[QGIS Commit] r8296 - trunk/qgis/src/plugins/spit
svn_qgis at osgeo.org
Fri Mar 28 16:34:21 EDT 2008
Author: timlinux
Date: 2008-03-28 16:34:21 -0400 (Fri, 28 Mar 2008)
New Revision: 8296
trunk/qgis/src/plugins/spit/qgsspitbase.ui
Updated to work under qt 4.2.1
Modified: trunk/qgis/src/plugins/spit/qgsspitbase.ui
--- trunk/qgis/src/plugins/spit/qgsspitbase.ui 2008-03-28 20:09:06 UTC (rev 8295)
+++ trunk/qgis/src/plugins/spit/qgsspitbase.ui 2008-03-28 20:34:21 UTC (rev 8296)
@@ -5,8 +5,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>662</width>
- <height>487</height>
+ <width>695</width>
+ <height>520</height>
</rect>
</property>
<property name="baseSize" >
@@ -22,437 +22,174 @@
<bool>true</bool>
</property>
<layout class="QGridLayout" >
- <property name="leftMargin" >
+ <property name="margin" >
<number>9</number>
</property>
- <property name="topMargin" >
- <number>9</number>
- </property>
- <property name="rightMargin" >
- </property>
- <property name="bottomMargin" >
- </property>
- <property name="horizontalSpacing" >
+ <property name="spacing" >
<number>6</number>
</property>
- <property name="verticalSpacing" >
- <number>6</number>
- </property>
- <item row="0" column="2" >
- <widget class="QLabel" name="txtHeading" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Minimum" hsizetype="Preferred" >
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
+ <item row="2" column="0" colspan="2" >
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ <property name="orientation" >
+ <enum>Qt::Horizontal</enum>
</property>
- <property name="font" >
- <font>
- <family>Sans Serif</family>
- <pointsize>20</pointsize>
- <weight>50</weight>
- <italic>false</italic>
- <bold>false</bold>
- <underline>false</underline>
- <strikeout>false</strikeout>
- </font>
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
</property>
- <property name="text" >
- <string>Shapefile to PostGIS Import Tool</string>
+ </widget>
+ </item>
+ <item rowspan="2" row="0" column="0" >
+ <widget class="QLabel" name="pixmapLabel1" >
+ <property name="pixmap" >
+ <pixmap resource="spit.qrc" >:/spit.png</pixmap>
</property>
- <property name="alignment" >
- <set>Qt::AlignCenter</set>
+ <property name="scaledContents" >
+ <bool>true</bool>
</property>
</widget>
</item>
- <item row="2" column="2" >
- <widget class="QGroupBox" name="groupBox_2" >
+ <item row="0" column="1" >
+ <widget class="QGroupBox" name="groupBox" >
<property name="title" >
- <string>Shapefile List</string>
+ <string>PostgreSQL Connections</string>
</property>
<number>9</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
- <item row="0" column="0" >
- <layout class="QHBoxLayout" >
- <property name="spacing" >
+ <item row="1" column="0" >
+ <spacer>
</property>
- <number>0</number>
+ <property name="sizeHint" >
+ <size>
+ <width>40</width>
+ <height>20</height>
+ </size>
</property>
+ </spacer>
+ </item>
+ <item row="0" column="0" colspan="4" >
+ <widget class="QComboBox" name="cmbConnections" >
+ <property name="minimumSize" >
+ <size>
+ <width>200</width>
+ <height>0</height>
+ </size>
</property>
+ </widget>
+ </item>
+ <item row="1" column="2" >
+ <widget class="QPushButton" name="btnEdit" >
+ <property name="toolTip" >
+ <string>Edit the current PostGIS connection</string>
</property>
+ <property name="whatsThis" >
</property>
- <item>
- <widget class="QPushButton" name="btnAddFile" >
- <property name="toolTip" >
- <string>Add a shapefile to the list of files to be imported</string>
- </property>
- <property name="whatsThis" >
- </property>
- <string>Add</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="btnRemoveFile" >
- <string>Remove the selected shapefile from the import list</string>
- </property>
- </property>
- <string>Remove</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="btnRemoveAll" >
- <string>Remove all the shapefiles from the import list</string>
- </property>
- </property>
- <string>Remove All</string>
- </property>
- </widget>
- </item>
- <item>
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeType" >
- <enum>QSizePolicy::Expanding</enum>
- </property>
- <property name="sizeHint" >
- <size>
- <width>200</width>
- <height>31</height>
- </size>
- </property>
- </spacer>
- </item>
- </layout>
+ <property name="text" >
+ <string>Edit</string>
+ </property>
+ </widget>
</item>
- <item row="1" column="0" >
- <widget class="Line" name="line1" >
- <property name="frameShape" >
- <enum>QFrame::HLine</enum>
+ <item row="1" column="3" >
+ <widget class="QPushButton" name="btnRemove" >
+ <string>Remove the current PostGIS connection</string>
</property>
- <property name="frameShadow" >
- <enum>QFrame::Sunken</enum>
</property>
+ <string>Remove</string>
</property>
</widget>
</item>
- <item row="2" column="0" >
+ <item row="1" column="1" >
+ <widget class="QPushButton" name="btnNew" >
+ <string>Create a new PostGIS connection</string>
</property>
</property>
+ <string>New</string>
</property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <widget class="QGroupBox" name="groupBox_2" >
+ <property name="title" >
+ <string>Import options and shapefile list</string>
+ </property>
+ <layout class="QGridLayout" >
+ <number>9</number>
+ </property>
+ <number>6</number>
+ </property>
+ <item row="5" column="0" >
+ <spacer>
</property>
+ <size>
+ <width>40</width>
+ </size>
</property>
- <item>
- <layout class="QVBoxLayout" >
- <item>
- <widget class="QLabel" name="label" >
- <string>Primary Key Column Name</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLineEdit" name="txtPrimaryKeyName" />
- </item>
- </layout>
- </item>
- <item>
- <spacer>
- </property>
- <size>
- <width>40</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <layout class="QGridLayout" >
- </property>
- </property>
- </property>
- </property>
- </property>
- </property>
- <item row="1" column="1" >
- </property>
- </property>
- </property>
- </property>
- </property>
- <item>
- <widget class="QLabel" name="textLabel1_2" >
- <string>SRID</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QSpinBox" name="spinSrid" >
- <property name="minimum" >
- <number>-1</number>
- </property>
- <property name="maximum" >
- <number>1000000</number>
- </property>
- <property name="value" >
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item row="0" column="1" >
- <widget class="QCheckBox" name="chkUseDefaultSrid" >
- <string>Set the SRID to the default value</string>
- </property>
- </property>
- <string>Use Default SRID</string>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item>
- </property>
- </property>
- </property>
- </property>
- </property>
- </property>
- <widget class="QCheckBox" name="chkUseDefaultGeom" >
- <string>Set the geometry column name to the default value</string>
- </property>
- </property>
- <string>Use Default Geometry Column Name</string>
- </property>
- </widget>
- </item>
- </property>
- </property>
- </property>
- </property>
- </property>
- <item>
- <widget class="QLabel" name="textLabel1_3" >
- <string>Geometry Column Name</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLineEdit" name="txtGeomName" />
- </item>
- </layout>
- </item>
- </layout>
- </item>
- </layout>
+ </spacer>
</item>
- <item row="3" column="0" >
- <widget class="Line" name="line3" >
+ <item row="5" column="1" colspan="2" >
+ <widget class="QPushButton" name="btnAddFile" >
+ <string>Add a shapefile to the list of files to be imported</string>
</property>
</property>
+ <string>Add</string>
</property>
</widget>
</item>
- <item row="4" column="0" >
+ <item row="5" column="3" colspan="2" >
+ <widget class="QPushButton" name="btnRemoveFile" >
+ <string>Remove the selected shapefile from the import list</string>
</property>
</property>
</property>
+ </widget>
+ </item>
+ <item row="5" column="5" >
+ <widget class="QPushButton" name="btnRemoveAll" >
+ <string>Remove all the shapefiles from the import list</string>
</property>
</property>
- <item>
- <spacer>
- </property>
- </property>
- <size>
- <width>140</width>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- </property>
- </property>
- </property>
- </property>
- </property>
- <item>
- <widget class="QLabel" name="textLabel1_4" >
- <string>Global Schema</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QComboBox" name="cmbSchema" >
- <property name="minimumSize" >
- <size>
- <height>24</height>
- </size>
- </property>
- <string/>
- </property>
- <property name="duplicatesEnabled" >
- <bool>false</bool>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- </layout>
+ <string>Remove All</string>
+ </property>
+ </widget>
</item>
- <item row="5" column="0" >
+ <item row="4" column="0" colspan="6" >
<widget class="QTableWidget" name="tblShapefiles" >
<property name="selectionMode" >
<enum>QAbstractItemView::MultiSelection</enum>
@@ -462,143 +199,110 @@
</property>
</widget>
</item>
- </layout>
- </widget>
- </item>
- <item row="1" column="2" >
- <widget class="QGroupBox" name="groupBox" >
- <property name="title" >
- <string>PostgreSQL Connections</string>
- </property>
- </property>
- </property>
- </property>
- </property>
- </property>
- </property>
+ <item row="0" column="4" colspan="2" >
+ <widget class="QLineEdit" name="txtGeomName" />
+ </item>
+ <item row="1" column="0" colspan="2" >
+ <widget class="QCheckBox" name="chkUseDefaultSrid" >
+ <string>Set the SRID to the default value</string>
</property>
</property>
+ <string>Use Default SRID or specify here</string>
</property>
+ </widget>
+ </item>
+ <widget class="QCheckBox" name="chkUseDefaultGeom" >
+ <string>Set the geometry column name to the default value</string>
</property>
</property>
+ <string>Use Default Geometry Column Name or specify here</string>
</property>
- <widget class="QPushButton" name="btnNew" >
- <string>Create a new PostGIS connection</string>
- </property>
- </property>
- <string>New</string>
- </property>
- </widget>
- </item>
- <item row="1" column="3" >
- <widget class="QPushButton" name="btnRemove" >
- <string>Remove the current PostGIS connection</string>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QPushButton" name="btnEdit" >
- <string>Edit the current PostGIS connection</string>
- </property>
- </property>
- <string>Edit</string>
- </property>
- </widget>
- </item>
- <item row="0" column="0" colspan="4" >
- <widget class="QComboBox" name="cmbConnections" >
- <size>
- <height>0</height>
- </size>
- </property>
- </widget>
- </item>
- </layout>
+ </widget>
</item>
+ <item row="1" column="2" colspan="4" >
+ <widget class="QSpinBox" name="spinSrid" >
+ <property name="maximum" >
+ <number>1000000</number>
+ </property>
+ <property name="minimum" >
+ <number>-1</number>
+ </property>
+ <property name="value" >
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="2" colspan="4" >
+ <widget class="QLineEdit" name="txtPrimaryKeyName" />
+ </item>
+ <item row="2" column="0" >
+ <widget class="QLabel" name="label" >
+ <string>Primary Key Column Name</string>
+ </property>
+ <property name="buddy" >
+ <cstring>txtPrimaryKeyName</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="0" >
+ <widget class="QLabel" name="textLabel1_4" >
+ <string>Global Schema</string>
+ </property>
+ <cstring>cmbSchema</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="1" colspan="5" >
+ <widget class="QComboBox" name="cmbSchema" >
+ <size>
+ <height>24</height>
+ </size>
+ </property>
+ <string/>
+ </property>
+ <property name="duplicatesEnabled" >
+ <bool>false</bool>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
- <item rowspan="3" row="0" column="0" >
- <widget class="QLabel" name="pixmapLabel1" >
- <property name="pixmap" >
- <pixmap resource="spit.qrc" >:/spit.png</pixmap>
- </property>
- <property name="scaledContents" >
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item rowspan="3" row="0" column="1" >
- <widget class="Line" name="line12" >
- <enum>QFrame::VLine</enum>
- </property>
- </property>
- <enum>Qt::Vertical</enum>
- </property>
- </widget>
- </item>
- <item row="3" column="0" colspan="3" >
- <widget class="QDialogButtonBox" name="buttonBox" >
- </property>
- <property name="standardButtons" >
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
- </property>
- </widget>
- </item>
</layout>
</widget>
<layoutdefault spacing="6" margin="11" />
+ <tabstops>
+ <tabstop>cmbConnections</tabstop>
+ <tabstop>btnNew</tabstop>
+ <tabstop>btnEdit</tabstop>
+ <tabstop>btnRemove</tabstop>
+ <tabstop>chkUseDefaultGeom</tabstop>
+ <tabstop>txtGeomName</tabstop>
+ <tabstop>chkUseDefaultSrid</tabstop>
+ <tabstop>spinSrid</tabstop>
+ <tabstop>txtPrimaryKeyName</tabstop>
+ <tabstop>cmbSchema</tabstop>
+ <tabstop>tblShapefiles</tabstop>
+ <tabstop>btnAddFile</tabstop>
+ <tabstop>btnRemoveFile</tabstop>
+ <tabstop>btnRemoveAll</tabstop>
+ <tabstop>buttonBox</tabstop>
+ </tabstops>
<resources>
<include location="spit.qrc" />
</resources>
