[QGIS Commit] r8276 - trunk/qgis
svn_qgis at osgeo.org
Tue Mar 25 22:16:31 EDT 2008
Author: timlinux
Date: 2008-03-25 22:16:31 -0400 (Tue, 25 Mar 2008)
New Revision: 8276
trunk/qgis/Doxyfile
Clean ups to doc generation
- filter out non useful / generated / copied in sources
- various other small tweaks to formatting
Modified: trunk/qgis/Doxyfile
--- trunk/qgis/Doxyfile 2008-03-26 01:56:24 UTC (rev 8275)
+++ trunk/qgis/Doxyfile 2008-03-26 02:16:31 UTC (rev 8276)
@@ -30,7 +30,7 @@
# If a relative path is entered, it will be relative to the location
# where doxygen was started. If left blank the current directory will be used.
-OUTPUT_DIRECTORY = qgis_api_doc
+OUTPUT_DIRECTORY = api_doc
# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
# 4096 sub-directories (in 2 levels) under the output directory of each output
@@ -87,7 +87,17 @@
# "The $name file" "is" "provides" "specifies" "contains"
# "represents" "a" "an" "the"
-ABBREVIATE_BRIEF =
+ABBREVIATE_BRIEF = "The $name class" \
+ "The $name widget" \
+ "The $name file" \
+ is \
+ provides \
+ specifies \
+ contains \
+ represents \
+ a \
+ an \
+ the
# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
# Doxygen will generate a detailed section even if there is only a brief
@@ -153,7 +163,7 @@
# If set to NO, the detailed description appears after the member
# documentation.
-DETAILS_AT_TOP = NO
+DETAILS_AT_TOP = YES
# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
# member inherits the documentation from any documented member that it
@@ -170,7 +180,7 @@
# The TAB_SIZE tag can be used to set the number of spaces in a tab.
# Doxygen uses this value to replace tabs by spaces in code fragments.
-TAB_SIZE = 8
+TAB_SIZE = 2
# This tag can be used to specify a number of aliases that acts
# as commands in the documentation. An alias has the form "name=value".
@@ -233,12 +243,12 @@
# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
# will be included in the documentation.
-EXTRACT_PRIVATE = YES
+EXTRACT_PRIVATE = NO
# If the EXTRACT_STATIC tag is set to YES all static members of a file
-EXTRACT_STATIC = NO
+EXTRACT_STATIC = YES
# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
# defined locally in source files will be included in the documentation.
@@ -459,7 +469,8 @@
# directories like "/usr/src/myproject". Separate the files or directories
# with spaces.
-INPUT = ./src
+INPUT = src \
+ tests
# If the value of the INPUT tag contains directories, you can use the
# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
@@ -468,7 +479,11 @@
# *.c *.cc *.cxx *.cpp *.c++ *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh *.hxx
# *.hpp *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm *.py
-FILE_PATTERNS =
+FILE_PATTERNS = *.h \
+ *.cpp \
+ src/core/spatialindex/* \
+ src/core/spatialindex/storagemanager/*.** \
+ *.dox
# The RECURSIVE tag can be used to turn specify whether or not subdirectories
# should be searched for input files as well. Possible values are YES and NO.
@@ -494,7 +509,11 @@
# against the file with absolute path, so to exclude all test directories
# for example use the pattern */test/*
-EXCLUDE_PATTERNS =
+EXCLUDE_PATTERNS = moc_* \
+ ui_* \
+ qrc_* \
+ src/core/sqlite/*
# The EXAMPLE_PATH tag can be used to specify one or more files or
# directories that contain example code fragments that are included (see
