[QGIS Commit] r8654 - in trunk/qgis/src: app core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jun 18 06:37:19 EDT 2008
Author: jef
Date: 2008-06-18 06:37:19 -0400 (Wed, 18 Jun 2008)
New Revision: 8654
   trunk/qgis/src/app/qgsdbsourceselect.cpp
   trunk/qgis/src/core/qgsvectorlayer.cpp
revert r8586 and solve issue in QgsVectorLayer (fixes #1126)
Modified: trunk/qgis/src/app/qgsdbsourceselect.cpp
--- trunk/qgis/src/app/qgsdbsourceselect.cpp	2008-06-18 07:49:58 UTC (rev 8653)
+++ trunk/qgis/src/app/qgsdbsourceselect.cpp	2008-06-18 10:37:19 UTC (rev 8654)
@@ -249,14 +249,6 @@
   m_selectedTables.clear();
-  QString currentSchema;
-  QString sql = "select current_schema()";
-  PGresult *result = PQexec(pd, sql.toUtf8());
-  if (result && PQresultStatus(result)==PGRES_TUPLES_OK && PQntuples(result)==1 )
-    currentSchema = QString::fromUtf8(PQgetvalue(result, 0, 0));
   typedef QMap<int, QVector<QString> > schemaInfo;
   QMap<QString, schemaInfo> dbInfo;
@@ -292,7 +284,7 @@
   //now traverse all the schemas and table infos
-  QString schemaName, tableName, geomColumnName;
+  QString schemaName, tableName, geomColumnName, sql;
   QString query;
   QMap<QString, schemaInfo>::const_iterator schema_it = dbInfo.constBegin();
@@ -335,13 +327,8 @@
-      if(schemaName!=currentSchema)
-	 query += "\"" + schemaName + "\".";
+      query += "\"" + schemaName + "\".\"" + tableName + "\" " + "(" + geomColumnName + ") sql=" + sql;
-      query += "\"" + tableName + "\" " + "(" + geomColumnName + ") sql=" + sql;
       m_selectedTables.push_back(query);
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2008-06-18 07:49:58 UTC (rev 8653)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2008-06-18 10:37:19 UTC (rev 8654)
@@ -2224,6 +2224,9 @@
           lName = name();
         setLayerName(lName);
         QgsDebugMsg("Beautifying layer name " + name());
+        // deal with unnecessary schema qualification to make v.in.ogr happy
+        mDataSource = mDataProvider->dataSourceUri();
       // label
More information about the QGIS-commit mailing list
