- mFilterInput = new QLineEdit(this);
- mypListTabLayout->addWidget(mFilterInput);
- mTabWidget->addTab( mypBase, tr("Modules List") );
- connect( mFilterInput, SIGNAL(textChanged(QString)),
- this, SLOT(filterChanged(QString)) );
+ //mListView2 = new QListView(this);
+ //mDockWidget = new QDockWidget(tr("Grass Tools"), 0);
+ //mDockWidget->setWidget(mListView2);
+ //mDockWidget->setObjectName("GrassTools");
+ //mDockWidget->setAllowedAreas(Qt::LeftDockWidgetArea | Qt::RightDockWidgetArea);
+ //mIface->addDockWidget(Qt::LeftDockWidgetArea, mDockWidget);
connect( mListView, SIGNAL(clicked(const QModelIndex)),
this, SLOT(listItemClicked(const QModelIndex)));
@@ -201,8 +163,7 @@
QString title = tr("GRASS Tools: ") + QgsGrass::getDefaultLocation()
+ "/" + QgsGrass::getDefaultMapset();
setCaption(title);
- mModulesListView->show();
- mListView->show();
// Add map browser
mBrowser = new QgsGrassBrowser ( mIface, this );
@@ -322,7 +283,6 @@
is.addPixmap ( pixmap2 );
mTabWidget->addTab ( m, is, "" );
- QgsGrassToolsTabWidget tw;
mTabWidget->setCurrentPage ( mTabWidget->count()-1 );
@@ -338,8 +298,8 @@
#ifdef QGISDEBUG
std::cerr << "QgsGrassTools::loadConfig(): " << filePath.toLocal8Bit().data() << std::endl;
#endif
- mModulesListView->setIconSize(QSize(80,22));
+ mModulesTree->clear();
+ mModulesTree->setIconSize(QSize(80,22));
QFile file ( filePath );
@@ -407,7 +367,7 @@
else
- item = new QTreeWidgetItem( mModulesListView, lastItem );
+ item = new QTreeWidgetItem( mModulesTree, lastItem );
if ( e.tagName() == "section" )
@@ -415,7 +375,7 @@
QString label = e.attribute("label");
QgsDebugMsg( QString("label = %1").arg(label) );
item->setText( 0, label );
- item->setExpanded(true); // for debuging to spare one click
+ item->setExpanded(true);
addModules ( item, e );
@@ -548,7 +508,7 @@
// Helper function for Tim's experimental model list
-void QgsGrassTools::filterChanged(QString theText)
+void QgsGrassTools::on_mFilterInput_textChanged(QString theText)
QgsDebugMsg("PluginManager filter changed to :" + theText);
QRegExp::PatternSyntax mySyntax = QRegExp::PatternSyntax(QRegExp::RegExp);
Modified: trunk/qgis/src/plugins/grass/qgsgrasstools.h
--- trunk/qgis/src/plugins/grass/qgsgrasstools.h 2008-07-14 20:23:43 UTC (rev 8777)
+++ trunk/qgis/src/plugins/grass/qgsgrasstools.h 2008-07-14 22:08:48 UTC (rev 8778)
@@ -31,8 +31,11 @@
class QgsGrassBrowser;
class QgsMapCanvas;
+#include "ui_qgsgrasstoolsbase.h"
#include <QDialog>
#include <QTabWidget>
+#include <QDockWidget>
// For experimental filterable list model by Tim
@@ -42,25 +45,13 @@
#include <QStandardItemModel>
#include <QSortFilterProxyModel>
-class QgsGrassToolsTabWidget: public QTabWidget
- Q_OBJECT;
-public:
- //! Constructor
- QgsGrassToolsTabWidget ( QWidget * parent = 0 );
- //! Destructor
- ~QgsGrassToolsTabWidget();
- QSize iconSize();
/*! \class QgsGrassTools
* \brief Interface to GRASS modules.
-class QgsGrassTools: public QDialog
+class QgsGrassTools: public QDialog, private Ui::QgsGrassToolsBase
Q_OBJECT;
@@ -107,8 +98,8 @@
//! Close open tabs with tools
void closeTools();
- //! Update the regex used to filter the modules list
- void filterChanged(QString theText);
+ //! Update the regex used to filter the modules list (autoconnect to ui)
+ void on_mFilterInput_textChanged(QString theText);
//! Run a module when its entry is clicked in the list view
void listItemClicked(const QModelIndex &theIndex );
//! Run a module given its module name e.g. r.in.gdal
@@ -126,17 +117,14 @@
//! Browser
QgsGrassBrowser *mBrowser;
- QgsGrassToolsTabWidget *mTabWidget;
- QTreeWidget *mModulesListView;
// For experimental model & filtered model by Tim
- QListView * mListView;
QStandardItemModel * mModelTools;
QSortFilterProxyModel * mModelProxy;
- QLineEdit * mFilterInput;
+ QListView * mListView2;
+ QDockWidget * mDockWidget;
Added: trunk/qgis/src/plugins/grass/qgsgrasstoolsbase.ui
--- trunk/qgis/src/plugins/grass/qgsgrasstoolsbase.ui (rev 0)
+++ trunk/qgis/src/plugins/grass/qgsgrasstoolsbase.ui 2008-07-14 22:08:48 UTC (rev 8778)
@@ -0,0 +1,118 @@
+<ui version="4.0" >
+ <class>QgsGrassToolsBase</class>
+ <widget class="QDialog" name="QgsGrassToolsBase" >
+ <property name="geometry" >
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>400</width>
+ <height>300</height>
+ </rect>
+ </property>
+ <property name="windowTitle" >
+ <string>Grass Tools</string>
+ </property>
+ <layout class="QGridLayout" >
+ <item row="0" column="0" >
+ <widget class="QTabWidget" name="mTabWidget" >
+ <property name="currentIndex" >
+ <number>0</number>
+ </property>
+ <widget class="QWidget" name="modulesTree" >
+ <attribute name="title" >
+ <string>Modules Tree</string>
+ </attribute>
+ <widget class="QTreeWidget" name="mModulesTree" >
+ <property name="indentation" >
+ <number>8</number>
+ </property>
+ <property name="rootIsDecorated" >
+ <bool>false</bool>
+ </property>
+ <property name="wordWrap" >
+ <bool>true</bool>
+ </property>
+ <property name="headerHidden" stdset="0" >
+ <bool>true</bool>
+ </property>
+ <column>
+ <property name="text" >
+ <string>1</string>
+ </property>
+ </column>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="modulesList" >
+ <string>Modules List</string>
+ </attribute>
+ <widget class="QListView" name="mListView" >
+ <property name="alternatingRowColors" >
+ <bool>true</bool>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0" >
+ <widget class="QLineEdit" name="mFilterInput" />
+ </item>
+ </layout>
+ </widget>
+ </widget>
+ </item>
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ <property name="orientation" >
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Close|QDialogButtonBox::Help|QDialogButtonBox::NoButton</set>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <resources/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>QgsGrassToolsBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel" >
+ <x>252</x>
+ <y>295</y>
+ </hint>
+ <hint type="destinationlabel" >
+ <x>157</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>320</x>
+ <y>295</y>
+ </hint>
+ <x>286</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
+</ui>
