[QGIS Commit] r8665 - in trunk/qgis: python/gui src/app src/gui
svn_qgis at osgeo.org
Sat Jun 21 11:34:02 EDT 2008
Author: jef
Date: 2008-06-21 11:34:01 -0400 (Sat, 21 Jun 2008)
New Revision: 8665
trunk/qgis/python/gui/qgsmapcanvas.sip
trunk/qgis/python/gui/qgsmaptool.sip
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/gui/qgsmapcanvas.cpp
trunk/qgis/src/gui/qgsmapcanvas.h
trunk/qgis/src/gui/qgsmaptool.h
update sip binding after r8656:
replaces QgsMapCanvas::restoreMapTool(), which shouldn't be public, with a
signal and handles it in QgisApp.
Modified: trunk/qgis/python/gui/qgsmapcanvas.sip
--- trunk/qgis/python/gui/qgsmapcanvas.sip 2008-06-21 10:07:01 UTC (rev 8664)
+++ trunk/qgis/python/gui/qgsmapcanvas.sip 2008-06-21 15:34:01 UTC (rev 8665)
@@ -211,7 +211,7 @@
//! called to write map canvas settings to project
void writeProject(QDomDocument &);
-signals:
+ signals:
/** Let the owner know how far we are with render operations */
void setProgress(int,int);
/** emits current mouse position */
@@ -242,8 +242,10 @@
//! Emit key release event
void keyReleased(QKeyEvent * e);
+ //! Emit map tool changed event
+ void mapToolSet(QgsMapTool *tool);
-protected:
+ protected:
//! Overridden key press event
void keyPressEvent(QKeyEvent * e);
Modified: trunk/qgis/python/gui/qgsmaptool.sip
--- trunk/qgis/python/gui/qgsmaptool.sip 2008-06-21 10:07:01 UTC (rev 8664)
+++ trunk/qgis/python/gui/qgsmaptool.sip 2008-06-21 15:34:01 UTC (rev 8665)
@@ -58,6 +58,11 @@
* If it does, we will be able to perform the zoom and then
* resume operations with the original / previously used tool.*/
virtual bool isZoomTool();
+ /** Check whether this MapTool performs an edit operation.
+ * If it does, we will deactivate it when editing is turned off
+ virtual bool isEditTool();
//! called when set as currently active map tool
virtual void activate();
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2008-06-21 10:07:01 UTC (rev 8664)
+++ trunk/qgis/src/app/qgisapp.cpp 2008-06-21 15:34:01 UTC (rev 8665)
@@ -1356,6 +1356,9 @@
connect(mMapCanvas, SIGNAL(scaleChanged(double)), this, SLOT(showScale(double)));
connect(mMapCanvas, SIGNAL(scaleChanged(double)), this, SLOT(updateMouseCoordinatePrecision()));
+ mNonEditMapTool=NULL;
+ connect(mMapCanvas, SIGNAL(mapToolSet(QgsMapTool *)), this, SLOT(mapToolChanged(QgsMapTool *)));
connect(mRenderSuppressionCBox, SIGNAL(toggled(bool )), mMapCanvas, SLOT(setRenderFlag(bool)));
// Do we really need this ??? - its already connected to the esc key...TS
@@ -4677,6 +4680,14 @@
+void QgisApp::mapToolChanged(QgsMapTool *tool)
+ if( tool && !tool->isEditTool() )
+ mNonEditMapTool = tool;
void QgisApp::showExtents()
// update the statusbar with the current extents.
@@ -4847,8 +4858,6 @@
return;
- mMapCanvas->restoreMapTool();
mActionToggleEditing->setEnabled(true);
mActionRemoveLayer->setEnabled(true);
mActionInOverview->setEnabled(true);
@@ -4864,6 +4873,11 @@
const QgsVectorLayer* vlayer = dynamic_cast<const QgsVectorLayer*>(layer);
const QgsVectorDataProvider* dprovider = vlayer->getDataProvider();
+ if( !vlayer->isEditable() && mMapCanvas->mapTool() && mMapCanvas->mapTool()->isEditTool() )
+ mMapCanvas->setMapTool(mNonEditMapTool);
if (dprovider)
//start editing/stop editing
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2008-06-21 10:07:01 UTC (rev 8664)
+++ trunk/qgis/src/app/qgisapp.h 2008-06-21 15:34:01 UTC (rev 8665)
@@ -318,6 +318,9 @@
//! starts/stops editing mode of the current layer
void toggleEditing();
+ //! map tool changed
+ void mapToolChanged(QgsMapTool *tool);
/** Activates or deactivates actions depending on the current maplayer type.
Is called from the legend when the current legend item has changed*/
void activateDeactivateLayerRelatedActions(QgsMapLayer* layer);
@@ -583,6 +586,8 @@
QgsMapTool* mAddRing;
QgsMapTool* mAddIsland;
} mMapTools;
+ QgsMapTool *mNonEditMapTool;
//!The name of the active theme
QString mThemeName;
Modified: trunk/qgis/src/gui/qgsmapcanvas.cpp
--- trunk/qgis/src/gui/qgsmapcanvas.cpp 2008-06-21 10:07:01 UTC (rev 8664)
+++ trunk/qgis/src/gui/qgsmapcanvas.cpp 2008-06-21 15:34:01 UTC (rev 8665)
@@ -87,7 +87,6 @@
mMapOverview = NULL;
mMapTool = NULL;
mLastNonZoomMapTool = NULL;
- mNonEditMapTool = NULL;
mDrawing = false;
mFrozen = false;
@@ -966,32 +965,16 @@
if (mMapTool)
mMapTool->activate();
+ emit mapToolSet(mMapTool);
} // setMapTool
-void QgsMapCanvas::restoreMapTool()
- if( !mMapTool )
- return;
- if( !mMapTool->isEditTool() )
- mNonEditMapTool = mMapTool;
- return;
- if ( mCurrentLayer && !mCurrentLayer->isEditable() )
- setMapTool(mNonEditMapTool);
void QgsMapCanvas::unsetMapTool(QgsMapTool* tool)
if (mMapTool && mMapTool == tool)
mMapTool->deactivate();
mMapTool = NULL;
+ emit mapToolSet(NULL);
setCursor(Qt::ArrowCursor);
Modified: trunk/qgis/src/gui/qgsmapcanvas.h
--- trunk/qgis/src/gui/qgsmapcanvas.h 2008-06-21 10:07:01 UTC (rev 8664)
+++ trunk/qgis/src/gui/qgsmapcanvas.h 2008-06-21 15:34:01 UTC (rev 8665)
@@ -234,9 +234,6 @@
//! zooms with the factor supplied. Factor > 1 zooms in
void zoom(double scaleFactor);
- //! restore tool on toggle editing
- void restoreMapTool();
public slots:
/**Repaints the canvas map*/
@@ -271,7 +268,7 @@
-signals:
+ signals:
@@ -302,7 +299,10 @@
-protected:
+ protected:
@@ -383,10 +383,10 @@
the last entry in case a lot of resize events arrive in short time*/
QList< QPair<int, int> > mResizeQueue;
- /** debugging member
- invoked when a connect() is made to this object
- void connectNotify( const char * signal );
+ /**debugging member
+ invoked when a connect() is made to this object
+ void connectNotify( const char * signal );
//! current layer in legend
QgsMapLayer* mCurrentLayer;
@@ -400,9 +400,6 @@
//! previous tool if current is for zooming/panning
QgsMapTool* mLastNonZoomMapTool;
- //! tool to restore when editing is toggled.
- QgsMapTool* mNonEditMapTool;
//! recently used extent
QgsRect mLastExtent;
Modified: trunk/qgis/src/gui/qgsmaptool.h
--- trunk/qgis/src/gui/qgsmaptool.h 2008-06-21 10:07:01 UTC (rev 8664)
+++ trunk/qgis/src/gui/qgsmaptool.h 2008-06-21 15:34:01 UTC (rev 8665)
@@ -80,8 +80,7 @@
- * If it does, we will deactivate it when editing is turned off and
- * reactivate it when editing is turned back on.
