[QGIS Commit] r8905 - trunk/qgis/src/plugins/north_arrow
svn_qgis at osgeo.org
Fri Jul 25 18:52:13 EDT 2008
Author: timlinux
Date: 2008-07-25 18:52:13 -0400 (Fri, 25 Jul 2008)
New Revision: 8905
Added:
trunk/qgis/src/plugins/north_arrow/northArrow.svg
icon updates & drop xpm in favour of qt resource
Added: trunk/qgis/src/plugins/north_arrow/northArrow.svg
--- trunk/qgis/src/plugins/north_arrow/northArrow.svg (rev 0)
+++ trunk/qgis/src/plugins/north_arrow/northArrow.svg 2008-07-25 22:52:13 UTC (rev 8905)
@@ -0,0 +1,197 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Created with Inkscape (http://www.inkscape.org/) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ width="32"
+ height="32"
+ id="svg2"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ version="1.0"
+ sodipodi:docname="northArrow.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape"
+ inkscape:export-filename="/home/timlinux/dev/cpp/qgis/src/plugins/north_arrow/icon.png"
+ inkscape:export-xdpi="91"
+ inkscape:export-ydpi="91">
+ <defs
+ id="defs4">
+ <marker
+ inkscape:stockid="Arrow2Mend"
+ orient="auto"
+ refY="0.0"
+ refX="0.0"
+ id="Arrow2Mend"
+ style="overflow:visible;">
+ <path
+ id="path3704"
+ style="font-size:12.0;fill-rule:evenodd;stroke-width:0.62500000;stroke-linejoin:round;"
+ d="M 8.7185878,4.0337352 L -2.2072895,0.016013256 L 8.7185884,-4.0017078 C 6.9730900,-1.6296469 6.9831476,1.6157441 8.7185878,4.0337352 z "
+ transform="scale(0.6) rotate(180) translate(0,0)" />
+ </marker>
+ <marker
+ inkscape:stockid="Arrow2Lend"
+ orient="auto"
+ refY="0.0"
+ refX="0.0"
+ id="Arrow2Lend"
+ <path
+ id="path3698"
+ transform="scale(1.1) rotate(180) translate(1,0)" />
+ </marker>
+ <marker
+ inkscape:stockid="Arrow1Lend"
+ orient="auto"
+ refY="0.0"
+ refX="0.0"
+ id="Arrow1Lend"
+ <path
+ id="path3680"
+ d="M 0.0,0.0 L 5.0,-5.0 L -12.5,0.0 L 5.0,5.0 L 0.0,0.0 z "
+ style="fill-rule:evenodd;stroke:#000000;stroke-width:1.0pt;marker-start:none;"
+ transform="scale(0.8) rotate(180) translate(12.5,0)" />
+ </marker>
+ <inkscape:perspective
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_x="0 : 526.18109 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_z="744.09448 : 526.18109 : 1"
+ inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
+ id="perspective10" />
+ <filter
+ inkscape:collect="always"
+ id="filter6635">
+ <feGaussianBlur
+ stdDeviation="0.4594659"
+ id="feGaussianBlur6637" />
+ </filter>
+ <filter
+ id="filter8798"
+ x="-0.15979082"
+ width="1.3195816"
+ y="-0.051197356"
+ height="1.1023947">
+ <feGaussianBlur
+ stdDeviation="0.58842229"
+ id="feGaussianBlur8800" />
+ </filter>
+ <filter
+ id="filter8879">
+ <feGaussianBlur
+ stdDeviation="0.11043758"
+ id="feGaussianBlur8881" />
+ </filter>
+ <filter
+ id="filter14188">
+ <feGaussianBlur
+ stdDeviation="0.31129871"
+ id="feGaussianBlur14190" />
+ </filter>
+ </defs>
+ <sodipodi:namedview
+ id="base"
+ pagecolor="#ffffff"
+ bordercolor="#666666"
+ borderopacity="1.0"
+ inkscape:pageopacity="0.0"
+ inkscape:pageshadow="2"
+ inkscape:zoom="24.1875"
+ inkscape:cx="15.958656"
+ inkscape:cy="17.466958"
+ inkscape:document-units="px"
+ inkscape:current-layer="layer2"
+ showgrid="false"
+ inkscape:window-width="1680"
+ inkscape:window-height="975"
+ inkscape:window-x="0"
+ inkscape:window-y="49" />
+ <metadata
+ id="metadata7">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:format>image/svg+xml</dc:format>
+ <dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <g
+ inkscape:label="Camada 1"
+ inkscape:groupmode="layer"
+ id="layer1">
+ <path
+ sodipodi:type="arc"
+ style="fill:#54d0ff;fill-opacity:1;fill-rule:nonzero;stroke:#656565;stroke-width:1.29499996;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:1"
+ id="path5544"
+ sodipodi:cx="15.979328"
+ sodipodi:cy="16"
+ sodipodi:rx="16.020672"
+ sodipodi:ry="15.958656"
+ d="M 32,16 A 16.020672,15.958656 0 1 1 -0.041343689,16 A 16.020672,15.958656 0 1 1 32,16 z"
+ transform="matrix(0.9305489,0,0,0.9305489,1.1924691,1.1525611)" />
+ <path
+ style="fill:none;fill-opacity:1;fill-rule:nonzero;stroke:#656565;stroke-width:1.29499996;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:1"
+ id="path6576"
+ sodipodi:cy="16"
+ transform="matrix(0.9305489,0,0,0.9305489,1.2958285,1.1525615)" />
+ <path
+ style="opacity:1;fill:none;fill-opacity:1;fill-rule:nonzero;stroke:#e8e8f4;stroke-width:0.75761736;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:0.90839696000000003"
+ id="path6583"
+ sodipodi:cy="16"
+ transform="matrix(0.9305489,0,0,0.9305489,1.2958284,1.1112176)" />
+ <path
+ style="opacity:1;fill:none;fill-opacity:1;fill-rule:nonzero;stroke:#010111;stroke-width:0.75761736000000002;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:0.90839696000000003;filter:url(#filter6635)"
+ id="path6585"
+ sodipodi:cy="16"
+ transform="matrix(0.9305489,0,0,0.9305489,1.2544848,1.1525613)" />
+ </g>
+ <g
+ id="layer2"
+ inkscape:label="needle">
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1.47275399999999990;stroke-linecap:butt;stroke-linejoin:miter;marker-start:none;marker-mid:none;marker-end:url(#Arrow1Lend);stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1;filter:url(#filter14188);opacity:0.90747331"
+ d="M 16.728606,13.715775 L 16.948473,5.2456668"
+ id="path14174" />
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1.472754;stroke-linecap:butt;stroke-linejoin:miter;marker-start:none;marker-mid:none;marker-end:url(#Arrow1Lend);stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ d="M 16.191733,13.265182 L 16.4116,4.7950741"
+ id="path6642" />
+ </g>
+ <g
+ id="layer3"
+ inkscape:label="markers" />
+</svg>
