[QGIS Commit] r8203 - trunk/qgis/cmake
svn_qgis at osgeo.org
Mon Mar 10 12:08:43 EDT 2008
Author: timlinux
Date: 2008-03-10 12:08:43 -0400 (Mon, 10 Mar 2008)
New Revision: 8203
trunk/qgis/cmake/FindGEOS.cmake
trunk/qgis/cmake/FindProj.cmake
Added the possibility to use these libs from non default locations by specifying them in LIB_DIR. Before this change, the presence of the lib in /usr or /usr/local would override command line specified paths
Modified: trunk/qgis/cmake/FindGEOS.cmake
--- trunk/qgis/cmake/FindGEOS.cmake 2008-03-10 16:05:55 UTC (rev 8202)
+++ trunk/qgis/cmake/FindGEOS.cmake 2008-03-10 16:08:43 UTC (rev 8203)
@@ -7,22 +7,28 @@
# GEOS_LIBRARY
+# Normally there is no need to specify /usr/... paths because
+# cmake will look there automatically. However the NO_DEFAULT_PATH
+# prevents this behaviour allowing you to use no standard file
+# locations in preference over standard ones. Note in this case
+# you then need to explicitly add /usr and /usr/local prefixes
+# to the search list. This applies both to FIND_PATH and FIND_LIBRARY
FIND_PATH(GEOS_INCLUDE_DIR geos.h
+ "$ENV{LIB_DIR}/include"
/usr/local/include
/usr/include
- #MSVC
- "$ENV{LIB_DIR}/include"
#mingw
c:/msys/local/include
+ NO_DEFAULT_PATH
FIND_LIBRARY(GEOS_LIBRARY NAMES geos PATHS
+ "$ENV{LIB_DIR}/lib"
/usr/local/lib
/usr/lib
- #MSVC
- "$ENV{LIB_DIR}/lib"
#mingw
c:/msys/local/lib
+ NO_DEFAULT_PATH
IF (GEOS_INCLUDE_DIR AND GEOS_LIBRARY)
Modified: trunk/qgis/cmake/FindProj.cmake
--- trunk/qgis/cmake/FindProj.cmake 2008-03-10 16:05:55 UTC (rev 8202)
+++ trunk/qgis/cmake/FindProj.cmake 2008-03-10 16:08:43 UTC (rev 8203)
@@ -7,20 +7,28 @@
# PROJ_LIBRARY
FIND_PATH(PROJ_INCLUDE_DIR proj_api.h
+ "$ENV{LIB_DIR}/include/proj"
/usr/local/include
/usr/include
- #msvc
- "$ENV{LIB_DIR}/include/proj"
#mingw
+ NO_DEFAULT_PATH
FIND_LIBRARY(PROJ_LIBRARY NAMES proj PATHS
/usr/local/lib
/usr/lib
c:/msys/local/lib
+ NO_DEFAULT_PATH
IF (PROJ_INCLUDE_DIR AND PROJ_LIBRARY)
