[QGIS Commit] r8671 - in trunk/qgis/src: app core ui
svn_qgis at osgeo.org
Mon Jun 23 04:54:39 EDT 2008
Author: timlinux
Date: 2008-06-23 04:54:39 -0400 (Mon, 23 Jun 2008)
New Revision: 8671
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/core/qgsexception.cpp
trunk/qgis/src/ui/qgsattributeactiondialogbase.ui
Updates for internationalisation from Carlos
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2008-06-22 15:00:52 UTC (rev 8670)
+++ trunk/qgis/src/app/qgisapp.cpp 2008-06-23 08:54:39 UTC (rev 8671)
@@ -1203,13 +1203,15 @@
"as the mouse is moved."));
mCoordsLabel->setToolTip(tr("Map coordinates at mouse cursor position"));
statusBar()->addPermanentWidget(mCoordsLabel, 0);
+ QString myIconPath = QgsApplication::themePath();
//stop rendering status bar widget
mStopRenderButton = new QToolButton( statusBar() );
mStopRenderButton->setMaximumWidth(20);
mStopRenderButton->setMaximumHeight(20);
-//#ifdef Q_WS_MAC //MH: disable the button on Mac for now to avoid problems with resizing
- mStopRenderButton->setEnabled(false);
-//#endif //Q_WS_MAC
+ QPixmap myStopPixmap;
+ myStopPixmap.load(myIconPath+"/mIconDelete.png");
+ mStopRenderButton->setIcon(myStopPixmap);
+ mStopRenderButton->setToolTip(tr("Stop map rendering") );
statusBar()->addPermanentWidget(mStopRenderButton, 0);
// render suppression status bar widget
mRenderSuppressionCBox = new QCheckBox(tr("Render"),statusBar());
@@ -1230,7 +1232,6 @@
// For Qt/Mac 3.3, the default toolbutton height is 30 and labels were expanding to match
mOnTheFlyProjectionStatusButton->setMaximumHeight(mScaleLabel->height());
QPixmap myProjPixmap;
- QString myIconPath = QgsApplication::themePath();
myProjPixmap.load(myIconPath+"/mIconProjectionDisabled.png");
mOnTheFlyProjectionStatusButton->setIcon(myProjPixmap);
QgsDebugMsg("Icon Path: " + myIconPath.toLocal8Bit());
@@ -1374,7 +1375,7 @@
// "theMapCanvas" used to find this canonical instance later
mMapCanvas = new QgsMapCanvas(this, "theMapCanvas" );
- mMapCanvas->setWhatsThis(tr("Map canvas. This is where raster and vector"
+ mMapCanvas->setWhatsThis(tr("Map canvas. This is where raster and vector "
"layers are displayed when added to the map"));
// mMapCanvas->setMinimumWidth(10);
Modified: trunk/qgis/src/core/qgsexception.cpp
--- trunk/qgis/src/core/qgsexception.cpp 2008-06-22 15:00:52 UTC (rev 8670)
+++ trunk/qgis/src/core/qgsexception.cpp 2008-06-23 08:54:39 UTC (rev 8671)
@@ -15,7 +15,7 @@
+#include <QObject>
#include "qgsexception.h"
Modified: trunk/qgis/src/ui/qgsattributeactiondialogbase.ui
--- trunk/qgis/src/ui/qgsattributeactiondialogbase.ui 2008-06-22 15:00:52 UTC (rev 8670)
+++ trunk/qgis/src/ui/qgsattributeactiondialogbase.ui 2008-06-23 08:54:39 UTC (rev 8671)
@@ -92,7 +92,7 @@
<string>Click to browse for an action</string>
</property>
<property name="whatsThis" >
- <string>Clicking the buttone will let you select an application to use as the action</string>
+ <string>Clicking the button will let you select an application to use as the action</string>
</property>
<property name="text" >
<string>...</string>
