[QGIS Commit] r8572 - trunk/qgis/debian
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Jun 1 08:10:56 EDT 2008
Author: jef
Date: 2008-06-01 08:10:56 -0400 (Sun, 01 Jun 2008)
New Revision: 8572
   trunk/qgis/debian/changelog
   trunk/qgis/debian/control
   trunk/qgis/debian/libqgis-core0.11.install
   trunk/qgis/debian/libqgis-gui0.11.install
   trunk/qgis/debian/libqgis1-dev.install
   trunk/qgis/debian/libqgisgrass0.11.install
   trunk/qgis/debian/libqgispython0.11.install
updates debian packaging
Modified: trunk/qgis/debian/changelog
--- trunk/qgis/debian/changelog	2008-06-01 10:21:43 UTC (rev 8571)
+++ trunk/qgis/debian/changelog	2008-06-01 12:10:56 UTC (rev 8572)
@@ -1,5 +1,17 @@
+qgis (0.11.0test2) experimental; urgency=low
+  * removed 'upstream' changes from changelog
+  * policy update 3.7.2 to 3.7.3
+  * python support: renamed qgis-python-plugin to python-qgis, moved to python
+    section, added Python:Provides
+  * replaced QGIS with Quantum GIS in descriptions
+  * moved so symlinks to dev package
+ -- Jürgen E. Fischer <jef at norbit.de>  Sun, 01 Jun 2008 13:45:39 +0200
 qgis (0.11.0test1) experimental; urgency=low
+  * prepackaging of Quantum GIS 0.11.0 'Mantis'
   * raised abi from 0.10 to 0.11
   * separate packages for python support
   * raised dependency from python-qt4* from 4.0.0 to 4.1.0
@@ -9,7 +21,7 @@
 qgis (0.10.0-2) gutsy; urgency=low
-  * fix libgdal1 grass depenency for ubuntu gutsy/hardy (1.4.0 | 1.5.0)
+  * fix libgdal1 grass dependency for ubuntu gutsy/hardy (1.4.0 | 1.5.0)
  -- Jürgen E. Fischer <jef at norbit.de>  Wed, 30 Apr 2008 22:35:42 +0200
@@ -26,34 +38,7 @@
 qgis (0.10.0) gutsy; urgency=low
-  * This release includes over 120 bug fixes and enchancements
-  * over the QGIS 0.9.1 release. In addition we have added
-  * the following new features:
-  * Improvements to digitising capabilities.
-  * Supporting default and defined styles (.qml) files for file based
-  * vector layers. With styles you can save the symbolisation
-  * and other settings associated with a vector layer and they
-  * will be loaded whenever you load that layer.
-  * Improved support for transparency and contrast stretching
-  * in raster layers. Support for color ramps in raster layers.
-  * Support for non-north up rasters. Many other raster
-  * improvements 'under the hood'.
-  * Updated icons for improved visual consistancy.
-  * Support for migration of old projects to work in newer QGIS versions.
+  * Quantum GIS 0.10.0 'Io' upstream release
  -- Jürgen E. Fischer <jef at norbit.de>  Fri, 18 Apr 2008 00:51:58 +0200
@@ -65,30 +50,13 @@
 qgis (0.9.2rc1) gutsy; urgency=low
-  * This release candidate includes over 40 bug fixes and enchancements
-  * Imrovements to digitising capabilities.
+  * new upstream release
  -- Tim Sutton <tim at linfiniti.com>  Mon, 28 Jan 2008 23:00:41 -0200
 qgis (0.9.1) gutsy; urgency=low
-  * This is a bug fix release
-  * 70 Bugs closed
-  * Added locale tab to options dialog so that locale can be overridden
-  * Cleanups and additions to GRASS tools
-  * Documentation updates
-  * Improvements for building under MSVC
-  * Progress indicators for WFS and WCS
  -- Tim Sutton <tim at linfiniti.com>  Fri, 07 Dec 2007 01:36:55 -0200
Modified: trunk/qgis/debian/control
--- trunk/qgis/debian/control	2008-06-01 10:21:43 UTC (rev 8571)
+++ trunk/qgis/debian/control	2008-06-01 12:10:56 UTC (rev 8572)
@@ -9,35 +9,31 @@
  libqt4-qt3support (>=4.2.0), libqt4-sql (>=4.2.0), python-qt4 (>=4.1.0), python-qt4-dev (>=4.1.0),
  python-sip4-dev (>= 4.5.0), libfontconfig1-dev, libxi-dev, libxrandr-dev, libxrender-dev, libice-dev,
  libsm-dev
-Standards-Version: 3.7.2
+Standards-Version: 3.7.3
 XS-Python-Version: current
 Homepage: http://qgis.org/
 Package: qgis
 Architecture: any
 Depends: ${shlibs:Depends}, ${misc:Depends}
-Suggests: qgis-plugin-grass, qgis-python-plugin
+Suggests: qgis-plugin-grass, python-qgis
 Description: Geographic Information System (GIS)
- A Geographic Information System (GIS) manages,
- analyzes, and displays databases of geographic
- information. Quantum GIS (QGIS) supports shapefile
- viewing and editing, spatial data storage with
- PostgreSQL/PostGIS, projection on-the-fly, map
- composition, and a number of other features via
- a plugin interface. QGIS also supports display
- of various georeferenced raster and Digital
- Elevation Model (DEM) formats including
- GeoTIFF, Arc/Info ASCII Grid, and USGS ASCII DEM.
+ A Geographic Information System (GIS) manages, analyzes, and displays
+ databases of geographic information. Quantum GIS (QGIS) supports shapefile
+ viewing and editing, spatial data storage with PostgreSQL/PostGIS, projection
+ on-the-fly, map composition, and a number of other features via a plugin
+ interface. QGIS also supports display of various georeferenced raster and
+ Digital Elevation Model (DEM) formats including GeoTIFF, Arc/Info ASCII Grid,
+ and USGS ASCII DEM.
 Package: libqgis-core0.11
 Architecture: any
 Replaces: qgis (<=0.9.2rc1)
 Conflicts: libqgis1
-Description: QGIS Geographic Information System - shared core library
- QGIS is a Geographic Information System (GIS)
- which manages, analyzes and display databases of
- geographic information.
+Description: Quantum GIS - shared core library
+ Quantum GIS is a Geographic Information System (GIS) which manages, analyzes
+ and display databases of geographic information.
  This package contains the shared core library that
  provides an interface for plugins.
@@ -47,54 +43,58 @@
 Conflicts: libqgis1
-Description: QGIS Geographic Information System - shared gui library
+Description: Quantum GIS - shared gui library
- This package contains the shared gui library that
- provides an interface for plugins.
+ This package contains the shared gui library that provides an interface for
+ plugins.
 Package: libqgis1-dev
 Architecture: any
 Section: libdevel
-Depends: qgis (= ${binary:Version}), libgdal1-dev | libgdal1-1.3.2-dev , libpq-dev | postgresql-dev, libgeos-dev (>= 2.0.1-1), grass-dev, libsqlite3-dev, libgsl0-dev, proj, libexpat1-dev, libqt4-core (>=4.2.0), libqt4-dev (>=4.2.0), libqt4-gui (>=4.2.0), libqt4-qt3support (>=4.2.0), libqt4-sql (>=4.2.0), python-qt4 (>=4.1.0), python-qt4-dev (>=4.1.0), qt4-designer (>=4.2.0)
+Depends: qgis (= ${binary:Version}), libgdal1-dev | libgdal1-1.3.2-dev,
+ libpq-dev | postgresql-dev, libgeos-dev (>= 2.0.1-1), grass-dev,
+ libsqlite3-dev, libgsl0-dev, proj, libexpat1-dev, libqt4-core (>=4.2.0),
+ libqt4-dev (>=4.2.0), libqt4-gui (>=4.2.0), libqt4-qt3support (>=4.2.0),
+ libqt4-sql (>=4.2.0), python-qt4 (>=4.1.0), python-qt4-dev (>=4.1.0),
+ qt4-designer (>=4.2.0), libqgispython0.11, libqgisgrass0.11, libqgis-gui0.11,
+ libqgis-core0.11
 Provides: libqgis-dev
 Conflicts: libqgis-dev, qgis-dev
 Replaces: qgis-dev
-Description: QGIS Geographic Information System - development files
+Description: Quantum GIS - development files
- This package contains the headers and libraries
- needed to develop plugins for QGIS.
+ This package contains the headers and libraries needed to develop plugins for
+ Quantum GIS.
 Package: qgis-plugin-grass
 Architecture: any
 Depends: qgis (= ${binary:Version}), ${shlibs:Depends}, ${misc:Depends}, libgdal1-1.4.0-grass | libgdal1-1.5.0-grass
-Description: Plugin for accessing GRASS data from QGIS
- This plugin enables a GRASS data access toolbox in the QGIS
- geographic data viewer.
+Description: Plugin for accessing GRASS data from Quantum GIS
+ This plugin enables a GRASS data access toolbox in the Quantum GIS geographic
+ data viewer.
 Package: libqgisgrass0.11
 Architecture: any
-Description: QGIS Geographic Information System - shared grass library
+Description: Quantum GIS - shared grass library
  This package contains the shared library for the grass plugin.
-Package: qgis-python-support
+Package: python-qgis
+Section: python
 Architecture: any
 Depends: libqgispython0.11, ${shlibs:Depends}, ${misc:Depends}
+Provides: ${python:Provides}
 XB-Python-Version: ${python:Versions}
-Description: QGIS Geographic Information System - python support
+Description: Python bindings to Quantum GIS
  This package contains the files for the Python support.
@@ -102,9 +102,8 @@
 Architecture: any
-Description: QGIS Geographic Information System - shared python library
+Description: Quantum GIS - shared Python library
  This package contains the shared library for the Python support.
Modified: trunk/qgis/debian/libqgis-core0.11.install
--- trunk/qgis/debian/libqgis-core0.11.install	2008-06-01 10:21:43 UTC (rev 8571)
+++ trunk/qgis/debian/libqgis-core0.11.install	2008-06-01 12:10:56 UTC (rev 8572)
@@ -1 +1 @@
-usr/lib/libqgis_core.so*
+usr/lib/libqgis_core.so.*
Modified: trunk/qgis/debian/libqgis-gui0.11.install
--- trunk/qgis/debian/libqgis-gui0.11.install	2008-06-01 10:21:43 UTC (rev 8571)
+++ trunk/qgis/debian/libqgis-gui0.11.install	2008-06-01 12:10:56 UTC (rev 8572)
@@ -1 +1 @@
-usr/lib/libqgis_gui.so*
+usr/lib/libqgis_gui.so.*
Modified: trunk/qgis/debian/libqgis1-dev.install
--- trunk/qgis/debian/libqgis1-dev.install	2008-06-01 10:21:43 UTC (rev 8571)
+++ trunk/qgis/debian/libqgis1-dev.install	2008-06-01 12:10:56 UTC (rev 8572)
@@ -1 +1,5 @@
 usr/include/qgis/*
+usr/lib/libqgispython.so
+usr/lib/libqgisgrass.so
Modified: trunk/qgis/debian/libqgisgrass0.11.install
--- trunk/qgis/debian/libqgisgrass0.11.install	2008-06-01 10:21:43 UTC (rev 8571)
+++ trunk/qgis/debian/libqgisgrass0.11.install	2008-06-01 12:10:56 UTC (rev 8572)
@@ -1,2 +1 @@
-usr/lib/libqgisgrass.so
 usr/lib/libqgisgrass.so.*
Modified: trunk/qgis/debian/libqgispython0.11.install
--- trunk/qgis/debian/libqgispython0.11.install	2008-06-01 10:21:43 UTC (rev 8571)
+++ trunk/qgis/debian/libqgispython0.11.install	2008-06-01 12:10:56 UTC (rev 8572)
@@ -1 +1 @@
-usr/lib/libqgispython.so*
+usr/lib/libqgispython.so.*
More information about the QGIS-commit mailing list
