[QGIS Commit] r8241 - trunk/qgis/src/plugins/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Mar 17 18:42:56 EDT 2008
Author: jef
Date: 2008-03-17 18:42:55 -0400 (Mon, 17 Mar 2008)
New Revision: 8241
   trunk/qgis/src/plugins/grass/qgsgrassattributes.cpp
   trunk/qgis/src/plugins/grass/qgsgrassbrowser.cpp
   trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
   trunk/qgis/src/plugins/grass/qgsgrasstools.cpp
more GRASS reindentation
Modified: trunk/qgis/src/plugins/grass/qgsgrassattributes.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassattributes.cpp	2008-03-17 22:01:26 UTC (rev 8240)
+++ trunk/qgis/src/plugins/grass/qgsgrassattributes.cpp	2008-03-17 22:42:55 UTC (rev 8241)
@@ -58,339 +58,339 @@
 QgsGrassAttributesKeyPress::QgsGrassAttributesKeyPress ( Q3Table *tab )
-    mTable = tab;
+  mTable = tab;
 QgsGrassAttributesKeyPress::~QgsGrassAttributesKeyPress () {};
 bool QgsGrassAttributesKeyPress::eventFilter( QObject *o, QEvent *e )
-    if ( e->type() == QEvent::KeyPress )
-	QKeyEvent *k = (QKeyEvent *)e;
-	if ( k->key() == Qt::Key_Tab ) {
-	    if ( mTable->currentRow() < mTable->numRows()-1 )
-		mTable->setCurrentCell( mTable->currentRow()+1, mTable->currentColumn() );
-	    return TRUE; // eat event
+  if ( e->type() == QEvent::KeyPress )
+    QKeyEvent *k = (QKeyEvent *)e;
+    if ( k->key() == Qt::Key_Tab ) {
+      if ( mTable->currentRow() < mTable->numRows()-1 )
+        mTable->setCurrentCell( mTable->currentRow()+1, mTable->currentColumn() );
+      return TRUE; // eat event
-    return FALSE; // standard event processing
+  return FALSE; // standard event processing
 QgsGrassAttributes::QgsGrassAttributes ( QgsGrassEdit *edit, QgsGrassProvider *provider, int line,
         QWidget * parent, const char * name, Qt::WFlags f )
     : QDialog(parent, f ), QgsGrassAttributesBase ()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassAttributes()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassAttributes()" << std::endl;
+#endif
-    setupUi(this);
+  setupUi(this);
-    mEdit = edit;
-    mProvider = provider;
-    mLine = line;
-    resultLabel->setText ( "" );
+  mEdit = edit;
+  mProvider = provider;
+  mLine = line;
-    // Remove old
-    while ( tabCats->count() ) {
-        tabCats->removePage( tabCats->currentPage() );
+  resultLabel->setText ( "" );
-    connect ( this, SIGNAL(destroyed()), mEdit, SLOT(attributesClosed()) );
+  // Remove old
+  while ( tabCats->count() ) {
+    tabCats->removePage( tabCats->currentPage() );
-    // TODO: does not work:
-    connect( tabCats, SIGNAL(void currentChanged(QWidget *)), this, SLOT(tabChanged(QWidget *)));
+  connect ( this, SIGNAL(destroyed()), mEdit, SLOT(attributesClosed()) );
-    resetButtons();
-    restorePosition();
+  // TODO: does not work:
+  connect( tabCats, SIGNAL(void currentChanged(QWidget *)), this, SLOT(tabChanged(QWidget *)));
+  resetButtons();
+  restorePosition();
 QgsGrassAttributes::~QgsGrassAttributes ()
-    #ifdef QGISDEBUG
-    std::cerr << "~QgsGrassAttributes()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "~QgsGrassAttributes()" << std::endl;
+#endif
-    saveWindowLocation();
+  saveWindowLocation();
 void QgsGrassAttributes::restorePosition()
-  #ifdef QGISDEBUG
+#ifdef QGISDEBUG
   std::cerr << "QgsGrassAttributes::restorePosition()" << std::endl;
-  #endif
+#endif
   QSettings settings;
   restoreGeometry(settings.value("/GRASS/windows/attributes/geometry").toByteArray());
 void QgsGrassAttributes::saveWindowLocation()
-  #ifdef QGISDEBUG
+#ifdef QGISDEBUG
   std::cerr << "QgsGrassAttributes::saveWindowLocation()" << std::endl;
-  #endif
+#endif
   QSettings settings;
   settings.setValue("/GRASS/windows/attributes/geometry", saveGeometry());
 int QgsGrassAttributes::addTab ( const QString & label )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassAttributes::addTab()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassAttributes::addTab()" << std::endl;
+#endif
-    Q3Table *tb = new Q3Table ( 2, 3 );
-    tb->setColumnReadOnly ( 0, TRUE );
-    tb->setColumnReadOnly ( 2, TRUE );
-    tb->setRowReadOnly ( 0, TRUE );
-    tb->setRowReadOnly ( 1, TRUE );
-    tb->horizontalHeader()->setLabel( 0, tr("Column") );
-    tb->horizontalHeader()->setLabel( 1, tr("Value") );
-    tb->horizontalHeader()->setLabel( 2, tr("Type") );  // Internal use
+  Q3Table *tb = new Q3Table ( 2, 3 );
+  tb->setColumnReadOnly ( 0, TRUE );
+  tb->setColumnReadOnly ( 2, TRUE );
+  tb->setRowReadOnly ( 0, TRUE );
+  tb->setRowReadOnly ( 1, TRUE );
-    tb->setLeftMargin(0); // hide row labels
+  tb->horizontalHeader()->setLabel( 0, tr("Column") );
+  tb->horizontalHeader()->setLabel( 1, tr("Value") );
+  tb->horizontalHeader()->setLabel( 2, tr("Type") );  // Internal use
-    tb->setText ( 0, 0, tr("Layer") );
-    tb->setText ( 1, 0, "Cat" );
+  tb->setLeftMargin(0); // hide row labels
-    tabCats->addTab ( tb, label );
+  tb->setText ( 0, 0, tr("Layer") );
+  tb->setText ( 1, 0, "Cat" );
-    // Move down with Tab, unfortunately it does not work if the cell is edited
-    // TODO: catch Tab also if the cell is edited
-    QgsGrassAttributesKeyPress *ef = new QgsGrassAttributesKeyPress ( tb );
-    tb->installEventFilter( ef );
+  tabCats->addTab ( tb, label );
-    resetButtons();
+  // Move down with Tab, unfortunately it does not work if the cell is edited
+  // TODO: catch Tab also if the cell is edited
+  QgsGrassAttributesKeyPress *ef = new QgsGrassAttributesKeyPress ( tb );
+  tb->installEventFilter( ef );
-    QSettings settings;
-    QString path = "/GRASS/windows/attributes/columnWidth/";
-    for ( int i = 0; i < 2; i++ )
-        bool ok;
-	int cw = settings.readNumEntry( path+QString::number(i), 30, &ok);
-	if ( ok ) tb->setColumnWidth (i, cw );
+  resetButtons();
-    connect ( tb->horizontalHeader(), SIGNAL(sizeChange(int,int,int)),
-	      this, SLOT(columnSizeChanged(int,int,int)) );
+  QSettings settings;
+  QString path = "/GRASS/windows/attributes/columnWidth/";
+  for ( int i = 0; i < 2; i++ )
+    bool ok;
+    int cw = settings.readNumEntry( path+QString::number(i), 30, &ok);
+    if ( ok ) tb->setColumnWidth (i, cw );
-    return ( tabCats->count() - 1 );
+  connect ( tb->horizontalHeader(), SIGNAL(sizeChange(int,int,int)),
+    this, SLOT(columnSizeChanged(int,int,int)) );
+  return ( tabCats->count() - 1 );
 void QgsGrassAttributes::setField ( int tab, int field )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassAttributes::setField()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassAttributes::setField()" << std::endl;
+#endif
-    Q3Table *tb = (Q3Table *) tabCats->page(tab);
+  Q3Table *tb = (Q3Table *) tabCats->page(tab);
-    QString str;
-    str.sprintf("%d", field);
-    tb->setText ( 0, 1, str );
+  QString str;
+  str.sprintf("%d", field);
+  tb->setText ( 0, 1, str );
 void QgsGrassAttributes::setCat ( int tab, const QString & name, int cat )
-    #ifdef QGISDEBUG
-    #endif
+#ifdef QGISDEBUG
+#endif
-    tb->setText ( 1, 0, name );
-    QString str;
-    str.sprintf("%d", cat);
-    tb->setText ( 1, 1, str );
+  tb->setText ( 1, 0, name );
+  QString str;
+  str.sprintf("%d", cat);
+  tb->setText ( 1, 1, str );
-void QgsGrassAttributes::addAttribute ( int tab, const QString &name, const QString &value,
-                                  const QString &type )
+void QgsGrassAttributes::addAttribute ( int tab, const QString &name, const QString &value,
+                                        const QString &type )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassAttributes::addAttribute(): " << name.toLocal8Bit().data() << ": " << value.toLocal8Bit().data() << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassAttributes::addAttribute(): " << name.toLocal8Bit().data() << ": " << value.toLocal8Bit().data() << std::endl;
+#endif
-    tb->setNumRows ( tb->numRows()+1 );
+  tb->setNumRows ( tb->numRows()+1 );
-    int row = tb->numRows()-1;
-    tb->setText ( row, 0, name );
+  int row = tb->numRows()-1;
+  tb->setText ( row, 0, name );
-    // I have no rational explanation why fromLocal8Bit is necessary, value should be in unicode
-    // because QgsGrassProvider::attributes is using mEncoding->toUnicode()
-//    tb->setText ( row, 1, QString::fromLocal8Bit(value) );
-    tb->setText ( row, 1, value );
-    tb->setText ( row, 2, type );
+  // I have no rational explanation why fromLocal8Bit is necessary, value should be in unicode
+  // because QgsGrassProvider::attributes is using mEncoding->toUnicode()
+  //    tb->setText ( row, 1, QString::fromLocal8Bit(value) );
+  tb->setText ( row, 1, value );
+  tb->setText ( row, 2, type );
-    resetButtons();
+  resetButtons();
 void QgsGrassAttributes::addTextRow ( int tab, const QString &text )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassAttributes::addTextRow()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassAttributes::addTextRow()" << std::endl;
+#endif
-    tb->setText ( row, 0, text );
-    tb->item(row,0)->setSpan(1,3); // must be after setText() whe item exists
+  tb->setText ( row, 0, text );
+  tb->item(row,0)->setSpan(1,3); // must be after setText() whe item exists
 void QgsGrassAttributes::updateAttributes ( )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassAttributes::updateAttributes()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassAttributes::updateAttributes()" << std::endl;
+#endif
-    if ( tabCats->count() == 0 ) return;
+  if ( tabCats->count() == 0 ) return;
-    Q3Table *tb = (Q3Table *) tabCats->currentPage();
+  Q3Table *tb = (Q3Table *) tabCats->currentPage();
-    if ( tb->numRows() > 2 ) {
+  if ( tb->numRows() > 2 ) {
-      // Stop editing (trick)
-      tb->setColumnReadOnly ( 1, TRUE );
-      tb->setColumnReadOnly ( 1, FALSE );
-      QString sql;
-      for ( int i = 2; i < tb->numRows(); i++ ) {
-	  if ( i > 2 ) sql.append (", ");
-	  QString val = tb->text(i, 1).stripWhiteSpace();
-	  if ( val.isEmpty() )
-	      sql.append ( tb->text(i, 0) + " = null" );
-          else
-	      if ( tb->text(i, 2) == "int" || tb->text(i, 2) == "double" ) {
-		  sql.append ( tb->text(i, 0) + " = " + val );
-	      } else {
-		  val.replace("'","''");
-		  sql.append ( tb->text(i, 0) + " = '" + val + "'" );
+    // Stop editing (trick)
+    tb->setColumnReadOnly ( 1, TRUE );
+    tb->setColumnReadOnly ( 1, FALSE );
-      #ifdef QGISDEBUG
-      std::cerr << "sql: " << sql.toLocal8Bit().data() << std::endl;
-      #endif
+    QString sql;
-      QString *error = mProvider->updateAttributes ( tb->text(0,1).toInt(), tb->text(1,1).toInt(), sql );
+    for ( int i = 2; i < tb->numRows(); i++ ) {
+      if ( i > 2 ) sql.append (", ");
-      if ( !error->isEmpty() ) {
-	  QMessageBox::warning( 0, tr("Warning"), *error );
-	  resultLabel->setText ( tr("ERROR") );
-      } else {
-	  resultLabel->setText ( tr("OK") );
+      QString val = tb->text(i, 1).stripWhiteSpace();
+      if ( val.isEmpty() )
+        sql.append ( tb->text(i, 0) + " = null" );
+      else
+        if ( tb->text(i, 2) == "int" || tb->text(i, 2) == "double" ) {
+          sql.append ( tb->text(i, 0) + " = " + val );
+        } else {
+          val.replace("'","''");
+          sql.append ( tb->text(i, 0) + " = '" + val + "'" );
-      delete error;
+#ifdef QGISDEBUG
+    std::cerr << "sql: " << sql.toLocal8Bit().data() << std::endl;
+#endif
+    QString *error = mProvider->updateAttributes ( tb->text(0,1).toInt(), tb->text(1,1).toInt(), sql );
+    if ( !error->isEmpty() ) {
+      QMessageBox::warning( 0, tr("Warning"), *error );
+      resultLabel->setText ( tr("ERROR") );
+    } else {
+      resultLabel->setText ( tr("OK") );
+    delete error;
 void QgsGrassAttributes::addCat ( )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassAttributes::addCat()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassAttributes::addCat()" << std::endl;
+#endif
-    mEdit->addCat( mLine );
-    // Select new tab
-    tabCats->setCurrentPage( tabCats->count()-1 );
-    resetButtons();
+  mEdit->addCat( mLine );
+  // Select new tab
+  tabCats->setCurrentPage( tabCats->count()-1 );
+  resetButtons();
 void QgsGrassAttributes::deleteCat ( )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassAttributes::deleteCat()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassAttributes::deleteCat()" << std::endl;
+#endif
-    int field = tb->text(0,1).toInt();
-    int cat = tb->text(1,1).toInt();
-    mEdit->deleteCat(mLine, field, cat);
+  int field = tb->text(0,1).toInt();
+  int cat = tb->text(1,1).toInt();
-    tabCats->removePage( tb );
-    delete tb;
-    resetButtons();
+  mEdit->deleteCat(mLine, field, cat);
+  tabCats->removePage( tb );
+  delete tb;
+  resetButtons();
 void QgsGrassAttributes::clear ( )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassAttributes::clear()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassAttributes::clear()" << std::endl;
+#endif
-    while ( tabCats->count() > 0 )
-        delete tb;
-    resetButtons();
+  while ( tabCats->count() > 0 )
+    delete tb;
+  resetButtons();
 void QgsGrassAttributes::tabChanged ( QWidget *widget )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassAttributes::tabChanged()" << std::endl;
-    #endif
-    //Q3Table *tb = (Q3Table *) tabCats->currentPage();
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassAttributes::tabChanged()" << std::endl;
+#endif
+  //Q3Table *tb = (Q3Table *) tabCats->currentPage();
 void QgsGrassAttributes::setLine ( int line )
-    mLine = line;
+  mLine = line;
 void QgsGrassAttributes::resetButtons ( )
-        deleteButton->setEnabled(false);
-        updateButton->setEnabled(false);
-    else
-        deleteButton->setEnabled(true);
-        updateButton->setEnabled(true);
+    deleteButton->setEnabled(false);
+    updateButton->setEnabled(false);
+  else
+    deleteButton->setEnabled(true);
+    updateButton->setEnabled(true);
 void QgsGrassAttributes::columnSizeChanged ( int section, int oldSize, int newSize )
-                   + QString::number(section);
-    std::cerr << "path = " << path.ascii() << " newSize = " << newSize << std::endl;
-    settings.writeEntry( path, newSize);
+    + QString::number(section);
+  std::cerr << "path = " << path.ascii() << " newSize = " << newSize << std::endl;
+  settings.writeEntry( path, newSize);
Modified: trunk/qgis/src/plugins/grass/qgsgrassbrowser.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassbrowser.cpp	2008-03-17 22:01:26 UTC (rev 8240)
+++ trunk/qgis/src/plugins/grass/qgsgrassbrowser.cpp	2008-03-17 22:42:55 UTC (rev 8241)
@@ -58,486 +58,486 @@
 	 QWidget * parent, Qt::WFlags f )
      : QMainWindow(parent, Qt::WType_Dialog), mIface(iface)
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser()" << std::endl;
+#endif
-    QActionGroup *ag = new QActionGroup ( this );
-    QToolBar *tb = addToolBar(tr("Tools"));
+  QActionGroup *ag = new QActionGroup ( this );
+  QToolBar *tb = addToolBar(tr("Tools"));
-    QString myIconPath = QgsApplication::themePath() + "/grass/";
-    mActionAddMap = new QAction(
-	                     QIcon(myIconPath+"grass_add_map.png"),
-	                     tr("Add selected map to canvas"), this);
-    mActionAddMap->setEnabled(false);
-    ag->addAction ( mActionAddMap );
-    tb->addAction ( mActionAddMap );
-    connect ( mActionAddMap, SIGNAL(triggered()), this, SLOT(addMap()) );
+  QString myIconPath = QgsApplication::themePath() + "/grass/";
+  mActionAddMap = new QAction(
+    QIcon(myIconPath+"grass_add_map.png"),
+    tr("Add selected map to canvas"), this);
+  mActionAddMap->setEnabled(false);
+  ag->addAction ( mActionAddMap );
+  tb->addAction ( mActionAddMap );
+  connect ( mActionAddMap, SIGNAL(triggered()), this, SLOT(addMap()) );
-    mActionCopyMap = new QAction(
-	                     QIcon(myIconPath+"grass_copy_map.png"),
-	                     tr("Copy selected map"), this);
-    mActionCopyMap->setEnabled(false);
-    ag->addAction ( mActionCopyMap );
-    tb->addAction ( mActionCopyMap );
-    connect ( mActionCopyMap, SIGNAL(triggered()), this, SLOT(copyMap()) );
+  mActionCopyMap = new QAction(
+    QIcon(myIconPath+"grass_copy_map.png"),
+    tr("Copy selected map"), this);
+  mActionCopyMap->setEnabled(false);
+  ag->addAction ( mActionCopyMap );
+  tb->addAction ( mActionCopyMap );
+  connect ( mActionCopyMap, SIGNAL(triggered()), this, SLOT(copyMap()) );
-    mActionRenameMap = new QAction(
-	                     QIcon(myIconPath+"grass_rename_map.png"),
-	                     tr("Rename selected map"), this);
-    mActionRenameMap->setEnabled(false);
-    ag->addAction ( mActionRenameMap );
-    tb->addAction ( mActionRenameMap );
-    connect ( mActionRenameMap, SIGNAL(triggered()), this, SLOT(renameMap()) );
+  mActionRenameMap = new QAction(
+    QIcon(myIconPath+"grass_rename_map.png"),
+    tr("Rename selected map"), this);
+  mActionRenameMap->setEnabled(false);
+  ag->addAction ( mActionRenameMap );
+  tb->addAction ( mActionRenameMap );
+  connect ( mActionRenameMap, SIGNAL(triggered()), this, SLOT(renameMap()) );
-    mActionDeleteMap = new QAction(
-	                     QIcon(myIconPath+"grass_delete_map.png"),
-	                     tr("Delete selected map"), this);
-    mActionDeleteMap->setEnabled(false);
-    ag->addAction ( mActionDeleteMap );
-    tb->addAction ( mActionDeleteMap );
-    connect ( mActionDeleteMap, SIGNAL(triggered()), this, SLOT(deleteMap()) );
+  mActionDeleteMap = new QAction(
+    QIcon(myIconPath+"grass_delete_map.png"),
+    tr("Delete selected map"), this);
+  mActionDeleteMap->setEnabled(false);
+  ag->addAction ( mActionDeleteMap );
+  tb->addAction ( mActionDeleteMap );
+  connect ( mActionDeleteMap, SIGNAL(triggered()), this, SLOT(deleteMap()) );
-    mActionSetRegion = new QAction(
-	                     QIcon(myIconPath+"grass_set_region.png"),
-	                     tr("Set current region to selected map"), this);
-    mActionSetRegion->setEnabled(false);
-    ag->addAction ( mActionSetRegion );
-    tb->addAction ( mActionSetRegion );
-    connect ( mActionSetRegion, SIGNAL(triggered()), this, SLOT(setRegion()) );
+  mActionSetRegion = new QAction(
+    QIcon(myIconPath+"grass_set_region.png"),
+    tr("Set current region to selected map"), this);
+  mActionSetRegion->setEnabled(false);
+  ag->addAction ( mActionSetRegion );
+  tb->addAction ( mActionSetRegion );
+  connect ( mActionSetRegion, SIGNAL(triggered()), this, SLOT(setRegion()) );
-    mActionRefresh = new QAction(
-	                     QIcon(myIconPath+"grass_refresh.png"),
-	                     tr("Refresh"), this);
-    ag->addAction ( mActionRefresh );
-    tb->addAction ( mActionRefresh );
-    connect ( mActionRefresh, SIGNAL(triggered()), this, SLOT(refresh()) );
+  mActionRefresh = new QAction(
+    QIcon(myIconPath+"grass_refresh.png"),
+    tr("Refresh"), this);
+  ag->addAction ( mActionRefresh );
+  tb->addAction ( mActionRefresh );
+  connect ( mActionRefresh, SIGNAL(triggered()), this, SLOT(refresh()) );
-    // Add model
-    mModel = new QgsGrassModel ( this );
+  // Add model
+  mModel = new QgsGrassModel ( this );
-    mTree = new QTreeView(0);
-    mTree->header()->hide();
-    mTree->setModel(mModel);
+  mTree = new QTreeView(0);
+  mTree->header()->hide();
+  mTree->setModel(mModel);
-    mTextBrowser = new QTextBrowser(0);
-    mTextBrowser->setTextFormat(Qt::RichText);
-    mTextBrowser->setReadOnly(TRUE);
+  mTextBrowser = new QTextBrowser(0);
+  mTextBrowser->setTextFormat(Qt::RichText);
+  mTextBrowser->setReadOnly(TRUE);
-    mSplitter = new QSplitter(0);
-    mSplitter->addWidget(mTree);
-    mSplitter->addWidget(mTextBrowser);
+  mSplitter = new QSplitter(0);
+  mSplitter->addWidget(mTree);
+  mSplitter->addWidget(mTextBrowser);
-    this->setCentralWidget(mSplitter);
+  this->setCentralWidget(mSplitter);
-    connect ( mTree->selectionModel(),
-	      SIGNAL(selectionChanged(QItemSelection,QItemSelection)),
-	      this, SLOT(selectionChanged(QItemSelection,QItemSelection)) );
+  connect ( mTree->selectionModel(),
+    SIGNAL(selectionChanged(QItemSelection,QItemSelection)),
+    this, SLOT(selectionChanged(QItemSelection,QItemSelection)) );
-	      SIGNAL(currentChanged(QModelIndex,QModelIndex)),
-	      this, SLOT(currentChanged(QModelIndex,QModelIndex)) );
+    SIGNAL(currentChanged(QModelIndex,QModelIndex)),
+    this, SLOT(currentChanged(QModelIndex,QModelIndex)) );
-    connect ( mTree, SIGNAL(doubleClicked(QModelIndex)),
-	      this, SLOT(doubleClicked(QModelIndex)) );
+  connect ( mTree, SIGNAL(doubleClicked(QModelIndex)),
+    this, SLOT(doubleClicked(QModelIndex)) );
 QgsGrassBrowser::~QgsGrassBrowser() { }
 void QgsGrassBrowser::refresh()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser::refresh()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser::refresh()" << std::endl;
+#endif
-    mModel->refresh();
-    mTree->update();
+  mModel->refresh();
+  mTree->update();
 void QgsGrassBrowser::addMap()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser::addMap()" << std::endl;
-    #endif
-    QModelIndexList indexes = mTree->selectionModel()->selectedIndexes();
-    bool mapSelected = false;
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser::addMap()" << std::endl;
+#endif
-    QList<QModelIndex>::const_iterator it = indexes.begin();
-    for (; it != indexes.end(); ++it)
+  QModelIndexList indexes = mTree->selectionModel()->selectedIndexes();
+  bool mapSelected = false;
+  QList<QModelIndex>::const_iterator it = indexes.begin();
+  for (; it != indexes.end(); ++it)
+    int type = mModel->itemType(*it);
+    QString uri = mModel->uri(*it);
+    QString mapset = mModel->itemMapset(*it);
+    QString map = mModel->itemMap(*it);
+    if ( type == QgsGrassModel::Raster )
-	int type = mModel->itemType(*it);
-	QString uri = mModel->uri(*it);
-        QString mapset = mModel->itemMapset(*it);
-        QString map = mModel->itemMap(*it);
-        if ( type == QgsGrassModel::Raster )
-            std::cerr << "add raster: " << uri.ascii() << std::endl;
-            mIface->addRasterLayer(uri, map);
-	    mapSelected = true;
-	else if ( type == QgsGrassModel::Vector )
-            QgsGrassUtils::addVectorLayers ( mIface,
-                                QgsGrass::getDefaultGisdbase(),
-                                QgsGrass::getDefaultLocation(),
-                                mapset, map );
-	else if ( type == QgsGrassModel::VectorLayer )
+      std::cerr << "add raster: " << uri.ascii() << std::endl;
+      mIface->addRasterLayer(uri, map);
+      mapSelected = true;
+    else if ( type == QgsGrassModel::Vector )
+      QgsGrassUtils::addVectorLayers ( mIface,
+        QgsGrass::getDefaultGisdbase(),
+        QgsGrass::getDefaultLocation(),
+        mapset, map );
+    else if ( type == QgsGrassModel::VectorLayer )
-            QStringList list = QgsGrassSelect::vectorLayers(
-                          mModel->itemMapset(*it), map );
+      QStringList list = QgsGrassSelect::vectorLayers(
+        mModel->itemMapset(*it), map );
-	    // TODO: common method for vector names
-	    QStringList split = QStringList::split ( '/', uri );
-	    QString layer = split.last();
+      // TODO: common method for vector names
+      QStringList split = QStringList::split ( '/', uri );
+      QString layer = split.last();
-            QString name = QgsGrassUtils::vectorLayerName (
-                                map, layer, list.size() );
-	    mIface->addVectorLayer( uri, name, "grass");
-	else if ( type == QgsGrassModel::Region )
-	    struct Cell_head window;
-            if ( !getItemRegion (*it, &window) ) continue;
-	    writeRegion ( &window );
+      QString name = QgsGrassUtils::vectorLayerName (
+        map, layer, list.size() );
+      mIface->addVectorLayer( uri, name, "grass");
+    else if ( type == QgsGrassModel::Region )
+      struct Cell_head window;
+      if ( !getItemRegion (*it, &window) ) continue;
+      writeRegion ( &window );
 void QgsGrassBrowser::doubleClicked(const QModelIndex & index)
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser::doubleClicked()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser::doubleClicked()" << std::endl;
+#endif
-    addMap();
+  addMap();
 QString QgsGrassBrowser::formatMessage( QString msg )
-    return msg.replace("<","&lt;").replace(">","&gt;").replace("\n","<br>");
+  return msg.replace("<","&lt;").replace(">","&gt;").replace("\n","<br>");
 void QgsGrassBrowser::copyMap()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser::copyMap()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser::copyMap()" << std::endl;
+#endif
+    QString typeName;
+    QString element;
+      element = "cell";
+      typeName = "rast";
+      element = "vector";
+      typeName = "vect";
+      element = "windows";
+      typeName = "region";
-        QString typeName;
-        QString element;
-           element = "cell";
-           typeName = "rast";
-            element = "vector";
-            typeName = "vect";
-            element = "windows";
-            typeName = "region";
+    QgsGrassElementDialog ed;
+    bool ok;
+    QString source;
+    QString suggest;
+    if ( mapset == QgsGrass::getDefaultMapset() )
+      source = map;
+    else
+      suggest = map;
+    QString newName = ed.getItem ( element, tr("New name"),
+      tr("New name"), suggest, source, &ok );
-        QgsGrassElementDialog ed;
-        bool ok;
-        QString source;
-        QString suggest;
-        if ( mapset == QgsGrass::getDefaultMapset() )
-            source = map;
-        else
-            suggest = map;
-        QString newName = ed.getItem ( element, tr("New name"),
-                          tr("New name"), suggest, source, &ok );
+    if ( !ok ) return;
-        if ( !ok ) return;
-        QString module = "g.copy";
+    QString module = "g.copy";
 #ifdef WIN32
-	module.append(".exe");
+    module.append(".exe");
 #endif
-        QProcess process(this);
-        QStringList args(typeName + "=" + map + "@" + mapset + "," + newName );
-        process.start(module, args );
-        if ( !process.waitForFinished() || process.exitCode() != 0 )
-            QString output ( process.readAllStandardOutput () );
-            QString error ( process.readAllStandardError () );
-            QMessageBox::warning( 0, tr("Warning"), tr("Cannot copy map ")
-                       + map + "@" + mapset
-                       + tr("<br>command: ") + module + " " + args.join(" ")
-                       + "<br>" + formatMessage(output)
-                       + "<br>" + formatMessage(error) );
-        else
-            refresh();
+    QProcess process(this);
+    QStringList args(typeName + "=" + map + "@" + mapset + "," + newName );
+    process.start(module, args );
+    if ( !process.waitForFinished() || process.exitCode() != 0 )
+      QString output ( process.readAllStandardOutput () );
+      QString error ( process.readAllStandardError () );
+      QMessageBox::warning( 0, tr("Warning"), tr("Cannot copy map ")
+        + map + "@" + mapset
+        + tr("<br>command: ") + module + " " + args.join(" ")
+        + "<br>" + formatMessage(output)
+        + "<br>" + formatMessage(error) );
+    else
+      refresh();
 void QgsGrassBrowser::renameMap()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser::renameMap()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser::renameMap()" << std::endl;
+#endif
+    if ( mapset != QgsGrass::getDefaultMapset() ) continue; // should not happen
+    QString typeName;
+    QString element;
+      element = "cell";
-	if ( mapset != QgsGrass::getDefaultMapset() ) continue; // should not happen
+    bool ok;
+      tr("New name"), "", map, &ok );
-        QString typeName;
-        QString element;
-           element = "cell";
-        bool ok;
-                          tr("New name"), "", map, &ok );
-        QString module = "g.rename";
+    QString module = "g.rename";
 #ifdef WIN32
 #endif
-        QStringList args(typeName + "=" + map + "," + newName );
-        process.start(module, QStringList( typeName + "=" + map + "," + newName ) );
-            QMessageBox::warning( 0, tr("Warning"), tr("Cannot rename map ")
-                       + map
-        else
-            refresh();
+    QStringList args(typeName + "=" + map + "," + newName );
+    process.start(module, QStringList( typeName + "=" + map + "," + newName ) );
+      QMessageBox::warning( 0, tr("Warning"), tr("Cannot rename map ")
+        + map
+    else
+      refresh();
 void QgsGrassBrowser::deleteMap()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser::deleteMap()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser::deleteMap()" << std::endl;
+#endif
+    QString typeName;
+    if ( type == QgsGrassModel::Raster ) typeName = "rast";
+    else if ( type == QgsGrassModel::Vector ) typeName = "vect";
+    else if ( type == QgsGrassModel::Region ) typeName = "region";
+      continue; // should not happen
-        QString typeName;
-        if ( type == QgsGrassModel::Raster ) typeName = "rast";
-        else if ( type == QgsGrassModel::Vector ) typeName = "vect";
-        else if ( type == QgsGrassModel::Region ) typeName = "region";
+    QMessageBox::StandardButton ret = QMessageBox::question ( 0, tr("Warning"),
+      tr("Delete map <b>") + map + "</b>",
+      QMessageBox::Ok | QMessageBox::Cancel );
-            continue; // should not happen
-        QMessageBox::StandardButton ret = QMessageBox::question ( 0, tr("Warning"),
-              tr("Delete map <b>") + map + "</b>",
-              QMessageBox::Ok | QMessageBox::Cancel );
+    if ( ret == QMessageBox::Cancel ) continue;
-        if ( ret == QMessageBox::Cancel ) continue;
-        QString module = "g.remove";
+    QString module = "g.remove";
 #ifdef WIN32
 #endif
-        QStringList args(typeName + "=" + map );
-        process.start(module, QStringList( typeName + "=" + map ) );
-            QMessageBox::warning( 0, tr("Warning"), tr("Cannot delete map ")
-                       + map
-        else
-            refresh();
+    QStringList args(typeName + "=" + map );
+    process.start(module, QStringList( typeName + "=" + map ) );
+      QMessageBox::warning( 0, tr("Warning"), tr("Cannot delete map ")
+        + map
+    else
+      refresh();
 void QgsGrassBrowser::setRegion()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser::setRegion()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser::setRegion()" << std::endl;
+#endif
-    // TODO multiple selection - extent region to all maps
-        if ( !getItemRegion (*it, &window) ) return;
+  // TODO multiple selection - extent region to all maps
+    if ( !getItemRegion (*it, &window) ) return;
 void QgsGrassBrowser::writeRegion(struct Cell_head *window )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser::writeRegion()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser::writeRegion()" << std::endl;
+#endif
-    QgsGrass::setMapset( QgsGrass::getDefaultGisdbase(),
-                         QgsGrass::getDefaultMapset() );
+  QgsGrass::setMapset( QgsGrass::getDefaultGisdbase(),
+    QgsGrass::getDefaultMapset() );
-    if ( G_put_window ( window ) == -1 )
-		 tr("Cannot write new region") );
-        return;
-    emit regionChanged();
+  if ( G_put_window ( window ) == -1 )
+      tr("Cannot write new region") );
+    return;
+  emit regionChanged();
 bool QgsGrassBrowser::getItemRegion( QModelIndex index, struct Cell_head *window )
-    #ifdef QGISDEBUG
-    #endif
+#ifdef QGISDEBUG
+#endif
-    int type = mModel->itemType(index);
-    QString mapset = mModel->itemMapset(index);
-    QString map = mModel->itemMap(index);
+  int type = mModel->itemType(index);
+  QString mapset = mModel->itemMapset(index);
+  QString map = mModel->itemMap(index);
-    int mapType = QgsGrass::Raster; //default in case no case matches
-    switch (type) {
+  int mapType = QgsGrass::Raster; //default in case no case matches
+  switch (type) {
         case QgsGrassModel::Raster :
-	    mapType = QgsGrass::Raster;
-            break;
+          mapType = QgsGrass::Raster;
+          break;
         case QgsGrassModel::Vector :
-	    mapType = QgsGrass::Vector;
-            break;
+          mapType = QgsGrass::Vector;
+          break;
         case QgsGrassModel::Region :
-	    mapType = QgsGrass::Region;
-            break;
-	default:
-            break;
-    return QgsGrass::mapRegion ( mapType, QgsGrass::getDefaultGisdbase(),
-            QgsGrass::getDefaultLocation(), mapset, map, window );
+          mapType = QgsGrass::Region;
+          break;
+        default:
+          break;
+  return QgsGrass::mapRegion ( mapType, QgsGrass::getDefaultGisdbase(),
+    QgsGrass::getDefaultLocation(), mapset, map, window );
 void QgsGrassBrowser::selectionChanged(const QItemSelection & selected, const QItemSelection & deselected)
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser::selectionChanged()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser::selectionChanged()" << std::endl;
+#endif
-    mTextBrowser->clear();
+  mTextBrowser->clear();
+    mTextBrowser->append ( mModel->itemInfo(*it) );
+    mTextBrowser->verticalScrollBar()->setValue(0);
+    if ( type == QgsGrassModel::Raster ||
+      type == QgsGrassModel::Vector ||
+      type == QgsGrassModel::VectorLayer )
-        mTextBrowser->append ( mModel->itemInfo(*it) );
-        mTextBrowser->verticalScrollBar()->setValue(0);
-        if ( type == QgsGrassModel::Raster ||
-             type == QgsGrassModel::Vector ||
-             type == QgsGrassModel::VectorLayer )
-	    mActionAddMap->setEnabled(true);
-        if ( type == QgsGrassModel::Raster || type == QgsGrassModel::Vector || type == QgsGrassModel::Region )
-            mActionSetRegion->setEnabled(true);
-            mActionCopyMap->setEnabled(true);
+      mActionAddMap->setEnabled(true);
+    if ( type == QgsGrassModel::Raster || type == QgsGrassModel::Vector || type == QgsGrassModel::Region )
+      mActionSetRegion->setEnabled(true);
+      mActionCopyMap->setEnabled(true);
-	        mActionDeleteMap->setEnabled(true);
-	        mActionRenameMap->setEnabled(true);
+        mActionDeleteMap->setEnabled(true);
+        mActionRenameMap->setEnabled(true);
 void QgsGrassBrowser::currentChanged(const QModelIndex & current, const QModelIndex & previous)
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassBrowser::currentChanged()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassBrowser::currentChanged()" << std::endl;
+#endif
 void QgsGrassBrowser::setLocation( const QString &gisbase, const QString &location )
-    mModel->setLocation(gisbase, location);
+  mModel->setLocation(gisbase, location);
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp	2008-03-17 22:01:26 UTC (rev 8240)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp	2008-03-17 22:42:55 UTC (rev 8241)
@@ -145,8 +145,8 @@
 bool QgsGrassModule::inExecPath ( QString file )
-    if ( findExec(file).isNull() ) return false;
-    return true;
+  if ( findExec(file).isNull() ) return false;
+  return true;
 QStringList QgsGrassModule::execArguments ( QString module )
@@ -353,7 +353,7 @@
   if ( arguments.size() == 0 )
     QMessageBox::warning( 0, tr("Warning"), tr("Cannot find module ")
-        + mXName );
+      + mXName );
     return;
@@ -367,13 +367,13 @@
   // ? Does binary on Win need .exe extention ?
   // Return code 255 (-1) was correct in GRASS < 6.1.0
-      || (process.exitCode() != 0 && process.exitCode() != 255) )
+    || (process.exitCode() != 0 && process.exitCode() != 255) )
     QgsDebugMsg("process.exitCode() = " + QString::number(process.exitCode()) );
     QMessageBox::warning( 0, tr("Warning"), tr("Cannot start module ") + mXName + "<br>"
-        + cmd + " " + arguments.join(" ") + "<br>"
-        + QString(process.readAllStandardOutput()) + "<br>"
-        + QString(process.readAllStandardError()) );
+      + cmd + " " + arguments.join(" ") + "<br>"
+      + QString(process.readAllStandardOutput()) + "<br>"
+      + QString(process.readAllStandardError()) );
     return;
   QByteArray gDescArray = process.readAllStandardOutput();
@@ -384,7 +384,7 @@
   int line, column;
   if ( !gDoc.setContent( (QByteArray)gDescArray, &err, &line, &column ) ) {
     QString errmsg = tr("Cannot read module description (") + mXName + tr("):\n") + err + tr("\nat line ")
-                     + QString::number(line) + tr(" column ") + QString::number(column);
+      + QString::number(line) + tr(" column ") + QString::number(column);
     QgsDebugMsg(errmsg);
     QgsDebugMsg(QString(gDescArray));
     QgsDebugMsg(QString(errArray));
@@ -424,7 +424,7 @@
           //QgsDebugMsg("element = " + element + " age = " + age);
           if ( age == "old" && ( element == "vector" || element == "cell") ) {
             QgsGrassModuleInput *mi = new QgsGrassModuleInput (
-                mModule, this, key, e, gDocElem, gnode, mParent );
+              mModule, this, key, e, gDocElem, gnode, mParent );
             layout->addWidget ( mi );
             created = true;
@@ -434,7 +434,7 @@
         if ( !created ) {
           QgsGrassModuleOption *so = new QgsGrassModuleOption (
-              mModule, key, e, gDocElem, gnode, mParent );
+            mModule, key, e, gDocElem, gnode, mParent );
           layout->addWidget ( so );
           created = true;
@@ -444,46 +444,46 @@
       else if ( optionType == "ogr" )
         QgsGrassModuleGdalInput *mi = new QgsGrassModuleGdalInput (
-            mModule, QgsGrassModuleGdalInput::Ogr, key, e,
-            gDocElem, gnode, mParent );
+          mModule, QgsGrassModuleGdalInput::Ogr, key, e,
+          gDocElem, gnode, mParent );
         mItems.push_back(mi);
       else if ( optionType == "gdal" )
-            mModule, QgsGrassModuleGdalInput::Gdal, key, e,
+          mModule, QgsGrassModuleGdalInput::Gdal, key, e,
       else if ( optionType == "field" )
         QgsGrassModuleField *mi = new QgsGrassModuleField (
       else if ( optionType == "selection" )
         QgsGrassModuleSelection *mi = new QgsGrassModuleSelection (
       else if ( optionType == "file" )
         QgsGrassModuleFile *mi = new QgsGrassModuleFile (
       else if ( optionType == "flag" )
         QgsGrassModuleFlag *flag = new QgsGrassModuleFlag (
         layout->addWidget ( flag );
         mItems.push_back(flag);
@@ -854,11 +854,11 @@
     int mapType;
     switch ( item->type() ) {
     case QgsGrassModuleInput::Raster :
-              break;
-            case QgsGrassModuleInput::Vector :
-              break;
+      break;
+    case QgsGrassModuleInput::Vector :
+      break;
     QStringList mm = item->currentMap().split("@");
@@ -972,7 +972,7 @@
   int line, column;
   if ( !qDoc.setContent( &qFile,  &err, &line, &column ) ) {
     QString errmsg = tr("Cannot read module file (") + path + tr("):\n") + err + tr("\nat line ")
     QMessageBox::warning( 0, tr("Warning"), errmsg );
     qFile.close();
@@ -1146,8 +1146,8 @@
       if ( outsideRegion.size() > 0 )
         QMessageBox questionBox( QMessageBox::Question, "Warning",
-            "Input " + outsideRegion.join(",") + " outside current region!",
+          "Input " + outsideRegion.join(",") + " outside current region!",
         QPushButton *resetButton = NULL;
         if  ( QgsGrass::versionMajor() > 6 || QgsGrass::versionMajor() == 6 && QgsGrass::versionMinor() >= 1 )
@@ -1163,7 +1163,7 @@
           if ( !mOptions->inputRegion ( &tempWindow, true ) )
             QMessageBox::warning ( 0, tr("Warning"),
-                tr("Cannot get input region" ) );
+              tr("Cannot get input region" ) );
             return;
@@ -1175,9 +1175,9 @@
     if ( outputExists.size() > 0 )
       QMessageBox::StandardButton ret = QMessageBox::question ( 0, "Warning",
-          "Output " + outputExists.join(",")
-          + " exists! Overwrite?",
+        "Output " + outputExists.join(",")
+        + " exists! Overwrite?",
       if ( ret == QMessageBox::Cancel ) return;
@@ -1220,12 +1220,12 @@
     /* WARNING - TODO: there was a bug in GRASS 6.0.0 / 6.1.CVS (< 2005-04-29):
-     * db_start_driver set GISRC_MODE_MEMORY eviroment variable to 1 if
-     * G_get_gisrc_mode() == G_GISRC_MODE_MEMORY but the variable wasn't unset
-     * if  G_get_gisrc_mode() == G_GISRC_MODE_FILE. Because QGIS GRASS provider starts drivers in
-     * G_GISRC_MODE_MEMORY mode, the variable remains set in variable when a module is run
-     * -> unset GISRC_MODE_MEMORY. Remove later once 6.1.x / 6.0.1 is widespread.
+    * db_start_driver set GISRC_MODE_MEMORY eviroment variable to 1 if
+    * G_get_gisrc_mode() == G_GISRC_MODE_MEMORY but the variable wasn't unset
+    * if  G_get_gisrc_mode() == G_GISRC_MODE_FILE. Because QGIS GRASS provider starts drivers in
+    * G_GISRC_MODE_MEMORY mode, the variable remains set in variable when a module is run
+    * -> unset GISRC_MODE_MEMORY. Remove later once 6.1.x / 6.0.1 is widespread.
     putenv ( "GISRC_MODE_MEMORY" );  // unset
     mOutputTextBrowser->clear();
@@ -1265,7 +1265,7 @@
     if ( execArguments.size() == 0 )
-          + mXName );
+        + mXName );
       return;
@@ -1337,7 +1337,7 @@
     if ( mProcess.state() != QProcess::Running )
       QMessageBox::warning( 0, tr("Warning"), tr("Cannot start module: ")
-          + mProcess.errorString() );
+        + mProcess.errorString() );
       return;
@@ -1452,9 +1452,9 @@
     QString map = mOutputVector.at(i);
     QStringList layers = QgsGrassSelect::vectorLayers (
-        QgsGrass::getDefaultMapset(), map );
+      QgsGrass::getDefaultMapset(), map );
     // check whether there are 1_* layers
     // if so, 0_* layers won't be added
@@ -2065,24 +2065,24 @@
   QHBoxLayout *l = new QHBoxLayout (this);
   mLayerComboBox = new QComboBox ();
   mLayerComboBox->setSizePolicy (QSizePolicy::Expanding,
-      QSizePolicy:: Preferred );
+    QSizePolicy:: Preferred );
   l->addWidget ( mLayerComboBox );
   QString region = qdesc.attribute("region");
   if ( mType == Raster
-      && QgsGrass::versionMajor() >= 6 && QgsGrass::versionMinor() >= 1
-      && region != "no"
+    && QgsGrass::versionMajor() >= 6 && QgsGrass::versionMinor() >= 1
+    && region != "no"
     QString iconPath = QgsApplication::themePath() + "/grass/";
     mRegionButton = new QPushButton(
-        QIcon(iconPath+"grass_set_region.png"), "" );
+      QIcon(iconPath+"grass_set_region.png"), "" );
     mRegionButton->setToolTip ( tr("Use region of this map") );
     mRegionButton->setCheckable ( true );
     mRegionButton->setSizePolicy (QSizePolicy::Minimum,
     l->addWidget ( mRegionButton );
@@ -2185,9 +2185,9 @@
       int geomType = provider->geometryType();
       if ( (geomType == QGis::WKBPoint && !(mVectorTypeMask & GV_POINT) ) ||
-          (geomType == QGis::WKBLineString && !(mVectorTypeMask & GV_LINE) ) ||
-          (geomType == QGis::WKBPolygon && !(mVectorTypeMask & GV_AREA) )
+        (geomType == QGis::WKBLineString && !(mVectorTypeMask & GV_LINE) ) ||
+        (geomType == QGis::WKBPolygon && !(mVectorTypeMask & GV_AREA) )
         continue;
@@ -2403,7 +2403,7 @@
 void QgsGrassModuleInput::changed(int i)
-    emit valueChanged();
+  emit valueChanged();
 QString QgsGrassModuleInput::ready()
@@ -2567,7 +2567,7 @@
       QgsVectorLayer *vector = (QgsVectorLayer*)layer;
       if ( vector->providerType() != "ogr"
-          && vector->providerType() != "postgres" ) continue;
+        && vector->providerType() != "postgres" ) continue;
       QgsDataProvider *provider = vector->getDataProvider();
@@ -2650,10 +2650,10 @@
       if  ( mOgrLayers[current].length() > 0 )
-            tr("PostGIS driver in OGR does not support schemas!<br>"
-              "Only the table name will be used.<br>"
-              "It can result in wrong input if more tables of the same name<br>"
-              "are present in the database.") );
+          tr("PostGIS driver in OGR does not support schemas!<br>"
+          "Only the table name will be used.<br>"
+          "It can result in wrong input if more tables of the same name<br>"
+          "are present in the database.") );
 #endif //GDAL_VERSION_NUM
@@ -2761,12 +2761,12 @@
 QStringList QgsGrassModuleField::options()
-    QStringList list;
+  QStringList list;
-    QString opt(mKey + "=" + mFieldComboBox->currentText() );
-    list.push_back( opt );
+  QString opt(mKey + "=" + mFieldComboBox->currentText() );
+  list.push_back( opt );
-    return list;
+  return list;
 QgsGrassModuleField::~QgsGrassModuleField()
@@ -2875,12 +2875,12 @@
 QStringList QgsGrassModuleSelection::options()
-    QStringList list;
+  QStringList list;
-    QString opt(mKey + "=" + mLineEdit->text() );
+  QString opt(mKey + "=" + mLineEdit->text() );
-    return list;
+  return list;
 QgsGrassModuleSelection::~QgsGrassModuleSelection()
@@ -2946,7 +2946,7 @@
   l->addWidget ( mBrowseButton );
   connect ( mBrowseButton, SIGNAL(clicked()),
-      this, SLOT(browse()) );
+    this, SLOT(browse()) );
 QStringList QgsGrassModuleFile::options()
@@ -2976,7 +2976,7 @@
 void QgsGrassModuleFile::browse()
   // TODO: unfortunately QFileDialog does not support 'new' directory
-  QFileDialog *fd = new QFileDialog ( this, NULL, mLineEdit->text() );
+  QFileDialog *fd = new QFileDialog( this, NULL, mLineEdit->text());
   fd->setDirectory ( QDir::current() );
Modified: trunk/qgis/src/plugins/grass/qgsgrasstools.cpp
--- trunk/qgis/src/plugins/grass/qgsgrasstools.cpp	2008-03-17 22:01:26 UTC (rev 8240)
+++ trunk/qgis/src/plugins/grass/qgsgrasstools.cpp	2008-03-17 22:42:55 UTC (rev 8241)
@@ -72,370 +72,370 @@
 #include "qgsgrassbrowser.h"
 QgsGrassToolsTabWidget::QgsGrassToolsTabWidget( QWidget * parent ):
-        QTabWidget(parent)
+  QTabWidget(parent)
-    // Default height seems to be too small for our purpose
-    int height = (int)(1.5 * tabBar()->iconSize().height());
-    // Max width (see QgsGrassModule::pixmap for hardcoded sizes)
-    int width = 3*height + 28 + 29;
-    tabBar()->setIconSize( QSize(width,height) );
+  // Default height seems to be too small for our purpose
+  int height = (int)(1.5 * tabBar()->iconSize().height());
+  // Max width (see QgsGrassModule::pixmap for hardcoded sizes)
+  int width = 3*height + 28 + 29;
+  tabBar()->setIconSize( QSize(width,height) );
 QSize QgsGrassToolsTabWidget::iconSize()
-    return tabBar()->iconSize();
+  return tabBar()->iconSize();
 QgsGrassToolsTabWidget::~QgsGrassToolsTabWidget() {}
 QgsGrassTools::QgsGrassTools ( QgisInterface *iface,
-             :QDialog ( parent )
+ : QDialog ( parent )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassTools()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassTools()" << std::endl;
+#endif
-   setWindowTitle ( tr("GRASS Tools") );
-//    setupUi(this);
+  setWindowTitle ( tr("GRASS Tools") );
+  //    setupUi(this);
-    mIface = iface;
-    mCanvas = mIface->getMapCanvas();
+  mIface = iface;
+  mCanvas = mIface->getMapCanvas();
-    connect( qApp, SIGNAL(aboutToQuit()),
-		         this, SLOT(closeTools()) );
+  connect( qApp, SIGNAL(aboutToQuit()),
+    this, SLOT(closeTools()) );
-    mTabWidget = new QgsGrassToolsTabWidget (this);
-    QVBoxLayout *layout1 = new QVBoxLayout(this);
-    layout1->addWidget(mTabWidget);
+  mTabWidget = new QgsGrassToolsTabWidget (this);
+  QVBoxLayout *layout1 = new QVBoxLayout(this);
+  layout1->addWidget(mTabWidget);
-    mModulesListView = new QTreeWidget();
-    mTabWidget->addTab( mModulesListView, tr("Modules") );
-    mModulesListView->setColumnCount(1);
-    QStringList headers;
-    headers << tr("Modules");
-    mModulesListView->setHeaderLabels(headers);
-    // Set list view
-    mModulesListView->clear();
-    mModulesListView->setSortingEnabled(false);
-    mModulesListView->setRootIsDecorated(true);
-//    mModulesListView->setResizeMode(QTreeWidget::AllColumns);
-    mModulesListView->header()->hide();
+  mModulesListView = new QTreeWidget();
+  mTabWidget->addTab( mModulesListView, tr("Modules") );
+  mModulesListView->setColumnCount(1);
+  QStringList headers;
+  headers << tr("Modules");
+  mModulesListView->setHeaderLabels(headers);
+  // Set list view
+  mModulesListView->clear();
+  mModulesListView->setSortingEnabled(false);
+  mModulesListView->setRootIsDecorated(true);
+  //    mModulesListView->setResizeMode(QTreeWidget::AllColumns);
+  mModulesListView->header()->hide();
-    connect( mModulesListView, SIGNAL(itemClicked(QTreeWidgetItem *, int)),
-		         this, SLOT(moduleClicked( QTreeWidgetItem *, int)) );
+  connect( mModulesListView, SIGNAL(itemClicked(QTreeWidgetItem *, int)),
+    this, SLOT(moduleClicked( QTreeWidgetItem *, int)) );
-    QString title = tr("GRASS Tools: ") + QgsGrass::getDefaultLocation()
-                + "/" + QgsGrass::getDefaultMapset();
-    setCaption(title);
+  QString title = tr("GRASS Tools: ") + QgsGrass::getDefaultLocation()
+    + "/" + QgsGrass::getDefaultMapset();
+  setCaption(title);
-    QString conf = QgsApplication::pkgDataPath() + "/grass/config/default.qgc";
+  QString conf = QgsApplication::pkgDataPath() + "/grass/config/default.qgc";
-    // Show before loadConfig() so that user can see loading
-    mModulesListView->show();
+  // Show before loadConfig() so that user can see loading
+  mModulesListView->show();
-    QApplication::setOverrideCursor(Qt::waitCursor);
-    loadConfig ( conf );
-    QApplication::restoreOverrideCursor();
-    //statusBar()->hide();
+  QApplication::setOverrideCursor(Qt::waitCursor);
+  loadConfig ( conf );
+  QApplication::restoreOverrideCursor();
+  //statusBar()->hide();
-    // Add map browser
-    // Warning: if browser is on the first page modules are
-    // displayed over the browser
-    mBrowser = new QgsGrassBrowser ( mIface, this );
-    mTabWidget->addTab( mBrowser, tr("Browser") );
+  // Add map browser
+  // Warning: if browser is on the first page modules are
+  // displayed over the browser
+  mBrowser = new QgsGrassBrowser ( mIface, this );
+  mTabWidget->addTab( mBrowser, tr("Browser") );
-    connect( mBrowser, SIGNAL(regionChanged()),
-		         this, SLOT(emitRegionChanged()) );
+  connect( mBrowser, SIGNAL(regionChanged()),
+    this, SLOT(emitRegionChanged()) );
 void QgsGrassTools::moduleClicked( QTreeWidgetItem * item, int column )
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassTools::moduleClicked()" << std::endl;
-    #endif
-    if ( !item ) return;
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassTools::moduleClicked()" << std::endl;
+#endif
+  if ( !item ) return;
-    QString name = item->text(1);
+  QString name = item->text(1);
 #ifdef QGISDEBUG
-    std::cerr << "name = " << name.ascii() << std::endl;
+  std::cerr << "name = " << name.ascii() << std::endl;
 #endif
-    if ( name.length() == 0 ) return;  // Section
+  if ( name.length() == 0 ) return;  // Section
 #ifndef WIN32
-    QgsGrassShell* sh = 0;
+  QgsGrassShell* sh = 0;
 #endif
-    QString path = QgsApplication::pkgDataPath() + "/grass/modules/" + name;
-    #ifdef QGISDEBUG
-    std::cerr << "path = " << path.ascii() << std::endl;
-    #endif
-    QWidget *m;
-    if ( name == "shell" )
-         // Set history file
-         QString mapsetPath = QgsGrass::getDefaultGisdbase() + "/"
-			+ QgsGrass::getDefaultLocation() + "/"
-			+ QgsGrass::getDefaultMapset();
-         // bash
-         QString hist = "HISTFILE=" + mapsetPath + "/.bash_history";
-         char *histChar = new char[hist.length()+1];
-         strcpy ( histChar, const_cast<char *>(hist.ascii()) );
-         putenv( histChar );
+  QString path = QgsApplication::pkgDataPath() + "/grass/modules/" + name;
+#ifdef QGISDEBUG
+  std::cerr << "path = " << path.ascii() << std::endl;
+#endif
+  QWidget *m;
+  if ( name == "shell" )
+    // Set history file
+    QString mapsetPath = QgsGrass::getDefaultGisdbase() + "/"
+      + QgsGrass::getDefaultLocation() + "/"
+      + QgsGrass::getDefaultMapset();
-         // csh/tcsh
+    // bash
+    QString hist = "HISTFILE=" + mapsetPath + "/.bash_history";
+    char *histChar = new char[hist.length()+1];
+    strcpy ( histChar, const_cast<char *>(hist.ascii()) );
+    putenv( histChar );
+    // csh/tcsh
 #ifndef WIN32
-         hist = "histfile=" + mapsetPath + "/.history";
-         histChar = new char[hist.length()+1];
+    hist = "histfile=" + mapsetPath + "/.history";
+    histChar = new char[hist.length()+1];
 #endif
 #ifdef WIN32
-         // Run MSYS if available
-         // Note: I was not able to run cmd.exe and command.com
-         //       with QProcess
+    // Run MSYS if available
+    // Note: I was not able to run cmd.exe and command.com
+    //       with QProcess
-         QString msysPath = appDir() + "/msys/bin/rxvt.exe";
-         QString myArguments = "-backspacekey ^H -sl 2500 -fg white -bg black -sr -fn Courier-16 -tn msys -geometry 80x25 -e    /bin/sh --login -i";
-         QFile file ( msysPath );
+    QString msysPath = appDir() + "/msys/bin/rxvt.exe";
+    QString myArguments = "-backspacekey ^H -sl 2500 -fg white -bg black -sr -fn Courier-16 -tn msys -geometry 80x25 -e    /bin/sh --login -i";
+    QFile file ( msysPath );
-         if ( !file.exists() )
-               tr("Cannot find MSYS (") + msysPath + ")" );
-         else
-           QProcess *proc = new QProcess(this);
-           //allow msys to exist in a path with spaces
-           msysPath =  "\"" + msysPath + "\""  ;
-           proc->start(msysPath + " " +  myArguments);
-           proc->waitForStarted();
-           if ( proc->state() != QProcess::Running )
-             QMessageBox::warning( 0, "Warning",
-                 "Cannot start MSYS (" + msysPath + ")" );
-         return;
+    if ( !file.exists() )
+        tr("Cannot find MSYS (") + msysPath + ")" );
+    else
+      QProcess *proc = new QProcess(this);
+      //allow msys to exist in a path with spaces
+      msysPath =  "\"" + msysPath + "\""  ;
+      proc->start(msysPath + " " +  myArguments);
+      proc->waitForStarted();
+      if ( proc->state() != QProcess::Running )
+        QMessageBox::warning( 0, "Warning",
+          "Cannot start MSYS (" + msysPath + ")" );
+    return;
 #else
-    #ifdef HAVE_OPENPTY
-        sh = new QgsGrassShell(this, mTabWidget);
-        m = dynamic_cast<QWidget *> ( sh );
-    #else
-	QMessageBox::warning( 0, tr("Warning"), tr("GRASS Shell is not compiled.") );
-    #endif // HAVE_OPENPTY
+#ifdef HAVE_OPENPTY
+    sh = new QgsGrassShell(this, mTabWidget);
+    m = dynamic_cast<QWidget *> ( sh );
+#else
+    QMessageBox::warning( 0, tr("Warning"), tr("GRASS Shell is not compiled.") );
+#endif // HAVE_OPENPTY
 #endif // ! WIN32
-    else
-	m = dynamic_cast<QWidget *> ( new QgsGrassModule ( this, name,
-                                      mIface, path, mTabWidget ) );
-    int height = mTabWidget->iconSize().height();
-    QPixmap pixmap = QgsGrassModule::pixmap ( path, height );
-    // Icon size in QT4 does not seem to be variable
-    // -> put smaller icons in the middle
-    QPixmap pixmap2 ( mTabWidget->iconSize() );
-    QPalette pal;
-    pixmap2.fill ( pal.color(QPalette::Window) );
-    QPainter painter(&pixmap2);
-    int x = (int) ( (mTabWidget->iconSize().width()-pixmap.width())/2 );
-    painter.drawPixmap ( x, 0, pixmap );
-    painter.end();
+  else
+    m = dynamic_cast<QWidget *> ( new QgsGrassModule ( this, name,
+      mIface, path, mTabWidget ) );
-    QIcon is;
-    is.addPixmap ( pixmap2 );
-    mTabWidget->addTab ( m, is, "" );
+  int height = mTabWidget->iconSize().height();
+  QPixmap pixmap = QgsGrassModule::pixmap ( path, height );
-   QgsGrassToolsTabWidget tw;
-    mTabWidget->setCurrentPage ( mTabWidget->count()-1 );
-    // We must call resize to reset COLUMNS enviroment variable
-    // used by bash !!!
+  // Icon size in QT4 does not seem to be variable
+  // -> put smaller icons in the middle
+  QPixmap pixmap2 ( mTabWidget->iconSize() );
+  QPalette pal;
+  pixmap2.fill ( pal.color(QPalette::Window) );
+  QPainter painter(&pixmap2);
+  int x = (int) ( (mTabWidget->iconSize().width()-pixmap.width())/2 );
+  painter.drawPixmap ( x, 0, pixmap );
+  painter.end();
+  QIcon is;
+  is.addPixmap ( pixmap2 );
+  mTabWidget->addTab ( m, is, "" );
+  QgsGrassToolsTabWidget tw;
+  mTabWidget->setCurrentPage ( mTabWidget->count()-1 );
+  // We must call resize to reset COLUMNS enviroment variable
+  // used by bash !!!
 #ifndef WIN32
-    if ( sh ) sh->resizeTerminal();
+  if ( sh ) sh->resizeTerminal();
 #endif
 bool QgsGrassTools::loadConfig(QString filePath)
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassTools::loadConfig(): " << filePath.toLocal8Bit().data() << std::endl;
-    #endif
-    mModulesListView->setIconSize(QSize(80,22));
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassTools::loadConfig(): " << filePath.toLocal8Bit().data() << std::endl;
+#endif
+  mModulesListView->setIconSize(QSize(80,22));
-    QFile file ( filePath );
+  QFile file ( filePath );
-    if ( !file.exists() ) {
-	QMessageBox::warning( 0, tr("Warning"), tr("The config file (") + filePath + tr(") not found.") );
-	return false;
-    if ( ! file.open( QIODevice::ReadOnly ) ) {
-	QMessageBox::warning( 0, tr("Warning"), tr("Cannot open config file (") + filePath + tr(")") );
-	return false;
-    QDomDocument doc ( "qgisgrass" );
-    QString err;
-    int line, column;
-    if ( !doc.setContent( &file,  &err, &line, &column ) ) {
-	QString errmsg = tr("Cannot read config file (") + filePath + "):\n" + err + tr("\nat line ")
-	std::cerr << errmsg.toLocal8Bit().data() << std::endl;
-	QMessageBox::warning( 0, tr("Warning"), errmsg );
-	file.close();
-	return false;
+  if ( !file.exists() ) {
+    QMessageBox::warning( 0, tr("Warning"), tr("The config file (") + filePath + tr(") not found.") );
+    return false;
+  if ( ! file.open( QIODevice::ReadOnly ) ) {
+    QMessageBox::warning( 0, tr("Warning"), tr("Cannot open config file (") + filePath + tr(")") );
+    return false;
-    QDomElement docElem = doc.documentElement();
-    QDomNodeList modulesNodes = docElem.elementsByTagName ( "modules" );
+  QDomDocument doc ( "qgisgrass" );
+  QString err;
+  int line, column;
+  if ( !doc.setContent( &file,  &err, &line, &column ) ) {
+    QString errmsg = tr("Cannot read config file (") + filePath + "):\n" + err + tr("\nat line ")
+    std::cerr << errmsg.toLocal8Bit().data() << std::endl;
+    QMessageBox::warning( 0, tr("Warning"), errmsg );
+    file.close();
+    return false;
-    if ( modulesNodes.count() == 0 ) {
-	 file.close();
-	 return false;
+  QDomElement docElem = doc.documentElement();
+  QDomNodeList modulesNodes = docElem.elementsByTagName ( "modules" );
-    QDomNode modulesNode = modulesNodes.item(0);
-    QDomElement modulesElem = modulesNode.toElement();
-    // Go through the sections and modules and add them to the list view
-    addModules ( 0, modulesElem );
+  if ( modulesNodes.count() == 0 ) {
     file.close();
-    return true;
+    return false;
+  QDomNode modulesNode = modulesNodes.item(0);
+  QDomElement modulesElem = modulesNode.toElement();
+  // Go through the sections and modules and add them to the list view
+  addModules ( 0, modulesElem );
+  file.close();
+  return true;
 void QgsGrassTools::addModules (  QTreeWidgetItem *parent, QDomElement &element )
-    QDomNode n = element.firstChild();
+  QDomNode n = element.firstChild();
-    QTreeWidgetItem *item;
-    QTreeWidgetItem *lastItem = 0;
-    while( !n.isNull() ) {
-	QDomElement e = n.toElement();
-	if( !e.isNull() ) {
-	    //std::cout << "tag = " << e.tagName() << std::endl;
+  QTreeWidgetItem *item;
+  QTreeWidgetItem *lastItem = 0;
+  while( !n.isNull() ) {
+    QDomElement e = n.toElement();
+    if( !e.isNull() ) {
+      //std::cout << "tag = " << e.tagName() << std::endl;
-	    if ( e.tagName() == "section" && e.tagName() == "grass" ) {
-		std::cout << "Unknown tag: " << e.tagName().toLocal8Bit().data() << std::endl;
-		continue;
-	    if ( parent ) {
-		item = new QTreeWidgetItem( parent, lastItem );
-	    } else {
-		item = new QTreeWidgetItem( mModulesListView, lastItem );
+      if ( e.tagName() == "section" && e.tagName() == "grass" ) {
+        std::cout << "Unknown tag: " << e.tagName().toLocal8Bit().data() << std::endl;
+        continue;
-	    if ( e.tagName() == "section" ) {
-		QString label = e.attribute("label");
-	        std::cout << "label = " << label.toLocal8Bit().data() << std::endl;
-		item->setText( 0, label );
-		item->setExpanded(true); // for debuging to spare one click
+      if ( parent ) {
+        item = new QTreeWidgetItem( parent, lastItem );
+      } else {
+        item = new QTreeWidgetItem( mModulesListView, lastItem );
-		addModules ( item, e );
-		lastItem = item;
-	    } else if ( e.tagName() == "grass" ) { // GRASS module
-		QString name = e.attribute("name");
-	        std::cout << "name = " << name.toLocal8Bit().data() << std::endl;
+      if ( e.tagName() == "section" ) {
+        QString label = e.attribute("label");
+        std::cout << "label = " << label.toLocal8Bit().data() << std::endl;
+        item->setText( 0, label );
+        item->setExpanded(true); // for debuging to spare one click
-                QString label = QgsGrassModule::label ( path );
-		QPixmap pixmap = QgsGrassModule::pixmap ( path, 25 );
+        addModules ( item, e );
-		item->setIcon( 0, QIcon(pixmap) );
-		item->setText( 1, name );
-		lastItem = item;
-	n = n.nextSibling();
+        lastItem = item;
+      } else if ( e.tagName() == "grass" ) { // GRASS module
+        QString name = e.attribute("name");
+        std::cout << "name = " << name.toLocal8Bit().data() << std::endl;
+        QString label = QgsGrassModule::label ( path );
+        QPixmap pixmap = QgsGrassModule::pixmap ( path, 25 );
+        item->setIcon( 0, QIcon(pixmap) );
+        item->setText( 1, name );
+        lastItem = item;
+    n = n.nextSibling();
 void QgsGrassTools::mapsetChanged()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassTools::mapsetChanged()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassTools::mapsetChanged()" << std::endl;
+#endif
-    closeTools();
-    mBrowser->setLocation( QgsGrass::getDefaultGisdbase(), QgsGrass::getDefaultLocation() );
+  closeTools();
+  mBrowser->setLocation( QgsGrass::getDefaultGisdbase(), QgsGrass::getDefaultLocation() );
 QgsGrassTools::~QgsGrassTools()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassTools::~QgsGrassTools()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassTools::~QgsGrassTools()" << std::endl;
+#endif
 QString QgsGrassTools::appDir(void)
-    return QgsApplication::applicationDirPath();
+  return QgsApplication::applicationDirPath();
 void QgsGrassTools::close(void)
-    hide();
+  hide();
 void QgsGrassTools::closeEvent(QCloseEvent *e)
-    e->accept();
+  e->accept();
 void QgsGrassTools::restorePosition()
-    restoreGeometry(settings.value("/GRASS/windows/tools/geometry").toByteArray());
-    show();
+  restoreGeometry(settings.value("/GRASS/windows/tools/geometry").toByteArray());
+  show();
 void QgsGrassTools::saveWindowLocation()
-    settings.setValue("/GRASS/windows/tools/geometry", saveGeometry());
+  settings.setValue("/GRASS/windows/tools/geometry", saveGeometry());
 void QgsGrassTools::emitRegionChanged()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassTools::emitRegionChanged()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassTools::emitRegionChanged()" << std::endl;
+#endif
 void QgsGrassTools::closeTools()
-    #ifdef QGISDEBUG
-    std::cerr << "QgsGrassTools::closeTools()" << std::endl;
-    #endif
+#ifdef QGISDEBUG
+  std::cerr << "QgsGrassTools::closeTools()" << std::endl;
+#endif
-    for ( int i = mTabWidget->count()-1; i > 1; i-- )
-         delete mTabWidget->widget(i);
-         mTabWidget->removeTab(i);
+  for ( int i = mTabWidget->count()-1; i > 1; i-- )
+    delete mTabWidget->widget(i);
+    mTabWidget->removeTab(i);
More information about the QGIS-commit mailing list
