[QGIS Commit] r8947 - in trunk/qgis/tests: src/core testdata
svn_qgis at osgeo.org
Tue Jul 29 12:17:47 EDT 2008
Author: timlinux
Date: 2008-07-29 12:17:47 -0400 (Tue, 29 Jul 2008)
New Revision: 8947
Added:
trunk/qgis/tests/testdata/expected_geometry_bufferCheck.png
trunk/qgis/tests/testdata/expected_geometry_differenceCheck1.png
trunk/qgis/tests/testdata/expected_geometry_differenceCheck2.png
trunk/qgis/tests/testdata/expected_geometry_intersectionCheck1.png
trunk/qgis/tests/testdata/expected_geometry_unionCheck1.png
trunk/qgis/tests/testdata/expected_geometry_unionCheck2.png
trunk/qgis/tests/src/core/qgsrenderchecker.cpp
trunk/qgis/tests/src/core/qgsrenderchecker.h
trunk/qgis/tests/src/core/testqgsgeometry.cpp
In renderchecker split runtest into two functions so that image based compares can be done in situations where a maprenderer is not needed. Added more tests for geometry functions (buffer, difference) and provide a visual report of geometry test results.
Modified: trunk/qgis/tests/src/core/qgsrenderchecker.cpp
--- trunk/qgis/tests/src/core/qgsrenderchecker.cpp 2008-07-29 09:17:31 UTC (rev 8946)
+++ trunk/qgis/tests/src/core/qgsrenderchecker.cpp 2008-07-29 16:17:47 UTC (rev 8947)
@@ -25,6 +25,7 @@
QgsRenderChecker::QgsRenderChecker( ) :
mReport(""),
mExpectedImageFile(""),
+ mRenderedImageFile(""),
mMismatchCount(0),
mMatchTarget(0),
mElapsedTime(0),
@@ -53,10 +54,7 @@
// Now render our layers onto a pixmap
QImage myImage( myExpectedImage.width() , myExpectedImage.height(), QImage::Format_RGB32 );
- QImage myDifferenceImage( myExpectedImage.width() , myExpectedImage.height(), QImage::Format_RGB32);
- QString myResultDiffImage = QDir::tempPath() + QDir::separator() + theTestName + "_result_diff.png";
myImage.fill ( qRgb( 152,219,249 ) );
- myDifferenceImage.fill ( qRgb( 152,219,249 ) );
QPainter myPainter( &myImage );
mpMapRenderer->setOutputSize( QSize ( myExpectedImage.width(),myExpectedImage.height() ),72 );
QTime myTime;
@@ -68,13 +66,47 @@
// Save the pixmap to disk so the user can make a
// visual assessment if needed
- QString myResultImage = QDir::tempPath() + QDir::separator() + theTestName + "_result.png";
- myImage.save (myResultImage);
+ mRenderedImageFile = QDir::tempPath() + QDir::separator() + theTestName + "_result.png";
+ myImage.save (mRenderedImageFile);
+ return compareImages(theTestName);
+bool QgsRenderChecker::compareImages( QString theTestName )
+ if (mExpectedImageFile.isEmpty())
+ qDebug("QgsRenderChecker::runTest failed - Expected Image (control) File not set.");
+ mReport= "<table>"
+ "<tr><td>Test Result:</td><td>Expected Result:</td></tr>\n"
+ "<tr><td>Nothing rendered</td>\n<td>Failed because Expected "
+ "Image File not set.</td></tr></table>\n";
+ return false;
+ if (mRenderedImageFile.isEmpty())
+ qDebug("QgsRenderChecker::runTest failed - Rendered Image File not set.");
+ return false;
+ // Load /create the images
+ QImage myExpectedImage (mExpectedImageFile);
+ QImage myResultImage (mRenderedImageFile);
+ QImage myDifferenceImage( myExpectedImage.width() , myExpectedImage.height(), QImage::Format_RGB32);
+ QString myResultDiffImage = QDir::tempPath() + QDir::separator() + theTestName + "_result_diff.png";
+ myDifferenceImage.fill ( qRgb( 152,219,249 ) );
// Set pixel count score and target
mMatchTarget = myExpectedImage.width() * myExpectedImage.height();
- int myPixelCount = myImage.width() * myImage.height();
+ int myPixelCount = myResultImage.width() * myResultImage.height();
// Set the report with the result
@@ -82,37 +114,33 @@
mReport += "<tr><td colspan=2>";
mReport += "Test image and result image for " + theTestName + "<br>"
"Expected size: " + QString::number(myExpectedImage.width()).toLocal8Bit() + "w x " +
- QString::number(myExpectedImage.width()).toLocal8Bit() + "h (" +
- QString::number(mMatchTarget).toLocal8Bit() + " pixels)<br>"
- "Actual size: " + QString::number(myImage.width()).toLocal8Bit() + "w x " +
- QString::number(myImage.width()).toLocal8Bit() + "h (" +
- QString::number(myPixelCount).toLocal8Bit() + " pixels)";
+ QString::number(myExpectedImage.width()).toLocal8Bit() + "h (" +
+ QString::number(mMatchTarget).toLocal8Bit() + " pixels)<br>"
+ "Actual size: " + QString::number(myResultImage.width()).toLocal8Bit() + "w x " +
+ QString::number(myResultImage.width()).toLocal8Bit() + "h (" +
+ QString::number(myPixelCount).toLocal8Bit() + " pixels)";
mReport += "</td></tr>";
mReport += "<tr><td colspan = 2>\n";
mReport += "Expected Duration : <= " + QString::number(mElapsedTimeTarget) +
- "ms (0 indicates not specified)<br>";
+ "ms (0 indicates not specified)<br>";
mReport += "Actual Duration : " + QString::number(mElapsedTime) + "ms<br>";
QString myImagesString= "</td></tr>"
"<tr><td>Test Result:</td><td>Expected Result:</td><td>Difference (all blue is good, any red is bad)</td></tr>\n"
"<tr><td><img src=\"file://" +
- myResultImage +
+ mRenderedImageFile +
"\"></td>\n<td><img src=\"file://" +
- mExpectedImageFile +
+ mExpectedImageFile +
"\"></td><td><img src=\"file://" +
- myResultDiffImage +
+ myResultDiffImage +
"\"></td>\n</tr>\n</table>";
// Put the same info to debug too
- qDebug ("Expected size: " + QString::number(myExpectedImage.width()).toLocal8Bit() + + "w x " +
- QString::number(myExpectedImage.width()).toLocal8Bit() + + "h");
- qDebug ("Actual size: " + QString::number(myImage.width()).toLocal8Bit() + + "w x " +
- QString::number(myImage.width()).toLocal8Bit() + + "h");
- // Now load the renderered image and the expected image
- // and then iterate through them counting how many
- // dissimilar pixel values there are
+ qDebug ("Expected size: " + QString::number(myExpectedImage.width()).toLocal8Bit() + "w x " +
+ QString::number(myExpectedImage.width()).toLocal8Bit() + "h");
+ qDebug ("Actual size: " + QString::number(myResultImage.width()).toLocal8Bit() + "w x " +
+ QString::number(myResultImage.width()).toLocal8Bit() + "h");
if (mMatchTarget!= myPixelCount )
@@ -123,13 +151,19 @@
mReport += myImagesString;
return false;
+ // Now iterate through them counting how many
+ // dissimilar pixel values there are
mMismatchCount = 0;
for (int x = 0; x < myExpectedImage.width(); ++x)
for (int y = 0; y < myExpectedImage.height(); ++y)
QRgb myExpectedPixel = myExpectedImage.pixel(x,y);
- QRgb myActualPixel = myImage.pixel(x,y);
+ QRgb myActualPixel = myResultImage.pixel(x,y);
if (myExpectedPixel != myActualPixel)
++mMismatchCount;
@@ -141,14 +175,14 @@
//save the diff image to disk
myDifferenceImage.save (myResultDiffImage);
// Send match result to debug
qDebug (QString::number(mMismatchCount).toLocal8Bit() + "/" +
- " pixels mismatched");;
+ " pixels mismatched");;
// Send match result to report
@@ -158,7 +192,7 @@
" pixels mismatched";
if ( mMismatchCount==0 )
mReport += "<tr><td colspan = 3>\n";
Modified: trunk/qgis/tests/src/core/qgsrenderchecker.h
--- trunk/qgis/tests/src/core/qgsrenderchecker.h 2008-07-29 09:17:31 UTC (rev 8946)
+++ trunk/qgis/tests/src/core/qgsrenderchecker.h 2008-07-29 16:17:47 UTC (rev 8947)
@@ -44,16 +44,27 @@
int elapsedTime() { return mElapsedTime; };
void setElapsedTimeTarget(int theTarget) { mElapsedTimeTarget = theTarget; };
void setExpectedImage (QString theImageFileName) { mExpectedImageFile = theImageFileName; };
+ void setRenderedImage (QString theImageFileName) { mRenderedImageFile = theImageFileName; };
void setMapRenderer ( QgsMapRender * thepMapRenderer) { mpMapRenderer = thepMapRenderer; };
+ * Test using renderer to generate the image to be compared.
* @param theTestName - to be used as the basis for writing a file to
- * /tmp/theTestName.png
+ * e.g. /tmp/theTestName.png
+ * @note make sure to call setExpectedImage and setMapRenderer first
bool runTest( QString theTestName );
+ * Test using two arbitary images (map renderer will not be used)
+ * @param theTestName - to be used as the basis for writing a file to
+ * @note: make sure to call setExpectedImage and setRenderedImage first.
+ bool compareImages( QString theTestName );
private:
QString mReport;
QString mExpectedImageFile;
+ QString mRenderedImageFile;
unsigned int mMismatchCount;
unsigned int mMatchTarget;
int mElapsedTime;
Modified: trunk/qgis/tests/src/core/testqgsgeometry.cpp
--- trunk/qgis/tests/src/core/testqgsgeometry.cpp 2008-07-29 09:17:31 UTC (rev 8946)
+++ trunk/qgis/tests/src/core/testqgsgeometry.cpp 2008-07-29 16:17:47 UTC (rev 8947)
@@ -21,6 +21,10 @@
#include <QFileInfo>
#include <QDir>
#include <QDesktopServices>
+#include <QVector>
+#include <QPointF>
+#include <QImage>
+#include <QPainter>
#include <iostream>
//qgis includes...
@@ -28,6 +32,9 @@
#include <qgsgeometry.h>
#include <qgspoint.h>
+//qgs unit test utility class
+#include "qgsrenderchecker.h"
/** \ingroup UnitTests
* This is a unit test for the different geometry operations on vector features.
@@ -40,10 +47,16 @@
void init();// will be called before each testfunction is executed.
void cleanup();// will be called after every testfunction.
- void intersectionCheck();
+ void intersectionCheck1();
+ void intersectionCheck2();
void unionCheck1();
void unionCheck2();
+ void differenceCheck1();
+ void differenceCheck2();
+ void bufferCheck();
private:
+ /** A helper method to do a render check to see if the geometry op is as expected */
+ bool renderCheck(QString theTestName, QString theComment="");
/** A helper method to return wkb geometry type as a string */
QString wkbTypeAsString( QGis::WKBTYPE theType );
/** A helper method to dump to qdebug the geometry of a multipolygon */
@@ -73,6 +86,11 @@
QgsGeometry * mpPolygonGeometryC;
QString mTestDataDir;
+ QImage mImage;
+ QPainter * mpPainter;
+ QPen mPen1;
+ QPen mPen2;
+ QString mReport;
@@ -89,10 +107,10 @@
mPointB = QgsPoint(100.0,40.0);
mPointC = QgsPoint(100.0,100.0);
mPointD = QgsPoint(40.0,100.0);
- mPointW = QgsPoint(1000.0,1000.0);
- mPointX = QgsPoint(1040.0,1000.0);
- mPointY = QgsPoint(1040.0,1040.0);
- mPointZ = QgsPoint(1000.0,1040.0);
+ mPointW = QgsPoint(200.0,200.0);
+ mPointX = QgsPoint(240.0,200.0);
+ mPointY = QgsPoint(240.0,240.0);
+ mPointZ = QgsPoint(200.0,240.0);
mPolygonA.clear();
mPolygonB.clear();
@@ -115,6 +133,33 @@
mpPolygonGeometryB = QgsGeometry::fromPolygon(mPolygonB);
mpPolygonGeometryC = QgsGeometry::fromPolygon(mPolygonC);
+ mImage = QImage ( 250,250, QImage::Format_RGB32 );
+ mImage.fill ( qRgb( 152,219,249 ) );
+ mpPainter = new QPainter(&mImage);
+ // Draw the test shapes first
+ mPen1 = QPen();
+ mPen1.setWidth(5);
+ mPen1.setBrush(Qt::green);
+ mpPainter->setPen(mPen1);
+ dumpPolygon(mPolygonA);
+ mPen1.setBrush(Qt::red);
+ dumpPolygon(mPolygonB);
+ mPen1.setBrush(Qt::blue);
+ dumpPolygon(mPolygonC);
+ mPen2 = QPen();
+ mPen2.setWidth(1);
+ mPen2.setBrush(Qt::black);
+ QBrush myBrush(Qt::DiagCrossPattern);
+ //set the pen to a different colour -
+ //any test outs will be drawn in pen2
+ mpPainter->setPen(mPen2);
+ mpPainter->setBrush(myBrush);
void TestQgsGeometry::cleanup()
@@ -123,6 +168,7 @@
delete mpPolygonGeometryA;
delete mpPolygonGeometryB;
delete mpPolygonGeometryC;
+ delete mpPainter;
void TestQgsGeometry::initTestCase()
@@ -134,19 +180,47 @@
QString qgisPath = QCoreApplication::applicationDirPath ();
QgsApplication::setPrefixPath(INSTALL_PREFIX, true);
QgsApplication::showSettings();
+ mReport += "<h1>Geometry Tests</h1>\n";
+ mReport += "<p><font color=\"green\">Green = polygonA</font></p>\n";
+ mReport += "<p><font color=\"red\">Red = polygonB</font></p>\n";
+ mReport += "<p><font color=\"blue\">Blue = polygonC</font></p>\n";
void TestQgsGeometry::cleanupTestCase()
// Runs once after all tests are run
+ QString myReportFile = QDir::tempPath() + QDir::separator() + "geometrytest.html";
+ QFile myFile ( myReportFile);
+ if ( myFile.open ( QIODevice::WriteOnly ) )
+ QTextStream myQTextStream ( &myFile );
+ myQTextStream << mReport;
+ myFile.close();
+ QDesktopServices::openUrl("file://"+myReportFile);
-void TestQgsGeometry::intersectionCheck()
+void TestQgsGeometry::intersectionCheck1()
QVERIFY ( mpPolygonGeometryA->intersects(mpPolygonGeometryB));
+ // should be a single polygon as A intersect B
+ QgsGeometry * mypIntersectionGeometry = mpPolygonGeometryA->intersection(mpPolygonGeometryB);
+ qDebug ("Geometry Type: " + wkbTypeAsString(mypIntersectionGeometry->wkbType()).toLocal8Bit());
+ QVERIFY (mypIntersectionGeometry->wkbType() == QGis::WKBPolygon);
+ QgsPolygon myPolygon = mypIntersectionGeometry->asPolygon();
+ QVERIFY (myPolygon.size() > 0); //check that the union created a feature
+ dumpPolygon(myPolygon);
+ delete mypIntersectionGeometry;
+ QVERIFY(renderCheck("geometry_intersectionCheck1","Checking if A intersects B"));
+void TestQgsGeometry::intersectionCheck2()
QVERIFY ( !mpPolygonGeometryA->intersects(mpPolygonGeometryC));
@@ -159,7 +233,10 @@
QgsMultiPolygon myMultiPolygon = mypUnionGeometry->asMultiPolygon();
QVERIFY (myMultiPolygon.size() > 0); //check that the union did not fail
dumpMultiPolygon(myMultiPolygon);
+ delete mypUnionGeometry;
+ QVERIFY(renderCheck("geometry_unionCheck1","Checking A union C produces 2 polys"));
void TestQgsGeometry::unionCheck2()
@@ -170,8 +247,63 @@
+ QVERIFY(renderCheck("geometry_unionCheck2", "Checking A union B produces single union poly"));
+void TestQgsGeometry::differenceCheck1()
+ // should be same as A since A does not intersect C so diff is 100% of A
+ QgsGeometry * mypDifferenceGeometry = mpPolygonGeometryA->difference(mpPolygonGeometryC);
+ qDebug ("Geometry Type: " + wkbTypeAsString(mypDifferenceGeometry->wkbType()).toLocal8Bit());
+ QVERIFY (mypDifferenceGeometry->wkbType() == QGis::WKBPolygon);
+ QgsPolygon myPolygon = mypDifferenceGeometry->asPolygon();
+ QVERIFY (myPolygon.size() > 0); //check that the union did not fail
+ delete mypDifferenceGeometry;
+ QVERIFY(renderCheck("geometry_differenceCheck1","Checking (A - C) = A"));
+void TestQgsGeometry::differenceCheck2()
+ // should be a single polygon as (A - B) = subset of A
+ QgsGeometry * mypDifferenceGeometry = mpPolygonGeometryA->difference(mpPolygonGeometryB);
+ QVERIFY(renderCheck("geometry_differenceCheck2", "Checking (A - B) = subset of A"));
+void TestQgsGeometry::bufferCheck()
+ QgsGeometry * mypBufferGeometry = mpPolygonGeometryB->buffer(10,10);
+ qDebug ("Geometry Type: " + wkbTypeAsString(mypBufferGeometry->wkbType()).toLocal8Bit());
+ QVERIFY (mypBufferGeometry->wkbType() == QGis::WKBPolygon);
+ QgsPolygon myPolygon = mypBufferGeometry->asPolygon();
+ QVERIFY (myPolygon.size() > 0); //check that the buffer created a feature
+ delete mypBufferGeometry;
+ QVERIFY(renderCheck("geometry_bufferCheck", "Checking buffer(10,10) of B"));
+bool TestQgsGeometry::renderCheck(QString theTestName, QString theComment)
+ mReport += "<h2>" + theTestName + "</h2>\n";
+ mReport += "<h3>" + theComment + "</h3>\n";
+ QString myTmpDir = QDir::tempPath() + QDir::separator() ;
+ QString myFileName = myTmpDir + theTestName + ".png";
+ QString myDataDir (TEST_DATA_DIR); //defined in CmakeLists.txt
+ QString myTestDataDir = myDataDir + QDir::separator();
+ mImage.save(myFileName,"PNG");
+ QgsRenderChecker myChecker;
+ myChecker.setExpectedImage ( myTestDataDir + "expected_" + theTestName + ".png" );
+ myChecker.setRenderedImage ( myFileName );
+ bool myResultFlag = myChecker.compareImages(theTestName);
+ mReport += myChecker.report();
+ return myResultFlag;
void TestQgsGeometry::dumpMultiPolygon( QgsMultiPolygon &theMultiPolygon )
qDebug ("Multipolygon Geometry Dump");
@@ -185,6 +317,7 @@
void TestQgsGeometry::dumpPolygon( QgsPolygon &thePolygon )
+ QVector<QPointF> myPoints;
for ( int j = 0; j < thePolygon.size(); j++ )
QgsPolyline myPolyline = thePolygon.at( j ); //rings of polygon
@@ -194,8 +327,10 @@
QgsPoint myPoint = myPolyline.at( k );
qDebug( "\t\t\tPoint in ring " + QString::number( k ).toLocal8Bit() + " :" + myPoint.stringRep().toLocal8Bit() );
+ myPoints << QPointF(myPoint.x(),myPoint.y());
+ mpPainter->drawPolygon(myPoints);
QString TestQgsGeometry::wkbTypeAsString( QGis::WKBTYPE theType )
Added: trunk/qgis/tests/testdata/expected_geometry_bufferCheck.png
(Binary files differ)
Property changes on: trunk/qgis/tests/testdata/expected_geometry_bufferCheck.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/qgis/tests/testdata/expected_geometry_differenceCheck1.png
Property changes on: trunk/qgis/tests/testdata/expected_geometry_differenceCheck1.png
Added: trunk/qgis/tests/testdata/expected_geometry_differenceCheck2.png
Property changes on: trunk/qgis/tests/testdata/expected_geometry_differenceCheck2.png
Added: trunk/qgis/tests/testdata/expected_geometry_intersectionCheck1.png
Property changes on: trunk/qgis/tests/testdata/expected_geometry_intersectionCheck1.png
Added: trunk/qgis/tests/testdata/expected_geometry_unionCheck1.png
Property changes on: trunk/qgis/tests/testdata/expected_geometry_unionCheck1.png
Added: trunk/qgis/tests/testdata/expected_geometry_unionCheck2.png
Property changes on: trunk/qgis/tests/testdata/expected_geometry_unionCheck2.png
