[QGIS Commit] r8300 - branches/ogr-plugin-branch/src/app
svn_qgis at osgeo.org
Fri Mar 28 17:52:51 EDT 2008
Author: gcontreras
Date: 2008-03-28 17:52:51 -0400 (Fri, 28 Mar 2008)
New Revision: 8300
branches/ogr-plugin-branch/src/app/qgisapp.cpp
branches/ogr-plugin-branch/src/app/qgsdbsourceselect.cpp
fixes to addDatabaseLayer method and fixes to addTables to support
the creation of ogr database layers using the ogr provider.
Modified: branches/ogr-plugin-branch/src/app/qgisapp.cpp
--- branches/ogr-plugin-branch/src/app/qgisapp.cpp 2008-03-28 21:48:04 UTC (rev 8299)
+++ branches/ogr-plugin-branch/src/app/qgisapp.cpp 2008-03-28 21:52:51 UTC (rev 8300)
@@ -2075,7 +2075,7 @@
QString connInfo = dbs->connInfo();
//QString connType = dbs->getConnectionType();
- //qDebug("addDatabase :"+connInfo);
+ qDebug("addDatabase :"+connInfo);
// for each selected table, connect to the database, parse the WKT geometry,
// and build a cavnasitem for it
// readWKB(connInfo,tables);
Modified: branches/ogr-plugin-branch/src/app/qgsdbsourceselect.cpp
--- branches/ogr-plugin-branch/src/app/qgsdbsourceselect.cpp 2008-03-28 21:48:04 UTC (rev 8299)
+++ branches/ogr-plugin-branch/src/app/qgsdbsourceselect.cpp 2008-03-28 21:52:51 UTC (rev 8300)
@@ -344,6 +344,8 @@
void QgsDbSourceSelect::addTables()
+ //check this to support ogr databases
m_selectedTables.clear();
typedef QMap<int, QVector<QString> > schemaInfo;
@@ -423,7 +425,16 @@
continue;
- query = "\"" + schemaName + "\".\"" + tableName + "\" " + "(" + geomColumnName + ") sql=" + sql;
+ //*****************************freddy
+ QString type=cmbType->currentText();
+ if(type.contains("Ogr",FALSE)>0)
+ query=tableName;
+ else
+ query = "\"" + schemaName + "\".\"" + tableName + "\" " + "(" + geomColumnName + ") sql=" + sql;
m_selectedTables.push_back(query);
@@ -684,7 +695,12 @@
QString QgsDbSourceSelect::connInfo()
- return m_connInfo;
+ //check here
+ if (type.startsWith("Ogr"))
+ return "type="+type+" "+m_connInfo;
+ else
+ return m_connInfo;
void QgsDbSourceSelect::setSql(const QModelIndex& index)
