[QGIS Commit] r8207 - trunk/qgis/src/app
svn_qgis at osgeo.org
Wed Mar 12 05:52:00 EDT 2008
Author: jef
Date: 2008-03-12 05:52:00 -0400 (Wed, 12 Mar 2008)
New Revision: 8207
trunk/qgis/src/app/qgsattributetable.cpp
code reindented
Modified: trunk/qgis/src/app/qgsattributetable.cpp
--- trunk/qgis/src/app/qgsattributetable.cpp 2008-03-11 23:47:55 UTC (rev 8206)
+++ trunk/qgis/src/app/qgsattributetable.cpp 2008-03-12 09:52:00 UTC (rev 8207)
@@ -58,8 +58,8 @@
QgsAttributeTable::~QgsAttributeTable()
void QgsAttributeTable::columnClicked(int col)
QApplication::setOverrideCursor(Qt::waitCursor);
@@ -67,12 +67,12 @@
//store the ids of the selected rows in a list
QList < int >idsOfSelected;
for (int i = 0; i < numSelections(); i++)
+ for (int j = selection(i).topRow(); j <= selection(i).bottomRow(); j++)
- for (int j = selection(i).topRow(); j <= selection(i).bottomRow(); j++)
- idsOfSelected.append(text(j, 0).toInt());
+ idsOfSelected.append(text(j, 0).toInt());
sortColumn(col, sort_ascending, true);
@@ -80,10 +80,10 @@
rowIdMap.clear();
int id;
for (int i = 0; i < numRows(); i++)
- id = text(i, 0).toInt();
- rowIdMap.insert(id, i);
+ id = text(i, 0).toInt();
+ rowIdMap.insert(id, i);
QObject::disconnect(this, SIGNAL(selectionChanged()), this, SLOT(handleChangedSelections()));
clearSelection(true);
@@ -92,9 +92,9 @@
QList < int >::iterator it;
for (it = idsOfSelected.begin(); it != idsOfSelected.end(); ++it)
- selectRowWithId((*it));
+ selectRowWithId((*it));
QObject::connect(this, SIGNAL(selectionChanged()), this, SLOT(handleChangedSelections()));
//change the sorting order after each sort
@@ -106,39 +106,39 @@
void QgsAttributeTable::keyPressEvent(QKeyEvent * ev)
if (ev->key() == Qt::Key_Control || ev->key() == Qt::Key_Shift)
- lockKeyPressed = true;
+ lockKeyPressed = true;
void QgsAttributeTable::keyReleaseEvent(QKeyEvent * ev)
- lockKeyPressed = false;
+ lockKeyPressed = false;
void QgsAttributeTable::handleChangedSelections()
Q3TableSelection cselection;
if (lockKeyPressed == false)
- //clear the list and evaluate the last selection
- emit selectionRemoved(false);
+ //clear the list and evaluate the last selection
+ emit selectionRemoved(false);
//if there is no current selection, there is nothing to do
if (currentSelection() == -1)
- return;
+ return;
cselection = selection(currentSelection());
for (int index = cselection.topRow(); index <= cselection.bottomRow(); index++)
- emit selected(text(index, 0).toInt(), false);
+ emit selected(text(index, 0).toInt(), false);
//don't send the signal repaintRequested() from here
//but in contentsMouseReleaseEvent() and rowClicked(int)
@@ -162,20 +162,21 @@
QString firstentry = text(0, col);
bool containsletter = false;
for (int i = 0; i < firstentry.length(); i++)
+ if (firstentry.ref(i).isLetter())
- if (firstentry.ref(i).isLetter())
- containsletter = true;
+ containsletter = true;
if (containsletter)
- qsort(0, numRows() - 1, col, ascending, true);
- } else
- qsort(0, numRows() - 1, col, ascending, false);
+ qsort(0, numRows() - 1, col, ascending, true);
+ else
+ qsort(0, numRows() - 1, col, ascending, false);
repaintContents();
@@ -187,59 +188,67 @@
int QgsAttributeTable::compareItems(QString s1, QString s2, bool ascending, bool alphanumeric)
if (alphanumeric)
+ if (s1 > s2)
- if (s1 > s2)
- if (ascending)
- return 1;
- } else
- return -1;
- } else if (s1 < s2)
- if (ascending)
- return -1;
- } else
- return 1;
- } else if (s1 == s2)
- return 0;
- } else //numeric
+ if (ascending)
+ return 1;
+ else
+ return -1;
+ else if (s1 < s2)
- double d1 = s1.toDouble();
- double d2 = s2.toDouble();
- if (d1 > d2)
- if (ascending)
- return 1;
- } else
- return -1;
- } else if (d1 < d2)
- if (ascending)
- return -1;
- } else
- return 1;
- } else if (d1 == d2)
- return 0;
+ if (ascending)
+ return -1;
+ else
+ return 1;
+ else if (s1 == s2)
+ return 0;
+ else //numeric
+ double d1 = s1.toDouble();
+ double d2 = s2.toDouble();
+ if (d1 > d2)
+ if (ascending)
+ return 1;
+ else
+ return -1;
+ else if (d1 < d2)
+ if (ascending)
+ return -1;
+ else
+ return 1;
+ else if (d1 == d2)
+ return 0;
return 0; // XXX has to return something; is this reasonable?
void QgsAttributeTable::qsort(int lower, int upper, int col, bool ascending, bool alphanumeric)
@@ -247,27 +256,27 @@
int i, j;
QString v;
if (upper > lower)
+ //chose a random element (this avoids n^2 worst case)
+ int element = int ( (double)rand() / (double)RAND_MAX * (upper - lower) + lower);
+ swapRows(element, upper);
+ v = text(upper, col);
+ i = lower - 1;
+ j = upper;
+ for (;;)
- //chose a random element (this avoids n^2 worst case)
- int element = int ( (double)rand() / (double)RAND_MAX * (upper - lower) + lower);
- swapRows(element, upper);
- v = text(upper, col);
- i = lower - 1;
- j = upper;
- for (;;)
+ while (compareItems(text(++i, col), v, ascending, alphanumeric) == -1);
+ while (compareItems(text(--j, col), v, ascending, alphanumeric) == 1 && j > 0); //make sure that j does not get negative
+ if (i >= j)
- while (compareItems(text(++i, col), v, ascending, alphanumeric) == -1);
- while (compareItems(text(--j, col), v, ascending, alphanumeric) == 1 && j > 0); //make sure that j does not get negative
- if (i >= j)
- break;
- swapRows(i, j);
- swapRows(i, upper);
- qsort(lower, i - 1, col, ascending, alphanumeric);
- qsort(i + 1, upper, col, ascending, alphanumeric);
+ break;
+ swapRows(i, j);
+ swapRows(i, upper);
+ qsort(lower, i - 1, col, ascending, alphanumeric);
+ qsort(i + 1, upper, col, ascending, alphanumeric);
void QgsAttributeTable::popupMenu(int row, int col, const QPoint& pos)
@@ -324,42 +333,42 @@
bool QgsAttributeTable::addAttribute(const QString& name, const QString& type)
- //first test if an attribute with the same name is already in the table
- for(int i=0;i<horizontalHeader()->count();++i)
+ //first test if an attribute with the same name is already in the table
+ for(int i=0;i<horizontalHeader()->count();++i)
+ if(horizontalHeader()->label(i)==name)
- if(horizontalHeader()->label(i)==name)
- //name conflict
- return false;
+ //name conflict
+ return false;
- mAddedAttributes.insert(name,type);
- QgsDebugMsg("inserting attribute " + name + " of type " + type + ", numCols: " + QString::number(numCols()) );
- //add a new column at the end of the table
- insertColumns(numCols());
- horizontalHeader()->setLabel(numCols()-1,name);
- mEdited=true;
- return true;
+ mAddedAttributes.insert(name,type);
+ QgsDebugMsg("inserting attribute " + name + " of type " + type + ", numCols: " + QString::number(numCols()) );
+ //add a new column at the end of the table
+ insertColumns(numCols());
+ horizontalHeader()->setLabel(numCols()-1,name);
+ mEdited=true;
+ return true;
void QgsAttributeTable::deleteAttribute(const QString& name)
- //check, if there is already an attribute with this name in mAddedAttributes
- QgsNewAttributesMap::iterator iter = mAddedAttributes.find(name);
- if(iter!=mAddedAttributes.end())
- mAddedAttributes.remove(iter);
- removeAttrColumn(name);
- else
- mDeletedAttributes.insert(name);
- mEdited=true;
+ //check, if there is already an attribute with this name in mAddedAttributes
+ QgsNewAttributesMap::iterator iter = mAddedAttributes.find(name);
+ if(iter!=mAddedAttributes.end())
+ mAddedAttributes.remove(iter);
+ removeAttrColumn(name);
+ else
+ mDeletedAttributes.insert(name);
+ mEdited=true;
@@ -384,7 +393,7 @@
for (int row = sel.topRow(); row < sel.topRow()+sel.numRows(); ++row)
for (int column = 0; column < numCols(); ++column)
- toClipboard += text(row, column) + fieldSep;
+ toClipboard += text(row, column) + fieldSep;
toClipboard += '\n';
@@ -417,53 +426,53 @@
QgsVectorDataProvider* provider = layer->getDataProvider();
if(provider)
+ QgsAttributeIds deletedIds;
+ QSet<QString>::const_iterator it = mDeletedAttributes.constBegin();
+ for(; it != mDeletedAttributes.constEnd(); ++it)
+ deletedIds.insert(provider->indexFromFieldName(*it));
- QgsAttributeIds deletedIds;
- QSet<QString>::const_iterator it = mDeletedAttributes.constBegin();
- for(; it != mDeletedAttributes.constEnd(); ++it)
- deletedIds.insert(provider->indexFromFieldName(*it));
+ isSuccessful = true;
+ if( !mAddedAttributes.empty() )
+ // add new attributes beforehand, so attribute changes can be applied
+ isSuccessful = layer->commitAttributeChanges(QgsAttributeIds(), mAddedAttributes, QgsChangedAttributesMap());
- isSuccessful = true;
- if( !mAddedAttributes.empty() )
- // add new attributes beforehand, so attribute changes can be applied
- isSuccessful = layer->commitAttributeChanges(QgsAttributeIds(), mAddedAttributes, QgsChangedAttributesMap());
+ if(isSuccessful)
+ QgsChangedAttributesMap attributeChanges; //convert mChangedValues to QgsChangedAttributesMap
+ int fieldIndex;
+ QMap<int, QMap<QString, QString> >::const_iterator att_it = mChangedValues.constBegin();
+ for(; att_it != mChangedValues.constEnd(); ++att_it)
+ QgsAttributeMap newAttMap;
+ QMap<QString, QString>::const_iterator record_it = att_it->constBegin();
+ for(; record_it != att_it->constEnd(); ++record_it)
+ fieldIndex = provider->indexFromFieldName(record_it.key());
+ if(fieldIndex != -1)
+ newAttMap.insert(fieldIndex, record_it.value());
+ else
+ QgsDebugMsg("Changed attribute " + record_it.key() + " not found");
+ attributeChanges.insert(att_it.key(), newAttMap);
- if(isSuccessful)
- QgsChangedAttributesMap attributeChanges; //convert mChangedValues to QgsChangedAttributesMap
- int fieldIndex;
- QMap<int, QMap<QString, QString> >::const_iterator att_it = mChangedValues.constBegin();
- for(; att_it != mChangedValues.constEnd(); ++att_it)
- QgsAttributeMap newAttMap;
- QMap<QString, QString>::const_iterator record_it = att_it->constBegin();
- for(; record_it != att_it->constEnd(); ++record_it)
- fieldIndex = provider->indexFromFieldName(record_it.key());
- if(fieldIndex != -1)
- newAttMap.insert(fieldIndex, record_it.value());
- else
- QgsDebugMsg("Changed attribute " + record_it.key() + " not found");
- attributeChanges.insert(att_it.key(), newAttMap);
- isSuccessful = layer->commitAttributeChanges(deletedIds,
- QgsNewAttributesMap(),
- attributeChanges);
+ isSuccessful = layer->commitAttributeChanges(deletedIds,
+ QgsNewAttributesMap(),
+ attributeChanges);
if (isSuccessful)
@@ -546,10 +555,10 @@
void QgsAttributeTable::putFeatureInTable(int row, QgsFeature& fet)
if(row >= numRows())//prevent a crash if a provider doesn't update the feature count properly
- setNumRows(row+1);
+ setNumRows(row+1);
//id-field
int id = fet.featureId();
setText(row, 0, QString::number(id));
@@ -568,131 +577,130 @@
//id column is not editable
if(column>0)
+ //find feature id
+ int id=text(row,0).toInt();
+ QString field = horizontalHeader()->label(column);
+ // add empty map for feature if doesn't exist
+ if (!mChangedValues.contains(id))
- //find feature id
- int id=text(row,0).toInt();
- QString field = horizontalHeader()->label(column);
- // add empty map for feature if doesn't exist
- if (!mChangedValues.contains(id))
- mChangedValues.insert(id, QMap<QString, QString>());
- mChangedValues[id].insert(field, text(row,column));
- mEdited=true;
+ mChangedValues.insert(id, QMap<QString, QString>());
+ mChangedValues[id].insert(field, text(row,column));
+ mEdited=true;
void QgsAttributeTable::clearEditingStructures()
- mDeletedAttributes.clear();
- mAddedAttributes.clear();
- mChangedValues.clear();
+ mDeletedAttributes.clear();
+ mAddedAttributes.clear();
+ mChangedValues.clear();
void QgsAttributeTable::removeAttrColumn(const QString& name)
- Q3Header* header=horizontalHeader();
- for(int i=0;i<header->count();++i)
+ Q3Header* header=horizontalHeader();
+ for(int i=0;i<header->count();++i)
+ if(header->label(i)==name)
- if(header->label(i)==name)
- removeColumn(i);
- break;
+ removeColumn(i);
+ break;
void QgsAttributeTable::bringSelectedToTop()
- blockSignals(true);
- int swaptorow=0;
- std::list<Q3TableSelection> selections;
- bool removeselection;
+ blockSignals(true);
+ int swaptorow=0;
+ std::list<Q3TableSelection> selections;
+ bool removeselection;
- for(int i=0;i<numSelections();++i)
- selections.push_back(selection(i));
+ for(int i=0;i<numSelections();++i)
+ selections.push_back(selection(i));
- Q3TableSelection sel;
+ Q3TableSelection sel;
- for(std::list<Q3TableSelection>::iterator iter=selections.begin();iter!=selections.end();++iter)
+ for(std::list<Q3TableSelection>::iterator iter=selections.begin();iter!=selections.end();++iter)
+ removeselection=true;
+ while(isRowSelected(swaptorow, true))//selections are not necessary stored in ascending order
- removeselection=true;
- while(isRowSelected(swaptorow, true))//selections are not necessary stored in ascending order
- ++swaptorow;
- for(int j=iter->topRow();j<=iter->bottomRow();++j)
- if(j>swaptorow)//selections are not necessary stored in ascending order
- swapRows(j,swaptorow);
- selectRow(swaptorow);
- ++swaptorow;
- else
- removeselection=false;//keep selection
- if(removeselection)
- removeSelection(*iter);
+ ++swaptorow;
- //clear and rebuild rowIdMap.
- rowIdMap.clear();
- int id;
- for (int i = 0; i < numRows(); i++)
+ for(int j=iter->topRow();j<=iter->bottomRow();++j)
+ if(j>swaptorow)//selections are not necessary stored in ascending order
+ swapRows(j,swaptorow);
+ selectRow(swaptorow);
+ ++swaptorow;
+ else
+ removeselection=false;//keep selection
+ if(removeselection)
+ removeSelection(*iter);
- blockSignals(false);
+ //clear and rebuild rowIdMap.
+ rowIdMap.clear();
+ int id;
+ for (int i = 0; i < numRows(); i++)
+ blockSignals(false);
void QgsAttributeTable::selectRowsWithId(const QgsFeatureIds& ids)
// if selecting rows takes too much time we can use progress dialog
- QProgressDialog progress( tr("Updating selection..."), tr("Abort"), 0, mSelected.size(), tabledisplay);
- int i=0;
- for(std::set<int>::iterator iter=mSelected.begin();iter!=mSelected.end();++iter)
- ++i;
- progress.setValue(i);
- qApp->processEvents();
- if(progress.wasCanceled())
- //deselect the remaining features if action was canceled
- mSelected.erase(iter,--mSelected.end());
- break;
- selectRowWithId(*iter);//todo: avoid that the table gets repainted during each selection
+ QProgressDialog progress( tr("Updating selection..."), tr("Abort"), 0, mSelected.size(), tabledisplay);
+ int i=0;
+ for(std::set<int>::iterator iter=mSelected.begin();iter!=mSelected.end();++iter)
+ ++i;
+ progress.setValue(i);
+ qApp->processEvents();
+ if(progress.wasCanceled())
+ //deselect the remaining features if action was canceled
+ mSelected.erase(iter,--mSelected.end());
+ break;
+ selectRowWithId(*iter);//todo: avoid that the table gets repainted during each selection
// to select more rows at once effectively, we stop sending signals to handleChangedSelections()
// otherwise it will repaint map everytime row is selected
QgsFeatureIds::const_iterator it;
for (it = ids.begin(); it != ids.end(); it++)
selectRowWithId(*it);
emit repaintRequested();
@@ -700,18 +708,18 @@
void QgsAttributeTable::showRowsWithId(const QgsFeatureIds& ids)
setUpdatesEnabled(false);
// hide all rows first
hideRow(i);
// show only matching rows
showRow(rowIdMap[*it]);
clearSelection(); // deselect all
setUpdatesEnabled(true);
repaintContents();
@@ -726,18 +734,18 @@
void QgsAttributeTable::rowClicked(int row)
if(checkSelectionChanges())//only repaint the canvas if the selection has changed
- emit repaintRequested();
+ emit repaintRequested();
void QgsAttributeTable::contentsMouseReleaseEvent(QMouseEvent* e)
Q3Table::contentsMouseReleaseEvent(e);
bool QgsAttributeTable::checkSelectionChanges()
@@ -746,17 +754,17 @@
- theCurrentSelection.insert(index);
+ theCurrentSelection.insert(index);
if(theCurrentSelection == mLastSelectedRows)
- return false;
+ return false;
else
- mLastSelectedRows = theCurrentSelection;
- return true;
+ mLastSelectedRows = theCurrentSelection;
+ return true;
