[QGIS Commit] r8258 - branches/rendercontext-branch/src/core
svn_qgis at osgeo.org
Fri Mar 21 06:59:42 EDT 2008
Author: mhugent
Date: 2008-03-21 06:59:42 -0400 (Fri, 21 Mar 2008)
New Revision: 8258
branches/rendercontext-branch/src/core/qgslabel.cpp
branches/rendercontext-branch/src/core/qgslabel.h
branches/rendercontext-branch/src/core/qgsmaplayer.cpp
branches/rendercontext-branch/src/core/qgsmaplayer.h
branches/rendercontext-branch/src/core/qgsmaprender.cpp
branches/rendercontext-branch/src/core/qgsmaprender.h
branches/rendercontext-branch/src/core/qgsrendercontext.cpp
branches/rendercontext-branch/src/core/qgsvectorlayer.cpp
branches/rendercontext-branch/src/core/qgsvectorlayer.h
Fixed problems with reprojecting
Modified: branches/rendercontext-branch/src/core/qgslabel.cpp
--- branches/rendercontext-branch/src/core/qgslabel.cpp 2008-03-21 00:45:50 UTC (rev 8257)
+++ branches/rendercontext-branch/src/core/qgslabel.cpp 2008-03-21 10:59:42 UTC (rev 8258)
@@ -83,9 +83,9 @@
-void QgsLabel::renderLabel( QPainter * painter, QgsRect &viewExtent,
- QgsCoordinateTransform* coordTransform,
- QgsMapToPixel *transform,
+void QgsLabel::renderLabel( QPainter * painter, const QgsRect& viewExtent,
+ const QgsCoordinateTransform* coordTransform,
+ const QgsMapToPixel *transform,
QgsFeature &feature, bool selected, QgsLabelAttributes *classAttributes,
double sizeScale )
@@ -336,8 +336,8 @@
void QgsLabel::renderLabel(QPainter* painter, QgsPoint point,
- QgsMapToPixel* transform,
+ const QgsMapToPixel* transform,
QString text, QFont font, QPen pen,
int dx, int dy,
double xoffset, double yoffset,
Modified: branches/rendercontext-branch/src/core/qgslabel.h
--- branches/rendercontext-branch/src/core/qgslabel.h 2008-03-21 00:45:50 UTC (rev 8257)
+++ branches/rendercontext-branch/src/core/qgslabel.h 2008-03-21 10:59:42 UTC (rev 8258)
@@ -79,9 +79,9 @@
/** \brief render label
* \param sizeScale global scale factor for size in pixels, labels in map units are not scaled
- void renderLabel ( QPainter* painter, QgsRect& viewExtent,
+ void renderLabel ( QPainter* painter, const QgsRect& viewExtent,
QgsFeature &feature, bool selected, QgsLabelAttributes *classAttributes=0, double sizeScale = 1.);
/** Reads the renderer configuration from an XML file
@@ -122,8 +122,8 @@
void renderLabel(QPainter* painter, QgsPoint point,
int dx, int dy,
Modified: branches/rendercontext-branch/src/core/qgsmaplayer.cpp
--- branches/rendercontext-branch/src/core/qgsmaplayer.cpp 2008-03-21 00:45:50 UTC (rev 8257)
+++ branches/rendercontext-branch/src/core/qgsmaplayer.cpp 2008-03-21 10:59:42 UTC (rev 8258)
@@ -131,7 +131,7 @@
return false;
-void QgsMapLayer::drawLabels(QPainter* painter, const QgsRenderContext& renderContext)
+void QgsMapLayer::drawLabels(QgsRenderContext& renderContext)
// std::cout << "In QgsMapLayer::draw" << std::endl;
Modified: branches/rendercontext-branch/src/core/qgsmaplayer.h
--- branches/rendercontext-branch/src/core/qgsmaplayer.h 2008-03-21 00:45:50 UTC (rev 8257)
+++ branches/rendercontext-branch/src/core/qgsmaplayer.h 2008-03-21 10:59:42 UTC (rev 8258)
@@ -76,7 +76,7 @@
/** Draw labels
* @TODO to be removed: used only in vector layers
- virtual void drawLabels(QPainter* painter, const QgsRenderContext& renderContext);
+ virtual void drawLabels(QgsRenderContext& renderContext);
/** Return the extent of the layer as a QRect */
const QgsRect extent();
Modified: branches/rendercontext-branch/src/core/qgsmaprender.cpp
--- branches/rendercontext-branch/src/core/qgsmaprender.cpp 2008-03-21 00:45:50 UTC (rev 8257)
+++ branches/rendercontext-branch/src/core/qgsmaprender.cpp 2008-03-21 10:59:42 UTC (rev 8258)
@@ -62,13 +62,13 @@
QgsRect QgsMapRender::extent()
- return mRenderContext.extent();
+ return mExtent;
void QgsMapRender::updateScale()
- mScale = mScaleCalculator->calculate(mRenderContext.extent(), mSize.width());
+ mScale = mScaleCalculator->calculate(mExtent, mSize.width());
bool QgsMapRender::setExtent(const QgsRect& extent)
@@ -103,7 +103,7 @@
return false;
- mRenderContext.setExtent(extent);
+ mExtent = extent;
if (!extent.isEmpty())
adjustExtentToSize();
return true;
@@ -132,7 +132,6 @@
int myWidth = mSize.width();
QgsMapToPixel newCoordXForm;
- QgsRect theExtent = mRenderContext.extent();
if (!myWidth || !myHeight)
@@ -143,9 +142,9 @@
// calculate the translation and scaling parameters
// mupp = map units per pixel
- double muppY = static_cast<double>(theExtent.height())
+ double muppY = static_cast<double>(mExtent.height())
/ static_cast<double>(myHeight);
- double muppX = static_cast<double>(theExtent.width())
+ double muppX = static_cast<double>(mExtent.width())
/ static_cast<double>(myWidth);
mMupp = muppY > muppX ? muppY : muppX;
@@ -154,39 +153,39 @@
if (muppY > muppX)
- dymin = theExtent.yMin();
- dymax = theExtent.yMax();
- whitespace = ((myWidth * mMupp) - theExtent.width()) * 0.5;
- dxmin = theExtent.xMin() - whitespace;
- dxmax = theExtent.xMax() + whitespace;
+ dymin = mExtent.yMin();
+ dymax = mExtent.yMax();
+ whitespace = ((myWidth * mMupp) - mExtent.width()) * 0.5;
+ dxmin = mExtent.xMin() - whitespace;
+ dxmax = mExtent.xMax() + whitespace;
else
- dxmin = theExtent.xMin();
- dxmax = theExtent.xMax();
- whitespace = ((myHeight * mMupp) - theExtent.height()) * 0.5;
- dymin = theExtent.yMin() - whitespace;
- dymax = theExtent.yMax() + whitespace;
+ dxmin = mExtent.xMin();
+ dxmax = mExtent.xMax();
+ whitespace = ((myHeight * mMupp) - mExtent.height()) * 0.5;
+ dymin = mExtent.yMin() - whitespace;
+ dymax = mExtent.yMax() + whitespace;
#ifdef QGISDEBUG
QgsDebugMsg("========== Current Scale ==========");
- QgsDebugMsg("Current extent is " + theExtent.stringRep());
+ QgsDebugMsg("Current extent is " + mExtent.stringRep());
QgsLogger::debug("MuppX", muppX, 1, __FILE__, __FUNCTION__, __LINE__);
QgsLogger::debug("MuppY", muppY, 1, __FILE__, __FUNCTION__, __LINE__);
QgsLogger::debug("Pixmap width", myWidth, 1, __FILE__, __FUNCTION__, __LINE__);
QgsLogger::debug("Pixmap height", myHeight, 1, __FILE__, __FUNCTION__, __LINE__);
- QgsLogger::debug("Extent width", theExtent.width(), 1, __FILE__, __FUNCTION__, __LINE__);
- QgsLogger::debug("Extent height", theExtent.height(), 1, __FILE__, __FUNCTION__, __LINE__);
+ QgsLogger::debug("Extent width", mExtent.width(), 1, __FILE__, __FUNCTION__, __LINE__);
+ QgsLogger::debug("Extent height", mExtent.height(), 1, __FILE__, __FUNCTION__, __LINE__);
QgsLogger::debug("whitespace: ", whitespace, 1, __FILE__, __FUNCTION__, __LINE__);
#endif
// update extent
- theExtent.setXmin(dxmin);
- theExtent.setXmax(dxmax);
- theExtent.setYmin(dymin);
- theExtent.setYmax(dymax);
+ mExtent.setXmin(dxmin);
+ mExtent.setXmax(dxmax);
+ mExtent.setYmin(dymin);
+ mExtent.setYmax(dymax);
// update the scale
updateScale();
@@ -197,7 +196,7 @@
newCoordXForm.setParameters(mMupp, dxmin, dymin, myHeight);
mRenderContext.setMapToPixel(newCoordXForm);
- mRenderContext.setExtent(theExtent);
+ mRenderContext.setExtent(mExtent);
@@ -205,7 +204,7 @@
QgsDebugMsg("========== Rendering ==========");
- if (mRenderContext.extent().isEmpty())
+ if (mExtent.isEmpty())
QgsLogger::debug("empty extent... not rendering");
return;
@@ -231,6 +230,8 @@
// render all layers in the stack, starting at the base
QListIterator<QString> li(mLayerSet);
li.toBack();
+ QgsRect r1, r2;
while (li.hasPrevious())
@@ -266,17 +267,19 @@
connect(ml, SIGNAL(drawingProgress(int,int)), this, SLOT(onDrawingProgress(int,int)));
- QgsRect r1 = mRenderContext.extent();
- QgsRect r2;
- bool split = splitLayersExtent(ml, r1, r2);
// Now do the call to the layer that actually does
// the rendering work!
+ bool split = false;
if (projectionsEnabled())
+ r1 = mExtent;
+ split = splitLayersExtent(ml, r1, r2);
ct = new QgsCoordinateTransform(ml->srs(), *mDestSRS);
+ mRenderContext.setExtent(r1);
else
@@ -292,9 +295,11 @@
if (split)
- //todo: set render context extent to r2
- //if (!ml->draw(painter, r2, mCoordXForm, ct, !mOverview))
- //emit drawError(ml);
+ mRenderContext.setExtent(r2);
+ if (!ml->draw(mRenderContext))
+ emit drawError(ml);
delete ct;
@@ -329,23 +334,28 @@
if ((ml->scaleBasedVisibility() && ml->minScale() < mScale && ml->maxScale() > mScale)
|| (!ml->scaleBasedVisibility()))
- QgsRect r2;
+ QgsRect r1 = mExtent;
else
ct = NULL;
- //ml->drawLabels(painter, r1, mCoordXForm, ct);
+ mRenderContext.setCoordTransform(ct);
+ ml->drawLabels(mRenderContext);
if (split)
- //ml->drawLabels(painter, r2, mCoordXForm, ct);
delete ct;
Modified: branches/rendercontext-branch/src/core/qgsmaprender.h
--- branches/rendercontext-branch/src/core/qgsmaprender.h 2008-03-21 00:45:50 UTC (rev 8257)
+++ branches/rendercontext-branch/src/core/qgsmaprender.h 2008-03-21 10:59:42 UTC (rev 8258)
@@ -178,11 +178,8 @@
//! scale calculator
QgsScaleCalculator * mScaleCalculator;
- //! utility class for transformation between map and pixmap units
- //QgsMapToPixel* mCoordXForm; //in mRenderContext
//! current extent to be drawn
- //QgsRect mExtent; //in mRenderContext
+ QgsRect mExtent;
//! indicates whether it's map image for overview
bool mOverview;
Modified: branches/rendercontext-branch/src/core/qgsrendercontext.cpp
--- branches/rendercontext-branch/src/core/qgsrendercontext.cpp 2008-03-21 00:45:50 UTC (rev 8257)
+++ branches/rendercontext-branch/src/core/qgsrendercontext.cpp 2008-03-21 10:59:42 UTC (rev 8258)
@@ -30,7 +30,7 @@
void QgsRenderContext::setCoordTransform(QgsCoordinateTransform* t)
- delete mCoordTransform;
+ //delete mCoordTransform;
mCoordTransform = t;
Modified: branches/rendercontext-branch/src/core/qgsvectorlayer.cpp
--- branches/rendercontext-branch/src/core/qgsvectorlayer.cpp 2008-03-21 00:45:50 UTC (rev 8257)
+++ branches/rendercontext-branch/src/core/qgsvectorlayer.cpp 2008-03-21 10:59:42 UTC (rev 8258)
@@ -277,17 +277,20 @@
//void QgsVectorLayer::drawLabels(QPainter * p, QgsRect & viewExtent, QgsMapToPixel * theMapToPixelTransform, QgsCoordinateTransform* ct)
-void QgsVectorLayer::drawLabels(QPainter* painter, const QgsRenderContext& renderContext)
+void QgsVectorLayer::drawLabels(QgsRenderContext& renderContext)
-#if 0 //todo: adapt to render context
- drawLabels(p, viewExtent, theMapToPixelTransform, ct, 1.);
-#endif //0
+ QPainter* thePainter = renderContext.painter();
+ if(!thePainter)
+ return;
+ drawLabels(thePainter, renderContext.extent(), &(renderContext.mapToPixel()), renderContext.coordTransform(), renderContext.scaleFactor());
// NOTE this is a temporary method added by Tim to prevent label clipping
// which was occurring when labeller was called in the main draw loop
// This method will probably be removed again in the near future!
-void QgsVectorLayer::drawLabels(QPainter * p, QgsRect & viewExtent, QgsMapToPixel * theMapToPixelTransform, QgsCoordinateTransform* ct, double scale)
+void QgsVectorLayer::drawLabels(QPainter * p, const QgsRect& viewExtent, const QgsMapToPixel* theMapToPixelTransform, const QgsCoordinateTransform* ct, double scale)
QgsDebugMsg("Starting draw of labels");
Modified: branches/rendercontext-branch/src/core/qgsvectorlayer.h
--- branches/rendercontext-branch/src/core/qgsvectorlayer.h 2008-03-21 00:45:50 UTC (rev 8257)
+++ branches/rendercontext-branch/src/core/qgsvectorlayer.h 2008-03-21 10:59:42 UTC (rev 8258)
@@ -340,7 +340,7 @@
bool draw(QgsRenderContext& renderContext);
/** Draws the layer labels using coordinate transformation */
- void drawLabels(QPainter* painter, const QgsRenderContext& renderContext);
+ void drawLabels(QgsRenderContext& renderContext);
/** \brief Draws the layer using coordinate transformation
* \param widthScale line width scale
@@ -357,7 +357,7 @@
/** \brief Draws the layer labels using coordinate transformation
* \param scale size scale, applied to all values in pixels
- void drawLabels(QPainter * p, QgsRect & viewExtent, QgsMapToPixel * cXf, QgsCoordinateTransform* ct, double scale);
+ void drawLabels(QPainter * p, const QgsRect& viewExtent, const QgsMapToPixel* cXf, const QgsCoordinateTransform* ct, double scale);
/** returns array of added features */
QgsFeatureList& addedFeatures();
