[QGIS Commit] r8613 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Sat Jun 7 19:48:30 EDT 2008
Author: taraathan
Date: 2008-06-07 19:48:30 -0400 (Sat, 07 Jun 2008)
New Revision: 8613
docs/trunk/english_us/user_guide/conventions.tex
modified existing macros to avoid tex primitives
added macros for radio buttons, selection fields, browse button, sliders and input fields
requires packages: amsmath and amssymb
move the macros for fonts styles to beginning
added macro \guilabel for the gui font
corrected name of grass module image
Modified: docs/trunk/english_us/user_guide/conventions.tex
--- docs/trunk/english_us/user_guide/conventions.tex 2008-06-07 04:01:29 UTC (rev 8612)
+++ docs/trunk/english_us/user_guide/conventions.tex 2008-06-07 23:48:30 UTC (rev 8613)
@@ -2,117 +2,181 @@
% options for boxes provided by fancybox package are:
% \fbox, \shadowbox, \doublebox, \ovalbox and \Ovalbox
+%%%%%%%%%%%%%%%%8%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
+\renewcommand{\usertext}[1]{\texttt{#1}}
+\renewcommand{\classname}[1]{\textsf{\textbf{#1}}}
+\renewcommand{\fieldname}[1]{\textsl{#1}}
+\renewcommand{\filename}[1]{\texttt{#1}}
+\renewcommand{\keystroke}[1]{\cornersize{.6}\ovalbox{\textsf{#1}}}
+\renewcommand{\method}[1]{\textsf{\textit{#1}}}
+\renewcommand{\server}[1]{\textit{#1}}
+\renewcommand{\sqltable}[1]{\textsf{\textbf{#1}}}
+\newcommand{\guilabel}[1]{\textsf{#1}}
\setlength{\shadowsize}{2pt}%
\newcommand{\nix}[1]{Under GNU/Linix, #1}
\newcommand{\win}[1]{Under MS Windows, #1}
\newcommand{\osx}[1]{Under Mac OS X, #1}
% button
\renewcommand{\button}[1]{%
-\lower4pt\hbox{%
-\shadowbox{\textsf{#1}}
+\raisebox{-6pt}{%
+\shadowbox{\guilabel{#1}}
% mainmenuopt
\newcommand{\mainmenuopt}[1]{%
-\mbox{}%
-\lower6pt\hbox{%
+\raisebox{-6pt}{%
\setlength{\fboxsep}{0pt}%
\shadowbox{\setlength{\fboxsep}{2pt}%
\fcolorbox[gray]{0.9}[gray]{0.9}%
-{\textsf{#1}}%
+{\guilabel{#1}}%
% dropmenuopt
\newcommand{\dropmenuopt}[1]{%
-\mbox{}%
-\lower6pt\hbox{%
+\raisebox{-6pt}{{%
\fcolorbox[rgb]{.95,.95,0.8}[rgb]{.95,.95,0.8}%
-{ \textsf{#1}}}%
+{ \guilabel{#1}}}%
+% dropmenucheck
+\newcommand{\dropmenucheck}[1]{%
+\raisebox{-6pt}{{%
+\setlength{\fboxsep}{0pt}%
+\shadowbox{\setlength{\fboxsep}{2pt}%
+\fcolorbox[rgb]{.95,.95,0.8}[rgb]{.95,.95,0.8}%
+{ $\boxtimes$ \guilabel{#1}}}%
% dropmenuopttwo
\newcommand{\dropmenuopttwo}[2]{%
-\mbox{}%
-\lower6pt\hbox{%
+\raisebox{-6pt}{%
-{\includegraphics[width=3mm]{#1} \textsf{#2}}}%
+{\includegraphics[width=3mm]{#1} \guilabel{#2}}}%
% tooltip
\newcommand{\tooltip}[1]{%
-\mbox{}%
-\raise2pt\hbox{%
-\fcolorbox{black}[rgb]{1,1,0.8}{\textsf{#1}}%
+\raisebox{-2pt}{%
+\fcolorbox{black}[rgb]{1,1,0.8}{\guilabel{#1}}%
% toolbtntwo
\newcommand{\toolbtntwo}[2]{%
-\mbox{}%
-\lower6pt\hbox{%
+\raisebox{-6pt}{%
\shadowbox{\includegraphics[width=7mm]{#1}}} %
\tooltip{#2}%
% toolboxtwo
\newcommand{\toolboxtwo}[2]{%
-\mbox{}%
-\lower6pt\hbox{%
+\raisebox{-6pt}{%
\shadowbox{%
-\includegraphics[width=5mm]{#1} #2%
+\includegraphics[width=5mm]{#1} \guilabel{#2}%
% toolboxthree
\newcommand{\toolboxthree}[3]{%
-\mbox{}%
-\lower6pt\hbox{%
+\raisebox{-6pt}{%
\shadowbox{%
\includegraphics[width=5mm]{#1}%
\includegraphics[width=5mm]{#2}%
- #3%
+ \guilabel{#3}%
% toolboxfour
\newcommand{\toolboxfour}[4]{%
-\mbox{}%
-\lower6pt\hbox{%
+\raisebox{-6pt}{%
\shadowbox{%
\includegraphics[width=5mm]{#3}%
- #4%
+ \guilabel{#4}%
%for backward compatibility!
\newcommand{\toolbox}[2]{%
\toolboxtwo{#1}{#2}%
% tab
\newcommand{\tab}[1]{%
-\lower4pt\hbox{%
+\raisebox{-6pt}{%
% checkbox
\newcommand{\checkbox}[1]{%
-%\mbox{}%
-\raise2pt\hbox{%
+\raisebox{2pt}{%
\fbox{%
-\mbox{}%
-\lower4pt\hbox{%
+\raisebox{-4pt}{%
\shadowbox{x}} %
-\textsf{#1}}%
+\guilabel{#1}}%
-\renewcommand{\usertext}[1]{\texttt{#1}}
-\renewcommand{\classname}[1]{\textsf{\textbf{#1}}}
-\renewcommand{\fieldname}[1]{\textsl{#1}}
-\renewcommand{\filename}[1]{\texttt{#1}}
-\renewcommand{\keystroke}[1]{\cornersize{.6}\ovalbox{\textsf{#1}}}
-\renewcommand{\method}[1]{\textsf{\textit{#1}}}
-\renewcommand{\server}[1]{\textit{#1}}
-\renewcommand{\sqltable}[1]{\textsf{\textbf{#1}}}
+% radiobuttonoff
+\newcommand{\radiobuttonoff}[1]{%
+\raisebox{-4pt}{%
+\setlength{\fboxsep}{1pt}%
+\shadowbox{%
+$\bigcirc$%
+\guilabel{#1}%
+% radiobuttonon
+\newcommand{\radiobuttonon}[1]{%
+$\odot$ %
+\guilabel{#1}%
+% selectnumber
+\newcommand{\selectnumber}[2]{%
+\fbox{%
+{#1} \fbox{{#2} %
+\raisebox{-6pt}{%
+\shadowbox{%
+${\blacktriangle}\atop{\blacktriangledown}$%
+% selectstring
+\newcommand{\selectstring}[2]{%
+\fbox{%
+\guilabel{#1} \fbox{\guilabel{#2} %
+\raisebox{-2pt}{%
+\shadowbox{%
+$\blacktriangledown$%
+% browsebutton
+\newcommand{\browsebutton}{%
+\raisebox{-6pt}{%
+\shadowbox{\rule[-1mm]{0mm}{4mm}{$\ldots$}}
+% selectcolor
+\newcommand{\selectcolor}[2]{%
+\fbox{\guilabel{#1} %
+\raisebox{-6pt}{%
+\fcolorbox{#2}{#2}{\rule{0mm}{5mm}\rule{35mm}{0mm}%
+% slider
+\newcommand{\slider}[3]{%
+\fbox{%
+\guilabel{#1} \guilabel{#2}\% %
+\raisebox{-2pt}{%
+\shadowbox{%
+$\triangledown$%
+\negthinspace\rule[1mm]{20mm}{1mm}
+% input text
+\newcommand{\inputtext}[2]{%
+\fbox{%
+\guilabel{#1} %
+\raisebox{-6pt}{%
+\shadowbox{\usertext{#2}}%
\subsection{Conventions}\label{label_conventions}
The conventions used in this manual are as follows.
@@ -122,11 +186,16 @@
%Use \mainmenuopt for main menu items that have no icon only text
%Main Menu includes: File, View, Layer, Settings, Plugins, Help
-\item Menu Option: \mainmenuopt{Layer} > %
+\item Menu Options: \mainmenuopt{Layer} > %
%Use \dropmenuopttwo for a drop-down menu item with an icon
%Use \dropmenuoptone for a drop-down menu item with no icon
-\dropmenuopttwo{addraster}{Add a Raster Layer}
+\dropmenuopttwo{addraster}{Add a Raster Layer}
+or
+\mainmenuopt{View} > %
+\dropmenuopt{Toolbar Visibility} > \dropmenucheck{Digitizing}
%Use \toolbtntwo for the toolbar items, including those that open dialogs
%These have an icon, and display a tooltip on hover
@@ -149,10 +218,33 @@
%The one you need depends on how many icons are required
%The number part of the name is the total number of arguments (N)
%The number of icons is (N-1)
-\item Toolbox Item: \toolboxtwo{add_grass_vector}{nviz - Open 3D-View in NVIZ}
+\item Toolbox Item: \toolboxtwo{nviz.1}{nviz - Open 3D-View in NVIZ}
-%Use checkbox for a checkbox item in a dialog popup
+%Use \checkbox for a checkbox item in a dialog popup
\item Checkbox: \checkbox{Render}
+%Use \radiobuttonoff for a radio button item in a dialog popup
+\item Radio Button: \radiobuttonon{Postgis SRID} \radiobuttonoff{EPSG ID}
+% Use \selectnumber for a selection box with up and down arrows
+% and a numerical value
+\item Select a Number: \selectnumber{Hue}{60}
+% Use \selectstring for a selection box with down arrows
+% and a string value
+\item Select a String: \selectstring{Outline style}{---Solid Line}
+% Use \browsebutton for a button that opens a file browser popup
+\item Browse for a File: \browsebutton
+% Use \selectcolor for a button which opens a color selector popup
+\item Select a Color: \selectcolor{Outline color}{yellow}
+\item Slider: \slider{Transparency}{0}{20mm}
+% Use \inputtext for a labelled field for user input of text
+\item Input Text: \inputtext{Display Name}{lakes.shp}
\end{itemize}
A shadow indicates a clickable GUI component.
