[QGIS Commit] r8286 - trunk/qgis/src/app
svn_qgis at osgeo.org
Thu Mar 27 05:13:21 EDT 2008
Author: jef
Date: 2008-03-27 05:13:21 -0400 (Thu, 27 Mar 2008)
New Revision: 8286
trunk/qgis/src/app/qgsdbsourceselect.cpp
put out a warning message when no accessible postgis tables were found
Modified: trunk/qgis/src/app/qgsdbsourceselect.cpp
--- trunk/qgis/src/app/qgsdbsourceselect.cpp 2008-03-27 00:44:22 UTC (rev 8285)
+++ trunk/qgis/src/app/qgsdbsourceselect.cpp 2008-03-27 09:13:21 UTC (rev 8286)
@@ -536,30 +536,39 @@
PGresult *result = PQexec(pg, sql.toUtf8());
if (result)
- for (int idx = 0; idx < PQntuples(result); idx++)
+ if( PQntuples(result)==0 )
- QString tableName = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, QString("f_table_name").toUtf8())));
- QString schemaName = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, QString("f_table_schema").toUtf8())));
+ QMessageBox::warning(this, tr("No accessible tables found"),
+ tr
+ ("Database connection was successful, but no accessible tables were found.\n\n"
+ "Please verify that you have SELECT privilege on a PostGIS' geometry_columns\n"
+ "table and at least one table carrying PostGIS geometry."));
+ else
+ for (int idx = 0; idx < PQntuples(result); idx++)
+ QString tableName = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, QString("f_table_name").toUtf8())));
+ QString schemaName = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, QString("f_table_schema").toUtf8())));
- QString column = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, QString("f_geometry_column").toUtf8())));
- QString type = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, QString("type").toUtf8())));
+ QString column = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, QString("f_geometry_column").toUtf8())));
+ QString type = QString::fromUtf8(PQgetvalue(result, idx, PQfnumber(result, QString("type").toUtf8())));
- QString as = "";
- if(type=="GEOMETRY" && !searchGeometryColumnsOnly)
- addSearchGeometryColumn(schemaName, tableName, column);
- as=type="WAITING";
+ QString as = "";
+ if(type=="GEOMETRY" && !searchGeometryColumnsOnly)
+ addSearchGeometryColumn(schemaName, tableName, column);
+ as=type="WAITING";
+ mTableModel.addTableEntry(type, schemaName, tableName, column, "");
- mTableModel.addTableEntry(type, schemaName, tableName, column, "");
ok = true;
PQclear(result);
//search for geometry columns in tables that are not in the geometry_columns metatable
QApplication::restoreOverrideCursor();
if (searchGeometryColumnsOnly)
