[QGIS Commit] r8792 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 16 05:57:42 EDT 2008
Author: timlinux
Date: 2008-07-16 05:56:54 -0400 (Wed, 16 Jul 2008)
New Revision: 8792
   trunk/qgis/src/app/qgspluginmanager.cpp
Fix bug in plugin manager introduced by recent changes I made that causes it to not remember loaded plugns properly
Modified: trunk/qgis/src/app/qgspluginmanager.cpp
--- trunk/qgis/src/app/qgspluginmanager.cpp	2008-07-16 09:21:41 UTC (rev 8791)
+++ trunk/qgis/src/app/qgspluginmanager.cpp	2008-07-16 09:56:54 UTC (rev 8792)
@@ -161,8 +161,7 @@
     //myData.setIcon(pixmap); //todo use a python logo here
     myData.setCheckable(true);
     myData.setRenderAsWidget(false);
-    QVariant myVariant = qVariantFromValue(myData);
-    mypDetailItem->setData(myVariant,PLUGIN_DATA_ROLE);
+    myData.setChecked(false); //start off assuming false
     // check to see if the plugin is loaded and set the checkbox accordingly
     QgsPluginRegistry *pRegistry = QgsPluginRegistry::instance();
@@ -177,9 +176,11 @@
       if (libName == packageName)
         // set the checkbox
-        mypDetailItem->setCheckState(Qt::Checked);
+        myData.setChecked(true);
+    QVariant myVariant = qVariantFromValue(myData);
+    mypDetailItem->setData(myVariant,PLUGIN_DATA_ROLE);
     // Add item to model
     mModelPlugins->appendRow(mypDetailItem);
@@ -358,7 +359,9 @@
     // FPV - I want to use index. You can do evrething with item.
     QModelIndex myIndex=mModelPlugins->index(row,0);
-    if (mModelPlugins->data(myIndex,Qt::CheckStateRole).toInt() == 0)
+    QgsDetailedItemData myData =
+        qVariantValue<QgsDetailedItemData>(mModelPlugins->data(myIndex,PLUGIN_DATA_ROLE));
+    if (!myData.isChecked())
       // iThe plugin name without version string in its data PLUGIN_LIB [ts]
@@ -402,7 +405,10 @@
   // FPV - I want to use item here. You can do everything with index if you want.
   for (int row=0;row < mModelPlugins->rowCount();row++)
-    if (mModelPlugins->item(row,0)->checkState() == Qt::Checked)
+        qVariantValue<QgsDetailedItemData>(mModelPlugins->item(row,0)->data(PLUGIN_DATA_ROLE));
+    if (myData.isChecked())
       QString pluginName = mModelPlugins->item(row,0)->data(PLUGIN_LIBRARY_NAME_ROLE).toString();
       bool pythonic = false;
More information about the QGIS-commit mailing list
