[QGIS Commit] r8669 - in branches/advanced_printing_branch/src: app
app/composer ui
svn_qgis at osgeo.org
Sun Jun 22 10:59:40 EDT 2008
Author: mhugent
Date: 2008-06-22 10:59:40 -0400 (Sun, 22 Jun 2008)
New Revision: 8669
branches/advanced_printing_branch/src/app/CMakeLists.txt
branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp
branches/advanced_printing_branch/src/app/composer/qgscomposer.h
branches/advanced_printing_branch/src/app/composer/qgscomposeritem.h
branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp
branches/advanced_printing_branch/src/app/composer/qgscomposermap.h
branches/advanced_printing_branch/src/app/composer/qgscomposerscalebar.cpp
branches/advanced_printing_branch/src/app/composer/qgscomposerscalebar.h
branches/advanced_printing_branch/src/app/composer/qgscomposerview.cpp
branches/advanced_printing_branch/src/app/composer/qgscomposerview.h
branches/advanced_printing_branch/src/app/composer/qgscomposition.cpp
branches/advanced_printing_branch/src/app/composer/qgscomposition.h
branches/advanced_printing_branch/src/ui/qgscomposerscalebarwidgetbase.ui
branches/advanced_printing_branch/src/ui/qgscompositionbase.ui
Started scale bar implementations. Not in a usable state yet
Modified: branches/advanced_printing_branch/src/app/CMakeLists.txt
--- branches/advanced_printing_branch/src/app/CMakeLists.txt 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/CMakeLists.txt 2008-06-22 14:59:40 UTC (rev 8669)
@@ -63,8 +63,8 @@
#composer/qgscomposerpicture.cpp
composer/qgscomposermapwidget.cpp
- #composer/qgscomposerscalebar.cpp
- #composer/qgscomposerscalebarwidget.cpp
+ composer/qgscomposerscalebar.cpp
+ composer/qgscomposerscalebarwidget.cpp
#composer/qgscomposervectorlegend.cpp
@@ -125,7 +125,7 @@
composer/qgscomposermapwidget.h
#composer/qgscomposerpicture.h
- #composer/qgscomposerscalebarwidget.h
+ composer/qgscomposerscalebarwidget.h
#composer/qgscomposervectorlegend.h
composer/qgscomposeritemgroup.h
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp 2008-06-22 14:59:40 UTC (rev 8669)
@@ -25,6 +25,8 @@
#include "qgscomposerlabelwidget.h"
#include "qgscomposermap.h"
#include "qgscomposermapwidget.h"
+#include "qgscomposerscalebar.h"
+#include "qgscomposerscalebarwidget.h"
#include "qgsexception.h"
#include "qgsproject.h"
#include "qgsmessageviewer.h"
@@ -91,6 +93,7 @@
connect(mView, SIGNAL(composerLabelAdded(QgsComposerLabel*)), this, SLOT(addComposerLabel(QgsComposerLabel*)));
connect(mView, SIGNAL(composerMapAdded(QgsComposerMap*)), this, SLOT(addComposerMap(QgsComposerMap*)));
connect(mView, SIGNAL(itemRemoved(QgsComposerItem*)), this, SLOT(deleteItem(QgsComposerItem*)));
+ connect(mView, SIGNAL(composerScaleBarAdded(QgsComposerScaleBar*)), this, SLOT(addComposerScaleBar(QgsComposerScaleBar*)));
mComposition = new QgsComposition(mQgis->getMapCanvas());
mView->setComposition(mComposition);
@@ -855,12 +858,12 @@
QSvgGenerator generator;
generator.setFileName(myOutputFileNameQString);
generator.setSize(QSize( (int)mComposition->paperWidth(), (int)mComposition->paperHeight() ));
- //generator.setResolution((int)(mComposition->resolution() / 25.4)); //because the rendering is done in mm, convert the dpi
+ generator.setResolution(25.4); //because the rendering is done in mm, convert the dpi
QPainter p(&generator);
QRectF renderArea(0,0, mComposition->paperWidth(), mComposition->paperHeight());
#endif
- mComposition->render(&p, renderArea);
+ mComposition->render(&p, renderArea, renderArea);
p.end();
mComposition->setPlotStyle ( QgsComposition::Preview );
@@ -939,11 +942,10 @@
void QgsComposer::on_mActionAddNewScalebar_activated(void)
-#if 0
- mComposition->setTool ( QgsComposition::AddScalebar );
- setToolActionsOff();
- mActionAddNewScalebar->setOn ( true );
-#endif //0
+ if(mView)
+ mView->setCurrentTool(QgsComposerView::AddScalebar);
void QgsComposer::on_mActionAddImage_activated(void)
@@ -1130,6 +1132,17 @@
mItemWidgetMap.insert(label, labelWidget);
+void QgsComposer::addComposerScaleBar(QgsComposerScaleBar* scalebar)
+ if(!scalebar)
+ return;
+ QgsComposerScaleBarWidget* sbWidget = new QgsComposerScaleBarWidget(scalebar);
+ mItemWidgetMap.insert(scalebar, sbWidget);
void QgsComposer::deleteItem(QgsComposerItem* item)
QMap<QgsComposerItem*, QWidget*>::iterator it = mItemWidgetMap.find(item);
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposer.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposer.h 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposer.h 2008-06-22 14:59:40 UTC (rev 8669)
@@ -23,6 +23,7 @@
class QgisApp;
class QgsComposerLabel;
class QgsComposerMap;
+class QgsComposerScaleBar;
class QgsComposerView;
class QgsComposition;
class QgsMapCanvas;
@@ -166,6 +167,9 @@
/**Adds a composer label to the item/widget map and creates a configuration widget for it*/
void addComposerLabel(QgsComposerLabel* label);
+ /**Adds a composer scale bar to the item/widget map and creates a configuration widget for it*/
+ void addComposerScaleBar(QgsComposerScaleBar* scalebar);
/**Removes item from the item/widget map and deletes the configuration widget*/
void deleteItem(QgsComposerItem* item);
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposeritem.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposeritem.h 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposeritem.h 2008-06-22 14:59:40 UTC (rev 8669)
@@ -89,6 +89,8 @@
virtual void addItem(QgsComposerItem* item) {}
virtual void removeItems() {}
+ const QgsComposition* composition() const {return mComposition;}
protected:
QgsComposition* mComposition;
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp 2008-06-22 14:59:40 UTC (rev 8669)
@@ -36,12 +36,14 @@
#include <iostream>
#include <cmath>
+int QgsComposerMap::mCurrentComposerId = 0;
QgsComposerMap::QgsComposerMap ( QgsComposition *composition, int x, int y, int width, int height )
: QgsComposerItem(x, y, width, height, composition)
mComposition = composition;
mMapCanvas = mComposition->mapCanvas();
- mName = "Map"; //QString(tr("Map %1").arg(mId)); //todo: make static member as counter
+ mId = mCurrentComposerId++;
// Cache
mCacheUpdated = false;
@@ -65,7 +67,7 @@
QGraphicsRectItem::show();
@@ -233,11 +235,6 @@
return calculator.calculate(mExtent, rect().width());
-QString QgsComposerMap::name ( void )
- return mName;
void QgsComposerMap::resize(double dx, double dy)
//setRect
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposermap.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposermap.h 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposermap.h 2008-06-22 14:59:40 UTC (rev 8669)
@@ -71,8 +71,8 @@
/** \brief Create cache image */
void cache ( void );
- /** \brief Map name, used in legend combobox etc. */
- QString name ( void );
+ /** \brief Get identification number*/
+ int id() const {return mId;}
/** resizes an item in x- and y direction (canvas coordinates)*/
void resize(double dx, double dy);
@@ -113,8 +113,8 @@
// Pointer to map canvas
QgsMapCanvas *mMapCanvas;
- QString mName;
+ /**Unique identifier*/
+ int mId;
// Map region in map units realy used for rendering
// It can be the same as mUserExtent, but it can be bigger in on dimension if mCalculate==Scale,
@@ -142,6 +142,9 @@
/**Store last scale factor to avoid unnecessary repaints in case preview mode is 'Render'*/
double mLastScaleFactorX;
+ /**For the generation of new unique ids*/
+ static int mCurrentComposerId;
/**Returns the zoom factor of the graphics view. If no
graphics view exists, the default 1 is returned*/
double horizontalViewScaleFactor() const;
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposerscalebar.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposerscalebar.cpp 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposerscalebar.cpp 2008-06-22 14:59:40 UTC (rev 8669)
@@ -15,10 +15,14 @@
+#include "qgscomposermap.h"
+#include "qgsrect.h"
+#include <QFontMetricsF>
+#include <QPainter>
-QgsComposerScaleBar::QgsComposerScaleBar(QgsComposition* composition): QgsComposerItem(0)
+QgsComposerScaleBar::QgsComposerScaleBar(QgsComposition* composition): QgsComposerItem(composition), mComposerMap(0), mStyle(QgsComposerScaleBar::Single_Box), mSegmentMM(0.0)
+ mLabelBarSpace = 3.0;
QgsComposerScaleBar::~QgsComposerScaleBar()
@@ -28,11 +32,174 @@
void QgsComposerScaleBar::paint (QPainter* painter, const QStyleOptionGraphicsItem* itemStyle, QWidget* pWidget)
- //soon...
+ //calculate top level of the bar
+ QFontMetricsF labelFontMetrics(mFont);
+ double barTopPosition = labelFontMetrics.height() + mLabelBarSpace;
+ switch(mStyle)
+ case QgsComposerScaleBar::Single_Box:
+ drawScaleBarSingleBox(painter, barTopPosition);
+ break;
+ default:
+ break;
+ drawLabels(painter);
+ //draw frame and selection boxes if necessary
+ drawFrame(painter);
+ if(isSelected())
+ drawSelectionBoxes(painter);
+void QgsComposerScaleBar::setNumUnitsPerSegment(double units)
+ mNumUnitsPerSegment = units;
+ refreshSegmentMM();
+void QgsComposerScaleBar::setComposerMap(const QgsComposerMap* map)
+ mComposerMap = map;
+void QgsComposerScaleBar::refreshSegmentMM()
+ if(mComposerMap)
+ //get extent of composer map
+ QgsRect composerMapRect = mComposerMap->extent();
+ //get mm dimension of composer map
+ QRectF composerItemRect = mComposerMap->rect();
+ //calculate size depending on mNumUnitsPerSegment
+ mSegmentMM = composerItemRect.width() / composerMapRect.width() * mNumUnitsPerSegment;
+void QgsComposerScaleBar::applyDefaultSettings()
+ mNumSegments = 3;
+ mNumSegmentsLeft = 1;
+ mHeight = 5;
+ mStyle = QgsComposerScaleBar::Single_Box;
+ mPen = QPen(QColor(0, 0, 0));
+ mPen.setWidthF(1.0);
+ mFont.setPointSizeF(8);
+ if(mComposerMap)
+ //calculate mNumUnitsPerSegment
+ double widthScaleBar = composerItemRect.width() / 5;
+ mNumUnitsPerSegment = composerMapRect.width() / 5 / 4;
+void QgsComposerScaleBar::drawLabels(QPainter* p)
+ if(!p)
+ return;
+ p->save();
+ p->setFont(mFont);
+ double fontHeight = labelFontMetrics.height();
+ double mCurrentXCoord = 0;
+ //draw labels of the left segments
+ for(int i = 0; i < mNumSegmentsLeft; ++i)
+ mCurrentXCoord += mSegmentMM / mNumSegmentsLeft;
+ double currentLabelNumber = 0.0;
+ //draw labels of the right segments
+ for(int i = 0; i < mNumSegments; ++i)
+ p->drawText(QPointF(mCurrentXCoord, fontHeight), QString::number(currentLabelNumber));
+ mCurrentXCoord += mSegmentMM;
+ currentLabelNumber += mNumUnitsPerSegment;
+ p->restore();
+void QgsComposerScaleBar::drawScaleBarSingleBox(QPainter* p, double barTopPosition) const
+ if(!p)
+ return;
+ p->save();
+ //mHeight, mBrush, mPen
+ p->setPen(mPen);
+ p->setBrush(mBrush);
+ bool useColor = true; //alternate brush color/white
+ //draw the left segments
+ if(useColor) //alternating colors
+ p->setBrush(QColor(255, 255, 255));
+ else
+ p->setBrush(QColor(0, 0, 0));
+ QRectF segmentRect(mCurrentXCoord, barTopPosition, mSegmentMM/mNumSegmentsLeft, mHeight);
+ p->drawRect(segmentRect);
+ useColor = !useColor;
+ //draw the right segments
+ else
+ QRectF segmentRect(mCurrentXCoord, barTopPosition, mSegmentMM, mHeight);
+ p->restore();
#if 0
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposerscalebar.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposerscalebar.h 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposerscalebar.h 2008-06-22 14:59:40 UTC (rev 8669)
@@ -19,6 +19,8 @@
#include "qgscomposeritem.h"
#include <QPen>
+class QgsComposerMap;
class QgsComposerScaleBar: public QgsComposerItem
public:
@@ -46,7 +48,7 @@
void setNumSegmentsLeft(int nSegmentsLeft) {mNumSegmentsLeft = nSegmentsLeft;}
double numUnitsPerSegment() const {return mNumUnitsPerSegment;}
- void setNumUnitsPerSegment(double units) {mNumUnitsPerSegment = units;}
+ void setNumUnitsPerSegment(double units);
QString unitLabeling() const {return mUnitLabeling;}
void setUnitLabeling(const QString& label){mUnitLabeling = label;}
@@ -63,11 +65,19 @@
double height() const {return mHeight;}
void setHeight(double h) {mHeight = h;}
+ void setComposerMap(const QgsComposerMap* map);
+ const QgsComposerMap* composerMap() const {return mComposerMap;}
+ /**Apply default settings (scale bar 1/5 of map item width)*/
+ void applyDefaultSettings();
+ void setStyle(QgsComposerScaleBar::Style style){mStyle = style;}
protected:
/**Reference to composer map object*/
- QgsComposerMap* mComposerMap;
+ const QgsComposerMap* mComposerMap;
/**Number of segments on right side*/
int mNumSegments;
/**Number of segments on left side*/
@@ -84,7 +94,23 @@
QBrush mBrush;
/**Height of bars/lines*/
double mHeight;
+ /**Scalebar style*/
+ QgsComposerScaleBar::Style mStyle;
+ /**Space between bar and Text labels*/
+ double mLabelBarSpace;
+ /**Width of a segment (in mm)*/
+ double mSegmentMM;
+ /**Calculates with of a segment in mm and stores it in mSegmentMM*/
+ void refreshSegmentMM();
+ /**Draw text labels using the current font*/
+ void drawLabels(QPainter* p);
+ /**Draws this bar using single box style
+ @param barTopPosition Item coordinates of the bar top. Necessary because of Labels*/
+ void drawScaleBarSingleBox(QPainter* p, double barTopPosition) const;
#endif //QGSCOMPOSERSCALEBAR_H
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposerview.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposerview.cpp 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposerview.cpp 2008-06-22 14:59:40 UTC (rev 8669)
@@ -22,6 +22,7 @@
#include "qgscomposerlabel.h"
#include "qgscomposeritemgroup.h"
QgsComposerView::QgsComposerView( QWidget* parent, const char* name, Qt::WFlags f) :
QGraphicsView(parent), mShiftKeyPressed(false), mRubberBandItem(0)
@@ -91,6 +92,27 @@
break;
+ case AddScalebar:
+ QgsComposerScaleBar* newScaleBar = new QgsComposerScaleBar(composition());
+ //take first available map...
+ QList<const QgsComposerMap*> mapItemList = composition()->composerMapItems();
+ if(mapItemList.size() > 0)
+ newScaleBar->setComposerMap(mapItemList.at(0));
+ newScaleBar->applyDefaultSettings(); //4 segments, 1/5 of composer map width
+ scene()->addItem(newScaleBar);
+ emit composerScaleBarAdded(newScaleBar);
+ newScaleBar->setSceneRect(QRectF(scenePoint.x(), scenePoint.y(), 20, 20)); //todo: change this...
+ scene()->clearSelection();
+ newScaleBar->setSelected(true);
+ emit selectedItemChanged(newScaleBar);
+ break;
default:
break;
@@ -119,6 +141,7 @@
QgsComposerMap* composerMap = new QgsComposerMap(composition(), mRubberBandItem->transform().dx(), mRubberBandItem->transform().dy(), mRubberBandItem->rect().width(), mRubberBandItem->rect().height());
+ composerMap->setPreviewMode(QgsComposerMap::Rectangle);
emit composerMapAdded(composerMap);
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposerview.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposerview.h 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposerview.h 2008-06-22 14:59:40 UTC (rev 8669)
@@ -26,6 +26,7 @@
class QgsComposerItem;
/**Widget to display the composer items. Manages the composer tools and the mouse/key events.
Creates the composer items according to the current map tools and keeps track off the rubber band item*/
@@ -88,6 +89,8 @@
void composerLabelAdded(QgsComposerLabel* label);
/**Is emitted when new composer map has been added to the view*/
void composerMapAdded(QgsComposerMap* map);
+ /**Is emmitted when new composer scale bar has been added*/
+ void composerScaleBarAdded(QgsComposerScaleBar* scalebar);
/**Is emitted when a composer item has been removed from the scene*/
void itemRemoved(QgsComposerItem*);
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposition.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposition.cpp 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposition.cpp 2008-06-22 14:59:40 UTC (rev 8669)
@@ -16,6 +16,7 @@
#include "qgscomposition.h"
#include <QGraphicsRectItem>
QgsComposition::QgsComposition(QgsMapCanvas* mapCanvas): QGraphicsScene(0), mMapCanvas(mapCanvas), mPlotStyle(QgsComposition::Preview), mPaperItem(0)
@@ -92,1015 +93,41 @@
return composerItemList;
-#if 0
-#include <typeinfo>
-#include "qgscomposition.h"
-#include "qgscomposer.h"
-#include "qgscomposeritem.h"
-#include "qgscomposeritemgroup.h"
-#include "qgscomposerlabel.h"
-#include "qgscomposerlabelwidget.h"
-#include "qgscomposermap.h"
-#include "qgscomposermapwidget.h"
-#include "qgscomposerpicture.h"
-#include "qgscomposerscalebar.h"
-#include "qgscomposervectorlegend.h"
-#include "qgscomposerview.h"
-#include "qgsmapcanvas.h"
-#include "qgsproject.h"
-#include <QGraphicsRectItem>
-#include <QMatrix>
-#include <QMessageBox>
-#include <QMouseEvent>
-#include <iostream>
-#include <math.h>
-QgsCompositionPaper::QgsCompositionPaper ( QString name, int w, int h, bool c)
- :mName(name), mWidth(w), mHeight(h), mCustom(c)
+QList<const QgsComposerMap*> QgsComposition::composerMapItems() const
+ QList<const QgsComposerMap*> resultList;
-QgsCompositionPaper::~QgsCompositionPaper ( )
-QgsComposition::QgsComposition( QgsComposer *c, int id )
- setupUi(this);
- connect(mPaperWidthLineEdit, SIGNAL(editingFinished()), this, SLOT(paperSizeChanged()));
- connect(mPaperHeightLineEdit, SIGNAL(editingFinished()), this, SLOT(paperSizeChanged()));
- connect(mPaperOrientationComboBox, SIGNAL(activated(int)), this, SLOT(paperSizeChanged()));
- connect(mPaperSizeComboBox, SIGNAL(activated(int)), this, SLOT(paperSizeChanged()));
- connect(mResolutionLineEdit, SIGNAL(editingFinished()), this, SLOT(resolutionChanged()));
-#ifdef QGISDEBUG
- std::cerr << "QgsComposition::QgsComposition()" << std::endl;
-#endif
- mId = id;
- mNextItemId = 1;
- mCanvas = 0;
- mPaperItem = 0;
- mComposer = c;
- mMapCanvas = c->mapCanvas();
- mView = c->view();
- mSelectedItem = 0;
- mPlotStyle = Preview;
- // Attention: Qt4.1 writes line width to PS/PDF still as integer
- // (using QPen->width() to get the value) so we MUST use mScale > 1
- // Note: It seems that Qt4.2 is using widthF so that we can set mScale to 1
- // and hopefuly we can remove mScale completely
- // Note: scale 10 make it inacceptable slow: QgsComposerMap 900x900mm on paper 1500x1000
- // cannot be smoothly moved even if mPreviewMode == Rectangle and no zoom in
- // scale 2 results in minimum line width 0.5 mmm which is too much
- mScale = 1;
- // Add paper sizes and set default.
- mPapers.push_back ( QgsCompositionPaper( tr("Custom"), 0, 0, 1 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("A5 (148x210 mm)"), 148, 210 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("A4 (210x297 mm)"), 210, 297 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("A3 (297x420 mm)"), 297, 420 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("A2 (420x594 mm)"), 420, 594 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("A1 (594x841 mm)"), 594, 841 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("A0 (841x1189 mm)"), 841, 1189 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("B5 (176 x 250 mm)"), 176, 250 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("B4 (250 x 353 mm)"), 250, 353 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("B3 (353 x 500 mm)"), 353, 500 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("B2 (500 x 707 mm)"), 500, 707 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("B1 (707 x 1000 mm)"), 707, 1000 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("B0 (1000 x 1414 mm)"), 1000, 1414 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("Letter (8.5x11 inches)"), 216, 279 ) );
- mPapers.push_back ( QgsCompositionPaper( tr("Legal (8.5x14 inches)"), 216, 356 ) );
- mPaper = mDefaultPaper = mCustomPaper = 0;
- for( int i = 0; i < (int)mPapers.size(); i++ ) {
- mPaperSizeComboBox->insertItem( mPapers[i].mName );
- // Map - A4 land for now, if future read from template
- if ( mPapers[i].mWidth == 210 && mPapers[i].mHeight == 297 ){
- mDefaultPaper = i;
- if ( mPapers[i].mCustom ) mCustomPaper = i;
- // Orientation
- mPaperOrientationComboBox->insertItem( tr("Portrait"), Portrait );
- mPaperOrientationComboBox->insertItem( tr("Landscape"), Landscape );
- mPaperOrientation = Landscape;
- mPaperUnitsComboBox->insertItem( "mm" );
- // Create canvas
- mPaperWidth = 1;
- mPaperHeight = 1;
- createCanvas();
- // Tool
- mRectangleItem = 0;
- mNewCanvasItem = 0;
- mTool = Select;
- mToolStep = 0;
-void QgsComposition::createDefault(void)
- mPaperSizeComboBox->setCurrentItem(mDefaultPaper);
- mPaperOrientationComboBox->setCurrentItem(Landscape);
- mUserPaperWidth = mPapers[mDefaultPaper].mWidth;
- mUserPaperHeight = mPapers[mDefaultPaper].mHeight;
- recalculate();
- mResolution = 300;
- setOptions();
- // Add the map to composition
- QgsComposerMap *m = new QgsComposerMap ( this, mNextItemId++,
- mScale*15, mScale*15, mScale*180, mScale*180 );
- mItems.push_back(m);
- // Add vector legend
- QgsComposerVectorLegend *vl = new QgsComposerVectorLegend ( this, mNextItemId++,
- mScale*210, mScale*100, 10 );
- mItems.push_back(vl);
- // Title
- QgsComposerLabel *tit = new QgsComposerLabel ( this, mNextItemId++,
- mScale*238, mScale*40, "Map", 24 );
- mItems.push_back(tit);
- // Tool
- mTool = Select;
- mToolStep = 0;
- writeSettings();
-void QgsComposition::createCanvas(void)
- if ( mCanvas ) delete mCanvas;
- mCanvas = new QGraphicsScene (0, 0, (int) mPaperWidth, (int) mPaperHeight);//top, left, width, height
- mCanvas->setBackgroundBrush( QColor(180,180,180) );
- // Paper
- if ( mPaperItem ) delete mPaperItem;
- mPaperItem = new QGraphicsRectItem( 0, 0, (int) mPaperWidth, (int) mPaperHeight, mPaperItem, mCanvas );
- mPaperItem->setBrush( QColor(255,255,255) );
- mPaperItem->setPen( QPen(QColor(0,0,0), 0) ); // 0 line width makes it use a cosmetic pen - 1px, regardless of scale.
- mPaperItem->setZValue(0);
- mPaperItem->setAcceptedMouseButtons(0);
- mPaperItem->show();
-void QgsComposition::resizeCanvas(void)
- mCanvas->setSceneRect(0, 0, (int) mPaperWidth * mScale, (int) mPaperHeight * mScale );
-#ifdef QGISDEBUG
- std::cout << "mCanvas width = " << mCanvas->width() << " height = " << mCanvas->height() << std::endl;
-#endif
- mPaperItem->setRect(QRectF(0, 0, (int) mPaperWidth * mScale, (int) mPaperHeight * mScale ));
-QgsComposition::~QgsComposition()
- mView->setScene ( 0 );
- delete mPaperItem;
- delete mCanvas;
-QgsMapCanvas *QgsComposition::mapCanvas(void) { return mMapCanvas; }
-void QgsComposition::setActive ( bool active )
- if ( active ) {
- mView->setScene ( mCanvas );
- mComposer->showCompositionOptions ( this );
- } else {
- // TODO
-void QgsComposition::mousePressEvent(QMouseEvent* e, bool shiftKeyPressed)
-#ifdef QGISDEBUG
- std::cerr << "QgsComposition::mousePressEvent() mTool = " << mTool << " mToolStep = "
- << mToolStep << std::endl;
-#endif
- QPointF p = mView->mapToScene(e->pos());
-// mGrabPoint = mCanvas.mapToItem(p);
- switch ( mTool )
+ QList<QGraphicsItem *> itemList = items();
+ QList<QGraphicsItem *>::iterator itemIt = itemList.begin();
+ for(; itemIt != itemList.end(); ++itemIt)
- case Select:
- QGraphicsItem* newItem = 0;
- newItem = mCanvas->itemAt(p);
- if(newItem == mPaperItem) //ignore clicks on the paper
- newItem = 0;
- QgsComposerItem* selectedItem = dynamic_cast<QgsComposerItem*>(newItem);
- if(selectedItem)
- if(!shiftKeyPressed)
- canvas()->clearSelection();
- //toggle selection state of selected item
- bool currentSelectState = selectedItem->isSelected();
- selectedItem->setSelected(!currentSelectState);
- mComposer->showItemOptions(selectedItem);
- break;
- case AddMap:
-#ifdef QGISDEBUG
- std::cerr << "AddMap" << std::endl;
-#endif
- if ( mToolStep == 0 )
+ const QgsComposerMap* composerMap = dynamic_cast<const QgsComposerMap*>(*itemIt);
+ if(composerMap)
- mRectangleItem = new QGraphicsRectItem( p.x(), p.y(), 0, 0, 0, mCanvas );//null parent
- mRectangleItem->setBrush( Qt::NoBrush );
- mRectangleItem->setPen( QPen(QColor(0,0,0), 0) );
- mRectangleItem->setZValue(100);
- mRectangleItem->show();
- mToolStep = 1;
+ resultList.push_back(composerMap);
-#ifdef QGISDEBUG
- std::cerr << "mToolStep = " << mToolStep << std::endl;
-#endif
- break;
- case AddLabel:
- if(mToolStep == 0)
- QgsComposerLabel* newLabelItem = new QgsComposerLabel(this);
- newLabelItem->setText("Quantum GIS");
- newLabelItem->adjustSizeToText();
- newLabelItem->setSceneRect(QRectF(p.x(), p.y(), newLabelItem->rect().width(), newLabelItem->rect().height()));
- newLabelItem->setZValue(60);
- QgsComposerLabelWidget* newLabelWidget = new QgsComposerLabelWidget(newLabelItem);
- mComposer->addItem(newLabelItem, newLabelWidget);
- mItems.push_back(newLabelItem);
- canvas()->addItem(newLabelItem);
- newLabelItem->setSelected ( true );
- mCanvas->update();
- mComposer->showItemOptions(newLabelItem);
- mSelectedItem = newLabelItem;
- newLabelItem->show();
- mToolStep = 1;
- setTool(Select);
- break;
- /* //other items besides map disabled for the moment
- case AddVectorLegend:
- mNewCanvasItem->setPos(p);
- QgsComposerVectorLegend *vl = dynamic_cast <QgsComposerVectorLegend*> (mNewCanvasItem);
- vl->writeSettings();
- mComposer->selectItem(); // usually just one legend
- // Select and show options
- vl->setSelected ( true );
- mComposer->showItemOptions ( vl->options() );
- mSelectedItem = dynamic_cast <QGraphicsItem*> (vl);
- break;
- case AddScalebar:
- QgsComposerScalebar *sb = dynamic_cast <QgsComposerScalebar*> (mNewCanvasItem);
- sb->writeSettings();
- mItems.push_back(sb);
- mComposer->selectItem(); // usually just one ???
- sb->setSelected ( true );
- mComposer->showItemOptions ( sb->options() );
- mSelectedItem = dynamic_cast <QGraphicsItem*> (sb);
- break;
- case AddPicture:
- //set up the bounding rectangle
- //note: this rectangle gets used to keep track of the beginning click point for a picture
- mRectangleItem->setPen( QPen(QColor(0,0,0), 0, Qt::DashLine) );
- QgsComposerPicture *pi = dynamic_cast <QgsComposerPicture*> (mNewCanvasItem);
- pi->setSize( 0, 0 );
- mToolStep = 1;
- break;
-void QgsComposition::mouseMoveEvent(QMouseEvent* e)
-#ifdef QGISDEBUG
- std::cerr << "QgsComposition::mouseMoveEvent() mTool = " << mTool << " mToolStep = "
-#endif
- switch ( mTool ) {
- case Select:
- if ( mSelectedItem ) {
- //mSelectedItem->setPos(p - mGrabPoint);
- //mCanvas->update();
- break;
- case AddMap:
- if ( mToolStep == 1 ) // draw rectangle while dragging
- double x, y;
- double w, h;
- x = p.x() < mRectangleItem->x() ? p.x() : mRectangleItem->rect().x();
- y = p.y() < mRectangleItem->y() ? p.y() : mRectangleItem->rect().y();
- w = fabs ( p.x() - mRectangleItem->rect().x() );
- h = fabs ( p.y() - mRectangleItem->rect().y() );
- mRectangleItem->setRect(QRectF(x, y, w, h));
- }//END if(mToolStep == 1)
- break;
- case AddPicture:
- double x, y;
- double w, h;
- pi->setPos(x + w/2, y + h/2);
- pi->setSize(w, h);
- break;
- case AddScalebar:
- case AddLabel:
- break;
-void QgsComposition::mouseReleaseEvent(QMouseEvent* e)
-#ifdef QGISDEBUG
- std::cerr << "QgsComposition::mouseReleaseEvent() mTool = " << mTool
- << " mToolStep = " << mToolStep << std::endl;
-#endif
- QPoint p = mView->mapFromScene(e->pos());
- case AddMap: // mToolStep should be always 1 but rectangle can be 0 size
- double x = mRectangleItem->rect().x();
- double y = mRectangleItem->rect().y();
- double w = mRectangleItem->rect().width();
- double h = mRectangleItem->rect().height();
- delete mRectangleItem;
- QgsComposerMap* m = 0;
- if ( w > 0 && h > 0 )
- mComposer->selectItem(); // usually just one map
- m = new QgsComposerMap ( this, x, y, w, h );
- QgsComposerMapWidget* w = new QgsComposerMapWidget(m);
- mComposer->addItem(m, w);
- m->setSelected ( true );
- mComposer->showItemOptions(m);
- mSelectedItem = m;
- else
- mToolStep = 0;
- mView->unsetCursor();
- break;
- /* //other items besides map are disabled for the moment
- case AddPicture:
- mNewCanvasItem = 0; // !!! Must be before mComposer->selectItem()
- pi->writeSettings();
- mItems.push_back(pi);
- pi->setSelected ( true );
- mComposer->showItemOptions ( pi->options() );
- mSelectedItem = dynamic_cast <QGraphicsItem*> (pi);
- } else {
- mToolStep = 0;
- break;
- case Select:
- // the object was probably moved
- QgsComposerItem *ci = dynamic_cast <QgsComposerItem *> (mSelectedItem);
- ci->writeSettings();
- break;
- //We don't do anything special for labels, scalebars, or vector legends
- /*case AddLabel:
- case AddScalebar:
- break;*/
-void QgsComposition::keyPressEvent ( QKeyEvent * e )
-#ifdef QGISDEBUG
- std::cout << "QgsComposition::keyPressEvent() key = " << e->key() << std::endl;
-#endif
- QList<QGraphicsItem *> selectionList = canvas()->selectedItems();
- if ( e->key() == Qt::Key_Delete) { // delete
- QList<QGraphicsItem *>::iterator sIt = selectionList.begin();
- for(; sIt != selectionList.end(); ++sIt)
- mComposer->removeItem(dynamic_cast<QgsComposerItem *>(*sIt));
- if(e->key() == Qt::Key_Left)
- ((QgsComposerItem*)(*sIt))->move(-1.0, 0.0);
- else if(e->key() == Qt::Key_Right)
- ((QgsComposerItem*)(*sIt))->move(1.0, 0.0);
- else if(e->key() == Qt::Key_Down)
- ((QgsComposerItem*)(*sIt))->move(0.0, 1.0);
- else if(e->key() == Qt::Key_Up)
- ((QgsComposerItem*)(*sIt))->move(0.0, -1.0);
-void QgsComposition::paperSizeChanged ( void )
-#ifdef QGISDEBUG
- std::cout << "QgsComposition::paperSizeChanged" << std::endl;
-#endif
- mPaper = mPaperSizeComboBox->currentItem();
- mPaperOrientation = mPaperOrientationComboBox->currentItem();
-#ifdef QGISDEBUG
- std::cout << "custom = " << mPapers[mPaper].mCustom << std::endl;
- std::cout << "orientation = " << mPaperOrientation << std::endl;
-#endif
- if ( mPapers[mPaper].mCustom ) {
- mUserPaperWidth = mPaperWidthLineEdit->text().toDouble();
- mUserPaperHeight = mPaperHeightLineEdit->text().toDouble();
- mPaperWidthLineEdit->setEnabled( TRUE );
- mPaperHeightLineEdit->setEnabled( TRUE );
- } else {
- mUserPaperWidth = mPapers[mPaper].mWidth;
- mUserPaperHeight = mPapers[mPaper].mHeight;
- mPaperWidthLineEdit->setEnabled( FALSE );
- mPaperHeightLineEdit->setEnabled( FALSE );
- setOptions();
- try
- recalculate();
- catch (std::bad_alloc& ba)
- Q_UNUSED(ba);
- // A better solution here would be to set the canvas back to the
- // original size and carry on, but for the moment this will
- // prevent a crash due to an uncaught exception.
- QMessageBox::critical( 0, tr("Out of memory"),
- tr("Qgis is unable to resize the paper size due to "
- "insufficient memory.\n It is best that you avoid "
- "using the map composer until you restart qgis.\n") );
-// mView->repaintContents(); //just repaint();?
- writeSettings();
+ return resultList;
-void QgsComposition::recalculate ( void )
+const QgsComposerMap* QgsComposition::getComposerMapById(int id) const
- if ( (mPaperOrientation == Portrait && mUserPaperWidth < mUserPaperHeight) ||
- (mPaperOrientation == Landscape && mUserPaperWidth > mUserPaperHeight) )
- mPaperWidth = mUserPaperWidth;
- mPaperHeight = mUserPaperHeight;
- } else {
- mPaperWidth = mUserPaperHeight;
- mPaperHeight = mUserPaperWidth;
-#ifdef QGISDEBUG
- std::cout << "mPaperWidth = " << mPaperWidth << " mPaperHeight = " << mPaperHeight << std::endl;
-#endif
- resizeCanvas();
- mComposer->zoomFull();
-void QgsComposition::resolutionChanged ( void )
- mResolution = mResolutionLineEdit->text().toInt();
- writeSettings();
-void QgsComposition::setOptions ( void )
- mPaperSizeComboBox->setCurrentItem(mPaper);
- mPaperOrientationComboBox->setCurrentItem(mPaperOrientation);
- mPaperWidthLineEdit->setText ( QString("%1").arg(mUserPaperWidth,0,'g') );
- mPaperHeightLineEdit->setText ( QString("%1").arg(mUserPaperHeight,0,'g') );
- mResolutionLineEdit->setText ( QString("%1").arg(mResolution) );
-void QgsComposition::setPlotStyle ( PlotStyle p )
- mPlotStyle = p;
- // Set all items
- for (std::list < QgsComposerItem * >::iterator it = mItems.begin(); it != mItems.end(); ++it) {
- (*it)->setPlotStyle( p ) ;
- // Remove paper if Print, reset if Preview
- if ( mPlotStyle == Print ) {
-// mPaperItem->setScene(0);
-// mCanvas->setBackgroundColor( Qt::white );
- } else {
-// mPaperItem->setScene(mCanvas);
-// mCanvas->setBackgroundColor( QColor(180,180,180) );
-double QgsComposition::viewScale ( void )
- double scale = mView->matrix().m11();
- return scale;
-//does this even work?
-void QgsComposition::refresh()
-#if 0
- // TODO add signals to map canvas
- QgsComposerItem *ci = (*it);
- if ( typeid (*ci) == typeid(QgsComposerMap) ) {
- QgsComposerMap *cm = dynamic_cast<QgsComposerMap*>(ci);
- cm->setCacheUpdated(false);
- } else if ( typeid (*ci) == typeid(QgsComposerVectorLegend) ) {
- QgsComposerVectorLegend *vl = dynamic_cast<QgsComposerVectorLegend*>(ci);
- vl->recalculate();
-#endif //0
-int QgsComposition::id ( void ) { return mId; }
-QgsComposer *QgsComposition::composer(void) { return mComposer; }
-QGraphicsScene *QgsComposition::canvas(void) { return mCanvas; }
-double QgsComposition::paperWidth ( void ) { return mPaperWidth; }
-double QgsComposition::paperHeight ( void ) { return mPaperHeight; }
-int QgsComposition::paperOrientation ( void ) { return mPaperOrientation; }
-int QgsComposition::resolution ( void ) { return mResolution; }
-int QgsComposition::scale( void ) { return mScale; }
-double QgsComposition::toMM ( int v ) { return v/mScale ; }
-int QgsComposition::fromMM ( double v ) { return (int) (v * mScale); }
-void QgsComposition::setTool ( Tool tool )
- // Stop old in progress
- QgsComposerItem *coi = dynamic_cast <QgsComposerItem *> (mSelectedItem);
- coi->setSelected ( false );
- mComposer->showItemOptions (0);
- if ( mNewCanvasItem ) {
- mNewCanvasItem->setPos(-1000, -1000);
- delete mNewCanvasItem;
- if ( mRectangleItem ) {
- // Start new
- /*if ( tool == AddVectorLegend ) { // Create temporary object
- if ( mNewCanvasItem ) delete mNewCanvasItem;
- // Create new object outside the visible area
- QgsComposerVectorLegend *vl = new QgsComposerVectorLegend ( this, mNextItemId++, -1000, -1000, (int) (mPaperHeight/50));
- mNewCanvasItem = dynamic_cast <QGraphicsItem *> (vl);
- mComposer->showItemOptions(vl);
- mView->viewport()->setMouseTracking ( true ); // to recieve mouse move
- else if ( tool == AddLabel ) {
- //QgsComposerLabel *lab = new QgsComposerLabel ( this, mNextItemId++, -1000, -1000, tr("Label"), (int) (mPaperHeight/20));
- //mNewCanvasItem = dynamic_cast <QGraphicsItem *> (lab);
- //mComposer->showItemOptions(lab);
- else if ( tool == AddScalebar ) {
- QgsComposerScalebar *sb = new QgsComposerScalebar ( this, mNextItemId++, -1000, -1000);
- mNewCanvasItem = dynamic_cast <QGraphicsItem*> (sb);
- mComposer->showItemOptions(sb);
- else if ( tool == AddPicture )
- while ( 1 ) // keep trying until we get a valid image or the user clicks cancel
- QString file = QgsComposerPicture::pictureDialog();
- if ( file.isNull() ) //user clicked cancel
- // TODO: This is not nice, because selectItem() calls
- // this function, do it better
- tool = Select;
- break; //quit the loop
- QgsComposerPicture *pi = new QgsComposerPicture ( this, mNextItemId++, file );
- if ( pi->pictureValid() )
-#ifdef QGISDEBUG
- std::cout << "picture is valid" << std::endl;
-#endif
- mNewCanvasItem = dynamic_cast <QGraphicsItem *> (pi);
- mComposer->showItemOptions(pi);
- mView->viewport()->setMouseTracking ( true ); // start tracking the mouse
- else
- QMessageBox::warning( this, tr("Warning"),
- tr("Cannot load picture.") );
- delete pi;
- }//END if(tool == AddPicture)*/
- mTool = tool;
- mToolStep = 0;
-void QgsComposition::groupItems()
- if(!mComposer || !canvas())
- return;
- QList<QGraphicsItem *> selectedItems = canvas()->selectedItems();
- if(selectedItems.size() < 2)
- return; //not enough items for a group
- QgsComposerItemGroup* itemGroup = new QgsComposerItemGroup(this);
- QList<QGraphicsItem *>::iterator itemIt = selectedItems.begin();
- for(; itemIt != selectedItems.end(); ++itemIt)
- itemGroup->addItem((QgsComposerItem*)(*itemIt));
- mComposer->addItem(itemGroup, 0);
- mCanvas->addItem(itemGroup);
- mItems.push_back(itemGroup);
- itemGroup->setSelected(true);
- mComposer->showItemOptions(0);
-void QgsComposition::ungroupItems()
- return;
- QgsComposerItemGroup* itemGroup = dynamic_cast<QgsComposerItemGroup*>(*itemIt);
- if(itemGroup)
+ if(composerMap)
- itemGroup->removeItems();
- mCanvas->removeItem(itemGroup);
- mComposer->removeItem(itemGroup);
+ if(composerMap->id() == id)
+ return composerMap;
-std::vector<QgsComposerMap*> QgsComposition::maps(void)
- std::vector<QgsComposerMap*> v;
- v.push_back ( dynamic_cast<QgsComposerMap*>(ci) );
- return v;
+ return 0;
-double QgsComposition::selectionBoxSize ( void )
- // Scale rectangle based on the zoom level, so we keep the rectangle a fixed size on the screen
- return 7.0/viewScale();
-QPen QgsComposition::selectionPen ( void )
- return QPen( QColor(0,0,255), 0) ;
-QBrush QgsComposition::selectionBrush ( void )
- return QBrush ( QBrush(QColor(0,0,255), Qt::SolidPattern) );
-void QgsComposition::emitMapChanged ( int id )
- emit mapChanged ( id );
-bool QgsComposition::writeSettings ( void )
-#if 0
- QString path, val;
- path.sprintf("/composition_%d/", mId );
- QgsProject::instance()->writeEntry( "Compositions", path+"width", mUserPaperWidth );
- QgsProject::instance()->writeEntry( "Compositions", path+"height", mUserPaperHeight );
- QgsProject::instance()->writeEntry( "Compositions", path+"resolution", mResolution );
- if ( mPaperOrientation == Landscape ) {
- val = "landscape";
- } else {
- val = "portrait";
- QgsProject::instance()->writeEntry( "Compositions", path+"orientation", val );
-#endif //0
- return true;
-bool QgsComposition::readSettings ( void )
-#if 0
-#ifdef QGISDEBUG
- std::cout << "QgsComposition::readSettings" << std::endl;
-#endif
- bool ok;
- mPaper = mCustomPaper;
- mUserPaperWidth = QgsProject::instance()->readDoubleEntry( "Compositions", path+"width", 297, &ok);
- mUserPaperHeight = QgsProject::instance()->readDoubleEntry( "Compositions", path+"height", 210, &ok);
- mResolution = QgsProject::instance()->readNumEntry( "Compositions", path+"resolution", 300, &ok);
- val = QgsProject::instance()->readEntry( "Compositions", path+"orientation", "landscape", &ok);
- if ( val.compare("landscape") == 0 ) {
- } else {
- mPaperOrientation = Portrait;
- recalculate();
- setOptions();
- // Create objects
- path.sprintf("/composition_%d", mId );
- QStringList el = QgsProject::instance()->subkeyList ( "Compositions", path );
- // First create the map(s) because they are often required by other objects
- for ( QStringList::iterator it = el.begin(); it != el.end(); ++it ) {
-#ifdef QGISDEBUG
- std::cout << "key: " << (*it).toLocal8Bit().data() << std::endl;
-#endif
- QStringList l = QStringList::split( '_', (*it) );
- if ( l.size() == 2 ) {
- QString name = l.first();
- QString ids = l.last();
- int id = ids.toInt();
- if ( name.compare("map") == 0 ) {
- QgsComposerMap *map = new QgsComposerMap ( this, id );
- mItems.push_back(map);
- if ( id >= mNextItemId ) mNextItemId = id + 1;
-#ifdef QGISDEBUG
-#endif
- if ( name.compare("vectorlegend") == 0 ) {
- QgsComposerVectorLegend *vl = new QgsComposerVectorLegend ( this, id );
- } else if ( name.compare("label") == 0 ) {
- QgsComposerLabel *lab = new QgsComposerLabel ( this, id );
- mItems.push_back(lab);
- } else if ( name.compare("scalebar") == 0 ) {
- QgsComposerScalebar *sb = new QgsComposerScalebar ( this, id );
- } else if ( name.compare("picture") == 0 ) {
- QgsComposerPicture *pi = new QgsComposerPicture ( this, id );
-#endif //0
- return true;
-#endif //0
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposition.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposition.h 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposition.h 2008-06-22 14:59:40 UTC (rev 8669)
@@ -19,6 +19,7 @@
#include <QGraphicsScene>
class QGraphicsRectItem;
class QgsMapCanvas;
@@ -52,6 +53,13 @@
QList<QgsComposerItem*> selectedComposerItems();
+ /**Returns pointers to all composer maps in the scene*/
+ QList<const QgsComposerMap*> composerMapItems() const;
+ /**Returns the composer map with specified id
+ @return id or 0 pointer if the composer map item does not exist*/
+ const QgsComposerMap* getComposerMapById(int id) const;
/**Returns pointer to qgis map canvas*/
QgsMapCanvas* mapCanvas(){return mMapCanvas;}
@@ -68,309 +76,5 @@
#endif
-#if 0
-#include "ui_qgscompositionbase.h"
-#include <list>
-#include <vector>
-class QgsComposer;
-class QgsComposerItem;
-class QgsComposerMap;
-class QgsComposerView;
-class QgsMapCanvas;
-class QGraphicsScene;
-class QGraphicsItem;
-class QGraphicsRectItem;
-class QDomDocument;
-class QDomNode;
-class QKeyEvent;
-class QMouseEvent;
-class QgsCompositionPaper
-public:
- QString mName;
- int mWidth;
- int mHeight;
- int mCustom;
- QgsCompositionPaper( QString name, int w, int h, bool c = false);
- ~QgsCompositionPaper();
-/** \class QgsComposition
- * \brief This class can store, write as XML and read from XML the description
- * map composition for printing.
-class QgsComposition: public QWidget, private Ui::QgsCompositionBase
- Q_OBJECT
-public:
- /** \brief Constructor. */
- QgsComposition ( QgsComposer *c, int id );
- /** \brief The destuctor. */
- ~QgsComposition();
- /** \brief Orientation */
- enum Orientation {
- Portrait = 0,
- Landscape
- /** \brief Current tool */
- enum Tool {
- Select = 0, // Select/Move item
- AddMap, // add new map
- AddVectorLegend, // add vector legend
- AddLabel, // add label
- AddScalebar, // add scalebar
- AddPicture // add raster/vector picture
- /** \brief Scaling mode, defines which parameters are fixed and which are changing */
- enum Calculate {
- Scale = 0, // Extent and paper are defined by user, scale is calculated
- Paper, // Extent and scale are defined by user, paper is calculated
- Extent // Paper and scale are defined by user, extent is calculated
- /** \brief Plot type */
- enum PlotStyle {
- Preview = 0, // Use cache etc
- Print, // Render well
- Postscript // Fonts need different scaling!
- /** \brief Font scaling factor for PostScript output
- * For output to Postscript the font must be scaled. But how?
- * The factor is an empirical value. In any case, each font scales
- * in in different way even if painter.scale() is used instead of
- * font size!!! -> Postscript is never exactly the same as in preview.
- // Hopefully no more needed
- static const double psFontScaleFactor() {
-#ifdef Q_OS_MACX
- return 1.85;
-#else
- return 2.45; // I have no idea why 2.45 - it is an empirical value
-#endif
- /** \brief Composition ID */
- int id ( void );
- /** \brief Get paper width */
- double paperWidth ( void );
- /** \brief Get paper height */
- double paperHeight ( void );
- /** \brief Get paper orientation */
- int paperOrientation ( void );
- /** \brief Get resolutin */
- int resolution ( void );
- /**Get active tool*/
- QgsComposition::Tool tool() const {return mTool;}
- /** \brief Create default composition */
- void createDefault ( void );
- /** \brief Remove all items */
- void clear ( void );
- /** \brief Recalculate page size according to mUserPaperWidth/Height and mPaperOrientation,
- * resize canvas and zoomFull */
- void recalculate(void);
- /** \brief pointer to map canvas */
- QgsMapCanvas *mapCanvas(void);
- /** \brief pointer to composer */
- QgsComposer *composer(void);
- /** \brief Set this composition as active, show its canvas with items and show general options */
- void setActive ( bool active );
- /** \brief returns pointer to canvas */
- QGraphicsScene *canvas(void);
- /** \brief recieves mousePressEvent from view */
- void mousePressEvent(QMouseEvent*, bool shiftKeyPressed = false);
- /** \brief recieves mouseReleaseEvent from view */
- void mouseReleaseEvent(QMouseEvent*);
- /** \brief recieves mouseMoveEvent from view */
- void mouseMoveEvent(QMouseEvent*);
- /** \brief recieves keyPressEvent from view */
- void keyPressEvent ( QKeyEvent * e );
- /** \brief set plot style, use before print */
- void setPlotStyle ( PlotStyle p );
- /** \brief Set composition optiones in GUI */
- void setOptions ( void );
- /** \brief Set tool */
- void setTool ( Tool tool );
- /**Insert a group containing the selected items*/
- void groupItems();
- /**Removes items from selected group and also the group item*/
- void ungroupItems();
- /** Refresh. Refresh objects which are not updated automaticaly, e.g. map object does not know
- * if a layer was switched on/off. Later should be substituted by appropriate signals
- * se by map canvas */
- void refresh();
- /** \brief Canvas scale */
- int scale (void);
- /** \brief convert canvas unit to mm */
- double toMM ( int v );
- /** \brief convert mm to canvas unit */
- int fromMM ( double v );
- /** \brief Return number screen pixels / canvas point */
- double viewScale( void );
- /** \brief Selection box size in _scene_ units */
- double selectionBoxSize ( void );
- /** \brief Selection box pen and brush */
- QPen selectionPen ( void );
- QBrush selectionBrush ( void );
- /** \brief vector of pointers to maps available in composition */
- std::vector<QgsComposerMap*> maps(void);
- /** \brief stores statei in project */
- bool writeSettings ( void );
- /** \brief read state from project */
- bool readSettings ( void );
- /** \brief stores state in DOM node */
- bool writeXML( QDomNode & node, QDomDocument & doc, bool templ = false );
- /** \brief sets state from DOM document */
- bool readXML( QDomNode & node );
- /** \brief Called map objects if changed, so that the composition can emit signal */
- void emitMapChanged ( int id );
-public slots:
- /** \brief Called by GUI if paper size was changed */
- void paperSizeChanged ( void );
- /** \brief Called by GUI if resolution was changed */
- void resolutionChanged ( void );
-signals:
- /** \brief Emitted when map was changed */
- void mapChanged ( int id );
-private:
- /** \brief composition id */
- int mId;
- /** \brief paper width in mm in GUI */
- double mUserPaperWidth;
- /** \brief paper height in mm in GUI */
- double mUserPaperHeight;
- /** \brief paper width in mm (orientaion applied) */
- double mPaperWidth;
- /** \brief paper height in mm (orientaion applied) */
- double mPaperHeight;
- /** \brief Papers */
- std::vector<QgsCompositionPaper> mPapers;
- /** \brief Current paper */
- int mPaper;
- /** \brief Default paper index */
- int mDefaultPaper;
- /** \brief Custom paper index */
- int mCustomPaper;
- int mPaperOrientation;
- QgsMapCanvas *mMapCanvas;
- QgsComposer *mComposer;
- /** \brief Canvas. One per composition, created by QgsComposition */
- QGraphicsScene *mCanvas;
- /** \brief Pointer to canvas view */
- QgsComposerView *mView;
- /** \brief List of all composer items */
- std::list<QgsComposerItem*> mItems;
- /** \brief Selected item, 0 if no item is selected */
- QGraphicsItem* mSelectedItem;
- /** \brief Item representing the paper */
- QGraphicsRectItem *mPaperItem;
- /** \brief Plot style */
- PlotStyle mPlotStyle;
- Tool mTool;
- /** \brief Tool step first is 0 */
- int mToolStep;
- /** \brief Temporary rectangle item used as rectangle drawn by mouse */
- QGraphicsRectItem *mRectangleItem;
- /** \brief Temporary item used as pointer to new objecs which must be drawn */
- QGraphicsItem *mNewCanvasItem;
- /** \brief Resolution in DPI */
- int mResolution;
- /** \brief canvas scale */
- int mScale;
- /** \brief id for next new item */
- int mNextItemId;
- QGraphicsRectItem *sizeBox;
- /** \brief Create canvas */
- void createCanvas(void);
- /** \brief Resize canvas to current paper size */
- void resizeCanvas(void);
- /** \brief Grab point, set with MousePressEvent */
- QPointF mGrabPoint;
-#endif
Modified: branches/advanced_printing_branch/src/ui/qgscomposerscalebarwidgetbase.ui
--- branches/advanced_printing_branch/src/ui/qgscomposerscalebarwidgetbase.ui 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/ui/qgscomposerscalebarwidgetbase.ui 2008-06-22 14:59:40 UTC (rev 8669)
@@ -30,7 +30,11 @@
</widget>
</item>
<item row="0" column="2" >
- <widget class="QDoubleSpinBox" name="mSegmentSizeSpinBox" />
+ <widget class="QDoubleSpinBox" name="mSegmentSizeSpinBox" >
+ <property name="maximum" >
+ <double>9999999999999.000000000000000</double>
+ </property>
+ </widget>
</item>
<item row="1" column="0" colspan="2" >
<widget class="QLabel" name="mNumbereOfSegmentsLabel" >
Modified: branches/advanced_printing_branch/src/ui/qgscompositionbase.ui
--- branches/advanced_printing_branch/src/ui/qgscompositionbase.ui 2008-06-21 19:08:34 UTC (rev 8668)
+++ branches/advanced_printing_branch/src/ui/qgscompositionbase.ui 2008-06-22 14:59:40 UTC (rev 8669)
@@ -10,9 +10,7 @@
</rect>
</property>
<property name="sizePolicy" >
- <sizepolicy>
- <hsizetype>7</hsizetype>
- <vsizetype>7</vsizetype>
+ <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
@@ -21,33 +19,55 @@
<string>Composition</string>
</property>
<layout class="QGridLayout" >
- <property name="margin" >
+ <property name="leftMargin" >
<number>9</number>
</property>
- <property name="spacing" >
+ <property name="topMargin" >
+ <number>9</number>
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
+ <property name="horizontalSpacing" >
<number>6</number>
</property>
+ <property name="verticalSpacing" >
+ <number>6</number>
+ </property>
<item row="0" column="0" colspan="2" >
<widget class="QGroupBox" name="groupBox" >
<property name="title" >
<string>Paper</string>
</property>
<number>9</number>
</property>
+ </property>
+ </property>
+ </property>
<number>6</number>
</property>
+ </property>
<item row="4" column="1" >
<widget class="QComboBox" name="mPaperOrientationComboBox" >
<property name="enabled" >
<bool>true</bool>
</property>
- <sizepolicy>
- <vsizetype>0</vsizetype>
+ <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
</sizepolicy>
@@ -66,9 +86,7 @@
<bool>false</bool>
</property>
- <sizepolicy>
</sizepolicy>
@@ -81,9 +99,7 @@
<bool>true</bool>
</property>
- <sizepolicy>
</sizepolicy>
@@ -93,9 +109,7 @@
<item row="4" column="0" >
<widget class="QLabel" name="textLabel7" >
- <sizepolicy>
- <hsizetype>5</hsizetype>
- <vsizetype>5</vsizetype>
+ <sizepolicy vsizetype="Preferred" hsizetype="Preferred" >
</sizepolicy>
@@ -111,9 +125,7 @@
<item row="3" column="0" >
<widget class="QLabel" name="textLabel6" >
- <sizepolicy>
</sizepolicy>
@@ -129,9 +141,7 @@
<item row="2" column="0" >
<widget class="QLabel" name="textLabel4" >
- <sizepolicy>
</sizepolicy>
@@ -147,9 +157,7 @@
<item row="1" column="0" >
<widget class="QLabel" name="textLabel5" >
- <sizepolicy>
</sizepolicy>
@@ -165,9 +173,7 @@
<item row="0" column="0" >
<widget class="QLabel" name="textLabel3" >
- <sizepolicy>
</sizepolicy>
@@ -183,7 +189,7 @@
</layout>
</widget>
</item>
- <item row="2" column="0" colspan="2" >
+ <item rowspan="2" row="1" column="0" colspan="2" >
<spacer>
<property name="orientation" >
<enum>Qt::Vertical</enum>
@@ -199,27 +205,6 @@
</property>
</spacer>
</item>
- <item row="1" column="0" >
- <widget class="QLabel" name="textLabel1" >
- <property name="sizePolicy" >
- <sizepolicy>
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="text" >
- <string>Resolution (dpi)</string>
- </property>
- <property name="buddy" >
- <cstring>mResolutionLineEdit</cstring>
- </property>
- </widget>
- </item>
- <item row="1" column="1" >
- <widget class="QLineEdit" name="mResolutionLineEdit" />
- </item>
</layout>
</widget>
<layoutdefault spacing="6" margin="11" />
