[QGIS Commit] r8942 - in trunk/qgis/src/plugins/grass/themes: .
classic
svn_qgis at osgeo.org
Mon Jul 28 14:38:28 EDT 2008
Author: timlinux
Date: 2008-07-28 14:38:27 -0400 (Mon, 28 Jul 2008)
New Revision: 8942
Added:
trunk/qgis/src/plugins/grass/themes/classic/
trunk/qgis/src/plugins/grass/themes/classic/.cvsignore
trunk/qgis/src/plugins/grass/themes/classic/CMakeLists.txt
trunk/qgis/src/plugins/grass/themes/classic/grass_add_map.png
trunk/qgis/src/plugins/grass/themes/classic/grass_add_raster.png
trunk/qgis/src/plugins/grass/themes/classic/grass_add_vector.png
trunk/qgis/src/plugins/grass/themes/classic/grass_add_vertex.png
trunk/qgis/src/plugins/grass/themes/classic/grass_browser_raster_layer.png
trunk/qgis/src/plugins/grass/themes/classic/grass_browser_vector_layer.png
trunk/qgis/src/plugins/grass/themes/classic/grass_clear_input.png
trunk/qgis/src/plugins/grass/themes/classic/grass_close_edit.png
trunk/qgis/src/plugins/grass/themes/classic/grass_close_mapset.png
trunk/qgis/src/plugins/grass/themes/classic/grass_copy_map.png
trunk/qgis/src/plugins/grass/themes/classic/grass_delete_line.png
trunk/qgis/src/plugins/grass/themes/classic/grass_delete_map.png
trunk/qgis/src/plugins/grass/themes/classic/grass_delete_vertex.png
trunk/qgis/src/plugins/grass/themes/classic/grass_edit.png
trunk/qgis/src/plugins/grass/themes/classic/grass_edit_attributes.png
trunk/qgis/src/plugins/grass/themes/classic/grass_module_error.png
trunk/qgis/src/plugins/grass/themes/classic/grass_module_warning.png
trunk/qgis/src/plugins/grass/themes/classic/grass_move_line.png
trunk/qgis/src/plugins/grass/themes/classic/grass_move_vertex.png
trunk/qgis/src/plugins/grass/themes/classic/grass_new_boundary.png
trunk/qgis/src/plugins/grass/themes/classic/grass_new_centroid.png
trunk/qgis/src/plugins/grass/themes/classic/grass_new_line.png
trunk/qgis/src/plugins/grass/themes/classic/grass_new_mapset.png
trunk/qgis/src/plugins/grass/themes/classic/grass_new_point.png
trunk/qgis/src/plugins/grass/themes/classic/grass_new_vector_layer.png
trunk/qgis/src/plugins/grass/themes/classic/grass_open_mapset.png
trunk/qgis/src/plugins/grass/themes/classic/grass_refresh.png
trunk/qgis/src/plugins/grass/themes/classic/grass_region.png
trunk/qgis/src/plugins/grass/themes/classic/grass_region_edit.png
trunk/qgis/src/plugins/grass/themes/classic/grass_rename_map.png
trunk/qgis/src/plugins/grass/themes/classic/grass_set_region.png
trunk/qgis/src/plugins/grass/themes/classic/grass_shell.png
trunk/qgis/src/plugins/grass/themes/classic/grass_split_line.png
trunk/qgis/src/plugins/grass/themes/classic/grass_tools.png
trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_connection.png
trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_constant.png
trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_function.png
trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_map.png
trunk/qgis/src/plugins/grass/themes/classic/mapcalc_delete.png
trunk/qgis/src/plugins/grass/themes/classic/mapcalc_open.png
trunk/qgis/src/plugins/grass/themes/classic/mapcalc_save.png
trunk/qgis/src/plugins/grass/themes/classic/mapcalc_save_as.png
trunk/qgis/src/plugins/grass/themes/classic/mapcalc_select.png
trunk/qgis/src/plugins/grass/themes/classic/world.png
Provide classic theme
Added: trunk/qgis/src/plugins/grass/themes/classic/.cvsignore
--- trunk/qgis/src/plugins/grass/themes/classic/.cvsignore (rev 0)
+++ trunk/qgis/src/plugins/grass/themes/classic/.cvsignore 2008-07-28 18:38:27 UTC (rev 8942)
@@ -0,0 +1,2 @@
+Makefile
+Makefile.in
Added: trunk/qgis/src/plugins/grass/themes/classic/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/themes/classic/CMakeLists.txt (rev 0)
+++ trunk/qgis/src/plugins/grass/themes/classic/CMakeLists.txt 2008-07-28 18:38:27 UTC (rev 8942)
@@ -0,0 +1,5 @@
+FILE (GLOB IMAGES *.png)
+INSTALL (FILES ${IMAGES}
+ DESTINATION ${QGIS_DATA_DIR}/themes/classic/grass)
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_add_map.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_add_map.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_add_raster.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_add_raster.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_add_vector.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_add_vector.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_add_vertex.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_add_vertex.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_browser_raster_layer.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_browser_raster_layer.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_browser_vector_layer.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_browser_vector_layer.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_clear_input.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_clear_input.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_close_edit.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_close_edit.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_close_mapset.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_close_mapset.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_copy_map.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_copy_map.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_delete_line.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_delete_line.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_delete_map.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_delete_map.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_delete_vertex.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_delete_vertex.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_edit.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_edit.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_edit_attributes.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_edit_attributes.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_module_error.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_module_error.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_module_warning.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_module_warning.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_move_line.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_move_line.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_move_vertex.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_move_vertex.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_new_boundary.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_new_boundary.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_new_centroid.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_new_centroid.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_new_line.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_new_line.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_new_mapset.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_new_mapset.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_new_point.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_new_point.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_new_vector_layer.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_new_vector_layer.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_open_mapset.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_open_mapset.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_refresh.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_refresh.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_region.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_region.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_region_edit.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_region_edit.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_rename_map.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_rename_map.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_set_region.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_set_region.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_shell.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_shell.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_split_line.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_split_line.png
Added: trunk/qgis/src/plugins/grass/themes/classic/grass_tools.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/grass_tools.png
Added: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_connection.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_connection.png
Added: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_constant.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_constant.png
Added: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_function.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_function.png
Added: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_map.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_add_map.png
Added: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_delete.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_delete.png
Added: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_open.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_open.png
Added: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_save.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_save.png
Added: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_save_as.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_save_as.png
Added: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_select.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/mapcalc_select.png
Added: trunk/qgis/src/plugins/grass/themes/classic/world.png
Property changes on: trunk/qgis/src/plugins/grass/themes/classic/world.png
