[QGIS Commit] r8628 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sun Jun 8 21:35:47 EDT 2008
Author: telwertowski
Date: 2008-06-08 21:35:46 -0400 (Sun, 08 Jun 2008)
New Revision: 8628
trunk/qgis/src/app/qgsserversourceselect.cpp
Additional conversion from Q3ListView to QTreeWidget. This is an addition to r8406 and fixes #1074.
For Q3ListView, each item is already set to the new selection state when on_lstLayers_selectionChanged is called. For QTreeWidget, each item still has the old selection state and selectedItems() must be used to get the new selection state.
Modified: trunk/qgis/src/app/qgsserversourceselect.cpp
--- trunk/qgis/src/app/qgsserversourceselect.cpp 2008-06-08 18:10:57 UTC (rev 8627)
+++ trunk/qgis/src/app/qgsserversourceselect.cpp 2008-06-09 01:35:46 UTC (rev 8628)
@@ -517,60 +517,47 @@
void QgsServerSourceSelect::on_lstLayers_itemSelectionChanged()
- QString layerName = "";
QStringList newSelectedLayers;
QStringList newSelectedStylesForSelectedLayers;
std::map<QString, QString> newSelectedStyleIdForLayer;
// Iterate through the layers
- QTreeWidgetItemIterator it( lstLayers );
- while ( *it )
+ QList<QTreeWidgetItem *> selected( lstLayers->selectedItems() );
+ QList<QTreeWidgetItem *>::iterator it;
+ for (it = selected.begin(); it != selected.end(); ++it)
QTreeWidgetItem *item = *it;
+ QString layerName;
- // save the name of the layer (in case only one of its styles was
- // selected)
- if (item->parent() == 0)
+ if (item->parent() != 0)
+ layerName = item->parent()->text(1);
+ newSelectedStylesForSelectedLayers += item->text(1);
+ else
layerName = item->text(1);
+ newSelectedStylesForSelectedLayers += "";
- if ( item->isSelected() )
+ newSelectedLayers += layerName;
+ newSelectedStyleIdForLayer[layerName] = item->text(0);
+ // Check if multiple styles have now been selected
+ if (
+ (!(m_selectedStyleIdForLayer[layerName].isNull())) && // not just isEmpty()
+ (newSelectedStyleIdForLayer[layerName] != m_selectedStyleIdForLayer[layerName])
- newSelectedLayers += layerName;
+ // Remove old style selection
+ lstLayers->findItems(m_selectedStyleIdForLayer[layerName], Qt::MatchRecursive).first()->setSelected(false);
- // save the name of the style selected for the layer, if appropriate
- if (item->parent() != 0)
- newSelectedStylesForSelectedLayers += item->text(1);
- else
- newSelectedStylesForSelectedLayers += "";
- newSelectedStyleIdForLayer[layerName] = item->text(0);
- // Check if multiple styles have now been selected
- if (
- (!(m_selectedStyleIdForLayer[layerName].isNull())) && // not just isEmpty()
- (newSelectedStyleIdForLayer[layerName] != m_selectedStyleIdForLayer[layerName])
- // Remove old style selection
- lstLayers->findItems(m_selectedStyleIdForLayer[layerName], 0).first()->setSelected(FALSE);
#ifdef QGISDEBUG
std::cout << "QgsServerSourceSelect::addLayers: Added " << item->text(0).toLocal8Bit().data() << std::endl;
#endif
- ++it;
// If we got some selected items, let the user play with projections
