[QGIS Commit] r8917 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sat Jul 26 05:36:31 EDT 2008
Author: jef
Date: 2008-07-26 05:36:31 -0400 (Sat, 26 Jul 2008)
New Revision: 8917
trunk/qgis/src/app/qgssinglesymboldialog.cpp
trunk/qgis/src/app/qgssinglesymboldialog.h
fix #1184
Modified: trunk/qgis/src/app/qgssinglesymboldialog.cpp
--- trunk/qgis/src/app/qgssinglesymboldialog.cpp 2008-07-26 09:29:38 UTC (rev 8916)
+++ trunk/qgis/src/app/qgssinglesymboldialog.cpp 2008-07-26 09:36:31 UTC (rev 8917)
@@ -94,9 +94,8 @@
const QgsFieldMap & fields = provider->fields();
QString str;
- mRotationClassificationComboBox->addItem(DO_NOT_USE_STR);
- mScaleClassificationComboBox->addItem(DO_NOT_USE_STR);
- mFieldMap.insert(std::make_pair(DO_NOT_USE_STR, -1));
+ mRotationClassificationComboBox->addItem(DO_NOT_USE_STR, -1);
+ mScaleClassificationComboBox->addItem(DO_NOT_USE_STR, -1);
for (QgsFieldMap::const_iterator it = fields.begin();
it != fields.end();
++it)
@@ -104,9 +103,8 @@
QVariant::Type type = (*it).type();
if (type == QVariant::Int || type == QVariant::Double)
- mRotationClassificationComboBox->addItem(it->name());
- mScaleClassificationComboBox->addItem(it->name());
- mFieldMap.insert(std::make_pair(it->name(), it.key()));
+ mRotationClassificationComboBox->addItem(it->name(), it.key());
+ mScaleClassificationComboBox->addItem(it->name(), it.key());
@@ -274,23 +272,12 @@
std::map<QString,int>::iterator iter;
if( mRotationClassificationComboBox->isEnabled() )
- sy->setRotationClassificationField(-1);
- iter=mFieldMap.find(mRotationClassificationComboBox->currentText());
- if(iter!=mFieldMap.end())
- sy->setRotationClassificationField(iter->second);
+ sy->setRotationClassificationField( mRotationClassificationComboBox->itemData( mRotationClassificationComboBox->currentIndex() ).toInt() );
if( mScaleClassificationComboBox->isEnabled() )
- sy->setScaleClassificationField(-1);
- iter = mFieldMap.find(mScaleClassificationComboBox->currentText());
- sy->setScaleClassificationField(iter->second);
+ sy->setScaleClassificationField( mScaleClassificationComboBox->itemData( mScaleClassificationComboBox->currentIndex() ).toInt() );
@@ -368,26 +355,14 @@
mPointSizeSpinBox->setValue ( sy->pointSize() );
- QString rotationclassfield = DO_NOT_USE_STR;
- QString scaleclassfield = DO_NOT_USE_STR;
- for(std::map<QString,int>::iterator it=mFieldMap.begin();it!=mFieldMap.end();++it)
- if(it->second == sy->rotationClassificationField())
- rotationclassfield=it->first;
- QgsDebugMsg(QString("Found rotation field " + rotationclassfield));
- if(it->second == sy->scaleClassificationField())
- scaleclassfield=it->first;
- QgsDebugMsg(QString("Found scale field " + scaleclassfield));
- mRotationClassificationComboBox->setItemText(
- mRotationClassificationComboBox->currentIndex(), rotationclassfield);
- mScaleClassificationComboBox->setItemText(
- mScaleClassificationComboBox->currentIndex(), scaleclassfield);
+ int index;
+ index = mRotationClassificationComboBox->findData( sy->rotationClassificationField() );
+ mRotationClassificationComboBox->setCurrentIndex( index<0 ? 0 : index);
+ index = mScaleClassificationComboBox->findData( sy->scaleClassificationField() );
+ mScaleClassificationComboBox->setCurrentIndex( index<0 ? 0 : index);
outlinewidthspinbox->setValue(sy->pen().widthF());
//set line width 1 as minimum to avoid confusion between line width 0 and no pen line style
@@ -471,26 +446,12 @@
if( mPointSizeSpinBox->isEnabled() && mPointSizeSpinBox->value()!=sy->pointSize() )
mPointSizeSpinBox->setEnabled(false);
- if( mRotationClassificationComboBox->isEnabled() && mRotationClassificationComboBox->currentText()!=rotationclassfield )
+ if( mRotationClassificationComboBox->isEnabled() &&
+ mRotationClassificationComboBox->itemData( mRotationClassificationComboBox->currentIndex() ).toInt() != sy->rotationClassificationField() )
mRotationClassificationComboBox->setEnabled(false);
- if( mScaleClassificationComboBox->isEnabled() && mScaleClassificationComboBox->currentText()!=scaleclassfield )
+ if( mScaleClassificationComboBox->isEnabled() &&
+ mScaleClassificationComboBox->itemData( mScaleClassificationComboBox->currentIndex() ).toInt() != sy->scaleClassificationField() )
mScaleClassificationComboBox->setEnabled(false);
if( outlinewidthspinbox->isEnabled() && outlinewidthspinbox->value() != sy->pen().widthF() )
Modified: trunk/qgis/src/app/qgssinglesymboldialog.h
--- trunk/qgis/src/app/qgssinglesymboldialog.h 2008-07-26 09:29:38 UTC (rev 8916)
+++ trunk/qgis/src/app/qgssinglesymboldialog.h 2008-07-26 09:36:31 UTC (rev 8917)
@@ -48,9 +48,6 @@
protected:
QgsVectorLayer* mVectorLayer;
- /**Stores the names and numbers of the fields with numeric values*/
- std::map<QString,int> mFieldMap;
- int mAngleClassificationField;
public slots:
/* arrange the widgets on this dialog to reflect the current state of QgsSymbol */
