[QGIS Commit] r8945 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Mon Jul 28 16:09:29 EDT 2008
Author: timlinux
Date: 2008-07-28 16:09:29 -0400 (Mon, 28 Jul 2008)
New Revision: 8945
trunk/qgis/src/app/qgsattributetabledisplay.cpp
trunk/qgis/src/app/qgsattributetabledisplay.h
trunk/qgis/src/ui/qgsattributetablebase.ui
Fix ticket #982 - combine start / stop editing into one button
Modified: trunk/qgis/src/app/qgsattributetabledisplay.cpp
--- trunk/qgis/src/app/qgsattributetabledisplay.cpp 2008-07-28 20:01:03 UTC (rev 8944)
+++ trunk/qgis/src/app/qgsattributetabledisplay.cpp 2008-07-28 20:09:29 UTC (rev 8945)
@@ -55,8 +55,6 @@
connect(mZoomMapToSelectedRowsButton, SIGNAL(clicked()), this, SLOT(zoomMapToSelectedRows()));
connect(mAddAttributeButton, SIGNAL(clicked()), this, SLOT(addAttribute()));
connect(mDeleteAttributeButton, SIGNAL(clicked()), this, SLOT(deleteAttributes()));
- connect(btnStartEditing, SIGNAL(clicked()), this, SLOT(startEditing()));
- connect(btnStopEditing, SIGNAL(clicked()), this, SLOT(stopEditing()));
connect(mSearchButton, SIGNAL(clicked()), this, SLOT(search()));
connect(mSearchShowResults, SIGNAL(activated(int)), this, SLOT(searchShowResultsChanged(int)));
connect(btnAdvancedSearch, SIGNAL(clicked()), this, SLOT(advancedSearch()));
@@ -69,17 +67,16 @@
mAddAttributeButton->setEnabled(false);
mDeleteAttributeButton->setEnabled(false);
- btnStopEditing->setEnabled(false);
int cap=layer->getDataProvider()->capabilities();
if((cap&QgsVectorDataProvider::ChangeAttributeValues)
||(cap&QgsVectorDataProvider::AddAttributes)
||(cap&QgsVectorDataProvider::DeleteAttributes))
- btnStartEditing->setEnabled(true);
+ btnEdit->setEnabled(true);
else
- btnStartEditing->setEnabled(false);
+ btnEdit->setEnabled(false);
// fill in mSearchColumns with available columns
@@ -175,8 +172,7 @@
if(editing)
- btnStopEditing->setEnabled(true);
+ btnEdit->setText(tr("Stop editing"));
buttonBox->button(QDialogButtonBox::Close)->setEnabled(false);
//make the dialog modal when in editable
//otherwise map editing and table editing
@@ -185,9 +181,27 @@
setModal(true);
show();
+ else
+ //revert button
+ QMessageBox::information(this,tr("Editing not permitted"),tr("The data provider is read only, editing is not allowed."));
+ btnEdit->setChecked(false);
+void QgsAttributeTableDisplay::on_btnEdit_toggled(bool theFlag)
+ if (theFlag)
+ startEditing();
+ else
+ stopEditing();
void QgsAttributeTableDisplay::stopEditing()
if(table()->edited())
@@ -213,8 +227,7 @@
return;
+ btnEdit->setText(tr("Start editing"));
buttonBox->button(QDialogButtonBox::Close)->setEnabled(true);
Modified: trunk/qgis/src/app/qgsattributetabledisplay.h
--- trunk/qgis/src/app/qgsattributetabledisplay.h 2008-07-28 20:01:03 UTC (rev 8944)
+++ trunk/qgis/src/app/qgsattributetabledisplay.h 2008-07-28 20:09:29 UTC (rev 8945)
@@ -60,6 +60,7 @@
protected slots:
void deleteAttributes();
void addAttribute();
+ void on_btnEdit_toggled(bool theFlag);
void startEditing();
void stopEditing();
void selectedToTop();
Modified: trunk/qgis/src/ui/qgsattributetablebase.ui
--- trunk/qgis/src/ui/qgsattributetablebase.ui 2008-07-28 20:01:03 UTC (rev 8944)
+++ trunk/qgis/src/ui/qgsattributetablebase.ui 2008-07-28 20:09:29 UTC (rev 8945)
@@ -162,20 +162,13 @@
</spacer>
</item>
<item>
- <widget class="QPushButton" name="btnStartEditing" >
+ <widget class="QPushButton" name="btnEdit" >
<property name="text" >
<string>Start editing</string>
</property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="btnStopEditing" >
- <property name="text" >
- <string>Stop editin&g</string>
+ <property name="checkable" >
+ <bool>true</bool>
</property>
- <property name="shortcut" >
- <string>Alt+G</string>
- </property>
</widget>
</item>
</layout>
@@ -272,8 +265,7 @@
<tabstop>mZoomMapToSelectedRowsButton</tabstop>
<tabstop>mAddAttributeButton</tabstop>
<tabstop>mDeleteAttributeButton</tabstop>
- <tabstop>btnStartEditing</tabstop>
- <tabstop>btnStopEditing</tabstop>
+ <tabstop>btnEdit</tabstop>
<tabstop>mSearchText</tabstop>
<tabstop>mSearchColumns</tabstop>
<tabstop>mSearchButton</tabstop>
