[QGIS Commit] r8211 - trunk/qgis/src/app
svn_qgis at osgeo.org
Wed Mar 12 16:43:20 EDT 2008
Author: jef
Date: 2008-03-12 16:43:20 -0400 (Wed, 12 Mar 2008)
New Revision: 8211
trunk/qgis/src/app/qgsattributetable.cpp
trunk/qgis/src/app/qgsattributetable.h
trunk/qgis/src/app/qgsattributetabledisplay.h
allow changing attributes of added and not yet commited features
Modified: trunk/qgis/src/app/qgsattributetable.cpp
--- trunk/qgis/src/app/qgsattributetable.cpp 2008-03-12 14:14:09 UTC (rev 8210)
+++ trunk/qgis/src/app/qgsattributetable.cpp 2008-03-12 20:43:20 UTC (rev 8211)
@@ -32,7 +32,6 @@
#include "qgsvectordataprovider.h"
#include "qgsvectorlayer.h"
-#include <iostream>
#include <stdlib.h>
QgsAttributeTable::QgsAttributeTable(QWidget * parent, const char *name):
@@ -586,14 +585,22 @@
int id=text(row,0).toInt();
QString field = horizontalHeader()->label(column);
- // add empty map for feature if doesn't exist
- if (!mChangedValues.contains(id))
+ if(id>=0)
- mChangedValues.insert(id, QMap<QString, QString>());
+ // add empty map for feature if doesn't exist
+ if (!mChangedValues.contains(id))
+ mChangedValues.insert(id, QMap<QString, QString>());
+ mChangedValues[id].insert(field, text(row,column));
+ mEdited=true;
- mChangedValues[id].insert(field, text(row,column));
- mEdited=true;
+ else
+ // added feature attribute changed
+ emit featureAttributeChanged(row,column);
Modified: trunk/qgis/src/app/qgsattributetable.h
--- trunk/qgis/src/app/qgsattributetable.h 2008-03-12 14:14:09 UTC (rev 8210)
+++ trunk/qgis/src/app/qgsattributetable.h 2008-03-12 20:43:20 UTC (rev 8211)
@@ -104,15 +104,16 @@
/** Shows all rows */
void showAllRows();
- public slots:
- void columnClicked(int col);
- void rowClicked(int row);
+ public slots:
+ void columnClicked(int col);
+ void rowClicked(int row);
// Called when the user requests a popup menu
void popupMenu(int row, int col, const QPoint& pos);
// Called when the user chooses an item on the popup menu
void popupItemSelected(QAction * menuAction);
- protected slots:
- void handleChangedSelections();
+ protected slots:
+ void handleChangedSelections();
/**Writes changed values to 'mChangedValues'*/
void storeChangedValue(int row, int column);
@@ -156,14 +157,15 @@
Also, mLastSelectedRows is updated*/
bool checkSelectionChanges();
-signals:
+ signals:
/**Is emitted when a row was selected*/
void selected(int, bool);
/**Is emitted when all rows have been deselected*/
void selectionRemoved(bool);
- /**Is emmited when a set of related selection and deselection signals have been emitted*/
+ /**Is emitted when a set of related selection and deselection signals have been emitted*/
void repaintRequested();
+ /**Is emitted when a attribute of a added feature is changed*/
+ void featureAttributeChanged(int row, int column);
private:
// Data to do with providing a popup menu of actions that
Modified: trunk/qgis/src/app/qgsattributetabledisplay.h
--- trunk/qgis/src/app/qgsattributetabledisplay.h 2008-03-12 14:14:09 UTC (rev 8210)
+++ trunk/qgis/src/app/qgsattributetabledisplay.h 2008-03-12 20:43:20 UTC (rev 8211)
@@ -73,8 +73,12 @@
void searchShowResultsChanged(int item);
void on_btnHelp_clicked();
+ public slots:
+ void changeFeatureAttribute(int row, int column);
signals:
void deleted();
private:
/** Set the icon theme for this dialog */
void setTheme();
