[QGIS Commit] r8253 - trunk/qgis/src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Mar 19 16:07:07 EDT 2008
Author: timlinux
Date: 2008-03-19 16:07:06 -0400 (Wed, 19 Mar 2008)
New Revision: 8253
   trunk/qgis/src/core/qgsmaplayerregistry.h
Cleanup comments and note that layers are deleted when removed from the registry
Modified: trunk/qgis/src/core/qgsmaplayerregistry.h
--- trunk/qgis/src/core/qgsmaplayerregistry.h	2008-03-19 18:34:19 UTC (rev 8252)
+++ trunk/qgis/src/core/qgsmaplayerregistry.h	2008-03-19 20:07:06 UTC (rev 8253)
@@ -67,49 +67,41 @@
  QgsMapLayer *  addMapLayer(QgsMapLayer * theMapLayer, bool theEmitSignal = TRUE);
  /** Remove a layer from qgis
     @note
     As a side-effect QgsProject is made dirty.
     Any canvases using that layer will need to remove it
     theEmitSignal - see addMapLayer()
+    The layer being removed is deleted as well as the registry
+    table entry.
  void removeMapLayer(QString theLayerId, bool theEmitSignal = TRUE);
  /** Remove all registered layers
     @note raises removedAll()
+    @note The layers are deleted as the registry is cleared!
  void removeAllMapLayers();
 signals:
     /** emitted when a layer is removed from the registry
        connected to main map canvas and overview map canvas remove()
  void layerWillBeRemoved(QString theLayerId);
     /** emitted when a layer is added to the registry
        connected to main map canvas and overview map canvas addLayer()
  void layerWasAdded(QgsMapLayer * theMapLayer);
  /** emitted when ALL layers are removed at once
     This could have been implemented by iteratively signalling
     layerWillBeRemoved() for each layer as it is removed.  However, this
     generally causes a cascade of effects that are unnecessary if we're
     ultimately removing all layers.  E.g., removing the legend item
     corresponding to the layer.  Why bother doing that when you're just going
     to clear everything anyway?
  void removedAll();
More information about the QGIS-commit mailing list
