[QGIS Commit] r8251 - trunk/qgis/src/app
    svn_qgis at osgeo.org
    Wed Mar 19 14:06:22 EDT 2008
Author: jef
Date: 2008-03-19 14:06:22 -0400 (Wed, 19 Mar 2008)
New Revision: 8251
   trunk/qgis/src/app/qgsdbtablemodel.cpp
fix setting of type column for postgis tables with multiple geometry columns
Modified: trunk/qgis/src/app/qgsdbtablemodel.cpp
--- trunk/qgis/src/app/qgsdbtablemodel.cpp	2008-03-19 18:01:15 UTC (rev 8250)
+++ trunk/qgis/src/app/qgsdbtablemodel.cpp	2008-03-19 18:06:22 UTC (rev 8251)
@@ -177,32 +177,29 @@
       continue;
-    if(itemFromIndex(currentTableIndex)->text() == table)
+    if(itemFromIndex(currentTableIndex)->text() == table &&
+       (geomColText==attribute || geomColText.startsWith( attribute + " AS ") ) )
       if(typeIsEmpty)
         removeRow(i, indexFromItem(schemaItem));
         return;
-      for(int j = 0; j < typeList.size(); ++j)
+      QGis::WKBTYPE wkbType = qgisTypeFromDbType(typeList.at(0));
+      QString iconPath = iconFilePathForType(wkbType);
+      itemFromIndex(currentTypeIndex)->setText(typeList.at(0)); //todo: add other rows
+      itemFromIndex(currentTypeIndex)->setIcon(QIcon(iconPath));
+      if(!geomColText.contains(" AS "))
-        if( j==0 )
-          QGis::WKBTYPE wkbType = qgisTypeFromDbType(typeList.at(0));
-          QString iconPath = iconFilePathForType(wkbType);
-          itemFromIndex(currentTypeIndex)->setText(typeList.at(0)); //todo: add other rows
-          itemFromIndex(currentTypeIndex)->setIcon(QIcon(iconPath));
-          if(!geomColText.contains(" AS "))
-            itemFromIndex(currentGeomColumnIndex)->setText(geomColText + " AS " + typeList.at(0));
-        else
-          //todo: add correct type
-          addTableEntry(typeList.at(j), schema, table, geomColText + " AS " + typeList.at(j), "");
+        itemFromIndex(currentGeomColumnIndex)->setText(geomColText + " AS " + typeList.at(0));
+      for(int j = 1; j < typeList.size(); ++j)
+        //todo: add correct type
+        addTableEntry(typeList.at(j), schema, table, geomColText + " AS " + typeList.at(j), "");
