[QGIS Commit] r8260 - in branches/rendercontext-branch/src:
	app/composer core
    svn_qgis at osgeo.org
    Sat Mar 22 02:54:30 EDT 2008
Author: mhugent
Date: 2008-03-22 02:54:29 -0400 (Sat, 22 Mar 2008)
New Revision: 8260
   branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp
   branches/rendercontext-branch/src/core/qgsmaprender.cpp
   branches/rendercontext-branch/src/core/qgsrendercontext.cpp
   branches/rendercontext-branch/src/core/qgsrendercontext.h
Make print composer work again, using render context only for raster layers for now
Modified: branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp
--- branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp	2008-03-21 11:58:36 UTC (rev 8259)
+++ branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp	2008-03-22 06:54:29 UTC (rev 8260)
@@ -23,6 +23,7 @@
 #include "qgsmaptopixel.h"
 #include "qgsproject.h"
 #include "qgsmaprender.h"
+#include "qgsrendercontext.h"
 #include "qgsvectorlayer.h"
 #include "qgslabel.h"
@@ -130,6 +131,11 @@
   int nlayers = mMapCanvas->layerCount();
     QgsCoordinateTransform* ct;
+    QgsRenderContext theRenderContext;
+    theRenderContext.setPainter(painter);
+    theRenderContext.setExtent(extent);
+    theRenderContext.setMapToPixel(*transform);
   for ( int i = nlayers - 1; i >= 0; i-- ) {
     QgsMapLayer *layer = mMapCanvas->getZpos(i);
@@ -144,6 +150,8 @@
       ct = NULL;
+    theRenderContext.setCoordTransform(ct);
     if ( layer->type() == QgsMapLayer::VECTOR ) {
       QgsVectorLayer *vector = dynamic_cast <QgsVectorLayer*> (layer);
@@ -180,20 +188,19 @@
         double sc = mExtent.width() / (multip*QGraphicsRectItem::rect().width());
         QgsMapToPixel trans ( sc, multip*QGraphicsRectItem::rect().height(), mExtent.yMin(), mExtent.xMin() );
+	theRenderContext.setMapToPixel(trans);
         painter->save();
         painter->scale( 1./multip, 1./multip);
-        //layer->draw( painter, extent, &trans, ct, FALSE);
+        layer->draw(theRenderContext);
         painter->restore();
       else
-        //layer->draw( painter, extent, transform, ct, FALSE);
-    delete ct;
   // Draw vector labels
@@ -246,8 +253,6 @@
         vector->drawLabels (  painter, extent, transform, ct, fontScale );
-      delete ct;
Modified: branches/rendercontext-branch/src/core/qgsmaprender.cpp
--- branches/rendercontext-branch/src/core/qgsmaprender.cpp	2008-03-21 11:58:36 UTC (rev 8259)
+++ branches/rendercontext-branch/src/core/qgsmaprender.cpp	2008-03-22 06:54:29 UTC (rev 8260)
@@ -302,8 +302,6 @@
-      delete ct;
       disconnect(ml, SIGNAL(drawingProgress(int,int)), this, SLOT(onDrawingProgress(int,int)));
     else
@@ -356,8 +354,6 @@
 	      mRenderContext.setExtent(r2);
 	      ml->drawLabels(mRenderContext);
-          delete ct;
Modified: branches/rendercontext-branch/src/core/qgsrendercontext.cpp
--- branches/rendercontext-branch/src/core/qgsrendercontext.cpp	2008-03-21 11:58:36 UTC (rev 8259)
+++ branches/rendercontext-branch/src/core/qgsrendercontext.cpp	2008-03-22 06:54:29 UTC (rev 8260)
@@ -30,7 +30,7 @@
 void QgsRenderContext::setCoordTransform(QgsCoordinateTransform* t)
-  //delete mCoordTransform;
+  delete mCoordTransform;
   mCoordTransform = t;
Modified: branches/rendercontext-branch/src/core/qgsrendercontext.h
--- branches/rendercontext-branch/src/core/qgsrendercontext.h	2008-03-21 11:58:36 UTC (rev 8259)
+++ branches/rendercontext-branch/src/core/qgsrendercontext.h	2008-03-22 06:54:29 UTC (rev 8260)
@@ -51,8 +51,7 @@
   //setters
-  /**Sets coordinate transformation. QgsRenderContext takes ownership of the pointer and takes \
-   care of releasing the memory properly*/
+  /**Sets coordinate transformation. QgsRenderContext takes ownership and deletes if necessary*/
   void setCoordTransform(QgsCoordinateTransform* t);
   void setMapToPixel(const QgsMapToPixel& mtp) {mMapToPixel = mtp;}
   void setExtent(const QgsRect& extent){mExtent = extent;}
