[QGIS Commit] r8401 - in trunk/qgis/src: app core/raster
svn_qgis at osgeo.org
Tue May 6 12:11:35 EDT 2008
Author: ersts
Date: 2008-05-06 12:11:35 -0400 (Tue, 06 May 2008)
New Revision: 8401
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.h
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
trunk/qgis/src/core/raster/qgsrasterlayer.h
-Fix problem with missing "Red" band under the gray scale selection pulldown
-This would have been a problem for all non-english systems
-The problem will be fully resolved once ts files are updated
-Closes ticket #923
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2008-05-06 09:32:47 UTC (rev 8400)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2008-05-06 16:11:35 UTC (rev 8401)
@@ -49,6 +49,8 @@
const char * const ident =
"$Id$";
+// Constant that signals property not used.
+const QString QgsRasterLayerProperties::QSTRING_NOT_SET = "Not Set";
QgsRasterLayerProperties::QgsRasterLayerProperties(QgsMapLayer *lyr, QWidget *parent, Qt::WFlags fl)
: QDialog(parent, fl),
@@ -146,30 +148,30 @@
// Set up the combo boxes that contain band lists using the qstring list generated above
if (mRasterLayer->getRasterLayerType()
== QgsRasterLayer::PALETTE) //paletted layers have hard coded color entries
- cboRed->addItem("Red");
- cboGreen->addItem("Red");
- cboBlue->addItem("Red");
+ cboRed->addItem(tr("Red"));
+ cboGreen->addItem(tr("Red"));
+ cboBlue->addItem(tr("Red"));
- cboRed->addItem("Green");
- cboGreen->addItem("Green");
- cboBlue->addItem("Green");
+ cboRed->addItem(tr("Green"));
+ cboGreen->addItem(tr("Green"));
+ cboBlue->addItem(tr("Green"));
- cboRed->addItem("Blue");
- cboGreen->addItem("Blue");
- cboBlue->addItem("Blue");
+ cboRed->addItem(tr("Blue"));
+ cboGreen->addItem(tr("Blue"));
+ cboBlue->addItem(tr("Blue"));
- cboRed->addItem(tr(QgsRasterLayer::QSTRING_NOT_SET));
- cboGreen->addItem(tr(QgsRasterLayer::QSTRING_NOT_SET));
- cboBlue->addItem(tr(QgsRasterLayer::QSTRING_NOT_SET));
+ cboRed->addItem(tr(QSTRING_NOT_SET));
+ cboGreen->addItem(tr(QSTRING_NOT_SET));
+ cboBlue->addItem(tr(QSTRING_NOT_SET));
- cboGray->addItem("Red");
- cboGray->addItem("Green");
- cboGray->addItem("Blue");
- cboGray->addItem(tr(QgsRasterLayer::QSTRING_NOT_SET));
+ cboGray->addItem(tr("Red"));
+ cboGray->addItem(tr("Green"));
+ cboGray->addItem(tr("Blue"));
+ cboGray->addItem(tr(QSTRING_NOT_SET));
lstHistogramLabels->insertItem(tr("Palette"));
@@ -268,16 +270,15 @@
cboGreen->addItem(myQString);
cboBlue->addItem(myQString);
-//TODO: Need to handle situations where a band is set to Not Set, currently if you set a band to this it will segfault.
- if (cboGray->count() != 1)
- cboxTransparencyBand->addItem(tr(QgsRasterLayer::QSTRING_NOT_SET));
- cboxTransparencyLayer->addItem(tr(QgsRasterLayer::QSTRING_NOT_SET));
+ cboxTransparencyBand->addItem(tr(QSTRING_NOT_SET));
+ cboxTransparencyLayer->addItem(tr(QSTRING_NOT_SET));
QMap<QString, QgsMapLayer *> myLayers = QgsMapLayerRegistry::instance()->mapLayers();
QMap<QString, QgsMapLayer *>::iterator it;
for(it = myLayers.begin(); it != myLayers.end(); it++)
@@ -641,17 +642,17 @@
QgsRasterLayer::PALETTED_SINGLE_BAND_PSEUDO_COLOR != mRasterLayer->getDrawingStyle() &&
QgsRasterLayer::PALETTED_MULTI_BAND_COLOR != mRasterLayer->getDrawingStyle())
- if(mRasterLayer->getRedBandName() != tr(QgsRasterLayer::QSTRING_NOT_SET))
+ if(mRasterLayer->getRedBandName() != tr(QSTRING_NOT_SET))
leRedMin->setText(QString::number(mRasterLayer->getMinimumValue(mRasterLayer->getRedBandName())));
leRedMax->setText(QString::number(mRasterLayer->getMaximumValue(mRasterLayer->getRedBandName())));
- if(mRasterLayer->getGreenBandName() != tr(QgsRasterLayer::QSTRING_NOT_SET))
+ if(mRasterLayer->getGreenBandName() != tr(QSTRING_NOT_SET))
leGreenMin->setText(QString::number(mRasterLayer->getMinimumValue(mRasterLayer->getGreenBandName())));
leGreenMax->setText(QString::number(mRasterLayer->getMaximumValue(mRasterLayer->getGreenBandName())));
- if(mRasterLayer->getBlueBandName() != tr(QgsRasterLayer::QSTRING_NOT_SET))
+ if(mRasterLayer->getBlueBandName() != tr(QSTRING_NOT_SET))
leBlueMin->setText(QString::number(mRasterLayer->getMinimumValue(mRasterLayer->getBlueBandName())));
leBlueMax->setText(QString::number(mRasterLayer->getMaximumValue(mRasterLayer->getBlueBandName())));
@@ -678,7 +679,7 @@
- if(mRasterLayer->getGrayBandName() != tr(QgsRasterLayer::QSTRING_NOT_SET))
+ if(mRasterLayer->getGrayBandName() != tr(QSTRING_NOT_SET))
leGrayMin->setText(QString::number(mRasterLayer->getMinimumValue(mRasterLayer->getGrayBandName())));
leGrayMax->setText(QString::number(mRasterLayer->getMaximumValue(mRasterLayer->getGrayBandName())));
@@ -754,7 +755,7 @@
else
- cboxTransparencyLayer->setCurrentIndex(cboxTransparencyLayer->findText(tr(QgsRasterLayer::QSTRING_NOT_SET)));
+ cboxTransparencyLayer->setCurrentIndex(cboxTransparencyLayer->findText(tr(QSTRING_NOT_SET)));
myIndex = cboxTransparencyBand->findText(mRasterLayer->getTransparentBandName());
@@ -764,7 +765,7 @@
else
- cboxTransparencyBand->setCurrentIndex(cboxTransparencyBand->findText(tr(QgsRasterLayer::QSTRING_NOT_SET)));
+ cboxTransparencyBand->setCurrentIndex(cboxTransparencyBand->findText(tr(QSTRING_NOT_SET)));
//add current NoDataValue to NoDataValue line edit
if(mRasterLayer->isNoDataValueValid())
@@ -1133,17 +1134,17 @@
//Set min max based on user defined values if all are set and stdDev is 0.0
if(rbtnThreeBandMinMax->isEnabled() && rbtnThreeBandMinMax->isChecked() && validUserDefinedMinMax())
mRasterLayer->setMinimumValue(cboRed->currentText(), leRedMin->text().toDouble(), false);
mRasterLayer->setMaximumValue(cboRed->currentText(), leRedMax->text().toDouble());
mRasterLayer->setMinimumValue(cboGreen->currentText(), leGreenMin->text().toDouble(), false);
mRasterLayer->setMaximumValue(cboGreen->currentText(), leGreenMax->text().toDouble());
mRasterLayer->setMinimumValue(cboBlue->currentText(), leBlueMin->text().toDouble(), false);
mRasterLayer->setMaximumValue(cboBlue->currentText(), leBlueMax->text().toDouble());
@@ -1167,7 +1168,7 @@
if(rbtnSingleBandMinMax->isEnabled() && rbtnSingleBandMinMax->isChecked() && validUserDefinedMinMax())
mRasterLayer->setMinimumValue(cboGray->currentText(), leGrayMin->text().toDouble(), false);
mRasterLayer->setMaximumValue(cboGray->currentText(), leGrayMax->text().toDouble());
@@ -1485,17 +1486,17 @@
if(rbtnThreeBandMinMax->isEnabled())
@@ -1511,7 +1512,7 @@
if(rbtnSingleBandMinMax->isEnabled())
@@ -1623,7 +1624,7 @@
void QgsRasterLayerProperties::on_cboBlue_currentIndexChanged(const QString& theText)
- if(mRasterLayerIsGdal && tr(QgsRasterLayer::QSTRING_NOT_SET) != theText)
+ if(mRasterLayerIsGdal && tr(QSTRING_NOT_SET) != theText)
leBlueMin->setText(QString::number(mRasterLayer->getMinimumValue(theText)));
leBlueMax->setText(QString::number(mRasterLayer->getMaximumValue(theText)));
@@ -1632,7 +1633,7 @@
void QgsRasterLayerProperties::on_cboGray_currentIndexChanged(const QString& theText)
leGrayMin->setText(QString::number(mRasterLayer->getMinimumValue(theText)));
leGrayMax->setText(QString::number(mRasterLayer->getMaximumValue(theText)));
@@ -1641,7 +1642,7 @@
void QgsRasterLayerProperties::on_cboGreen_currentIndexChanged(const QString& theText)
leGreenMin->setText(QString::number(mRasterLayer->getMinimumValue(theText)));
leGreenMax->setText(QString::number(mRasterLayer->getMaximumValue(theText)));
@@ -1650,7 +1651,7 @@
void QgsRasterLayerProperties::on_cboRed_currentIndexChanged(const QString& theText)
leRedMin->setText(QString::number(mRasterLayer->getMinimumValue(theText)));
leRedMax->setText(QString::number(mRasterLayer->getMaximumValue(theText)));
@@ -1743,10 +1744,10 @@
void QgsRasterLayerProperties::on_cboxTransparencyLayer_currentIndexChanged(const QString& theText)
- if(theText == tr(QgsRasterLayer::QSTRING_NOT_SET))
+ if(theText == tr(QSTRING_NOT_SET))
cboxTransparencyBand->clear();
else
@@ -1759,7 +1760,7 @@
QgsRasterLayer* myRasterLayer = (QgsRasterLayer*)it.value();
int myBandCount = myRasterLayer->getBandCount();
for(int bandRunner = 1; bandRunner <= myBandCount; bandRunner++)
cboxTransparencyBand->addItem(myRasterLayer->getRasterBandName(bandRunner));
@@ -2459,7 +2460,7 @@
// Populate transparency table with single value transparency pixels
populateTransparencyTable();
// If no band is selected but there are multiple bands, selcet the first as the default
- if(cboGray->currentText() == tr(QgsRasterLayer::QSTRING_NOT_SET) && 1 < cboGray->count())
+ if(cboGray->currentText() == tr(QSTRING_NOT_SET) && 1 < cboGray->count())
cboGray->setCurrentIndex(0);
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.h
--- trunk/qgis/src/app/qgsrasterlayerproperties.h 2008-05-06 09:32:47 UTC (rev 8400)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.h 2008-05-06 16:11:35 UTC (rev 8401)
@@ -120,6 +120,9 @@
private:
+ /** \brief A constant that signals property not used */
+ static const QString QSTRING_NOT_SET;
/** \brief Pointer to the raster layer that this property dilog changes the behaviour of. */
QgsRasterLayer * mRasterLayer;
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-05-06 09:32:47 UTC (rev 8400)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-05-06 16:11:35 UTC (rev 8401)
@@ -106,7 +106,7 @@
-const QString QgsRasterLayer::QSTRING_NOT_SET = QString("Not Set");
+const QString QgsRasterLayer::QSTRING_NOT_SET = "Not Set";
Builds the list of file filter strings to later be used by
@@ -387,6 +387,7 @@
mStandardDeviations(0),
mDataProvider(0)
mUserDefinedRGBMinMaxFlag = false; //defaults needed to bypass stretch
mUserDefinedGrayMinMaxFlag = false;
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-05-06 09:32:47 UTC (rev 8400)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-05-06 16:11:35 UTC (rev 8401)
@@ -180,9 +180,6 @@
Q_OBJECT
public:
- // Static constant defining flag for XML
- static const QString QSTRING_NOT_SET;
// Static methods:
@@ -1006,6 +1003,9 @@
// Private member vars
+ /** \brief Static constant defining flag for XML and a constant that signals property not used */
/** \brief Raster width. */
int mRasterXDim;
/** \brief Raster Height. */
