[QGIS Commit] r8926 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Sun Jul 27 00:47:10 EDT 2008
Author: taraathan
Date: 2008-07-27 00:47:09 -0400 (Sun, 27 Jul 2008)
New Revision: 8926
docs/trunk/english_us/user_guide/conventions.tex
in conventions.tex, added comments for text styles
style fieldname has been commented out
use guilabel, usertext or searchstring instead
macro toolbox has been commented out
use toolboxtwo instead
Modified: docs/trunk/english_us/user_guide/conventions.tex
--- docs/trunk/english_us/user_guide/conventions.tex 2008-07-27 03:18:10 UTC (rev 8925)
+++ docs/trunk/english_us/user_guide/conventions.tex 2008-07-27 04:47:09 UTC (rev 8926)
@@ -3,19 +3,28 @@
% \fbox, \shadowbox, \doublebox, \ovalbox and \Ovalbox
%%%%%%%%%%%%%%%%8%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
+% general styles for text that the user should type in from the keyboard
\renewcommand{\usertext}[1]{\texttt{#1}}
-\renewcommand{\classname}[1]{\textsf{\textbf{#1}}}
-\renewcommand{\fieldname}[1]{\textsl{#1}}
\renewcommand{\filename}[1]{\texttt{#1}}
+% style for user input by individual keystrokes
\renewcommand{\keystroke}[1]{\cornersize{.6}\ovalbox{\textsf{#1}}}
+% generic style for text that appears in the GUI
+\newcommand{\guilabel}[1]{\textsf{#1}}
+\newcommand{\guiheading}[1]{\textsf{#1}}
+% some styles for use only when discussing Python coding
+\renewcommand{\classname}[1]{\textsf{\textbf{#1}}}
\renewcommand{\method}[1]{\textsf{\textit{#1}}}
-\renewcommand{\server}[1]{\textit{#1}}
-\renewcommand{\sqltable}[1]{\textsf{\textbf{#1}}}
-\newcommand{\guilabel}[1]{\textsf{#1}}
+%\renewcommand{\fieldname}[1]{\textsl{#1}}
\newcommand{\object}[1]{\textsf{\textit{#1}}}
+% some styles for the Qt GUI
\newcommand{\qtmainmenuopt}[1]{\textsf{#1}}
\newcommand{\qtdropmenuopt}[1]{\textsf{#1}}
\newcommand{\qtdialog}[1]{\textsf{#1}}
+% ??? these styles are from Gary
+\renewcommand{\server}[1]{\textit{#1}}
+\renewcommand{\sqltable}[1]{\textsf{\textbf{#1}}}
\newcommand{\dialog}[1]{
\fcolorbox[rgb]{0.2,0.2,0.95}[rgb]{0.2,0.2,0.95}{%
@@ -112,10 +121,10 @@
\includegraphics[width=5mm]{#3}%
\guilabel{#4}%
-%for backward compatibility!
-\newcommand{\toolbox}[2]{%
-\toolboxtwo{#1}{#2}%
+%not to be used anymore
+%\newcommand{\toolbox}[2]{%
+%\toolboxtwo{#1}{#2}%
% tab
\newcommand{\tab}[1]{%
\raisebox{-6pt}{%
@@ -286,7 +295,7 @@
\item Keystroke Combinations: press \keystroke{Ctrl-B}, meaning press and
hold the Ctrl key and then press the B key.
\item Name of a File: \filename{lakes.shp}
-\item Name of a Field: \fieldname{NAMES}
+%\item Name of a Field: \fieldname{NAMES}
\item Name of a Class: \classname{NewLayer}
\item Method: \method{classFactory}
\item Server: \server{example needed here}
