[QGIS Commit] r8907 - trunk/qgis/src/plugins/grid_maker
svn_qgis at osgeo.org
Fri Jul 25 18:58:07 EDT 2008
Author: timlinux
Date: 2008-07-25 18:58:07 -0400 (Fri, 25 Jul 2008)
New Revision: 8907
Added:
trunk/qgis/src/plugins/grid_maker/graticule.png
trunk/qgis/src/plugins/grid_maker/graticule.svg
Removed:
trunk/qgis/src/plugins/grid_maker/grid_pic2.png
trunk/qgis/src/plugins/grid_maker/icon.xpm
trunk/qgis/src/plugins/grid_maker/gridmaker_plugin.qrc
trunk/qgis/src/plugins/grid_maker/plugin.cpp
trunk/qgis/src/plugins/grid_maker/pluginguibase.ui
icon updates & drop xpm in favour of qt resource
Added: trunk/qgis/src/plugins/grid_maker/graticule.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grid_maker/graticule.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/qgis/src/plugins/grid_maker/graticule.svg
--- trunk/qgis/src/plugins/grid_maker/graticule.svg (rev 0)
+++ trunk/qgis/src/plugins/grid_maker/graticule.svg 2008-07-25 22:58:07 UTC (rev 8907)
@@ -0,0 +1,216 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Created with Inkscape (http://www.inkscape.org/) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ width="32"
+ height="32"
+ id="svg2"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ version="1.0"
+ sodipodi:docname="graticule.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape"
+ inkscape:export-filename="/home/timlinux/dev/cpp/qgis/src/plugins/grid_maker/graticule.png"
+ inkscape:export-xdpi="91"
+ inkscape:export-ydpi="91">
+ <defs
+ id="defs4">
+ <marker
+ inkscape:stockid="Arrow2Mend"
+ orient="auto"
+ refY="0.0"
+ refX="0.0"
+ id="Arrow2Mend"
+ style="overflow:visible;">
+ <path
+ id="path3704"
+ style="font-size:12.0;fill-rule:evenodd;stroke-width:0.62500000;stroke-linejoin:round;"
+ d="M 8.7185878,4.0337352 L -2.2072895,0.016013256 L 8.7185884,-4.0017078 C 6.9730900,-1.6296469 6.9831476,1.6157441 8.7185878,4.0337352 z "
+ transform="scale(0.6) rotate(180) translate(0,0)" />
+ </marker>
+ <marker
+ inkscape:stockid="Arrow2Lend"
+ orient="auto"
+ refY="0.0"
+ refX="0.0"
+ id="Arrow2Lend"
+ <path
+ id="path3698"
+ transform="scale(1.1) rotate(180) translate(1,0)" />
+ </marker>
+ <marker
+ inkscape:stockid="Arrow1Lend"
+ orient="auto"
+ refY="0.0"
+ refX="0.0"
+ id="Arrow1Lend"
+ <path
+ id="path3680"
+ d="M 0.0,0.0 L 5.0,-5.0 L -12.5,0.0 L 5.0,5.0 L 0.0,0.0 z "
+ style="fill-rule:evenodd;stroke:#000000;stroke-width:1.0pt;marker-start:none;"
+ transform="scale(0.8) rotate(180) translate(12.5,0)" />
+ </marker>
+ <inkscape:perspective
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_x="0 : 526.18109 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_z="744.09448 : 526.18109 : 1"
+ inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
+ id="perspective10" />
+ <filter
+ inkscape:collect="always"
+ id="filter6635">
+ <feGaussianBlur
+ stdDeviation="0.4594659"
+ id="feGaussianBlur6637" />
+ </filter>
+ </defs>
+ <sodipodi:namedview
+ id="base"
+ pagecolor="#ffffff"
+ bordercolor="#666666"
+ borderopacity="1.0"
+ inkscape:pageopacity="0.0"
+ inkscape:pageshadow="2"
+ inkscape:zoom="24.1875"
+ inkscape:cx="15.958656"
+ inkscape:cy="16"
+ inkscape:document-units="px"
+ inkscape:current-layer="layer2"
+ showgrid="false"
+ inkscape:window-width="1680"
+ inkscape:window-height="975"
+ inkscape:window-x="0"
+ inkscape:window-y="49" />
+ <metadata
+ id="metadata7">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:format>image/svg+xml</dc:format>
+ <dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <g
+ inkscape:label="Camada 1"
+ inkscape:groupmode="layer"
+ id="layer1"
+ style="display:inline">
+ <path
+ sodipodi:type="arc"
+ style="fill:#54d0ff;fill-opacity:1;fill-rule:nonzero;stroke:#656565;stroke-width:1.29499996;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:1"
+ id="path5544"
+ sodipodi:cx="15.979328"
+ sodipodi:cy="16"
+ sodipodi:rx="16.020672"
+ sodipodi:ry="15.958656"
+ d="M 32,16 A 16.020672,15.958656 0 1 1 -0.041343689,16 A 16.020672,15.958656 0 1 1 32,16 z"
+ transform="matrix(0.9305489,0,0,0.9305489,1.1924691,1.1525611)" />
+ <path
+ style="fill:none;fill-opacity:1;fill-rule:nonzero;stroke:#656565;stroke-width:1.29499996;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:1"
+ id="path6576"
+ sodipodi:cy="16"
+ transform="matrix(0.9305489,0,0,0.9305489,1.2958285,1.1525615)" />
+ <path
+ style="opacity:1;fill:none;fill-opacity:1;fill-rule:nonzero;stroke:#e8e8f4;stroke-width:0.75761735;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:0.90839694"
+ id="path6583"
+ sodipodi:cy="16"
+ transform="matrix(0.9305489,0,0,0.9305489,1.2958284,1.1112176)" />
+ <path
+ style="opacity:1;fill:none;fill-opacity:1;fill-rule:nonzero;stroke:#010111;stroke-width:0.75761735;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:0.90839694;filter:url(#filter6635)"
+ id="path6585"
+ sodipodi:cy="16"
+ transform="matrix(0.9305489,0,0,0.9305489,1.2544848,1.1525613)" />
+ </g>
+ <g
+ id="layer2"
+ inkscape:label="grid">
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1.08446538px;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 4.0361842,11.149364 C 4.0361842,11.149364 13.182587,2.0476048 17.294624,3.4599468 C 21.406662,4.8722887 28.131957,10.835511 28.131957,10.783201"
+ id="path4504"
+ sodipodi:nodetypes="csc" />
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1.07075274px;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 4.3626382,21.217921 C 4.3626382,21.217921 13.261205,30.338085 17.261823,28.922886 C 21.262439,27.507689 27.805504,21.532409 27.805504,21.584824"
+ id="path4506"
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.97540808px;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 3.7452154,14.910932 C 3.7452154,14.910932 12.83056,8.6472511 16.866529,9.6445329 C 20.902499,10.641815 28.1883,14.872664 28.1883,14.872664"
+ id="path4508"
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.96522206px;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 3.8183314,17.123494 C 3.8183314,17.123494 12.907462,23.254482 16.945113,22.278328 C 20.982765,21.302172 28.271602,17.160952 28.271602,17.160952"
+ id="path4510"
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1.09322631px;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 3.6489319,15.950508 L 28.24548,16.002749"
+ id="path4512" />
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.94975972px;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 18.001127,3.9285892 C 18.001127,3.9285892 22.970386,13.150597 21.908034,17.343601 C 20.845684,21.536602 18.237206,28.4988 18.276551,28.4988"
+ id="path4514"
+ <path
+ d="M 14.166699,3.8461807 C 14.166699,3.8461807 9.5102745,13.120431 10.572626,17.313434 C 11.634977,21.506436 13.930622,28.416391 13.891276,28.416391"
+ id="path4516"
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.88342524px;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 22.025768,6.1780552 C 22.025768,6.1780552 27.329742,13.551713 26.335658,16.873017 C 25.341569,20.194322 22.063912,26.292918 22.063912,26.292918"
+ id="path4518"
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.88461685px;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 10.200515,6.0318924 C 10.200515,6.0318924 5.3667133,13.52737 6.3609683,16.857074 C 7.355224,20.186779 10.162363,26.197617 10.162363,26.197617"
+ id="path4520"
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.95528823px;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 16.015114,3.6351193 L 15.975798,28.59174"
+ id="path4522" />
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1.08676291px;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 4.079452,11.088326 C 4.079452,11.088326 3.5639596,13.999939 3.6853823,16.262437 C 3.8036032,18.465277 4.3947078,21.282865 4.3947078,21.282865"
+ id="path4526"
+ <path
+ d="M 28.158085,10.961456 C 28.158085,10.961456 28.669617,13.930619 28.549127,16.237835 C 28.431815,18.484215 27.845252,21.357491 27.845252,21.357491"
+ id="path4528"
+ </g>
+</svg>
Deleted: trunk/qgis/src/plugins/grid_maker/grid_pic2.png
Modified: trunk/qgis/src/plugins/grid_maker/gridmaker_plugin.qrc
--- trunk/qgis/src/plugins/grid_maker/gridmaker_plugin.qrc 2008-07-25 22:55:26 UTC (rev 8906)
+++ trunk/qgis/src/plugins/grid_maker/gridmaker_plugin.qrc 2008-07-25 22:58:07 UTC (rev 8907)
@@ -1,5 +1,5 @@
<RCC>
<qresource prefix="/" >
- <file>grid_pic2.png</file>
+ <file>graticule.png</file>
</qresource>
</RCC>
Deleted: trunk/qgis/src/plugins/grid_maker/icon.xpm
Modified: trunk/qgis/src/plugins/grid_maker/plugin.cpp
--- trunk/qgis/src/plugins/grid_maker/plugin.cpp 2008-07-25 22:55:26 UTC (rev 8906)
+++ trunk/qgis/src/plugins/grid_maker/plugin.cpp 2008-07-25 22:58:07 UTC (rev 8907)
@@ -35,8 +35,6 @@
//the gui subclass
#include "plugingui.h"
-// xpm for creating the toolbar icon
-#include "icon.xpm"
static const char * const ident_ = "$Id$";
@@ -90,7 +88,7 @@
void QgsGridMakerPlugin::initGui()
// Create the action for tool
- myQActionPointer = new QAction(QIcon(icon), tr("&Graticule Creator"), this);
+ myQActionPointer = new QAction(QIcon(":/graticule.png"), tr("&Graticule Creator"), this);
myQActionPointer->setWhatsThis(tr("Creates a graticule (grid) and stores the result as a shapefile"));
// Connect the action to the run
connect(myQActionPointer, SIGNAL(activated()), this, SLOT(run()));
Modified: trunk/qgis/src/plugins/grid_maker/pluginguibase.ui
--- trunk/qgis/src/plugins/grid_maker/pluginguibase.ui 2008-07-25 22:55:26 UTC (rev 8906)
+++ trunk/qgis/src/plugins/grid_maker/pluginguibase.ui 2008-07-25 22:58:07 UTC (rev 8907)
@@ -13,27 +13,51 @@
<string>QGIS Graticule Creator</string>
</property>
<property name="windowIcon" >
- <iconset/>
+ <iconset resource="gridmaker_plugin.qrc" >:/graticule.png</iconset>
</property>
<layout class="QGridLayout" >
- <property name="margin" >
+ <property name="leftMargin" >
<number>9</number>
</property>
- <property name="spacing" >
+ <property name="topMargin" >
+ <number>9</number>
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
+ <property name="horizontalSpacing" >
<number>6</number>
</property>
+ <property name="verticalSpacing" >
+ <number>6</number>
+ </property>
<item row="5" column="1" >
<widget class="QGroupBox" name="groupBox_2" >
<property name="title" >
<string>Graticle size</string>
</property>
<number>9</number>
</property>
+ </property>
+ </property>
+ </property>
<number>6</number>
</property>
+ </property>
<item row="0" column="3" >
<widget class="QLineEdit" name="leYInterval" />
</item>
@@ -69,12 +93,24 @@
<string>End point (upper right)</string>
</property>
<number>9</number>
</property>
+ </property>
+ </property>
+ </property>
<number>6</number>
</property>
+ </property>
<widget class="QLineEdit" name="leYUpperRight" />
</item>
@@ -110,12 +146,24 @@
<string>Origin (lower left)</string>
</property>
<number>9</number>
</property>
+ </property>
+ </property>
+ </property>
<number>6</number>
</property>
+ </property>
<widget class="QLineEdit" name="leYLowerLeft" />
</item>
@@ -161,12 +209,21 @@
<string>Output (shape) file</string>
</property>
<layout class="QHBoxLayout" >
- <number>11</number>
- </property>
<number>6</number>
</property>
+ <number>11</number>
+ </property>
+ </property>
+ </property>
+ </property>
<item>
<widget class="QLineEdit" name="leOutputShapeFile" />
</item>
@@ -186,12 +243,21 @@
<string>Type</string>
</property>
- </property>
<number>6</number>
</property>
+ </property>
+ </property>
+ </property>
+ </property>
<item>
<widget class="QRadioButton" name="radPoint" >
<property name="text" >
@@ -220,9 +286,9 @@
<property name="html" >
<string><html><head><meta name="qrichtext" content="1" /><style type="text/css">
p, li { white-space: pre-wrap; }
-</style></head><body style=" font-family:'Sans Serif'; font-size:9pt; font-weight:400; font-style:normal; text-decoration:none;">
+</style></head><body style=" font-family:'Verdana'; font-size:10pt; font-weight:400; font-style:normal;">
<p style=" margin-top:12px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Arial'; font-size:11pt;"><span style=" font-size:10pt;">This plugin will help you to build a graticule shapefile that you can use as an overlay within your qgis map viewer.</span></p>
-<p style=" margin-top:12px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Arial'; font-size:10pt;">Please enter all units in decimal degrees</p></body></html></string>
+<p style=" margin-top:12px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Arial';">Please enter all units in decimal degrees</p></body></html></string>
</property>
</widget>
</item>
@@ -232,10 +298,10 @@
<string/>
</property>
<property name="pixmap" >
- <pixmap resource="gridmaker_plugin.qrc" >:/grid_pic2.png</pixmap>
+ <pixmap resource="gridmaker_plugin.qrc" >:/graticule.png</pixmap>
</property>
<property name="scaledContents" >
- <bool>true</bool>
+ <bool>false</bool>
</property>
</widget>
</item>
