[QGIS Commit] r8604 - trunk/qgis/src/mac/Contents
svn_qgis at osgeo.org
Fri Jun 6 11:46:26 EDT 2008
Author: telwertowski
Date: 2008-06-06 11:46:26 -0400 (Fri, 06 Jun 2008)
New Revision: 8604
trunk/qgis/src/mac/Contents/CMakeLists.txt
trunk/qgis/src/mac/Contents/Info.plist.cmake
Get svn revison number for Mac Info.plist from top-level source directory rather then current source directory.
Modified: trunk/qgis/src/mac/Contents/CMakeLists.txt
--- trunk/qgis/src/mac/Contents/CMakeLists.txt 2008-06-06 13:29:03 UTC (rev 8603)
+++ trunk/qgis/src/mac/Contents/CMakeLists.txt 2008-06-06 15:46:26 UTC (rev 8604)
@@ -6,6 +6,7 @@
DEPENDS ${SVN_MARKER}
COMMAND ${CMAKE_COMMAND}
-D CURRENT_SOURCE_DIR=${CMAKE_CURRENT_SOURCE_DIR}
+ -D SOURCE_DIR=${CMAKE_SOURCE_DIR}
-D VERSION=${COMPLETE_VERSION}-${RELEASE_NAME}
-P ${CMAKE_CURRENT_SOURCE_DIR}/Info.plist.cmake)
Modified: trunk/qgis/src/mac/Contents/Info.plist.cmake
--- trunk/qgis/src/mac/Contents/Info.plist.cmake 2008-06-06 13:29:03 UTC (rev 8603)
+++ trunk/qgis/src/mac/Contents/Info.plist.cmake 2008-06-06 15:46:26 UTC (rev 8604)
@@ -5,7 +5,7 @@
# Read the revision if installed, else set to "unknown"
IF (SVNVERSION)
- EXEC_PROGRAM (${SVNVERSION} ARGS ${CURRENT_SOURCE_DIR} OUTPUT_VARIABLE REVISION)
+ EXEC_PROGRAM (${SVNVERSION} ARGS ${SOURCE_DIR} OUTPUT_VARIABLE REVISION)
ELSE (SVNVERSION)
SET (REVISION unknown)
ENDIF (SVNVERSION)
