[QGIS Commit] r8263 - in trunk/qgis: python/core src/core
svn_qgis at osgeo.org
Mon Mar 24 14:31:09 EDT 2008
Author: jef
Date: 2008-03-24 14:31:08 -0400 (Mon, 24 Mar 2008)
New Revision: 8263
trunk/qgis/python/core/qgsspatialrefsys.sip
trunk/qgis/src/core/qgsspatialrefsys.cpp
trunk/qgis/src/core/qgsspatialrefsys.h
- speed up QgsSpatialRefSys after migration to OGR C-API:
- create and destroy OGRSpatialReferenceH in constructor/destructor
- move the PROJ.4 strings to OGR instead of a member variable and keep
track its validity in mIsValidFlag.
This reduces the need to allocate/deallocate of OGR structures and PROJ.4
parsing and thereby speeds it up quite a bit. Especially when on-the-fly
projection is in use.
- collect common code of createFromSrid, createFromEpsg and createFromSrsId
in the new loadFromDb method
NOTE: invalid PROJ.4 strings are now lost, I hope that doesn't break
anything.
Modified: trunk/qgis/python/core/qgsspatialrefsys.sip
--- trunk/qgis/python/core/qgsspatialrefsys.sip 2008-03-24 16:22:32 UTC (rev 8262)
+++ trunk/qgis/python/core/qgsspatialrefsys.sip 2008-03-24 18:31:08 UTC (rev 8263)
@@ -20,6 +20,8 @@
//! Default constructor
QgsSpatialRefSys();
+ ~QgsSpatialRefSys();
* Constructs a SRS object from a WKT string
@@ -34,7 +36,6 @@
QgsSpatialRefSys(const long theId, SRS_TYPE theType=POSTGIS_SRID);
// Misc helper functions -----------------------
void createFromId(const long theId, SRS_TYPE theType=POSTGIS_SRID);
Modified: trunk/qgis/src/core/qgsspatialrefsys.cpp
--- trunk/qgis/src/core/qgsspatialrefsys.cpp 2008-03-24 16:22:32 UTC (rev 8262)
+++ trunk/qgis/src/core/qgsspatialrefsys.cpp 2008-03-24 18:31:08 UTC (rev 8263)
@@ -45,13 +45,14 @@
: mMapUnits(QGis::UNKNOWN),
mIsValidFlag(0)
- // NOOP
+ mSRS = OSRNewSpatialReference(NULL);
QgsSpatialRefSys::QgsSpatialRefSys(QString theWkt)
mIsValidFlag(0)
createFromWkt(theWkt);
@@ -60,9 +61,15 @@
mIsValidFlag(0)
createFromId(theId, theType);
+QgsSpatialRefSys::~QgsSpatialRefSys()
+ OSRDestroySpatialReference( mSRS );
void QgsSpatialRefSys::createFromId(const long theId, SRS_TYPE theType)
switch (theType)
@@ -80,10 +87,8 @@
//THIS IS BAD...THIS PART OF CODE SHOULD NEVER BE REACHED...
QgsLogger::critical("Unexpected case reached in " + QString(__FILE__) + " : " + QString(__LINE__));
bool QgsSpatialRefSys::createFromOgcWmsCrs(QString theCrs)
QStringList parts = theCrs.split(":");
@@ -111,6 +116,11 @@
return TRUE;
+QgsSpatialRefSys::QgsSpatialRefSys(const QgsSpatialRefSys &srs)
+ *this = srs;
// Assignment operator
QgsSpatialRefSys& QgsSpatialRefSys::operator=(const QgsSpatialRefSys& srs)
@@ -121,12 +131,18 @@
mDescription = srs.mDescription;
mProjectionAcronym = srs.mProjectionAcronym;
mEllipsoidAcronym = srs.mEllipsoidAcronym;
- mProj4String = srs.mProj4String;
mGeoFlag = srs.mGeoFlag;
mMapUnits = srs.mMapUnits;
mSRID = srs.mSRID;
mEpsg = srs.mEpsg;
mIsValidFlag = srs.mIsValidFlag;
+ if(mIsValidFlag)
+ char *proj4src = NULL;
+ OSRExportToProj4(srs.mSRS, &proj4src);
+ OSRImportFromProj4(mSRS, proj4src);
+ CPLFree(proj4src);
return *this;
@@ -136,99 +152,55 @@
void QgsSpatialRefSys::validate()
- QgsDebugMsg("QgsSpatialRefSys::validate");
- //dont bother trying to do an initial test with gdal if
- //the proj4String is not even populated
- if (QString::null!=mProj4String && !mProj4String.isEmpty())
- //first of all use gdal to test if this is an ok srs already
- //if not we will prompt the user for and srs
- //then retest using gdal
- //if the retest fails we will then set this srs to the GEOCS/WGS84 default
- QgsDebugMsg("Use GDAL to vaildate");
+ if(mIsValidFlag)
+ return;
- /* Here are the possible OGR error codes :
- typedef int OGRErr;
- #define OGRERR_NONE 0
- #define OGRERR_NOT_ENOUGH_DATA 1 --> not enough data to deserialize
- #define OGRERR_NOT_ENOUGH_MEMORY 2
- #define OGRERR_UNSUPPORTED_GEOMETRY_TYPE 3
- #define OGRERR_UNSUPPORTED_OPERATION 4
- #define OGRERR_CORRUPT_DATA 5
- #define OGRERR_FAILURE 6
- #define OGRERR_UNSUPPORTED_SRS 7 */
- //get the wkt into ogr
- //this is really ugly but we need to get a QString to a char**
- const char *mySourceCharArrayPointer = mProj4String.latin1();
- //create the sr and populate it from a wkt proj definition
- OGRSpatialReferenceH myOgrSpatialRef = OSRNewSpatialReference(NULL);
- OGRErr myInputResult =
- OSRImportFromProj4( myOgrSpatialRef, mySourceCharArrayPointer );
- OSRDestroySpatialReference( myOgrSpatialRef );
- if (myInputResult==OGRERR_NONE)
- //srs is valid so nothing more to do...
- createFromProj4(mProj4String);
- return;
// try to validate using custom validation routines
if (mCustomSrsValidation)
mCustomSrsValidation(this);
- // This is the second check after the user assigned SRS has been retrieved
- // If it still does not work, we will simply use the QgsSpatialRefSys const GEOPROJ4 for the job
+ if(!mIsValidFlag)
+ // set the default
+ createFromProj4(GEOPROJ4);
- OGRErr myInputResult = OSRImportFromProj4( myOgrSpatialRef, mySourceCharArrayPointer );
+bool QgsSpatialRefSys::createFromSrid(long id)
+ return loadFromDb( QgsApplication::srsDbFilePath(), "srid", id);
+bool QgsSpatialRefSys::createFromEpsg(long id)
+ return loadFromDb( QgsApplication::srsDbFilePath(), "epsg", id);
- if (! myInputResult==OGRERR_NONE)
- //default to proj 4..if all else fails we will use that for this srs
- mProj4String = GEOPROJ4;
+bool QgsSpatialRefSys::createFromSrsId(long id)
+ return loadFromDb( id<100000 ? QgsApplication::srsDbFilePath() : QgsApplication::qgisUserDbFilePath(), "srs_id", id);
-bool QgsSpatialRefSys::createFromSrid(long theSrid)
+bool QgsSpatialRefSys::loadFromDb(QString db, QString field, long id)
- QgsDebugMsg("QgsSpatialRefSys::createFromSrid");
+ QgsDebugMsg("load SRS from " + db + " where " + field + " is " + QString::number(id));
+ mIsValidFlag=false;
- // Get the full path name to the sqlite3 spatial reference database.
- QString myDatabaseFileName = QgsApplication::srsDbFilePath();
- QFileInfo myInfo (myDatabaseFileName);
- if (!myInfo.exists())
+ QFileInfo myInfo(db);
+ if(!myInfo.exists())
- QgsDebugMsg("QgsSpatialRefSys::createFromSrid failed : " + myDatabaseFileName +
- " does not exist!");
- return false;
+ QgsDebugMsg("failed : " + db + " does not exist!");
+ return mIsValidFlag;
sqlite3 *myDatabase;
const char *myTail;
sqlite3_stmt *myPreparedStatement;
int myResult;
//check the db is available
- myResult = openDb(myDatabaseFileName, &myDatabase);
+ myResult = openDb(db, &myDatabase);
if(myResult)
- return false;
+ QgsDebugMsg("failed : " + db + " could not be opened!");
@@ -242,7 +214,7 @@
is_geo integer NOT NULL);
- QString mySql = "select srs_id,description,projection_acronym,ellipsoid_acronym,parameters,srid,epsg,is_geo from tbl_srs where srid='" + QString::number(theSrid) + "'";
+ QString mySql = "select srs_id,description,projection_acronym,ellipsoid_acronym,parameters,srid,epsg,is_geo from tbl_srs where " + field + "='" + QString::number(id) + "'";
myResult = sqlite3_prepare(myDatabase, mySql.utf8(), mySql.length(), &myPreparedStatement, &myTail);
// XXX Need to free memory from the error msg if one is set
if(myResult == SQLITE_OK && sqlite3_step(myPreparedStatement) == SQLITE_ROW)
@@ -251,19 +223,18 @@
mDescription = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,1));
mProjectionAcronym = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,2));
mEllipsoidAcronym = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,3));
- mProj4String = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,4));
+ QString proj4String = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,4));
mSRID = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,5)).toLong();
mEpsg = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,6)).toLong();
int geo = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,7)).toInt();
mGeoFlag = (geo == 0 ? false : true);
setMapUnits();
mIsValidFlag = true;
+ OSRImportFromProj4( mSRS, (const char *)proj4String.latin1() );
else
- QgsDebugMsg("QgsSpatialRefSys::createFromSrid failed : " + mySql);
- mIsValidFlag = false;
+ QgsDebugMsg("failed : " + mySql);
sqlite3_finalize(myPreparedStatement);
sqlite3_close(myDatabase);
@@ -272,32 +243,20 @@
bool QgsSpatialRefSys::createFromWkt(QString theWkt)
+ mIsValidFlag = false;
if (theWkt.isEmpty())
QgsDebugMsg("QgsSpatialRefSys::createFromWkt -- theWkt is uninitialised, operation failed")
QgsLogger::critical("QgsSpatialRefSys::createFromWkt -- theWkt is uninitialised, operation failed");
- return false;
QgsDebugMsg("QgsSpatialRefSys::createFromWkt(QString theWkt) using: " + theWkt);
- const char *myCharArrayPointer = theWkt.latin1(); //Why doesn't it work with toLocal8Bit().data()?
- char *pWkt = (char *)myCharArrayPointer;
+ char *pWkt = (char *)theWkt.latin1();
- OGRSpatialReferenceH myOgrSpatialRef = OSRNewSpatialReference( NULL );
+ OGRErr myInputResult = OSRImportFromWkt( mSRS, &pWkt );
- OGRErr myInputResult = OSRImportFromWkt( myOgrSpatialRef, &pWkt );
if (myInputResult != OGRERR_NONE)
QgsDebugMsg("vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv");
@@ -305,20 +264,16 @@
QgsDebugMsg("This SRS could *** NOT *** be set from the supplied WKT ");
QgsDebugMsg("INPUT: " + theWkt);
QgsDebugMsg("^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^");
- return false;
// always morph from esri as it doesn't hurt anything
// FW: Hey, that's not right! It can screw stuff up! Disable
//myOgrSpatialRef.morphFromESRI();
// create the proj4 structs needed for transforming
- OSRExportToProj4(myOgrSpatialRef, &proj4src);
+ OSRExportToProj4(mSRS, &proj4src);
//now that we have the proj4string, delegate to createFromProj4String so
// that we can try to fill in the remaining class members...
@@ -330,173 +285,18 @@
//setMapunits will be called by createfromproj above
-bool QgsSpatialRefSys::createFromEpsg(long theEpsg)
+bool QgsSpatialRefSys::isValid() const
- QgsDebugMsg("QgsSpatialRefSys::createFromEpsg with " + QString::number(theEpsg));
+ if (mIsValidFlag)
+ return true;
+ QgsDebugMsg("It's an invalid SRS without valid proj4 string");
- sqlite3 *myDatabase;
- const char *myTail;
- sqlite3_stmt *myPreparedStatement;
- int myResult;
- //check the db is available
- if(myResult)
- return false;
- srs_id INTEGER PRIMARY KEY,
- description text NOT NULL,
- projection_acronym text NOT NULL,
- ellipsoid_acronym NOT NULL,
- parameters text NOT NULL,
- srid integer NOT NULL,
- epsg integer NOT NULL,
- is_geo integer NOT NULL);
- QString mySql = "select srs_id,description,projection_acronym,ellipsoid_acronym,parameters,srid,epsg,is_geo from tbl_srs where epsg='" + QString::number(theEpsg) + "'";
- myResult = sqlite3_prepare(myDatabase, mySql.utf8(), mySql.length(), &myPreparedStatement, &myTail);
- // XXX Need to free memory from the error msg if one is set
- if(myResult == SQLITE_OK && sqlite3_step(myPreparedStatement) == SQLITE_ROW)
- mSrsId = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,0)).toLong();
- mDescription = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,1));
- mProjectionAcronym = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,2));
- mEllipsoidAcronym = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,3));
- mSRID = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,5)).toLong();
- mEpsg = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,6)).toLong();
- int geo = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,7)).toInt();
- mGeoFlag = (geo == 0 ? false : true);
- setMapUnits();
- mIsValidFlag = true;
- else
- QgsLogger::critical(" QgsSpatialRefSys::createFromEpsg failed : " + mySql);
- sqlite3_finalize(myPreparedStatement);
- sqlite3_close(myDatabase);
- return mIsValidFlag;
+ return false;
-bool QgsSpatialRefSys::createFromSrsId (long theSrsId)
- QgsDebugMsg("QgsSpatialRefSys::createFromSrsId");
- QString myDatabaseFileName;
- // Determine if this is a user projection or a system on
- // user projection defs all have srs_id >= 100000
- if (theSrsId>= USER_PROJECTION_START_ID)
- myDatabaseFileName = QgsApplication::qgisUserDbFilePath();
- QFileInfo myFileInfo;
- myFileInfo.setFile(myDatabaseFileName);
- if ( !myFileInfo.exists( ) )
- QgsLogger::warning("QgsSpatialRefSys::createFromSrid failed : users qgis.db not found");
- else //must be a system projection then
- myDatabaseFileName = QgsApplication::srsDbFilePath();
- int myResult;
- if(myResult)
- return false;
- QString mySql = "select srs_id,description,projection_acronym,ellipsoid_acronym,parameters,srid,epsg,is_geo from tbl_srs where srs_id='" + QString::number(theSrsId) + "'";
- setMapUnits();
- else
- QgsLogger::warning("QgsSpatialRefSys::createFromSrsId failed : " + mySql);
-bool QgsSpatialRefSys::isValid() const
- if (mProj4String.isEmpty())
- return false;
- OGRErr myResult = OSRImportFromProj4( myOgrSpatialRef, mySourceCharArrayPointer );
- if (myResult==OGRERR_NONE)
- //QgsDebugMsg("The OGRe says it's a valid SRS with proj4 string: " + mProj4String);
- return true;
- else
- QgsDebugMsg("The OGRe says it's an invalid SRS (OGRErr = "
- + QString::number(myResult)
- + ") with proj4 string: " + mProj4String);
- return false;
bool QgsSpatialRefSys::createFromProj4 (const QString theProj4String)
// Examples:
// +proj=tmerc +lat_0=0 +lon_0=-62 +k=0.999500 +x_0=400000 +y_0=0
@@ -513,7 +313,7 @@
myStart = myProjRegExp.search(theProj4String, myStart);
if (myStart==-1)
- QgsLogger::warning("QgsSpatialRefSys::createFromProj4 error proj string supplied has no +proj argument");
+ QgsDebugMsg("error proj string supplied has no +proj argument");
else
@@ -540,13 +340,9 @@
if (myStart==-1 && mEllipsoidAcronym.isNull())
QgsLogger::warning("QgsSpatialRefSys::createFromProj4 error proj string supplied has no +ellps or +a argument");
- //mproj4string must be set here for the rest of this method to behave in a meaningful way...
- mProj4String = theProj4String;
* We try to match the proj string to and srsid using the following logic:
@@ -559,15 +355,18 @@
QgsSpatialRefSys::RecordMap myRecord;
if (!mDescription.stripWhiteSpace ().isEmpty())
- myRecord = getRecord("select * from tbl_srs where description='" + mDescription.stripWhiteSpace () + "'");
+ myRecord = getRecord("select * from tbl_srs where description='" + mDescription.stripWhiteSpace () + "'");
-// if (!myRecord.empty())
-// What if descriptions aren't unique?
- if (false)
+ * - if the above does not match perform a whole text search on proj4 string (if not null)
+ QgsDebugMsg("QgsSpatialRefSys::createFromProj4 wholetext match on name failed, trying proj4string match");
+ myRecord = getRecord("select * from tbl_srs where parameters='" + theProj4String.stripWhiteSpace () + "'");
+ if (!myRecord.empty())
mySrsId=myRecord["srs_id"].toLong();
- QgsDebugMsg("QgsSpatialRefSys::createFromProj4 Projection Description match search for srsid returned srsid: "\
- + QString::number(mySrsId));
+ QgsDebugMsg("QgsSpatialRefSys::createFromProj4 proj4string match search for srsid returned srsid: " + QString::number(mySrsId));
if (mySrsId > 0)
createFromSrsId(mySrsId);
@@ -575,93 +374,70 @@
else
- * - if the above does not match perform a whole text search on proj4 string (if not null)
- QgsDebugMsg("QgsSpatialRefSys::createFromProj4 wholetext match on name failed, trying proj4string match");
- myRecord = getRecord("select * from tbl_srs where parameters='" + mProj4String.stripWhiteSpace () + "'");
- if (!myRecord.empty())
+ // Ticket #722 - aaronr
+ // Check if we can swap the lat_1 and lat_2 params (if they exist) to see if we match...
+ // First we check for lat_1 and lat_2
+ QRegExp myLat1RegExp( "\\+lat_1=\\S+" );
+ QRegExp myLat2RegExp( "\\+lat_2=\\S+" );
+ int myStart1 = 0;
+ int myLength1 = 0;
+ int myStart2 = 0;
+ int myLength2 = 0;
+ QString lat1Str = "";
+ QString lat2Str = "";
+ myStart1 = myLat1RegExp.search(theProj4String, myStart1);
+ myStart2 = myLat2RegExp.search(theProj4String, myStart2);
+ if ((myStart1 != -1) && (myStart2 != -1))
- mySrsId=myRecord["srs_id"].toLong();
- QgsDebugMsg("QgsSpatialRefSys::createFromProj4 proj4string match search for srsid returned srsid: " \
- if (mySrsId > 0)
+ myLength1 = myLat1RegExp.matchedLength();
+ myLength2 = myLat2RegExp.matchedLength();
+ lat1Str = theProj4String.mid(myStart1+LAT_PREFIX_LEN,myLength1-LAT_PREFIX_LEN);
+ lat2Str = theProj4String.mid(myStart2+LAT_PREFIX_LEN,myLength2-LAT_PREFIX_LEN);
+ // If we found the lat_1 and lat_2 we need to swap and check to see if we can find it...
+ if ((lat1Str != "") && (lat2Str != ""))
+ // Make our new string to check...
+ QString theProj4StringModified = theProj4String;
+ // First just swap in the lat_2 value for lat_1 value
+ theProj4StringModified.replace(myStart1+LAT_PREFIX_LEN,myLength1-LAT_PREFIX_LEN,lat2Str);
+ // Now we have to find the lat_2 location again since it has potentially moved...
+ myStart2 = 0;
+ theProj4StringModified.replace(myStart2+LAT_PREFIX_LEN,myLength2-LAT_PREFIX_LEN,lat1Str);
+ QgsDebugMsg("QgsSpatialRefSys::createFromProj4 - trying proj4string match with swapped lat_1,lat_2");
+ myRecord = getRecord("select * from tbl_srs where parameters='" + theProj4StringModified.stripWhiteSpace () + "'");
- createFromSrsId(mySrsId);
+ // Success! We have found the proj string by swapping the lat_1 and lat_2
+ OSRImportFromProj4(mSRS, (const char *)theProj4StringModified.latin1() );
+ mySrsId=myRecord["srs_id"].toLong();
+ if (mySrsId > 0)
+ createFromSrsId(mySrsId);
else
- // Ticket #722 - aaronr
- // Check if we can swap the lat_1 and lat_2 params (if they exist) to see if we match...
- // First we check for lat_1 and lat_2
- QRegExp myLat1RegExp( "\\+lat_1=\\S+" );
- QRegExp myLat2RegExp( "\\+lat_2=\\S+" );
- int myStart1 = 0;
- int myLength1 = 0;
- int myStart2 = 0;
- int myLength2 = 0;
- QString lat1Str = "";
- QString lat2Str = "";
- myStart1 = myLat1RegExp.search(theProj4String, myStart1);
- myStart2 = myLat2RegExp.search(theProj4String, myStart2);
- if ((myStart1 != -1) && (myStart2 != -1))
- myLength1 = myLat1RegExp.matchedLength();
- myLength2 = myLat2RegExp.matchedLength();
- lat1Str = theProj4String.mid(myStart1+LAT_PREFIX_LEN,myLength1-LAT_PREFIX_LEN);
- lat2Str = theProj4String.mid(myStart2+LAT_PREFIX_LEN,myLength2-LAT_PREFIX_LEN);
- // If we found the lat_1 and lat_2 we need to swap and check to see if we can find it...
- if ((lat1Str != "") && (lat2Str != ""))
- // Make our new string to check...
- QString theProj4StringModified = theProj4String;
- // First just swap in the lat_2 value for lat_1 value
- theProj4StringModified.replace(myStart1+LAT_PREFIX_LEN,myLength1-LAT_PREFIX_LEN,lat2Str);
- // Now we have to find the lat_2 location again since it has potentially moved...
- myStart2 = 0;
- theProj4StringModified.replace(myStart2+LAT_PREFIX_LEN,myLength2-LAT_PREFIX_LEN,lat1Str);
- QgsDebugMsg("QgsSpatialRefSys::createFromProj4 - trying proj4string match with swapped lat_1,lat_2");
- myRecord = getRecord("select * from tbl_srs where parameters='" + theProj4StringModified.stripWhiteSpace () + "'");
- // Success! We have found the proj string by swapping the lat_1 and lat_2
- mProj4String = theProj4StringModified;
- if (mySrsId > 0)
- else
- // Last ditch attempt to piece together what we know of the projection to find a match...
- QgsDebugMsg("QgsSpatialRefSys::createFromProj4 globbing search for srsid from this proj string");
- mySrsId = findMatchingProj();
- QgsDebugMsg("QgsSpatialRefSys::createFromProj4 globbing search for srsid returned srsid: "\
- if (mySrsId > 0)
+ // Last ditch attempt to piece together what we know of the projection to find a match...
+ QgsDebugMsg("QgsSpatialRefSys::createFromProj4 globbing search for srsid from this proj string");
+ mySrsId = findMatchingProj();
+ QgsDebugMsg("QgsSpatialRefSys::createFromProj4 globbing search for srsid returned srsid: " + QString::number(mySrsId));
+ if (mySrsId > 0)
- /* If its still empty after all the above steps then all we can do is keep the proj string
- * with what was passed in and hope for the best...If its not empty we can fill other member details in
- from the record*/
+ // NOTE: if its still empty after all the above steps then, the projection string is lost. Is that bad?
QgsSpatialRefSys::RecordMap QgsSpatialRefSys::getRecord(QString theSql)
QgsSpatialRefSys::RecordMap myMap;
QString myFieldName;
@@ -826,14 +602,16 @@
QString QgsSpatialRefSys::proj4String() const
- if (mProj4String.isNull())
+ if(!mIsValidFlag)
return "";
- else
- return mProj4String;
+ QString proj4String;
+ proj4String = proj4src;
+ return proj4String;
/*! Get this Geographic? flag
* @return bool theGeoFlag Whether this is a geographic or projected coordinate system
@@ -882,7 +660,7 @@
void QgsSpatialRefSys::setProj4String (QString theProj4String)
+ mIsValidFlag = OSRImportFromProj4(mSRS, (const char *)theProj4String.latin1())==OGRERR_NONE;
void QgsSpatialRefSys::setGeographicFlag (bool theGeoFlag)
@@ -905,24 +683,22 @@
void QgsSpatialRefSys::setMapUnits()
+ if (!mIsValidFlag)
- QgsLogger::warning("No proj4 projection string. Unable to set map units.");
+ QgsLogger::warning("No valid projection. Unable to set map units.");
mMapUnits = QGis::UNKNOWN;
return;
char *unitName;
- OSRImportFromProj4(myOgrSpatialRef, mProj4String.latin1());
// Of interest to us is that this call adds in a unit parameter if
// one doesn't already exist.
- OSRFixup(myOgrSpatialRef);
+ OSRFixup(mSRS);
- if (OSRIsProjected(myOgrSpatialRef))
+ if (OSRIsProjected(mSRS))
- double toMeter = OSRGetLinearUnits(myOgrSpatialRef,&unitName);
+ double toMeter = OSRGetLinearUnits(mSRS,&unitName);
QString unit(unitName);
// If the units parameter was created during the Fixup() call
@@ -950,7 +726,7 @@
else
- OSRGetAngularUnits(myOgrSpatialRef, &unitName);
+ OSRGetAngularUnits(mSRS, &unitName);
if (unit == "degree")
mMapUnits = QGis::DEGREES;
@@ -961,10 +737,8 @@
QgsDebugMsg("Projection has angular units of " + unit);
* check if srs is a geocs or a proj cs (using ogr isGeographic)
* then sequentially walk through the database (first users qgis.db srs tbl then
@@ -977,7 +751,7 @@
long QgsSpatialRefSys::findMatchingProj()
QgsDebugMsg("QgsSpatialRefSys::findMatchingProj...");
- if (mEllipsoidAcronym.isNull() || mProjectionAcronym.isNull() || mProj4String.isNull())
+ if (mEllipsoidAcronym.isNull() || mProjectionAcronym.isNull() || !mIsValidFlag)
QgsLogger::warning("QgsSpatialRefSys::findMatchingProj will only work if prj acr ellipsoid acr and proj4string are set!...");
return 0;
@@ -994,7 +768,6 @@
if(myResult)
@@ -1011,9 +784,9 @@
QString mySrsId = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,0));
QString myProj4String = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement, 1));
- if (this->equals(myProj4String))
+ if (equals(myProj4String))
- QgsDebugMsg("QgsSpatialRefSys::findMatchingProj -------> MATCH FOUND in srs.db srsid: " + mySrsId);
+ QgsDebugMsg("QgsSpatialRefSys::findMatchingProj -------> MATCH FOUND in srs.db srsid: " + mySrsId);
// close the sqlite3 statement
@@ -1051,9 +824,9 @@
- QgsDebugMsg("QgsSpatialRefSys::findMatchingProj -------> MATCH FOUND in user qgis.db srsid: " + mySrsId);
+ QgsDebugMsg("QgsSpatialRefSys::findMatchingProj -------> MATCH FOUND in user qgis.db srsid: " + mySrsId);
@@ -1071,15 +844,28 @@
return 0;
bool QgsSpatialRefSys::operator==(const QgsSpatialRefSys &theSrs)
- //qWarning("QgsSpatialRefSys::operator==(const QgsSpatialRefSys &theSrs) called ");
- //simply delegate to the overloaded == operator below...
- return this->equals(theSrs.mProj4String);
+ if (!mIsValidFlag || !theSrs.mIsValidFlag)
+ return false;
+ else if (OSRIsGeographic(mSRS) && OSRIsGeographic(theSrs.mSRS))
+ // qWarning("QgsSpatialRefSys::operator== srs1 and srs2 are geographic ");
+ return OSRIsSameGeogCS(mSRS,theSrs.mSRS);
+ else if (OSRIsProjected(mSRS) && OSRIsProjected(theSrs.mSRS))
+ // qWarning("QgsSpatialRefSys::operator== srs1 and srs2 are projected ");
+ return OSRIsSame(mSRS, theSrs.mSRS);
+ else
+ return false;
bool QgsSpatialRefSys::operator!=(const QgsSpatialRefSys &theSrs)
@@ -1087,84 +873,23 @@
return ! (*this == theSrs);
-bool QgsSpatialRefSys::equals(QString theProj4CharArray)
+bool QgsSpatialRefSys::equals(QString theProj4String)
- //qWarning("QgsSpatialRefSys::operator==(const char *theProj4CharArray) called ");
- bool myMatchFlag = false; //guilty until proven innocent
- const char *myCharArrayPointer1 = mProj4String.latin1();
- //note that the proj strings above do not neccessarily need to be exactly the
- //same for the projections they define to be equivalent, which is why I dont just
- //compare the proj parameter strings and return the result
- OGRSpatialReferenceH myOgrSpatialRef1 = OSRNewSpatialReference( NULL );
- OGRSpatialReferenceH myOgrSpatialRef2 = OSRNewSpatialReference( NULL );
- OGRErr myInputResult1 = OSRImportFromProj4( myOgrSpatialRef1, myCharArrayPointer1 );
- OGRErr myInputResult2 = OSRImportFromProj4( myOgrSpatialRef1, theProj4CharArray.latin1() );
- // Could do some error reporting here...
- if (myInputResult1 != OGRERR_NONE)
- if (myInputResult2 != OGRERR_NONE)
- if (OSRIsGeographic(myOgrSpatialRef1) && OSRIsGeographic(myOgrSpatialRef2))
-// qWarning("QgsSpatialRefSys::operator== srs1 and srs2 are geographic ");
- myMatchFlag = OSRIsSameGeogCS(myOgrSpatialRef1,myOgrSpatialRef2);
- else if (OSRIsProjected(myOgrSpatialRef1) && OSRIsProjected(myOgrSpatialRef2))
-// qWarning("QgsSpatialRefSys::operator== srs1 and srs2 are projected ");
- myMatchFlag = OSRIsSame(myOgrSpatialRef1,myOgrSpatialRef2);
- } else {
-// qWarning("QgsSpatialRefSys::operator== srs1 and srs2 are different types ");
- myMatchFlag = false;
- OSRDestroySpatialReference( myOgrSpatialRef1 );
- OSRDestroySpatialReference( myOgrSpatialRef2 );
- return myMatchFlag;
+ QgsSpatialRefSys r;
+ r.setProj4String(theProj4String);
+ return *this==r;
QString QgsSpatialRefSys::toWkt() const
- OGRErr myInputResult = OSRImportFromProj4(myOgrSpatialRef,mProj4String.latin1());
QString myWkt;
- if (myInputResult == OGRERR_NONE)
+ char* WKT;
+ if(OSRExportToWkt(mSRS,&WKT) == OGRERR_NONE)
- char* WKT;
- if(OSRExportToWkt(myOgrSpatialRef,&WKT) == OGRERR_NONE)
- myWkt = WKT;
- OGRFree(WKT);
+ myWkt = WKT;
+ OGRFree(WKT);
return myWkt;
@@ -1294,8 +1019,7 @@
mySql += QString::number(theSrsId);
QgsDebugMsg("QgsSpatialRefSys::getProj4FromSrsId : mySrsId = " + QString::number(theSrsId));
- QgsDebugMsg("QgsSpatialRefSys::getProj4FromSrsId : USER_PROJECTION_START_ID = " +\
-QString::number(USER_PROJECTION_START_ID));
+ QgsDebugMsg("QgsSpatialRefSys::getProj4FromSrsId : USER_PROJECTION_START_ID = " + QString::number(USER_PROJECTION_START_ID));
QgsDebugMsg("QgsSpatialRefSys::getProj4FromSrsId :Selection sql : " + mySql);
@@ -1380,6 +1104,6 @@
QgsDebugMsg("***SpatialRefSystem***");
QgsDebugMsg("* Valid : " + (mIsValidFlag?QString("true"):QString("false")));
QgsDebugMsg("* SrsId : " + QString::number(mSrsId));
- QgsDebugMsg("* Proj4 : " + mProj4String);
+ QgsDebugMsg("* Proj4 : " + proj4String() );
QgsDebugMsg("* Desc. : " + mDescription);
Modified: trunk/qgis/src/core/qgsspatialrefsys.h
--- trunk/qgis/src/core/qgsspatialrefsys.h 2008-03-24 16:22:32 UTC (rev 8262)
+++ trunk/qgis/src/core/qgsspatialrefsys.h 2008-03-24 18:31:08 UTC (rev 8263)
@@ -53,6 +53,8 @@
QgsSpatialRefSys();
@@ -67,6 +69,8 @@
+ //! copy constructor
+ QgsSpatialRefSys(const QgsSpatialRefSys& srs);
//! Assignment operator
QgsSpatialRefSys& operator=(const QgsSpatialRefSys& srs);
@@ -158,14 +162,15 @@
/*! Find out whether this SRS is correctly initialised and useable */
bool isValid() const;
- /*! Perform some validation on this SRS. If the sts doesnt validate the
- * default behaviour settings for layers with unknown SRS will be
+ /*! Perform some validation on this SRS. If the sts doesn't validate the
+ * default behaviour settings for layers with unknown SRS will be
* consulted and acted on accordingly. By hell or high water this
* method will do its best to make sure that this SRS is valid - even
* if that involves resorting to a hard coded default of geocs:wgs84.
* @note It is not usually neccessary to use this function, unless you
- * are trying to force theis srs to be valid.
+ * are trying to force this srs to be valid.
void validate();
@@ -330,7 +335,7 @@
/*! Print the description if debugging
- void debugPrint();
+ void debugPrint();
private:
// Open SQLite db and show message if ccannot be opened
// returns the same code as sqlite3_open
@@ -344,8 +349,6 @@
QString mProjectionAcronym ;
//!The official proj4 acronym for the ellipoid
QString mEllipsoidAcronym;
- //!Proj4 format specifies (excluding proj and ellips) that define this srs.
- QString mProj4String ;
//!Whether this is a geographic or projected coordinate system
bool mGeoFlag;
//! The map units
@@ -359,6 +362,10 @@
//! Work out the projection units and set the appropriate local variable
void setMapUnits();
+ void *mSRS;
+ bool loadFromDb(QString db, QString field, long id);
static CUSTOM_SRS_VALIDATION mCustomSrsValidation;
